30 Seconds Outdoor Deck Cleaner Review 3.1/5 (7)
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking cleaning and prep. My 30 Seconds Outdoor Cleaner review is based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
Quick Verdict - Deck Cleaner Review
  • 30 Seconds Outdoor Deck Cleaner earned an overall rating of 6.75 out of 10, making it a below-average choice for serious deck prep.
  • The product is essentially bleach with soap additives, which can damage wood lignin and leave the surface unbalanced for stain absorption.
  • It scored a 5 out of 10 for removing graying and oxidation, meaning it falls short on heavily weathered or deteriorated Western Red Cedar and similar wood types.
  • Application is simple and earns a 9 out of 10 for ease, requiring only a pump sprayer with no mixing needed.
  • A dedicated deck cleaner and brightener system is still required before staining; skipping proper prep is one of the top reasons deck stains fail early.
6.75 Overall Rating 30 Seconds Cleaner
30 Seconds Outdoor Deck Cleaner is a ready-to-use cleaning solution designed to quickly remove dirt, algae, mold, and mildew from exterior surfaces. It is marketed as a fast and easy option that requires minimal effort compared to traditional deck cleaning systems.
From my experience restoring decks since 1993, products like this are best suited for light cleaning rather than full deck preparation before staining. While it can improve the appearance of the wood, it does not replace the need for a proper cleaner and brightener system when prepping for stain.
Overall, 30 Seconds Cleaner can be useful for quick cleaning and maintenance, but it is not a complete prep solution for staining projects.
Note: We used the 30 Second Cleaner to prep a wood deck in our test results.
🔹 Quick Verdict – 30 Seconds Deck Cleaner
30 Seconds Outdoor Deck Cleaner – Quick Review
  • Best For: Light cleaning and maintenance
  • Not Ideal For: Full deck prep before staining
  • Type: Ready-to-use surface cleaner
  • My Overall Rating: 6.75/10
This is a convenient product for quick cleaning, but it should not be relied on for proper deck prep before staining.
30 Seconds Deck Cleaner Rating (1-10)
How I Rated 30 Second Cleaner
My 30 Second Cleaner review contains a 5-step process and the final average score. Each step is on a scale of 1-10.
  1. Removal of Graying and Dirt
  2. Cost Per Square Foot
  3. Removal of Old Stain (if applicable)
  4. Ease of Application
  5. Final Appearance after Cleaning
  6. 30 Second Cleaner Final Score
5-Step Review of 30 Seconds Deck Cleaner
1. Removal of Graying, Dirt, Grime: 5
The 30 Seconds Outdoor Deck Cleaner did poorly cleaning and removing the graying. The cleaner removed mildew and mold, but it does nothing to remove old deteriorated coatings and oxidation/graying of the wood. It lightened the color of the wood slightly. On inspection of the contents, it is bleach with soap additives.
2. Cost Per Square Foot: 7
It’s cheap for a liquid outdoor deck and mildew cleaner, but since it does not work very well, we could not give it a better rating here.
3. Ease of Application: 9
The 30-Second Outdoor Deck Cleaner applies easily with a pump sprayer. No mixing is needed—just fill the sprayer and apply. Consistency is not an issue with the sprayer’s clogging.
4. Final Appearance of Cleaning: 6
We were not impressed with the overall cleaning, it just bleached out the wood somewhat.
Overall Score for 30 Seconds Outdoor Deck Cleaner: 6.75
30 Seconds Outdoor Deck Cleaner is a poor way to prep your wood or deck for a stain. It is bleach with some soap in it. Bleach is bad for exterior wood as it damages the lignin or “glue” that holds the wood’s cellular structure together. Bleach is also bad for the surrounding areas and can be used without proper equipment or protection.
Looking For a Better Deck Cleaner?
Where To Buy: Home Depot, Lowes
Product Type: Deck Cleaner and Mold/Mildew Remover
Available Sizes: 1 Gallon and Ready to use Spray Bottles
Application Tools: Pump Sprayer and Hose
Manufacturer: 30 Second Outdoor Deck Cleaner
Deck Square Footage: 600
The Condition of Deck: Heavily grayed with mold/mildew.
How Much Product Used:
1 Gallon Retails for $20.99 per gallon.
🔹 Pros and Cons – 30 Seconds Outdoor Deck Cleaner
30 Seconds Outdoor Deck Cleaner – Pros
  • Very easy to use with no mixing required
  • Works quickly to remove surface dirt, algae, and mildew
  • Can be used on multiple exterior surfaces
30 Seconds Outdoor Deck Cleaner – Cons
  • Contains bleach, which can be bad for wood fibers
  • Does not properly prep wood for staining
  • Does not remove deep oxidation or old stain residue
  • No brightening step included
  • Can leave the wood unbalanced for stain absorption
  • Limited effectiveness on heavily weathered decks
🔹 Best Uses for 30 Seconds Cleaner
  • Removing surface algae and mildew
  • Quick cleanup for lightly soiled decks
  • Cleaning surrounding areas like siding or railings
Not Ideal For:
  • Prepping wood before staining
  • Removing heavy oxidation or graying
  • Restoring older or heavily weathered decks
  • Apply evenly to the surface
  • Allow proper dwell time for cleaning
  • Rinse thoroughly
  • Avoid letting the product dry on the surface
While this product works well for maintenance, it should not replace proper prep before staining.
  • Use a true deck cleaner and brightener before staining
  • Do not rely on quick cleaners for prep
  • Proper prep improves stain penetration and longevity
From my experience, using the wrong type of cleaner before staining is one of the main reasons stains fail early.
🔹 Who Should Use 30 Seconds Cleaner?
You should consider this product if:
  • You want a quick and easy cleaning solution
  • Your deck is lightly dirty or has surface mildew
  • You need a general-purpose outdoor cleaner
  • You are preparing a deck for staining
  • Your wood is heavily weathered or grayed
  • You need deep cleaning or stain removal
🔹 FAQs – 30 Seconds Outdoor Deck Cleaner
Can 30 Seconds Cleaner be used before staining a deck?
No, it is not designed for proper deck prep and should not be used as a substitute for a cleaner and brightener system.
Does it remove old stain?
No, it only removes surface dirt and mildew.
Do you need to use a brightener after using this?
Yes, if you plan to stain the deck, a brightener is still required.
How long does it take to work?
It works quickly, usually within minutes of application.
Is it safe for all wood types?
Yes, when used properly, but always test a small area first.
Can it damage plants or surrounding areas?
It can if not rinsed properly, so always protect surrounding vegetation.
🔹 Final Thoughts – 30 Seconds Outdoor Deck Cleaner
30 Seconds Outdoor Deck Cleaner is a convenient option for light cleaning, but it is not a substitute for proper deck prep before staining. It works best as a quick solution for removing surface dirt and mildew.
From my hands-on experience, proper deck prep requires a dedicated cleaner and brightener system. While products like this can help with maintenance, they should not be used when preparing wood for a new stain.
If you use it for what it is designed for, it can be a helpful tool—but it is not a complete solution for deck restoration.
My #1 Best Deck Cleaner
My #2 Best Deck Cleaner
My #3 Best Deck Cleaner
My Honorable Mention
*Ships Free
*Ships Free
*Brightener Additional
*Ships Free
The Best Deck Cleaner Video
17 Comments
annette vallejo
annette vallejo
i used the 30 seconds outdoor cleaner and it did not say to put gloves on and now my four fingers feel like they are burning do i have to go to the emergency for this
Rus
Rus
It does not show any corrosive warning label says biodegradable does not recommend wearing gloves yet I now have chemical burns on my hands and in a lot of pain . Will be contacting government oversight to report lack of adequate safety labels .
ToolGuyPa
ToolGuyPa
I followed the directions exactly as written. Results were awful. Try another product. If I could return an empty container back to the store I’d be on my way right now. Don’t waste your money.
Al
Al
BQPC
BQPC
I am a professional Painting Contractor, If I were rating this product on ability to clean surface alone it would be 4 stars, how ever I must say that it advertises it WILL NOT KILL PLANTS on multiple spots on label, FYI THAT IS A LIE. I have photos, killed about $1500 Worth of plants at a clients house, I am extremely unhappy and believe if they say it will not kill plants that they should reimburse my clients. Its not that it does that which annoys me, its that they say it doesn’t but it did, otherwise I would have covered plants.
Fran
Fran
I used this straight out of the bottle. Big mistake. I am on day 12 of what looks like a sunburn. On day 2 I had tingling under my skin on top of my hands under cold water through day 10. I also couldn’t use hot water. Day 12 and it hurts to bend my knuckles which are white but the sensitivity to cold is just about gone and I can shower with hot water again. Shouldn’t I be better by now? I’ve kept them covered when outside to avoid sun exposure.
Robert Davidson
Robert Davidson
I tried this on my wood deck at home to test it before recommending purchasing at the property management company I work for. I cannot reccomend this product because of the lackluster results I had using it. The bottle says spray on and hose off, but only in the fine print does it advise that you will need to scrub vigorously on algae stained wood decks.
Karen Ward
Karen Ward
Does it damage brick?
Alan MASSING
Alan MASSING
I thought this product worked fairly well however I used it on concrete that has been resurfaced and sealed. I believe it ate through the seal and bleached some of the stain that is part of the resurfaced concrete. Not real happy about it but nothing i can do now.
Jason Lane
Jason Lane
I tried this product this weekend. When first using I thought it was great. However when I woke up in morning to a white fence I was pissed. Any help to get this white residue? My fence is cedar with allot of gray. What do you recommend? Thanks
cam
cam
to prevent damage to plants with 30 seconds, spray plants with water first and do not use 30 seconds in the scorching sun. As with anything, a little common sense goes a long way in making a project successful.
Shirley
Shirley
This product is garbage. Waster of money and time and deck looks bad after using it.
17
