Deck Stain Is Not Drying 5/5 (1)
Why is my Deck Stain Not Drying?
There are a variety of reasons why your deck stain may not be drying properly. First and foremost you want to consider which type of deck stain you are using. Water-based deck stain may dry as soon as 1-4 hours, while oil-based may take anywhere from 4-24 hours. You want to give enough time to ensure that the stain dries and that it is not exposed to rain or other moisture sources.
  • Overapplication is a top cause of deck stain not drying; applying too thick a coat leads to poor drying and finish issues.
  • Applying a second coat too soon before the first coat dries can prevent proper drying and affect appearance.
  • Always wipe away excess stain during application; leftover pooling stain will stay tacky and not dry correctly.
  • Keep your deck stain protected from rain and moisture during the full drying window to avoid drying failures.
  • Never apply deck stain to a wet or damp deck surface, as existing moisture will prevent proper drying.
Deck Stain Not DryingDeck Stain Drying Issues
You may also find that if the deck stain is not drying, that you may have overapplied. If you put on a coat that is too thick, this may influence the feel and appearance. If you put on a second coat too soon or didn’t wipe away any excess, these can all be factors in the deck stain not drying. Be sure that you allow ample drying time, that you put on an even coat, and that you do not apply to a deck that is not dry beforehand.
More Info on Deck Stain Drying Issues
Have a Deck Stain question? Ask in the comments below.
0 Comments
