Deck Stain Reviews Ratings
Deck Stain Help Articles
Sherwin Williams Deckscapes OIL Based Review 2.88/5 (7)
2.88/57
SW Deckscapes Oil Review
Long-lasting penetrating oil-based formula protects the beauty of wood with a rich semi-transparent stain. Scuff-resistant formula with maximum UV protection that resists fading.
Waterproofs to prevent moisture damage.
Note: This is a test in the Sherwin Williams Deckscapes Oil Based Formula. This formula tested better than their water based version. See Here for Water Based Review: SW Deckscapes Review
Sherwin Williams DeckScapes Stain Scores (1-10)
Appearance After Initial Stain Application: 7.5
– Sherwin Williams DeckScapes in the oil formula penetrated much better then their waterborne version. Application of the stain was decent and the color of the Cedar bark was a brown cedar. After drying a day, the stain looked blotchy in appearance. We applied a light second coat to even out the look.
– 2 years later the Sherwin Williams DeckScapes lost about 30% of its original color.
Wear/Tear and Peeling: 7
– The Oil based version of the Deckscapes is definitely an improvement over the water version. The oil penetrates deep into the wood. This resulted in average wear and tear for our test deck.
Cost Per Square Foot: 8
– We used 7 gallons of stain for our 800 sq foot test deck. 2 Coats of stain were applied to the deck surface, one day apart. Cost to stain was around $.30 a foot.
Preventing Mold/Mildew/Algae: 6
– The oil based version of the Deckscapes had a decent amount of black mold growing covering about 40% of the surface. The mold appeared to be growing underneath the stain. This would make reapplication difficult.
Ease of Application: 8
– The SW Deckscapes applies fairly easily. We used a pump sprayer and stain pad application. flooring was applied with the pad while the railings were sprayed. Back brushing was minimal and coverage was adequate. No overlapping of the stain on the flooring. We had to apply a second coat though to the floor as the first coat penetrated very deep and looked light.
Color Shifting (darkening) after 2 Years: 6
– The stain darkened considerably after 2 years. Looked like a muddy brown color instead of the original rich cedar. A combination of mold and UV darkening the stain.
Ease of Reapplication: 6
– Reapplication of the DeckScapes would require stripping of the old stain. Failure to remove would cause the appearance to darken considerably if another coat was applied on top of the wood. Cleaning alone would not be enough to remove the mold and restore the original color. Fortunately, stripping of this stain would be easy.
Overall Score SW Deckscapes at 2 Year Period: 6.9
– Much better than the waterborne but not up to par with other oil based deck stains. If you had to choose between the two versions of the Deckscapes, then absolutely choose the oil based version.
Where To Buy: Sherwin Williams
Cost: $32.99 per Gallon, $160.99 per 5 Gallon Pail
Stain Type: Semi-Transparent – Oil
Available Colors: 30 Different Colors
Coats Required: 1-2 Coats
Coverage Per Gallon: 150-200 sq. ft in field tests
Dry Time: 4-12 Hours 24 hours fro recoat
VOC Compliant: 550 Compliant – Cannot be sold to all states.
Manufacturer: Sherwin Williams
When Tested: August 2010 -2012
Deck Square Footage: 800 Square Feet
Cedar Bark
*All products tested and results are from our hands on experience. We offer no guarantee of similar results. Take inconsideration that results may differ widely due to different wood types, exposure to UV radiation, and natural weathering.
21 responses to “Sherwin Williams Deckscapes OIL Based Review”
  1. Nancy says:
    I would not recommend this product to my worst enemy. We spent hundreds of dollars on multiple gallons of this stain for a deck and a custom wood playset. We waited the recommended time for wood drying/curing prior to the application of the product. Both pieces are faded and the deck had a terrible mold problem. The product was applied onto dry clean wood in both cases (oil based stain) and several coats were applied. I filed a complaint with Sherwin Williams who promised to send someone out to inspect the deck and playset – they never called or came. Spoke with a friend who is in upper management at SW and he didn't seem to care either. Don't waste your money on this product!!! We just stripped the deck and are preparing to re-stain it this week. That is what brought me to this site – don't want to make another mistake and can't trust store employees.
    • Job says:
      Nancy I'm a contractor that used this product and I had a terrible experience with it. Looks terrible. How did you strip the deck?? I've used SW seal and stain remover product that is supposed to be for this and tried to power wash it off… It's not doing the job. any suggestions?? JPL
  2. Greg Baron says:
    I stained a new deck for a customer 2013 late spring and and deck was installed in previous fall using Deckscapes semi transparent oil base, I cleaned and power washed deck because of the weathering and some slight fadeing. The would was completely dry and temperature was ideal. I applied it in the am in the shade so it would not dry to fast . did the job in two mornings before the sun hit it . Ive been painting and staining for 30 years. the coustomer came to me ,a friend and she said the stain on the horizontal surfaces was all flaking off??????? Never had this happen she was in tears. I have to go to the store in Brockport ny and find out what they are going do to help, GOOD LUCK RIGHT . I would never use their exterior stain again. And their interior , exterior paint prices are getting outragous,I have found that valspar is a very good paint and you cant beat their prices. My name is Greg Garon
  3. Wil says:
    I used this on a fence last summer. It is not even one year and it is already flaking in areas. This was for a regular customer too. Very embarrasing. Sherwin Williams always promotes their products like they are the best around and worth the extra costs. I have been dissapointed too many times with their paints as well
  4. David says:
    Bought this and applied it last year to a clean wood deck. So disappointing. Stain is already coming off in areas and showing wear. Will need ro re-stain my deck in one year! Don't buy this junk!
    • Joe says:
      Having the same problem, stain applied to new deck material after allowing for wood to cure. Stain is coming off in areas and same with wearing. Going for TWP this time. For anyone looking to stain outdoor wood, steer clear of this inferior product.
  5. ron smith says:
    the person at the store llied about the product information i guess to make a sale on top of that the color was suposed to be pink and it was a very dark brown the store maplewood, mn
  6. Sure Shot Stain says:
    I need to find the best (easiest to use) stripper for SW Deckscape OIL based stain. Thanks
    • Was it a semi-trans or solid stain?
      • Sure Shot Stain says:
        Sorry,, yes it is the Semi-transparent. This "deck" is an elevated walkway at a local school, where they unforutnately used this SW product. It is peeling, allowing mold development etc. My guess is that the applicator did not properly prep the wood but IMHO this is still not a product I would use. I think I can go back over it with a solid but they are going to be right back in the same situation in another year or two so I think stripping and starting over going to a true oil based that can be recoated without stripping is a better option. Thanks for the help.
        • Yes strip it off and start over. Try the RAD Stain Stripper kits which also has a wood brightener. Stain with a penetrating oil like the TWP or Armstrong Clark.
  7. Sure Shot Stain says:
    RAD seems to have a consumer and a contractor grade product. I have to assume you are referring to the contractor grade which is fine since I am one, I primarily do fences though hence my questions on the deck. I have seen the references to "furring" and it seems to be a direct result of allowing the product to sit on the deck for too long, am I correct? Using a pressure washer and direct injection it would seem that it would help prevent the chemical dwell time induced furring but I am also a little confused as to how the direct injection method allows the stripper time to work. My intent is restain the deck using Wood Defender deck stain since it can be reapplied without stripping when the job needs to be redone. I really appreciate the help you provide here. Thanks.
  8. Sure Shot Stain says:
    Thanks for the reply. The article you referred me to was helpful but didn't really address the question about using the direct injection method of stripping. Do you have anything to offer regarding that? "Using a pressure washer and direct injection it would seem that it would help prevent the chemical dwell time induced furring but I am also a little confused as to how the direct injection method allows the stripper time to work."
    Thanks again.
    • There is not any difference between injecting or pumping it on when it comes to furring. We find that inject can be done if an easy strip. Better to pump spray a stripper on for more difficult strips.
  9. Terry says:
    Help! I stained my deck (after power washing it and allowing it to dry for 24 hours) with Sherwin Williams SuperDeck semi transparent stain…I used a brush as I like the way it usually turns out. After about a month it looked dirty, so I power washed it to try to get rid of the "dirty look". It worked…however here I am about 3 weeks later, and again my deck looks dirty. I can rub the dirt off with a little water. Why is this happening? I've stained my deck using Sherwin Williams for many years and I've never had this issue. Has anyone else had this issue? What can I do to fix this? Any help would be greatly appreciated. Thanks!
  10. Bobby Pearson says:
    We had the deck prepared by a professional. Had the stain applied by a professional. The stain would not dry. It continues to be tacky to this day, at least what is left does. Stain was applied on May 16th of 2016. One month later,all of the deck exposed to the elements turned black. The only part that is the color it should be is a small area under the covered part of the deck. This is not mold. Because the stain never dried,the water went into the wood and bled the tannic acid out of the wood. We may have to replace the entire deck. Store that sold us the stain offered to refund our money if we would sign a legal document. releasing sherwin williams of any liability. We were not to contact any attorney or even tell anyone how badly this stain reacted. I refused to accept the payment based on the fact that we may have to replace the entire deck. Don't buy this product.
  11. James Holmes says:
    This stain sucks ..I'm applying my 3rd time in as many years .I doing all the right things but this stain does not hold up at all .
    Sherwin Williams can care less about too..thank you!
Leave a Reply
Deck Stain Help Stats
as of December 2016
  • 14,000+ Contributors
  • 3600+ Forum Help Posts
  • 2800+ Consumer Star Ratings
Google Search
Find Products?
Manufacturers and Websites:
...See All Product Websites
Help/Reviews
Login
