Deck Stain Reviews Ratings
Deck Stain Help Articles
Wolman DuraStain Review 3.43/5 (12)
3.43/512
Wolman Durastain Review
Wolman™ DuraStain Semi-Transparent Stain protects new and older decking/wood from UV radiation, mold growth, and rotting.
Beautifies wood with a richly pigmented, semi-transparent, matte finish while providing durability and prolonged color retention. Retains color longer than traditional semi-transparent stains. Ideal for wood exposed to severe sun.
Wolman™ DuraStain Stain Scores (1-10)
Appearance After Initial Stain Application: 3
– When applied the Wolman™ DuraStain looks very unnatural. The stain sits on top of the wood similar to a paint or solid deck stain. It actually looks like a paint with just a small amount of transparency. The Natural Redwood color that used masked the wood grain instead of enhancing the wood grain.
– Wolman™ DuraStain does an excellent job at preventing graying. We attribute this to the overall appearance of the stain. This product looks very close to a solid color stain. Lots of pigment means excellent UV protection. There was little to no graying of the stain that was still left on the deck. The areas that peeled (see below) had turned gray since the wood was bare.
Wear/Tear and Peeling: 3
– We were not impressed with the Wolman™ DuraStain when it came to preventing peeling at the two-year mark. When a stain does not penetrate into the wood but rather “films” on top of the wood then the chance for peeling is greatly enhanced. The Wolman had peeled on 30% of the flooring.
Cost Per Square Foot: 7
– Wolman™ DuraStain retails for $29.99 a gallon. We applied two coats to the 650 square foot deck using a total of 8 gallons of stain costing a  total of $240.
– Zero mold on the deck stain. A small amount of green algae was present in the wood where the Wolman had peeled. Very good results as we would expect with a water based stain.
Ease of Application: 4
– The Wolman™ DuraStain does not apply with a pump sprayer. The stain is very thick, like a paint. We tried a stain pad and had issues with application. We ended up rolling and brushing the stain. The first coat was very uneven as we found that the stain dries extremely fast and overlaps. We decided that a second coat was needed to even the appearance. The second application applied much easier and did help even out the coating. The second coat heavily masked the transparency of the wood grain.
– No darkening of the stain was apparent after the two years of testing.
Difficulty of Reapplication: 5
– Preparation for reapplication would depend on if you want to remove the stain and start over with a different product or stay with the Wolman™ DuraStain. If switching brands of stain, the DuraStain would need to be removed by stripping and heavy sanding. Very labor intensive! If re-coating with the DuraStain, then a good thorough cleaning should be sufficient.
Overall Score Wolman™ DuraStain at 2 Year Period: 6.125
– Wolman™ DuraStain is very good at UV protection, mold resistance and color shifting (lack of darkening). What we did not like is the way the DuraStain creates a film on the surface like a paint. This caused the non-transparent look to the wood grain and increased the probability of peeling. We would rate this stain as a semi-solid, not a semi-transparent stain.
If you are looking for a natural looking wood decking stain then the Wolman™ DuraStain would not be a good choice.
Where To Buy: Paint and Hardware Store or Online
Cost: $34.99 per Gallon
Available Colors: Natural Cedar, Natural Redwood, Woodland Brown, Chestnut Brown, Cape Cod Gray, Sea Shore Gray
Coats Required: 1 Coat. 2nd coat if needed can be applied 72 hours after the first coat.
Coverage Per Gallon: 150-200 sq. ft in field tests
Application Tools: Airless Sprayer, Brush, Roller
Dry Time: 6-12 Hours
Cleanup: Soap and Water
Manufacturer: Wolman
When Tested: August 2006
Deck Wood Type: Pine Dock
Deck Square Footage: 650 Square Foot Deck
Natural Redwood
*All products tested and results are from our hands-on experience. We offer no guarantee of similar results. Take inconsideration that results may differ widely due to different wood types, exposure to UV radiation, and natural weathering.
23 responses to “Wolman DuraStain Review”
  1. Ken says:
    Hi I have the Wolman durastain applied on my deck several years ago and I want to strip it and applied a different stain most likely TWP. What stripper do you recommend? Restore a Deck, HD80 or Defy.
    • Ken, Wolman Durastain is almost like a paint. I am not sure anything will easily remove it. You could try one of the strippers but most likely you will need to sand off the rest.
      • m t says:
        Would you like me to send you a picture of a deck that I cleaned yesterday that had this product on it where it all cleaned off.
  2. Ed Cinquini says:
    My wife and I used Wolman 5 years ago on a 35 year old wood deck. After four years in Oregon rain the product was still beading water but did not to bead in the five winter. The color did look fake from the beginning; turned the wood a muddy brown. It never peeled and held up well in wear areas. In the last couple of years we started to develop moss between the boards, its Oregon. At that the time the cost was very reasonable. Not sure if we will put same product on due to the color.
  3. Bob says:
    Semi-transparent???? Might as well applied a latex paint. Would only recommend applying over pine as you will never know anything else is hiding underneath. The natural ceder looks like milk mustard. I spent 4 hours preping my ceder deck, only to be shocked by how bad the "natural" redwood looked. It looks like a bad sunburn. Thought it would fade……….wrong. I just created a big problem down the road judging by the above comments.
  4. aksakko says:
    We applied this product to our pressure treated pine deck 2.5 years ago, and after only about a year it started peeling terribly. Now it practically peeling from the wind! very unhappy with this product, but at least it shouldn't be much work to strip off and start fresh. If only the sap coming up from every other board was as easy to remove!!
  5. R. Poppelrieter says:
    I prepped my one and a half year old deck as recommended and then applied Wolman's Durastain. It started peeling the next year and by year two it looked like an old delapitated deck with patches of bare wood and peeling stain on all of the horizontal surfaces. I have previously used Cabots and Behr with varying results on other decks but have never seen anything as bad as this before. I took pictures and receipt and got my money back with an in-store coupon. One saleman did not seem surprised as if this was the norm for this stain. Now I have to sand the whole deck to re-stain with a different brand and have already spent over $40.00 dollars on sanding belts as they gum up with all the peeled stain, not to mention the intense labor I have had to expend. Good luck if you are trying to save some dollars by buying this stain. I would not recomend this stain to my worst enemy.
  6. Jeff says:
    Peeling even from the uprights after 1 year. Not at all recommended.
  7. Kimberly says:
    We reapplied the stain last autumn after cleaning it, as is recommended. Within a few months it had chipped away again. Any advice? Also, I can't seem to get the deck clean. I've tried various products, but as soon as it dries, it looks just as dirty as before. It's a superficial layer of dirt on top, that no matter what I do won't come off.
  8. Simon says:
    can durastain be topcoated with a clear? maybe varathane spar urethane?
  9. Nick says:
    Why can't it be top coated?
  10. Gerry says:
    Prepped the cedar railing and the cedar horizontal surfaces as directed on the can and on the web site. Also confirmed usage & directions with 'expert' at Menards. We took five weeks for the whole job just to be sure everything was clean & dry before application. Applied as per directions. Used DuraStain solid stain on railing which held up very well so far. Used DuraStain semi-transparent on deck boards. It lasted two weeks before it started to chip. Now, 18 months later it's rolling off in little strips when you walk on it or sweep it. We are not rookies at deck finishing. This product is lousy. All that work and product was a waste.
  11. mike says:
    I used this 5 years ago and it's really held up well. Of course the top of the wood has worn so now I'm going to use it again this summer.
  12. Mary says:
    We used Wolman Dura Stain the summer of 2014 on our back deck of treated lumbar. By March of 2015 the "Stain" was already peeling off the deck. It now needs to be re"stained" in July of 2015. Should have lasted longer than one winter. Very Disappointed with this product. It was a lot of hot, hard work to get the deck done and now it looks terrible.
  13. Jill says:
    I just used Wolman semi transparent stain on my deck. It took quite a while to do 2 decks, ever since I did it the squirrels have literally eaten the stain clear down into the wood. It's gotten so bad that I'm going to have to start replacing some of the wood and totally resting my decks with a different stain. The decks are 5 and 3 years old, they did not bother the decks at all until I used the stain.
  14. Sue says:
    We put Wollman Stain on our two decks and were terribly disappointed. The next year the horizontal boards were peeling and looked awful. After putting that much work into a deck it was totally disappointing.
  15. Jack says:
    Use wolman F and P on Pine log home. Goes on easy and I can paint whole house in 2 days. Live up on top of a mountain and sun beats on house. Stain fades a little bit after 3 years. I can spray house down with water and it still beads up! No peeling what so ever. Mom has a cedar log home and uses Sikkens. Terrible stain. Peels all over the place or blisters. At 90 dollars a can(sikkens) I will stick with my 35 dollar Wolmans.
  16. Mickey says:
    I am looking for the top rated solid color dock stain. It is an older deck, that is overdue for stain. It has been power washed.
    Don't really care if it shows wood tone. Thanks.
  17. Ken says:
    Surprised to see so many issues with it… Used this on our deck 5 years ago that has heavy traffic and the railing still is in good condition, the steps and floor is worn and needs help. Can't find the product nearby though.
Leave a Reply
Deck Stain Help Stats
as of December 2016
  • 14,000+ Contributors
  • 3600+ Forum Help Posts
  • 2800+ Consumer Star Ratings
Google Search
Find Products?
Manufacturers and Websites:
...See All Product Websites
Help/Reviews
Login
