Best Deck Stain for High Traffic? 5/5 (1)
Best deck stain for high traffic?
The best type of deck stain for high traffic decks are semi-transparent penetrating deck stains. Not all semi-transparent deck stains are penetrating. Penetrating deck stains are best for high traffic areas because they age and wear away rather than peeling or cracking. It is also easier to reapply new deck stain, often without removing the old stain. The best brands of deck stain for high traffic decks are TWP, Armstrong Clark, and Restore-A-Deck.
  • Semi-transparent penetrating deck stains are best for high traffic decks because they wear away gradually instead of peeling or cracking.
  • Top recommended brands for high traffic decks include TWP, Armstrong Clark, and Restore-A-Deck.
  • Even the best penetrating deck stains last only 1 to 3 years, so plan for regular reapplication regardless of conditions.
  • Reapply semi-transparent deck stain at the first sign of wear, not after failure, to use less stain and better protect the wood.
How often reapply stain for high traffic?
Even penetrating deck stains do not last more than 1 – 3 years regardless of the conditions that can age a deck. Reapplying a semi-transparent deck stain can be done when you first start noticing wear. It is best not to wait for the stain to fail completely before applying a new coat of stain. This will allow you to use less stain in reapplication and best protect the wood.
More information about deck stains for high traffic
0 Comments
