Hi, I am Scott Paul. I have been prepping and stripping exterior wood decks since 1993. To save time and money, we started using Restore-A-Deck prep and stains. These products allow my team to finish the entire deck restoration on the same day! See here for more info about me.
- Check the weather forecast before starting; you need a completely rain-free day to complete your full deck restoration in one day.
- Use a deck cleaner for maintenance prep or a deck stain stripper to remove old coatings before reapplying a new stain.
- Apply a wood brightener after cleaning or stripping to restore pH balance and improve stain penetration and adhesion.
- Stain can be applied to damp wood, but avoid soaking wet surfaces; work in small sections and never over-apply.
- Restore-A-Deck Wood Stain is the top recommended option for same-day application due to its durability and deep penetration on damp wood.
Tips on Restoring Your Deck in One Day
See our Deck Stain Facts section, which includes over 150 simple Q&A articles answering all your questions about deck staining, cleaning, and prep.
In recent years, a few innovative deck and wood stains have entered the market, making it possible to prep and stain your deck on the same day. As professional contractors, this has been a game-changer—saving both time and money. Homeowners no longer have to wait days or even weeks for the wood to dry or for unpredictable weather to cooperate. With this streamlined process, your deck restoration can be completed in a single day, freeing up your weekends for other projects.
Scott’s Pro Tips on Restoring a Deck in One Day
Here are the three essential steps for prepping and staining your deck on the same day. Before starting, check the weather forecast and ensure a rain-free day.
- Step 1: Prep the Deck – Choose the right cleaner or stripper.
- Step 2: Brighten the Wood – Neutralize the surface for optimal stain absorption.
- Step 3: Stain the Deck – Apply a stain designed for damp wood.
Step 1: Choose a Deck Cleaner or Deck Stain Stripper
Before deciding on a cleaner or stripper, ask yourself:
✔ Is the wood new or old?
✔ Does it already have a stain?
✔ If so, what type of stain was previously used (oil-based or water-based)?
✔ Are you happy with the current stain and color?
These questions will guide you in choosing between a deck cleaner or a deck stain stripper.
Wood Deck Cleaner
A deck cleaner is ideal for general maintenance and preparation before reapplying the same stain brand and color. It removes:
✔ Dirt, grime, and mildew
✔ Mold and algae
✔ Surface contaminants
Pro Tip: Deck cleaners are not formulated to remove existing deck stains. If your deck has an old stain you want to remove, use a deck stain stripper instead.
Deck Stain Stripper
If your deck has a previous stain that needs to be removed, a stain stripper is your best option. A stripper will remove:
✔ Old coatings (oil-based, water-based, and latex-based stains)
✔ Clear sealers, transparent, and semi-transparent stains
✔ Dirt, mold, and mill glaze
Since strippers contain strong chemicals, take precautions:
✔ Keep surrounding plants and grass wet or covered.
✔ Avoid contact with pets and children.
✔ Apply the stripper with a pump sprayer, allow 20 minutes of dwell time, then rinse with a pressure washer.
✔ If the stain is not entirely removed, sand any remaining areas with 80-grit sandpaper.
After cleaning or stripping, applying a wood brightener (neutralizer) is essential. Brightener:
✔ Restores the wood’s pH balance.
✔ Enhances stain penetration and adhesion.
✔ Gives wood a fresh, natural look before staining.
Application:
- Use a pump sprayer to apply the wood brightener.
- Let it sit for 10-15 minutes.
- Rinse thoroughly with a garden hose or light pressure wash.
Once complete, your deck is prepped and ready for staining.
Step 3: Staining a Damp Wood Deck
The key to staining your deck on the same day is ensuring that visible water has dried off before application. While the deck can be damp to the touch, avoid staining soaking wet wood.
✔ Choose a stain specifically designed for damp wood.
✔ Apply only as much stain as the wood can absorb—do not over-apply.
✔ Work in small sections to maintain a consistent finish.
Best Stains for Damp Wood Application
The two main deck stains that allow same-day application are:
✅ Restore-A-Deck Wood Stain (Recommended)
✔ Can be applied to damp or dry wood.
✔ Penetrates deeply, enhancing durability.
✔ Saves significant time by eliminating drying delays.
We have tested this stain extensively and now use it regularly due to its superior performance and ease of application.
Restore-A-Deck Semi-Transparent Stain
❌ BEHR Premium Quick Dry Oil-Based Wood Finish (Not Recommended)
✔ Allows for same-day staining but has poor durability and performance.
✔ We experienced inconsistent results, and consumer reviews confirm similar issues.
Damp Deck After Prep
Deck Prep and Stain in One Day
Watch: How to Restore Your Deck in One Day
🎥 Watch our full deck restoration video here for a step-by-step visual guide.
Need Help Restoring Your Deck?
If you have questions about this process or need personalized advice, leave a comment below! Be sure to include details about your deck’s condition, stain type, and any challenges you’re facing.
✔ Expert guidance from professional contractors.
✔ Over 30 years of deck restoration experience.
✔ Get recommendations tailored to your specific deck.
Let’s get your deck looking great—all in just one day! 🚀
I applied one coat of TWP Semi Solid Stain 2 years ago after stripping the prior semi transparent stain. The stain has worn down in some high traffic areas approaching the front door, in some sports exposing the bare wood. Can I apply a new coat after cleaning? I’d prefer to not have to strip and brighten every time the deck needs a new coat. What do you recommend?
Since it has some bare spots, it would be best to strip and brighten for prep so the new coating is even. If you just clean, those spots may be lighter in color.
After 2.5 full days of stripping, sanding, brushing, power washing we still can’t get the paint off our deck. We are not original owners so don’t know what type of paint/how long it’s been on. Any advice to get these spots that aren’t coming up??
That is a solid stain. You need to power sand and/or use a Paint Stripper.
New cedar deck, weathered for 10 months. Next weekend it’s time to stain.
1. How do you keep from getting the deck dirty between the cleaning/brightening/staining phases? We’ll need to walk on it after cleaning and then again after brightening…. I feel silly asking this.
2. Do you have anything written out/videos about the reapplication procedure in 2-3 years? Curious if you need to clean and brighten again.
Thank you for this very informative and helpful website!
Hello. I’ve got a pine wood deck that hasn’t been stained in about 2 1/2 years. It’s obviously needing to be stained now. I’m in California’s central valley and the deck is in full sun pretty much all day and was originally stained with Thomson’s All In One semi transparent. What do you recommend for the best and longest lasting stain?
Post some pics for prep advice. Once the old coating is removed, try Armstrong Clark Stains or Restore A Deck Stains.
I have a cedar deck that was put on 3 years ago. I let it be for a year before staining. I used TWP 100 for the stain. I think I should have done 2 coats because most of it has worn off. I need to redo the deck. I watched the video with the Restore a deck, and I’m just not sure what to do? Should I clean it and do TWP again or do the Restore a Deck? My deck faces west so it is in direct sun. Any advice would really be appreciated.
Patty
Use the Restore A Deck Cleaner and Brightener for prep and then recoat.
Great. Should I do 2 coats this time, since I coat of the TWP only lasted I year??
Thank you!!
Sure.
My deck is 22 years old (possibly cedar, not regular pressure treated wood) and was stained several times with a solid stain, most recently three to five years ago. A BEHR or Sherwin Williams product was used. It gets intense Atlanta GA direct sun from 2 PM to 5 PM. The boards have cracks and I’ve filled them with DAP Plastic Wood All-purpose wood filler. I’m trying to determine whether I should prime the boards after sanding and cleaning them. I have purchased Zinsser Bulls Eye 1-2-3 Water-based Interior/Exterior Primer. Also, I have bought Sherwin Williams SuperDeck Waterbourne Formula Exterior Deck Stain.
Do I need to prime the deck or can I just apply the Exterior Deck Stain? Is Zinsser compatible with SWP SupoerDeck Solid Stain?
I didn’t realize how complicated this area is. Please let me know the correct way to move forward. Thank You!
VR,
Michael
Primers are typically not suggested with deck stains so no, we would not use it.
I have a redwood color deck. Can I change the color to Cape Cod Gray with a Cabot Acrylic solid stain and sealer without stripping it first??
Possibly. Post some pictures.
Hi!
We just bought a house with a large wrap around deck that we love. It was definitely that gray, dirty untaken care of color when we got it. No clue when it was last stained and our neighbor said it’s many years old and surprised it’s still in such good shape since old owners did not take care of it.
Before I found this website I tried to follow the Home Depot guide.
So far my husband power washed, used a deck cleaner, and power washed again. We reallllyyy want to start using the deck ASAP. The deck now looks like brand new color wise (raw wood look). Would it be okay to use the restore a deck brightner and stain? I’m nervous because I saw you cannot put water based over oil based and I have no clue what was used prior. We also don’t want to really strip the deck now that we already did the cleaner.
Please post some pictures in comment area for help with this.
It looks ready to stain. Brightener then stain will bo okay.
Great! Considering we do not know if it was ever stained before or what it was stained with, do you recommend using a specific kind of stain? I’m concerned to use the water based restore a deck and have it not adhere well
It will be fine to use any stain type since it is down to the bare wood.
We stained our treated pine deck with TP-100 after using the Gemini cleaning process – that was in late 2017 — we need to re-stain the deck — obviously should have done sooner, but it is what it is — do we need to use the Gemini process again? We are using the TP-100 again — it was an excellent product for us — we just should have reapplied much sooner..
Yes, use their Gemini Restore kit for prep.
Thank you – appreciate your fast reply!
IHave sanded with an orbital sander down to bare wood now im going to stain i didnt brighten .should i have ? And should i apply thompsons water seal over the stain and if so how soon after
Never apply a sealer over a deck stain, it will peel. You should clean and brighten after sanding for the final prep.
Hi, I have a cedar deck and will be using RAD stripper and brightener tomorrow to remove the old stain I applied 4 years ago and now looks like crap. I won’t be staining on the same day, and quite possibly not for a couple weeks after. I’ve watched some of the videos here and there is a lot of discussion about staining right after when the wood is wet. If I decide to stain the day after or the week after, do you recommend I wet the deck again? Or is there a good stain I can use on dry wood? Do I need to reapply brightener right before staining if I stain at a later date? I live in the Pacific Northwest if that makes any difference. Any advice would be appreciated.
The RAD Stains can be applied to dry or damp wood. We personally like to apply to damp wood as it is easier. If you do this, just lightly mist with water and then stain. You brighten right after stripping, not days or weeks later.
Thank you. Do you need to do any sanding on the deck after strip/brighten and before staining?
Typically no.
Hello. I have used Deck Revive on my deck twice and have gotten 17 years of use out of my deck. I also of course used their primer with it. The product is now starting to lose it’s adhesion ans is lifting in about 30% of the surface area. We will be selling our hime and want to do a quick fix if possible. My question is can I use a regular acrylic latex solid deck paint over the Deck Revive? Thanks.
No, nothing will work over it.
I have a large deck that is 2yrs old. It was treated with Thompsons clear waterseal when new and another coat applied at 1 yr. I am not pleased with the effectiveness of Thompsons product and would like to use something different. Some areas are bleached almost white and some are perfectly aged.. I like the natural color of pt yellow pine as it has aged and would like to stay in same color range. I would like a product that lasts and process isn’t too labor intense to apply. What product do you recommend for my project?
Try the Defy Extreme Clear.
I am getting my deck power washed tomorrow morning (Thursday). I need to stain the deck after that and have it be dry by Saturday evening. What products do you recommend to do that?
I spent the past two days stripping and brightening the railing around my 16×16 deck (lots of spindles). Tomorrow I have to sand those small areas where the stain didn’t come off. I won’t have time to stain until next week. Should I brighten after I sand tomorrow or before I stain next week? I am using RAD products which are working very well. Thanks!
Brighten when done with sanding.
I had my deck extended to 24 feet long.. Now I am ready to get it stained. I have been giving estimates from $1100 to $2400 what is the right price to pay or should I do it myself
Depends on many variables but most importantly the total sq footage of all the wood.
I was told by our HOA that SuperDeck Exterior Oil-Based Semi-Transparent Stain was the “approved” deck stain
and I could not to use anything else.
“Last year” I sanded my entire deck, followed all instructions, and stained the deck.
I then found and began reading reviews on SuperDeck and they were not good.
Since my deck was done last year can I clean the deck and apply another brand of Oil based Semi-transparent Stain?
My current color is a dark brown and a different brand does not have to be a perfect match.
Seems like as long as I use another brand that is an Oil-Based Semi-Transparent Stain, I should be
able clean my deck and apply a better product?
Please advice and thank you for your time in answer my post.
Daniel LeBlanc
No. To use a different brand (does not matter if oil or water-based) you will need to strip off the SD and then Brighten the wood. Good news is that it is very easy to remove the SD with the RAD Stripper: https://www.deckstainhelp.com/restore-a-deck-injectable-deck-stain-stripper-review/
Anytime you use a pressure washer (like mentioned in the Deck Stripper paragraph), isn’t it necessary to sand the wood afterwards since power washing tends to raise the grain of the wood which could cause splinters if stepped on? Excuse my ignorance if this is not true and/or unclear. Thanks for answering!
Raising the grain somewhat is okay as it helps the stain to soak in better. Pressure washing does not cause splinters though unless you have really bad technique and are way too close with the tip.
Great! Sounds good. And what would be considered “too close with the tip” in relation to the deck board? Thank you again.
It depends on the psi of the machine but 6-12 inches away is normal.
I used deck cleaner on the spindles and mixture of powdered oxygen bleach and dishwashing detergent to clean the deck. Sanded the spindles after cleaning.
Deck color is uneven…
Should I wash entire deck again with a deck cleaner, then use a brightener prior to staining with oil based stain?
Do you have a current stain on the wood? If so you should strip and brighten for prep.
I am concerned I may not have enough RAD brightener to finish my project. The painter is starting today and I am in a panic.
What would happen if the brightener was mixed a little weaker than one container per 5 gallon water?
If I run out what would happen if brightener is not used after the cleaner on the back side of the fence? (I am not real concerned about the appearance since it is not seen by anyone…Just want to protect it with stain.)
Is there any other product that would work that I could buy locally?
I have 5lbs of oxalic acid in addition to the 2 containers of RAD brightener but don’t know anyone locally who sells it to buy more.
What ratio should it be mixed? (I have read 1.5 c per gallon of water.)
Thank you so much for your help.
Mix 6-8 oz per gallon and you will be okay
What is the best approach and product(s) for restoring our dock?
Lots of variables for prep. See this: https://www.deckstainhelp.com/best-deck-prep-clean-strip-or-sand-the-deck/
I am confused about the use of Oxalic Acid in preparing a deck for staining. It is advertised as both a cleaner and brightener but it has been suggested I need to use Sodium Per-carbonate to clean followed by Oxalic acid to brighten. If is does both I am wondering why I need the first step. Although I did read where RAD brightener can be used as both a cleaner and brightener on redwood but to use cleaner first on pine….wondering what the difference is????
Are you familiar with the Concrobium house and deck wash and the Concrobium mold eraser as a cleaning and brightening prep for wood? Wondering how it compares to the other products. My concern is the mold eraser directions instruct you not to rinse ( I think other brighteners say to rinse) and to let it dry completely which would nullify the advantage of staining with the RAD semi transparent stain on damp wood.
Oh, one last question…what do you do to deal with all the pollen when preparing a deck? Should we just wait a few more weeks and hope it is gone?
Love your site and have learned so much from it but the more I learn the more confused I get! 😥
Oxalic acid or any brightener is not a cleaner. You always use a cleaner (or stripper) first and then brightener after. RAD Brightener does not clean any wood, just brightens and neutralizes. Concrobium is different and we do not use it as it had little to no effect when testing. Wait for pollen to go away.
Thanks for your quick response. Just an FYI, my comment on the RAD Brightener was based on the following sentence on their website about the RAD brightener:
“The product can be used as a cleaner and brightener for redwood, or as a neutralizer to further brighten wood species, like pine, that have been cleaned with Restore-A-Deck Wood Cleaner or stripped with Restore-A-Deck Stain Stripper.”
I am sure that is a typo and there is nothing in the product that actually “cleans” wood.
We have two sets of outdoor steps at our house at the lake. They need to be re-stained and have an oil base stain last applied. We have sanded both sets of steps. Are the next steps…a primer…then a restore deck kit…and then stain? Do I have that right? Am I missing any steps? thx
You cannot use a primer for a deck stain. The rest is correct.
thx… and sorry I mean’t to say “stripper” as the 1st step
After we applied the stain it looked great but we had some cold weather the next night with some snow. We noticed white streaks on the deck. Is that because the cold weather impaired the curing process? Can we apply another coat of stain when the weather is warmer or do we need to do something else to resolve? thx
Let is sit for a week and see if it goes away naturally. What stain brand did you use?
Arborcoat semi-transparent
Hopefully, it goes away naturally as you may need to sand it off if it does not.
thx for your advice…
We have a new pressure treated ground contact wooden dock. It was built last October. It is in the direct sun most of the day and is located in the southern part of Alabama. What cleaner do you recommend? Do we need to use a brighter? We are totally confused about which stain and sealer to use. We
prefer a transparent stain. Any help would be greatly appreciated.
Clean and brighten for the prep. Use Restore A Deck Kits. Stain with Restore A Deck Stains or TWP 100 Series.
Why is it necesssary to use a brighter on new wood? One or two coats of stain?
You have to both clean and brighten the new wood to remove the oxidation and mill glaze. One coat: https://www.deckstainhelp.com/staining-a-new-deck/
I want to clean & restore a 2 yr old redwood deck fully exposed to southern sun & northern Cal rains previously treated with PreservaWood penetrating oil stain & sealer. Should I first do cleaning, then the brightening processes & does it have to dry completely in between, before new stain! And, can I change the stain product & color slightly darker ? Can you recommend products to use? I’d like to avoid sanding if possible
You need to strip, not clean. Strip and then brighten the wood for the prep. Do not let it dry between. Once done you can change to any products you want. Try one of these stains: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
I have a deck that was stained with Penofin three years ago. It didn’t hold up very well. So this year I power washed and sanded the decking with a floor sander almost down to bare wood. It is a clear cedar deck so then I stained in with TWP 101 (cedar semi transparent stain). It turned out great! If I want to stain it again with the same product next summer, how do I prepare my deck?
Use their Gemini Restore Kit for the prep.
And then I can put another coat of TWP 101?
What would you recommend for a cedar deck that has been stained with penafin clear stain a year ago?
Strip and brighten the wood for prep and stain with Restore A Deck stain.
I have the cleaner and Brightener as well as the light walnut stain for my TIGER deck. (RAD)
I did the sunroom a couple of weeks ago in one day and it turned out beautiful !
Here is my question : i have a 12 x 42 deck that is also Tigerwood. There is no way i can do it all in one day. The sunroom almost killed me! How should i go about it without there being overlaps? Should i do the cleaner and Brightener one day and the stain the next after i dampen the wood or can i do the deck in 1/3’s? I just do not want it to be obvious that i stopped and started. The deck is very gray. It has never been treated in any way. Can i clean or brighten twice to get the best out of it or leave it on longer? Please advise. Thanks!!!
Stain the next day and stain it all at once. Dampen the wood first. You can prep it twice if needed.
I have been using Flood CWF-UV penetrating wood finish for years…clear natural. The wood is looking gray. Can I use Flood cedar stain now to brighten the deck?
You have to clean and brighten first, not just apply a stain over it.
What products do you suggest I use to clean and brighten to achieve the best results with Flood?
Restore A Deck Prep products.
I just built a 2 tier deck with light brown pressure treated lumber. I don’t want to stain it so what can I put on it to keep its own colour and waterproof it?
It must be stained if you want to maintain color and prevent UV graying. Clear sealers have no UV protection and will gray in months. What you want to do is not possible. Best to use a penetrating semi-transparent stain. In addition, see this about new wood: https://www.deckstainhelp.com/staining-a-new-deck/
Thanks for your quick and informative reply. Greatly appreciated.
what is rating for Cabot Deckcorrect ??
No review here but have had a few customer comments and they were not positive.
Agree. Cabot has not held up
Hi. Thank you for all your helpful advice and the time you put into answering all these questions.
I recently stripped a 26×16 deck which was covered in Solid stain. It took weeks of stripping and sanding as i had limited time but, it looks great now. All old stain removed, i cleaned the deck and lightly sanded after dry to remove raised and loose fibers.
The wood is very clean but i didn’t stabilize with brighter. I would still like to do so prior to staining so, would it still be alright for me to do so 6 days later?
If so, are these the correct steps:
-Dampen the wood
-Apply the brightener.
-Let sit and Scrub..
-Finally, rinse off.
Also, I was thinking of using Restore a deck brightener and stain. What is your advice?
Thank you in advance.
Forgot to attach picture…
Yes, you can still brighten the wood. Just apply and rinse after 15 minutes to a damp deck. No need to scrub. The RAD products work well.
Can you recommend any Sherwin Williams semi transparent deck stain and cleaner?
Nope. SW makes poor deck products.
