Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My Cabot Australian Timber Oil Stain review is based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
7.19 Overall Rating Cabot Wood & Deck Stain
Cabot Wood and Deck Stains offer three-way protection for exterior wood and decking. They offer maximum durability from water damage while penetrating deep into the wood. Containing linseed oil and Trans-oxides, Cabot Stains will reflect UV damage, giving long-lasting protection. Cabot has traditionally been one of the leaders in the exterior wood restoration industry.
Cabot Wood Deck Stains are widely available and come in several versions, including semi-transparent, semi-solid, and solid color finishes. They are marketed as durable coatings designed to protect exterior wood while enhancing its appearance.
From my experience restoring decks since 1993, Cabot products vary quite a bit depending on the version you use. Some perform better than others, but many of them tend to act more like surface coatings rather than true penetrating stains, especially the semi-solid and solid versions.
Overall, Cabot stains can provide a decent initial appearance, but long-term performance and ease of maintenance are not always as strong as higher-quality penetrating stains.
🔹 Quick Verdict – Cabot Deck Stains
Cabot Wood Deck Stain – Quick Review
- Best For: Availability and initial appearance
- Not Ideal For: Long-term performance and easy maintenance
- Type: Oil-based or water-based (varies by version)
- My Overall Rating: 7.19/10
Cabot stains can look good at first, but performance varies depending on the product line. In many cases, they behave more like coatings and can be harder to maintain over time.
How I Rated Cabot® Cabot’s Australian Timber Oil
My Cabot’s Australian Timber Oil review contains an 8-step process and the final average score. Each step is on a scale of 1-10.
- The appearance of Cabot’s Australian Timber Oil after Application
- Preventing UV Graying after 2 years
- Peeling or Wearing
- Cost Per Square Foot Cabot’s Australian Timber Oil
- Preventing Mold and Mildew
- Color Shifting/Darkening
- Reapplication Difficulty
8-Step Review of Cabot’s Australian Timber Oil
1. Appearance After Initial Stain Application: 7
The Natural Tone of the Cabot Stain did a remarkable job of restoring the wood colors in our pine deck. However, the stain did not penetrate into the wood as expected and left shiny spots throughout the flooring.
2. Preventing UV Graying at 2-Year Mark: 6
The Cabot Deck Stain showed 60% color retention after 2 years. The Natural tint faded in color significantly on the flooring. We expected better results from Cabot Australian Timber Oil.
3. Wear/Tear and Peeling: 7.5
The Cabot Stain was completely gone on 25% of the decking surface after two years. It seemed that the winter substantially damaged the stain as there was heavy wearing.
4. Cost Per Square Foot: 8
We only needed one gallon of Cabot’s to cover the 200 square feet, which equates to $.28 a square foot.
5. Preventing Mold/Mildew/Algae: 6
After 2 years, a decent amount of mold was growing on about 30% of the deck. In addition, algae growth was observed under the railings and around the house’s perimeter.
6. Ease of Application: 8.5
The Australian Timber Oil did not apply as easily as we would like. The finish spread very well regarding coverage, but we had difficulty getting the stain to absorb evenly into the wood. We used a stain pad applicator and applied it evenly, but the Cabot dried tacky and sticky in several areas.
7. Color Shifting (darkening) after 2 Years: 7.5
Darkening of the stain had occurred where the stain was still attached to the wood. Mostly due to dirt and mold.
8. Difficulty of Reapplication: 7
I would suggest a heavy stripping followed by a wood brightening to restore the Cabot Stain. We suggest stain removal since the stain had worn in places and there was mold/algae. This would be the best way to prep for another coat of stain.
Overall Score Cabot Wood Deck Stain at 2-Year Period: 7.19
The Cabot Australian Timber Oil had an average score compared to other stains we tested. We expected more from Cabot when it comes to preventing mold and algae. In addition, the UV resistance scored low. It’s not a bad stain, but it not the best either. It is a good option if you are limited to buying from a big box store. There are better decking stains online.
Where To Buy: Select Hardware Stores or Online
Cost: $55.99 per Gallon, $295.99 per 5 Gallon Pail
Stain Type: Semi-Transparent
Available Colors: Amberwood, Honey Teak, Mahogany Flame, Natural
Application Temperature: 45-90 F
Coats Required: 1-2 Coats
Coverage Per Gallon: 200-300 sq. ft
Dry Time: 24 Hours
Manufacturer: Cabot
Deck Wood Type: Pine
Deck Square Footage: 200
UV Exposure: Mostly Sun with southern exposure
Stain Color Used: Natural
🔹 Cabot Wood Deck Stain – Pros and Cons
Pros
- Widely available and easy to find
- Multiple product options and finishes
- Good initial color and appearance
- Can help hide imperfections (semi-solid and solid versions)
- Established brand with long history
Cons
- Performance varies significantly by version
- Many products sit more on the surface than penetrate
- Risk of peeling or uneven wear over time
- Can require more prep for recoating
- Not as easy to maintain as penetrating stains
🔹 Best Wood Types for Cabot Stain
- Older wood needing coverage: Can improve appearance
- Decks where color uniformity is important: Provides consistent finish
Not Ideal For:
- New wood – better penetrating options available
- Decks where easy maintenance is a priority
- Hardwoods (IPE, Cumaru, etc.) – not designed for proper absorption
- Follow product-specific instructions carefully
- Avoid over-application
- Be aware that thicker coatings increase failure risk
Maintenance can be more involved depending on the Cabot product used.
- Monitor for peeling or uneven wear
- Recoating may require additional prep or stripping
- Do not allow coatings to fully fail
- Plan maintenance coats when possible
From my experience, once coatings begin to fail, they often require more work to correct compared to penetrating stains.
🔹 Who Should Use Cabot Stain?
You should consider Cabot if:
- You want a readily available product
- You are focused on initial appearance
- You want more coverage options
- You want long-term durability
- You want easier maintenance and recoating
- You prefer a true penetrating stain
🔹 Cabot Wood Deck Stain – FAQs
Is Cabot a penetrating stain?
It depends on the version, but many Cabot products behave more like surface coatings.
Does Cabot stain peel?
Yes, some versions can peel or wear unevenly over time.
How long does Cabot deck stain last?
Performance varies, but it often depends on prep, exposure, and product type.
Can Cabot stain be reapplied easily?
Not always. Additional prep or stripping may be required depending on wear.
Is Cabot good for new wood?
There are better options that penetrate more effectively and last longer.
How does Cabot perform in full sun?
It can fade and wear unevenly, especially with surface-level coatings.
🔹 Cabot Wood Deck Stain – Final Thoughts
Cabot Wood Deck Stains are a well-known option that can provide a decent initial appearance, but performance can vary widely depending on the product line. Many versions tend to act more like coatings, which can lead to more involved maintenance over time.
From my hands-on experience, penetrating stains still offer better long-term results and are much easier to maintain compared to products that sit on the surface.
If your goal is convenience and availability, Cabot may be a consideration. If your goal is long-term performance and ease of maintenance, there are better options available.
After 2 years Australian Timber oil is flaking on our Pergola & our Cedar Fence. We pay top dollar for this CRAP. Writing to Cabot is nothing more than a BLACK HOLE – no response. Our Pergola shelf is perfect example of NO TRAFFIC yet peeling up…
Terrible product. Gone in 6 months. Expensive. I will be going back to Lowe’s to complain
Never ever again will purchase we put it on our deck after about a year and now it’s peeling up and flaking , looks horrible.
We had the same problem! Now I have to scrape it off and start over. The color also didnt look like the chip either. Worst stain ever!
This review is in regards to the natural tone product ,applied the the product in accordance with the prep and all others requirements. This is a 35 year old front porch victorian out of the elements porch. Used one gallon , it has now been almost two weeks since the application it’s sticky as you walk on it. Called Cabot today 7/11.2019 told them of the issue there recommendation was to go buy a a jug of simple green to clean the deck !WHAT! a joke! OH YEA! call the simple green company and ask how to use it. Not what I expected and to say it didn’t absorb the product what a joke a 35 year old deck cleaned and prep per ther instructions not to mention a deck that has never had a product put on it that was a joke! This is a poor product BUYER BEWARE!
Cabot stain is a terrible product. I applied on my new redwood deck and after 2 years, I had to sand down deck to remove massive peeling. It caused a lot of work. I am a contractor and I will do my best to pass along this information to all customers.
Yes I agree, same thing do not use this product
Agree. Sticky at first even after power washing the deck and allowing it to dry, All it does is seal in moisture and next year it starts rotting. 2 years after application, the whole deck is rotted.
My next deck paint will be no paint. When I can get a home loan will replace with trex. What a disappointment!
I live in Northern, Illinois and have a cedar deck. I replaced all f my decking and let it “weather” for a year before applying a stain. I really shopped around for a good product and was advised by Lowes, that for my area and the finish I wanted, they recommended Cabot Australian Timber Oil. I contacted Cabot and they told me the procedure to follow. Well, I purchased 2 gallons of the product, cleaned deck, per instructions and let dry completely. I applied the stain, and as it dried, it looked like a million bucks. Looks were deceiving. This was May of 2018. Here it is, mid April 2019 and my deck looks terrible (wish I could attach photos). I just contacted cabot and was advised they would send me a refund, with proof of purchase. Now, let me ask you. How many people keep a receipt that long? Then they went on to tell me, that was about the life expectancy of the product. My advice: STEER CLEAR OF THIS TERRIBLE, TERRIBLE PRODUCT!!!
I absolutely agree. I will never touch a Cabot product again. OR a Sherwin Wms (since they now own Cabot) I loved SW for years. Until I suddenly didn’t, when I accidentally encountered their woter-borne semi-trans stain. My FIRST disaster (which ended in replacing the deck) (time had come. 20 yrs old)
New deck I had a shop apply Cabot semi-transparent alkyd stain to my new air dried in a ‘spa-drying’ shop. CVG cedar. It was a disaster that I am still dealing with a year later. Cabot rep came out and just shrugged and said ‘I don ‘t know”. The shop said they followed normal coating procedure -drying green wood for 2 wks at 80º before coating.. long story, Wine Valley Siding (the shop that coated it) told me to take it up with the lumber broker. I knew I was screwed. It appeared that it was a mill-glaze issue. The lumber vender steered me away from sanding,. (Thanks LS Cedar, Vashon Island.)I am happy to have found this site. I have just pressure washed the crap off my deck, what was left. Now trying to determine the next step. Sand? Brighten? G&T seems to be the only way to go. I hope my photos get posted!
Misery loves company. So happy to have found this site!
Hey cabot You won’t get my money again guaranteed
