Deck Staining and Sealing Instructions  4.8/5 (5)
This post was updated on February 25, 2024
Deck Staining Sealing Tips 2024
We appreciate your input here at Deckstainhelp.com as we continue to expand our content and serve as your go-to source for the latest deck restoration news and trending topics through 2024. In this updated article, we provide some tips for the best way to stain and seal your wood deck. As always, make sure you read the directions, as they vary from brand to brand. Feel free to leave a comment below.
Deck Staining and Sealing Instructions and How To Tips for Best Results
The instructions for staining and sealing a deck will vary from product to product. It’s always best to follow the manufacturer’s suggested application instructions for the best results. There are however some basic tips and techniques that will aid in staining and sealing with any deck protection product.
With a new deck stain or sealer application, it is important to remember that the product needs to penetrate the wood for optimal protection. The wood should be cleaned thoroughly prior to any type of application. Any old existing deck stain or sealer also needs to be removed from the wood prior to a new coat.
With most wood cleaning or stain removal products, it is necessary to apply a wood deck brightener to correct the pH level of the wood. Once the wood is allowed to dry for a few days then it is ready to be stained or sealed.
As previously stated, it is important to follow the deck stain label instructions before beginning. Generally speaking most deck stains and sealers can be applied using a brush, roller, stain pad, pump, or airless sprayer.
The most common mistake made is to over apply the deck stain or sealer. When stain puddles up and is allowed to dry it will leave an inconsistent shiny look on the surface.
These puddles of over-applied stain will eventually begin to crack, peel, and flake off the wood jeopardizing the wood’s appearance and integrity. Once the wood stain or sealer soaks into the wood wipe or back brush any excessive puddles,  drips, or runs to prevent over application. Only apply as much stain as the wood will soak up.
Another unwanted occurrence when it comes to deck staining and sealing instructions is leaving lap marks. This occurs when you stop and start staining in the middle of a board during application. To avoid lap marks continue applying stain to an entire board once you have started. Then move to the next board and coat it entirely from one end to the other before moving on to the next board and so on.
Following these basic deck staining and sealing instructions will give your deck better protection and a better overall finish.
#As an article and comment contributor to the site, Scott has been around the pressure washing industry since attending college. In 1993 he started his first company called Oakland Pressure Wash specializing in exterior pressure washing and deck staining. That company evolved into OPW L.L.C. shortly thereafter concentrating more on exterior wood and deck restoration. Scott and his Deck Cleaning Michigan company have restored over 10,000 decks in the Metro Detroit area since the early years. He has become an authority in the deck restoration industry and has contributed to numerous wood restoration forums and informative sites. All the products he suggests through this site are sold through online sites and in retail stores, allowing the consumer to choose their own means of purchase. Scott’s eCommerce sites do sell many top brands he endorses and if you appreciate any of the help he has offered then feel free to purchase from one of them.
Subscribe
Notify of
18 Comments
Rose Babb
Rose Babb
The article is named deck stain AND sealing instructions. But I don’t see any info on the sealing process. I have a new 3 month old deck. I’m ready to start the prep. Staining is pretty straight forward. I’ve stained wood for other projects but have never sealed a deck.
Christina
Christina
As soon as the morning dew dries, the deck is in the sun. Which is better — staining while dewy or while in the sun?
Rustynetter
Rustynetter
Can I wait for the morning dew to “burn off” and then stain later that same morning?
Philip
Philip
I hired a handyman to stain my brand new deck. He cleaned the deck using the Behr All-in-one Wood cleaner. But after the cleaning, the deck looks dull/discolored than before. (See attached pic) Unfortunately it was done while I was at work, so not sure what happened. Would it be because he might not have rinsed off with water after applying the cleaner? . Any easy way to restore the color to the original new look? I bought the clear transparent wood finish, so however it looks now, would be the final look too 🙁
Debbie
Debbie
I Have been trying to get my deck stained, but Every morning my deck is wet from dew! Can I still go ahead and stain or will that ruin the wood or how the stain adheres to the wood???
Jay
Jay
Is it better to start with the railing or decking when applying stain for the first time?
Elizabeth
Elizabeth
I'm confused about the back wiping. It says to back wipe here, but in another section of your site it says NOT to backwipe because it won't cure correctly and stain will come off on your hands, clothes, etc.
Lori
Lori
We are staining our deck with TWP 100 – Redwood. Ten days ago, we stripped it and brightened it with Restore-A-Deck. Since then, the weather has not cooperated. It rained on and off all last week. It rained on Monday night, and I had planned to stain today (Wed) since the deck seemed to be dry last night. It was cold last night and the deck was damp this morning from dew or frost. The deck does not get much sun and did not completely dry out today. I am hoping to stain tomorrow. Can I cover the deck with plastic to prevent the dew from getting it wet again tonight? If I stain tomorrow, will the dew hurt it tomorrow night? It is 67 degrees right now and a low of 45 is predicted for tonight. In the next week, there is no rain in the forecast, and it is not supposed to be much cooler than it was today. Thanks for your help.
I replaced some rotted boards on my 30 yr old redwood deck, stripped/brightened(RAD) and lightly sanded my entire deck 2 months ago. I waited the 2 months to let the new boards age before I stained with Armstrong semi-solid. The old boards soaked up the stain instantly to a point where I was wondering if I needed a second coat. I only got 2/3 thru staining yesterday before dark and it rained 3 hrs later (I need to wait until dry again before finishing). However this morning I noticed water beading ONLY on the new boards, the old boards are just damp. Furthermore I ran my hand across some old boards and a little stain appeared on my hands.
1) Did the rain 3 hrs later create a problem with drying?
2) Do I need a second AC coat on the old boards since no water is beading?
3) If I need a second coat, would a clear coat be okay since 2 coats of semi-solid will look too solid?
18
