Deck Stain vs. Paint: Which Is Better for Your Deck? 4.8/5 (11)
Hi, I’m Scott Paul, a licensed exterior restoration contractor with over 30 years of experience and 10,000+ deck restorations. This review of deck stain vs. paint is based on my own hands-on field testing, not manufacturer claims. See my full credentials and testing stats here.
Should you paint or stain a deck? It is one of the most common questions I get at DeckStainHelp.com, and the answer starts with understanding what paint and stain actually do to wood. Paint sits on top of the boards, while stain soaks into them, and that one difference decides how your deck looks, how long it lasts, and how much work every future recoat will take.
Paint or Stain a Deck? Quick Answer
  • Stain is the better choice for most wood decks. It soaks in, wears evenly, and recoats after a simple cleaning.
  • Paint sits on top of the wood and hides the grain, and on deck floors it eventually peels and has to be scraped and sanded.
  • Never use house paint on a deck floor. It is made for vertical surfaces.
  • For a painted look without the peeling, use a solid color deck stain.
  • Deck stain needs recoating every 2 to 4 years, depending on type and sun exposure.
Contents
  1. Should You Paint or Stain a Deck?
  2. Staining Versus Painting a Deck: Side by Side
  3. House Paint or Deck Stain?
  4. Appearance of Deck Stain vs. Paint
  5. Which Lasts Longer: Deck Stain or Paint?
  6. Deck Stain Types vs. Paint
  7. Cost Comparison: My Favorite Stains by Type
  8. My Favorite Deck Paint or Stain
  9. Frequently Asked Questions
For most wood decks, you should stain rather than paint. Stain penetrates the wood, wears away gradually, and can be refreshed with a cleaning and a new coat. Paint forms a film on top of the boards, and on a deck floor that film eventually peels from foot traffic, standing water, and sun, which means scraping and sanding before you can recoat.
Paint makes sense in only a few situations: the wood is badly weathered and you want to hide it completely, you want a bright color that stains do not offer, or the surface is vertical, like railings and skirting, where peeling is less of a problem. If you want the look of paint on a deck floor, a solid color deck stain gives a similar opaque finish with far less peeling.
Staining versus painting a deck comes down to six practical differences. The last row is the one most comparisons leave out, and in my experience it is the one that matters most over the life of a deck.
Deck Stain Deck Paint
Cost Similar per gallon, no primer needed Similar per gallon, plus primer
Prep work Clean and brighten Clean, dry, and prime
Coats Usually one or two, no brush marks Primer plus two coats, shows brush and roller marks
Look Shows the grain, except solid stain Hides the grain completely
Years between coats 2 to 4 years on a deck floor Can go longer if prep and primer are done right
When it is time to recoat Wears evenly. Clean the deck and apply a fresh coat. Peels in patches. Scrape, sand, and prime before repainting.
If you are comparing stain to house paint, stain is the better choice for a wood deck. House paint is designed for vertical surfaces such as walls and trim, not horizontal surfaces like deck boards. It is much thicker, and it will wear and peel when applied to a deck. Stain is more budget friendly, easier to apply, and shows off the natural look of the wood.
There are coatings made specifically for horizontal wood, such as a deck floor, and house paint is not one of them. If you like the look of paint more than stain, buy a deck paint made for horizontal surfaces rather than leftover house paint.
Comparison of deck paint versus deck stain on wood surfaces
The main differences between deck paint and deck stain are appearance and ease of application. Deck paint covers the grain completely, hides blemishes, and comes in almost any color. Stain shows the grain to some degree. Semi transparent stains come mostly in wood tones, while semi solid and solid stains come in a wide range of colors, including grays, blues, and black. Stain can often be applied in one coat without brush or roller marks, while deck paint needs multiple coats and is harder to apply smoothly.
Deck stain lasts far longer than house paint on a wood deck. Compared to a true deck paint, paint can go longer between coats when it is applied correctly over a primer. The difference is how each one fails. Stain wears away gradually and evenly, so a recoat is a cleaning and a fresh coat. Paint peels and chips in patches, and every bare spot has to be scraped, sanded, and primed before you can repaint. Over the life of a deck, that makes stain much less work.
Exterior wood and deck stains come in four main types: transparent, semi transparent, semi solid, and solid color. All are designed for decks, but each has a different appearance and lifespan. Here is how each type compares to paint.
Solid Color Deck Stain vs. Paint
Solid deck stains look like deck paint. They cover the wood completely, so the grain is no longer visible. Once you apply a solid deck stain, plan on sticking with it, because removing it later takes a stripper and often sanding.
Differences Between Solid Stain and Paint
Both hide the grain and look similar, but a solid color stain has a thinner consistency. That lets it penetrate the wood surface instead of sitting entirely on top, which is a major advantage over paint because it is much less likely to peel.
Is Solid Stain Better Than Paint?
Solid deck stain is better than house paint for your deck. It adheres better and is not prone to peeling the way house paint is.
$72.99
Semi Solid Deck Stain vs. Paint
A semi solid deck stain shows only a little of the wood grain because it carries a high amount of pigment. Semi solid stains come in both oil based and water based versions. I prefer oil based semi solids because they soak deeper into the wood than water based semi solid stains.
Difference Between Paint and Semi Solid Stain
Transparency and penetration are the main differences. A semi solid stain lets some grain show and soaks into the wood, while paint hides the grain and forms a film on top.
Semi Transparent Deck Stain vs. Paint
Semi transparent deck stains carry enough pigment to protect the wood while highlighting its natural grain. They are among my favorites, and they come in both oil based and water based versions. See my picks for the best semi transparent deck stains.
Comparing Semi Transparent Wood Stain vs. Paint
In most cases, semi transparent deck stains penetrate the wood very well and highlight the grain, while paint hides the grain completely.
Transparent deck stains contain minimal pigment, so they look the most natural. They last about 12 to 18 months.
Difference Between Transparent Deck Stain and Paint
Paint covers the wood, while a transparent stain looks the most natural and does not hide the grain at all. It is also the easiest type of stain to remove and reapply.
Here is how my top pick in each stain category is priced per gallon.
Stain Type My Pick Price Per Gallon
Solid Color Deck Stain Restore A Deck Solid Color $72.99
Semi Solid Deck Stain TWP Semi Solid Pro Series $79.99
Semi Transparent Deck Stain TWP 100 Pro Series $72.95
Transparent Deck Stain Armstrong Clark Wood Stain $72.95 to $83.95
There is no single best deck stain for every situation, but my favorites by category are Restore A Deck Solid Color for a solid finish, TWP Semi Solid Pro Series for a semi solid, TWP 100 Pro Series for semi transparent coverage, and Armstrong Clark Wood Stain for a transparent, natural look. TWP 100 is restricted in about 20 states and Canada because of its VOC content, so in those areas I recommend TWP 1500 or Armstrong Clark instead.
Frequently Asked Questions About Deck Paint and Stain
What is the difference between paint and stain?
Paint is a thick coating that sits on top of the wood and hides the grain completely. Stain is thinner and soaks into the wood, so it shows the grain to some degree and wears away gradually instead of peeling. On a deck, that difference decides how much work every future recoat takes.
Is it better to paint or stain treated wood?
Stain is better for pressure treated wood. The preservatives in treated lumber make it harder for paint to bond, while stain penetrates and handles sun, rain, and snow better than deck paint.
Is deck stain more affordable than deck paint?
Usually yes. Quality deck stain and deck paint cost about the same per gallon, but paint also needs a primer and usually two coats, and failed paint must be scraped and sanded before recoating. Stain skips the primer and recoats with just a cleaning.
How long does deck stain last compared to deck paint?
Deck stain needs recoating every 2 to 4 years depending on type and exposure. Deck paint can go longer when applied correctly, but when it fails it peels and chips and must be scraped and sanded. Stain wears evenly and is far easier to recoat.
Can I paint over an old deck stain?
Not without proper prep. Residual oils and stain in the wood interfere with paint adhesion and lead to peeling. To switch from stain to paint, strip, clean, and prime the deck first.
What type of stain looks most like paint but performs better?
Solid color deck stain. It covers the grain like paint, but its thinner consistency lets it penetrate the wood surface, which greatly reduces peeling and flaking.
Which lasts longer on a deck floor, semi transparent or solid stain?
Solid stain usually lasts more years between coats because its heavy pigment blocks more UV. Semi transparent stain is easier to maintain, since it recoats after a cleaning, while failing solid stain often needs heavier prep.
Have a Question on Deck Stain vs. Paint? Ask Below
29 Comments
7 months ago
I live in the Caribbean the only wood you can get here is wet pine.my deck only lasted 7 years with paint on it and it is rotting. I’m going to redo it and going to buy the wood ahead of time to let it dry a little What would you recommend putting on it for paint or stain or something else?
Kathy
Kathy
My 16 x 12 pressure treated deck is over 20yrs old – (purchased home in 2020) my neighbor informed me it had “never” been taken care of. I had to paint/stain it – HOA insistence.. I used slip proof deck paint for safety reasons. 2025- I have scraped lots of paint off after reading don’t sand pressure treated wood?? I now must sand the remaining that wont come off ( about 8% of the entire deck) paint stripper was of no good use! Luckily the boards are in quite decent shape otherwise. So after all that hard work, I need good advise, What stain should I use? semi transparent or solid ? oil or water based? , I don’t really care if I see wood grain or not preservation and longevity of the stain is much more important. I live in the NE so snow is an issue, I have to use snow removal pellets “Salt” in the winter time. -suggestion on what kind would be very appreciated. PS note to any readers, slip proof paint is not all that is cracked up to be.
Kathy
Kathy
I hope my pics came through
17514950031384021145301723461564
17514951767038159136201310697731
Vince
Vince
Eccellent Info…Excellent Presentation…Thx gor the Info…Vince…Maine
bill
bill
My deck had the stairs and several floor boards replaced recently, and partly because the wood is lighter than the old boards (much lighter when wet as you can see, but keep in mind this hasn’t been power washed recently), I want to stain it in a way that it will all look uniform. I’ll go with a solid stain if I must, but wondering if a semi-solid or semi-transparent would be enough?
deck-wet
bill
bill
I was afraid of that – appreciate the quick reply!
Wendell Caldwell
Wendell Caldwell
What do you use to remove the solid stain
Sheila
Sheila
Our deck has pine sap leaching through the knots and crevices. It currently has a solid stain that needs to be reapplied. What do we need to do before we restain to correct this problem?
Trudy
Trudy
Why is my deck stain peeling
Lisa Keough
Lisa Keough
We used your deck stain stripper & additive and it worked great! So much better than a Sherwin Williams stripper we tried! So now our entire horizontal dock surfaces have been stained in semi transparent and we love it! We are in FL on the gulf. Now we want to do the vertical trim in WHITE-we need to hide some (not too many) drips too. Would you recommend a white exterior paint or white stain on the vertical trim….is there such a thing as white stain? It has an old coat of semi transparent stain on it that is in good shape and not peeling. We do NOT want to remove that as it would be rediculously tedious and are hoping to find a product that will just go over it-hiding grain and previous color. Most of the vertical trim is shaded. We also need it to be non porous to avoid mildew and such. So we’re thinking something w a slight sheen would be nice. Thanks in advance!
Gates Johnson
Gates Johnson
My deck is a few years old. About two years ago it was painted with a solid deck paint. Now it is flaking badly. I am having it pressure washed and sanded, but not down to bare wood. I am totally disappointed in the deck paint and want to use an oil-based stain that penetrates that wood and is rain resistant. My question is… Can I use stain now since the deck will still have patches of paint? Or will I have to remove all the paint?
Meghan
Meghan
Is this true even for using a solid stain? Thank you… I have the same problem as this poster.
Tim Claypool
Tim Claypool
I built a new deck next to my swimming pool last summer (2020) using treated pine. This year I am ready to put a protective coat of something on it.
There is so much information out there and everyone I talk to says something different. I’m kind of leaning towards water based over oil based but I feel overwhelmed!!! We want to stay close to the natural color of the wood but I read above that a transparent stain will only last 12-18 months. I live in N. E. Ohio in the snow belt so this is going to go through all kinds of rain and snow. I liked the article you did on “Restore A Deck”
Please help me!
Harjeet
Harjeet
I had my deck painted 2 years ago.
Can i get a semi transparent stain, or i need to sand everything down before getting to semi transparent paint
Glenn Badham
Glenn Badham
I asked for my deck to be stained. When I returned to my lake house it was painted.
Now it is peeling. Is it possible to remove the paint and then stain the deck. Do any of these products work?
Smart Strip
Multi Strip
Deck is 6 years old and looks terrible.
29
