4.8K
How to fix a deck stain you don’t like?
How to fix a deck stain you don’t like depends on the type of deck stain. Semi-transparent and semi-solid penetrating deck stains must be removed by stripping the deck, sanding the deck, or both. Failing to remove the disliked stain sufficiently prevents the new stain from penetrating into the wood properly. Solid deck stains do not have to be removed, instead you can just apply a new color over it.
- For semi-transparent and semi-solid penetrating deck stains, you must strip or sand the deck before applying a new stain.
- Failing to fully remove a penetrating deck stain prevents the new stain from absorbing properly into the wood.
- Solid deck stains do not require removal; you can apply a new color directly over the existing stain.
- Stripping, sanding, or a combination of both are the main methods for removing an unwanted semi-transparent or semi-solid stain.
- Proper deck prep, including cleaning and stripping, is essential before reapplying any new penetrating deck stain.
- When working with solid color deck stains, reapplication is simpler since the old color does not need to be fully removed.
More information about fixing a deck stain you don’t like
- Remove Deck Stain When Reapplying?
- How To Sand Your Wood Deck
- How to Reapply a Solid Color Deck Stain
Last years wife picked a grey stain, and learned to hate it over time. Should we sand? Strip? Before applying new stain? Looking for guidance for most efficient
Reply back with some pics for prep help. You can post them in the comments. Also, what brand and type of stain was used prior?
I have a 10 x 12 redwood deck built last fall. Two weeks ago, before finding your product, I ended up at a big box store and was talked into using Olympic Waterguard Clear wood sealer. I wanted less color but a “wet wood” look. I was told this product would be what I wanted. Since it was water clean-up and no where on the product did it mention it was an Acrylic product, I gave it a try.
The result was a disaster. It doesn’t even look like I did anything to the deck other than the water beads up on it. I now realize it is an acrylic product. Will your RAD Stripper product strip off the sealant? My railings are black metal and so I am concerned about using paint
stripper products possibly damaging the rails.
I do have a pressure washer, Any suggestions? Any help would be greatly appreciated.
Post some pics of the decks current condtion for help with prep.
It rained last night. Thanks again.
