Best Deck Stain for Older Decks 5/5 (1)
Exterior Wood Stain for Older Decks
Older decks often require more coats of stain due to increased porosity, but the best option is to use a semi-transparent or semi-solid penetrating deck stain. These stains soak deep into the wood, offering superior protection while enhancing the deck’s appearance.
  • For older decks, semi-transparent and semi-solid penetrating stains are the best choice, soaking deep into wood for long-lasting protection.
  • Penetrating stains prevent peeling and flaking by soaking into the wood rather than forming a surface film, ideal for weathered decks.
  • Restore-A-Deck is a top pick for aging decks, offering excellent penetration, UV protection, and mildew resistance in a water-based formula.
  • TWP (Total Wood Preservative) and Armstrong-Clark are highly recommended oil-based options that deeply nourish and condition older, worn-out wood.
  • Proper cleaning and brightening before staining are essential steps to achieving the best results on an older deck.
  • Semi-transparent stains allow the wood grain to show through while enriching its natural color.
  • Semi-solid stains provide more coverage, hiding imperfections while still offering some visibility of the wood grain.
By penetrating the wood rather than forming a surface film, these stains help prevent peeling and flaking, making them ideal for weathered decks that need long-lasting protection.
Best Brand of Deck Stain for Older Decks
For aging decks, Restore-A-Deck is one of the best stain options. This water-based semi-transparent stain is specifically designed for older wood, offering excellent penetration, UV protection, and mildew resistance.
Other highly recommended brands include:
  • TWP (Total Wood Preservative) – A high-quality oil-based semi-transparent stain that deeply nourishes and protects older wood.
  • Armstrong-Clark – Another oil-based semi-transparent stain, known for its conditioning oils that restore dry, worn-out decking.
Each of these stains helps revive older decks by sealing out moisture, preventing further wood decay, and enhancing durability.
Would you like recommendations for prepping an older deck before staining? Proper cleaning and brightening are key to getting the best results!
Stain Comparison Chart for Older Decks
Brand Type Transparency Best for Key Benefits Durability Drying Time Mold/Mildew Resistance UV Protection Ease of Application
Restore-A-Deck Water-Based Semi-Transparent Older decks needing fast drying & easy application Eco-friendly, can be applied same day as cleaning 3-5 years 4-6 hours High High Easy
TWP (Total Wood Preservative) Oil-Based Semi-Transparent Older wood requiring deep penetration & UV protection Deeply penetrates, prevents mold/mildew, long-lasting 3-6 years 24-48 hours High High Moderate
Armstrong-Clark Oil-Based Semi-Transparent Older decks needing conditioning oils & durability Contains conditioning oils, flexible finish, easy reapplication 3-5 years 24-48 hours High High Moderate
5 Comments
NanaEllen
NanaEllen
Also, we would like to change the color from the red/brown to a medium /dark brown. Any advice on how to address this? Will we just need to see if 1 coat will cover?
IMG_6712
NanaEllen
NanaEllen
Thank you Scott. Deck is 23 years old and we have had it stained every year with a semi-transparent stain? Photos attached of the worst area and then also what the majority of the deck looks like. Would you recommend Restore-A- Deck or TWP or Clark product based on the condition of the deck based on viewing these pics?
IMG_6711
IMG_6712
NanaEllen
NanaEllen
Reply to  NanaEllen
Thank you Mark. The company we use has always used TWP oil. The flats have been stained every year. Entire deck every other year. Just 1 coat. I did think it looked like it was a thicker coat last year.
I would also like to change the color so it has more brown in it, however they are advising that Dark Oak will look too dark. Any suggestions on color? Do you know what ratio if any of Pecan and Dark Oak would give a medium brown color?
5
