Best Fence Stain? 5/5 (1)
Best Fence Stain: What to Use and Why
Hi, I’m Scott Paul, a licensed exterior restoration contractor with over 30 years of experience and 10,000+ deck restorations. This guide to the best fence stain is based on my own hands-on field testing, not manufacturer claims. See my full credentials and testing stats here.
Deck stain can be used to stain a fence, but not every deck stain is the right choice for this purpose. Semi-transparent penetrating deck stains are best for fences because they penetrate the wood to protect it against both moisture and sun. The penetrating nature of these fence stains also makes application easier, helping you avoid the drips that are inevitable when painting a fence. Semi-transparent penetrating stains are best for fences because they let the natural wood grain show through. The best semi-transparent penetrating fence stains are TWP, Armstrong Clark, and Restore-A-Deck.
Best Fence Stain — Quick Answer
  • The best fence stains are semi-transparent penetrating oils: TWP, Armstrong Clark, and Restore-A-Deck
  • Penetrating stains are better than paint or solid stains for fences — no drips, and the wood grain still shows through
  • All three top picks hold up for 3 to 5+ years on a fence, longer than on a deck floor since fences don't take foot traffic and have less UV oxidation
  • Proper prep (cleaning and brightening) matters as much as the product choice for a long-lasting result
Table of Contents
Best Fence Stain Comparison
Stain Type DSH Rating Coverage/Gallon Cost/Gallon
TWP Oil-based, penetrating 8.5–8.69/10 150–250 sq ft $41.99–$46.99
Armstrong Clark Oil-based, penetrating 8.5/10 150–200 sq ft $72.95–$83.95
Restore-A-Deck Water-based, penetrating 8.63/10 100–150 sq ft $47.99
All three are strong choices for a fence — the right pick often comes down to whether you prefer oil-based (TWP, Armstrong Clark) or water-based (Restore-A-Deck), and which wood type you’re staining.
Why Penetrating Stains Are Best for Fences
FTWP1515 Honeytone Fenceences take less abuse than a deck floor — no foot traffic, no furniture, no direct contact wear — but they face constant exposure to sun and rain on both sides. A penetrating semi-transparent stain soaks into the wood fibers rather than sitting on the surface, which means it won’t peel or crack the way a solid stain or paint can over time. It also makes application faster and more forgiving, since drips and runs are far less of an issue than with a film-forming product.
Once you have picked a stain, follow my step by step guide on how to stain a wood fence for prep, application, and avoiding lap marks.
Semi-Transparent Stain Photos
All stains that are used on decking can be used on fencing. The positives are that the stains will last 2-3 times longer on vertical wood like fences.
How to Stain a Fence Video
Best Fence Stain FAQ
What’s the best fence stain for cedar?
TWP, Armstrong Clark, and Restore-A-Deck all perform well on cedar fencing. Cedar is naturally rot-resistant and takes penetrating oil stains well, so any of the three top picks will highlight the grain nicely. If you want an oil-based option, TWP or Armstrong Clark are excellent on cedar; if you prefer water-based, Restore-A-Deck is a strong choice with good color retention.
How long does fence stain last?
A quality semi-transparent penetrating stain on a fence typically lasts 4 to 5 years or longer, outperforming what you’d see on a deck floor since fences don’t take foot traffic or furniture wear. TWP and Armstrong Clark have both shown minimal fading on vertical surfaces like railings and fence boards in our testing, often holding up even longer than that on the shaded side of a fence.
Should I use semi-transparent or solid stain on a fence?
Semi-transparent penetrating stain is the better choice for most fences. It soaks into the wood instead of forming a surface film, so it won’t peel or crack the way solid stains and paints can, and it lets the natural wood grain show through. Solid stains can work if you want to fully hide the wood’s natural color or cover an older, less attractive fence, but they carry a higher risk of peeling over time, especially on horizontal cap rails exposed to direct sun.
How do I prepare a fence for staining?
Clean the fence with a deck and fence cleaner to remove dirt, mildew, and graying, then rinse thoroughly and let it dry completely, typically 24 to 48 hours depending on weather. If the fence has old, failing stain, you may need a stain stripper rather than just a cleaner. Proper prep matters just as much as the stain you choose — even the best fence stain won’t perform well over dirty or improperly dried wood.
Which is the single best fence stain: TWP, Armstrong Clark, or Restore-A-Deck?
All three are excellent choices, and the best pick depends on your priorities. Armstrong Clark and TWP score highest in our overall testing (8.5 and up to 8.69) and are both oil-based penetrating stains with strong mold resistance. Restore-A-Deck is the top water-based option, scoring 8.63, and offers easier cleanup and lower VOCs if that’s a priority for your project.
Can I stain a new wood fence right away?
It depends on the wood. Pressure-treated fencing usually needs to weather for a few weeks to a few months before staining, so the wood can dry out enough to absorb the stain properly. Cedar and redwood fencing can often be stained sooner. See our guide on staining new wood for specific wait times by wood type before starting your fence project.
More Information on Best Fence Stains
0 Comments
