Bakers Wood Stain Review – Updated 2026 3.8/5 (2)
Bakers Wood Stain Review 2026
Welcome to Deckstainhelp.com, your number-one source for deck staining tips and the latest industry news on the internet. Bakers Wood Stain continues to follow the same wear patterns and UV resistance as years before. Leave us a comment if you’ve used Bakers Wood Stain and how it’s held up to the test of time.
  • Baker's Gray-Away Wood Stain scored an overall 7.25 out of 10 after two years of real-world testing on a 400 square foot pressure treated pine deck.
  • UV protection was underwhelming at the two-year mark, with noticeable fading, washed-out color, and significant wood graying across the entire deck surface.
  • Mold, mildew, and algae were found living in and on the finish, with black mildew spots and algae growth especially along the outer deck edges.
  • Coverage averaged only 125 square feet per gallon, far below the labeled rate, driving costs up to 50 cents per square foot for the test deck.
  • Baker's Wood Stain is reportedly a modified, watered-down version of TWP 200 Series Stain, repackaged by Texas Wood Products after altering the original Gemini/Amteco formula.
Bakers Wood Deck Stain
Note: This is an updated Review for the Bakers Gray Away Stain
Baker’s® Gray-Away® Wood Stain from Texas Wood Products is recommended for decks, fences, roofs, wood siding, and log cabins. Baker’s Wood Stain is a premium, long-lasting wood sealer preservative with unique UV resisting pigments. Special resins and penetrating oils have made Baker’s Wood Stain a leading professional’s choice stain for exterior wood surfaces.
Bakers Wood Deck Stain Ratings (1-10)
Appearance After Initial Stain Application: 7
–On our test deck, we chose to use the Super Cedar color. The final appearance was an even finish. The wood knots were light compared to the rest of the surface that highlighted the wood grain with a golden hue.
Preventing UV Graying at 2 Year Mark: 7
–To say the least, we were unimpressed with Baker’s Wood Stain at the 2-year period. The overall coloring was faded and washed out. There was a significant amount of wood graying over the entire deck.
Wear/Tear and Peeling: 7
–Baker’s Deck Stain does penetrate well. About a third of the finish was worn away though in the high traffic areas after 2 years. In more protected areas where stain remained there was no significant peeling.
Cost Per Square Foot: 7
–Baker’s Stain is on the less expensive end of most wood stains we have tested. The coverage rate of our test deck was not that great, which drove up the overall cost. We averaged a low 125 square feet per gallon spread rate. For a 400 square foot deck, we needed 6 gallons of Baker’s Stain. This drove our cost up to .50 cents per square foot.
Preventing Mold/Mildew/Algae: 7
–Both mold and mildew were found living in the finish. Black mildew spots were abundant in the stain along with algae growth on top of the stain especially near the outside edges of the floor.
Ease of Application: 7.5
–For ease of application, we experienced average results. Due to a low coverage rate, we had to give Baker’s a lower score. We used a sprayer for the first coat and a stain pad for the second coat. We had 3 hours of labor applying 2 coats of Baker’s Stain on our 400 square foot test deck.
Color Shifting (darkening) after 2 Years: 8
–Color shifting score was not great due to the black mildew and algae problems that we experienced after 2 years. Some darkening was noticed.
The difficulty of Reapplication: 7
–We believe it would be best to strip Baker’s Wood Stain off completely to get back down to bare wood. Baker’s should strip off fairly easily due to wearing off so much after 2 years. A decent wood deck stain stripper should work well to remove Baker’s. If the Baker’s had faded evenly, you would be able to clean and reapply instead of stripping.
Overall Score Bakers Wood Stain at 2 Year Period: 7.25
–This is a slightly above the average stain. After some research, we found that Baker’s is a watered-down version off of TWP 200 Stain. Our investigation uncovered the fact that Texas Wood Products buys TWP in concentration from Gemini/Amteco (manufacturer of TWP) then changes the formula. They package it as Baker’s Wood Stain. The result is a different version of TWP Stain. We suggest using TWP Wood Stains if you want the full results of a professional oil-based exterior wood stain.
Cost: $43.99 per Gallon, $179.99 per 5 Gallon Pail
Stain Type: Oil-Based semi-transparent
Available Colors: Super Clear, Super Gold Cedar, Super Cedar, Super Cedar Dark, Walnut, Super Redwood, Driftwood, Special Blend, Redwood, Cedar tone, Natural Cedar, Sierra, Red Barn, Oak, Chocolate, Dark Oak, Coffee, Taupe, Driftwood, Slate Gray, Gray Stone, Dark Gray, Espresso, Ebony
Coats Required: 2 Coats. “Wet on Wet”
Coverage Per Gallon: 150-200 sq. ft
Dry Time: 48 Hours
Cleanup: Mineral Spirits
VOC Compliant: 250 Compliant
Manufacturer: Bakers Wood Products
Deck Square Footage: 400
UV Exposure: Full Deck
Stain Color Used: Super Cedar Gold
2 Comments
Jim Millman
Jim Millman
I do not see anything about Penofin deck finishes. How do they rate in your opinion. A few years ago I had a professional deck refinisher do my deck with Penofin when I was disabled and the deck looked and lasted better than when I used the Olympic semi-transparent finish.
2
