Defy Epoxy Fortified Wood Stain is a MPI “green” certified exterior stain that protects wood from the damaging effects of weather. The “Epoxy” is not like an traditional epoxy that goes on a garage floor but rather a synthetic epoxy resin that penetrates deep into the pores of the wood. This epoxy resin hardens inside the wood creating a weather proof barrier that prevents water damage and UV graying.
Defy Epoxy Wood Stain can be used on all types of unfinished exterior fencing, decking, and wood structures/homes.
Defy Epoxy Wood Stain Scores (1-10)
- Defy Epoxy in the Light Walnut color added a rich semi-transparent look to the natural grain. The Light Walnut color was a medium brown with a slight hint of red. Our 300 foot deck attained a nice “mahogany” look to it after drying.
- We tested the Defy Epoxy for 2.5 years. When evaluating the deck we would say that 90% of the original color remained on the vertical railings and 80% remained on the horizontal flooring.
Wear/Tear and Peeling: 7.5
- The Defy Epoxy did well on 75% of the deck when it comes to wearing/peeling. There were zero issues with the verticals but there was a some wear/tear on the flooring. It is noted that this deck is used for everyday access into the home. This is acceptable in our opinion and other related stains have shown wearing in high traffic areas.
Cost Per Square Foot: 7
- Defy Epoxy Stain costs $35.99 per gallon. We applied the suggested two coats of stain wet on wet. Three gallons of Epoxy Stain were used for the 300 foot test deck. Translates to $.36 a square foot.
- There was no mold or mildew on the deck after 2.5 years.
Ease of Application: 7.5
- We found that the Defy Epoxy Stain was a little difficult to apply. Saversystems, the manufacturer of Defy products suggests applying two coats of stain “wet on wet”. We watched the free DVD that came with the stain and followed the directions. The first coat penetrated into the wood extremely well. So well that we needed to move fast so the stain would not dry. The second coat was applied 30 minutes after the first coat. This second coat was substantially easier to apply and evened out the overall appearance. We would suggest tarping the floor when staining the rails to avoid drips drying on the floor.
- No darkening and just a slight fading after 2.5 years.
Difficulty of Reapplication:8
- Defy Epoxy would be easy to re-coat since the stain penetrated into the wood with little to no darkening. Using the Defy Wood Cleaner would be enough to prep the wood.
Overall Score Defy Epoxy Stain at 2 Year Period: 8.25
- Defy Wood Stains continue to impress. We found that the Defy brand of stains will penetrate better into the wood then any other water based stain on the market. The Defy Epoxy easily outperforms other water based stains such as Behr Premium and Sherwin Williams Deckscapes, putting the Defy Stains on par with many high end oil based stains.
Help or Questions? Google Search Defy Stain
Cost: $35.99 per Gallon, $179.99 per 5 Gallon Pail w/Free Delivery
Available Colors: Cedartone, Natural Pine, Light Walnut, Clear, Redwood, Driftwood Gray
Dry Time: 2-4 Hours
Cleanup: Soap and Water
Manufacturer: Saver Systems
Location of Deck: Kentucky
When Tested: May 2007
Deck Square Footage: 300 Square feet
UV Exposure: 40% Shade 60% Full Sun
How Many Years Tested: 2.5 Years
[...] Defy Extreme Wood Stain is an improved version of the Defy Epoxy Fortified Wood Stain. Containing the same ingredients but with the added UV protection of the zinc oxide nano particles [...]
Are you aware that your pages will not print? I wanted to print-out the info and then confer with my husband. Soome pages will print, but never the first page.
Not sure why you have the issue but they do print from our end.
Do you have any pictures of this deck? We are building a home on the panhandle of florida and have a 400 sq ft pressure treated pine deck that I plan on staining in a couple of months. I am thinking about using the Defy Extreme in walnut. I know you tested the Defy Extreme but I think it was in the cedar color. Do you recommend both a wood cleaner and brightner prior to applying the stain? One more question. When you apply wet on wet, recommendations on what to do to prevent stepping on areas already stained when applying the second coat.Really enjoy your site as it is packed with excellent information and helped me with my choosing a stain.
We have added the picture. Yes you should clean and brighten the wood. You can step in your first coat after about 20 minutes just do not step in your second coat.
We have a white cedar deck that has not been treated. It was installed last summer/fall and is a weathered grey color right now. I need to treat it with something in the next few weeks.
I have had very bad experience with Cabot's water-based deck stain and wouldn't go with water-based again. All I want to do is apply a product that will protect the wood, not change the color much.
I live on the ocean in Maine where the weather is challenging, to put it mildly. Part of this deck is on the water-facing side and also a Southern exposure, so it takes a beating.
Recommendations? I looked up TWP and Defy stains and it seems they're not available in my area…
Donna, Defy is water based so that is out. TWP 1500 would be a good choice if you can find it locally or online.
you are not supposed to apply a second coat if the first is dry. so how do you apply second coat wet on last section where you only have one exit.
Bill, apply the first coating to the entire floor then reapply another coat to the floor after about 20 minutes.
Can this product be applied to Trex decking? We live in southern New Mexico and our deck is starting to deteriorate so we need to seal it.
Teri, I am not sure on that. I would contact the manufacturer directly at http://www.saversystems.com
I live in Omaha, Nebraska and had a new Cedar fence put up in November. I plan on staining it this spring and wanted you suggestion on what stain to use. I would like to preserve the Cedar natural look, but a stain that will provide the longest amount of protection. Considering it will only be a few months after the fence was up, do I need apply any cleaning products as part of the preparation process or would a power wash alone be sufficient?
Mike, If you have rough wood as most fences do then you can just do a light cleaning to remove dirt then stain. if the wood has started to gray then you would want a wood cleaner. Pigments in the stain is the key to longer life. The richer the tone the longer it takes to fade is the general rule. I would look at TWP Stains or Defy Extreme Stain.
[...] Important Note: This is Our 2nd Review of Defy Epoxy Fortified Wood Stain. Our first review of the Defy Epoxy Stain was started in 2007 and completed in 2009. See Here for First Review: Defy Epoxy Stain Review [...]
I have about 2.5 gallons of Defy Epoxy Fortified Stain left that i bought in Sept 2007. It has been in my non heated garage all those years. Any ideas on whether it would still be OK to use?
Hard to say but probably okay.
