Deck Stain is Too Dark 5/5 (1)
Why Deck stain is too dark?
Deck stain can come out too dark when you overapply the stain. The deck stain may also have trouble drying properly or curing fully if you used too much stain. The only way to fix a deck stained too dark is to remove and reapply the stain. Prep is very important for reapplying the stain in a way that will not be too dark. Staining the deck evenly is important for ensuring the deck stain isn’t too dark a second time.
  • The only fix for deck stain that is too dark is to fully remove the stain and reapply it correctly.
  • Use a deck stain stripper followed by power washing to prep the deck before reapplying stain.
  • Let the deck dry for at least 24 hours, then spot sand any areas needing extra attention before restaining.
  • Some stains, like Penofin and Super Deck, naturally darken over time, which can cause unexpected color changes.
Note: Some deck stains darken over time. Notably Penofin Stains and Super Deck Stains.
Why did my deck stain turn black?
How do I prep to reapply the stain when deck stain is too dark?
Start by applying a deck stain stripper, then power wash the deck to clean it. Let the deck dry fully for at least 24 hours, then go back and spot sand any spots that need some additional care. You will not be able to remove all of the solid stain from the deck, but the goal is to remove as much as possible without heavy sanding.
[woo_product_slider id=”30701″]
More information on how to prep to reapply deck stain
0 Comments
