Penofin Hardwood Stain Review 2026 — IPE & Exotic Wood Results 2.5/5 (21)
Penofin Hardwood Stain review for IPE and exotic hardwoods
Penofin Hardwood Wood Stain Review 2026
Penofin Hardwood stain is a Brazilian Rosewood Oil-based formula specifically designed to penetrate dense exotic hardwoods like IPE, teak, and mahogany. After testing it on a 300-square-foot IPE deck over one year, my verdict is honest: Penofin produces one of the most beautiful initial finishes I have seen on IPE — rich, natural, and deeply penetrating. But the UV protection is poor, the mold resistance is weak, and Penofin themselves told us the stain needs reapplication every 3 to 6 months on IPE to retain color. For a premium-priced product, that reapplication frequency is a significant drawback. If you are staining an IPE deck and want the best long-term performance, TWP Natural Effect, Armstrong Clark Hardwood, and Restore-A-Deck Exotic Hardwood all outperform Penofin in our testing.
Note: This is our second review of Penofin Stain for Hardwoods. Our first review was conducted in 2008 and completed in 2009. We are not aware of any product reformulations between the two tests. Results in this second review were worse than the first, which may reflect differences in UV exposure and wood type between the two test surfaces. See our first review here: Penofin Exotic Hardwood Stain Review.
Quick Answer: Is Penofin Hardwood Stain Worth It?
  • Penofin Hardwood scored a 6 out of 10 overall, with an exceptional initial appearance on IPE but poor UV protection and mold resistance.
  • Penofin requires reapplication every 3 to 6 months on IPE, according to the manufacturer, making annual ownership costs significantly higher than competing products.
  • UV protection scored 1 out of 10, with most color lost by the six-month mark on the 300-square-foot IPE test deck.
  • The Brazilian Rosewood Oil base promotes mold growth in shaded or moisture-prone areas, causing visible black discoloration in the wood grain.
  • TWP Natural Effect, Armstrong Clark Hardwood, and Restore-A-Deck Exotic Hardwood all outperform Penofin in UV protection, mold resistance, and color stability on IPE.
Penofin Hardwood Stain Ratings (1–10)
Penofin uses sustainably harvested Brazilian Rosewood Oil as its base, which the manufacturer states is the only formula capable of penetrating the dense fiber structure of exotic hardwoods like IPE, mahogany, teak, and Brazilian Redwood. Unlike high-solid stains that coat the surface, Penofin is designed to allow the wood to breathe — an important characteristic when working with exotic hardwoods that expand and contract significantly. All ratings below are based on our one-year test on a 300-square-foot IPE deck. Testing for exotic hardwoods is shortened to one year because IPE and similar dense species always fade faster than cedar, redwood, or pine regardless of stain brand.
Appearance After Initial Application
Score: 10 / 10
Penofin Hardwood produces one of the best-finished appearances we have seen on IPE. The Natural color highlighted the IPE beautifully with rich, natural reddish-brown tones that complemented the wood’s grain perfectly. The stain penetrated deeply with no surface filming, and the initial result looked like professionally finished exotic hardwood furniture. If initial appearance is your primary criterion, Penofin is difficult to beat.
UV Protection at 1 Year
Score: 1 / 10
UV protection is Penofin Hardwood’s most serious weakness and the reason we cannot recommend it for IPE decks that receive significant sun exposure. The stain retained little to no color after one year on our IPE test surface. The homeowner called us at the six-month mark to report the stain had disappeared in the sun and turned black in shaded areas. We inspected and confirmed the homeowner’s assessment. When we contacted Penofin, their representative told us that IPE requires reapplication every 3 to 6 months to retain color — a maintenance schedule that is impractical for most homeowners and significantly increases the annual cost of ownership.
Wear, Tear, and Peeling
Score: 9 / 10
Penofin has consistently demonstrated excellent penetration ability across our tests, including on exotic hardwoods. Despite the significant UV color loss, there was very little physical wearing of the stain on the deck surface at the one-year mark. Because Penofin penetrates into the wood fiber rather than forming a surface film, it does not peel. The wear resistance score reflects the formula’s genuine penetration strength — the problem is not how the stain wears but how quickly its UV inhibitors deplete.
Cost Per Square Foot
Score: 7 / 10
Coverage on IPE is reasonable — one gallon covered our 300-square-foot test deck in a single coat, which aligns with the manufacturer’s stated coverage of 300 to 400 square feet per gallon on exotic hardwoods. At $69.99 per gallon, that works out to approximately $0.23 per square foot for one coat. The problem is the reapplication frequency. If Penofin requires recoating every 3 to 6 months on IPE as the manufacturer suggests, the annual cost of product alone becomes $0.46 to $0.92 per square foot — significantly higher than competing hardwood stains that last 12 months between coats.
Mold, Mildew, and Algae Resistance
Score: 4 / 10
Mold resistance was a significant problem in our test. The Penofin darkened considerably over the one-year test period, and a good portion of that darkening was due to mold growth. Visible black dots were noticeable in the wood grain in shaded areas of the deck. This is a pattern we have observed on multiple decks stained with Penofin through the years — the Brazilian Rosewood Oil base can promote mold growth in low-light or moisture-prone areas. For IPE decks that are partially covered or in humid environments, this is a serious concern.
Ease of Application
Score: 7 / 10
Penofin applies easily and the formula spreads well on IPE surfaces. The score of 7 rather than a higher rating reflects one significant drawback: the odor. The Brazilian Rosewood Oil base produces an extremely strong smell during application — strong enough to cause eye watering. If not for the odor, this category would score a 9 or 10. Plan for adequate ventilation and consider eye protection during application. The stain itself applies smoothly with a pad, brush, or sprayer and requires no back-wiping on properly prepped IPE.
Color Shift After 1 Year
Score: 2 / 10
Color shifting was severe in our test. Penofin has a documented issue with turning brown or even black after exposure to the elements — we have observed this pattern on numerous decks stained with Penofin over the years. On our IPE test deck, the color faded significantly in sun-exposed areas while turning dark brown in covered or shaded areas. The combination of UV fade and mold-related darkening created a visually inconsistent deck surface at the one-year mark that required stripping before any reapplication could be considered.
Ease of Reapplication
Score: 8 / 10
Despite the poor UV and mold performance, reapplication itself is relatively straightforward. The darkened Penofin can be removed with a quality deck stain stripper and light pressure washing at 1,500 to 2,000 psi. Once stripped and brightened, the IPE surface is ready for a fresh coat of any compatible stain. The ease of removal is one of the few practical advantages Penofin has in the maintenance cycle — the stain does not bond so aggressively that stripping becomes a major project.
Overall Score at 1 Year
Score: 6 / 10
Penofin Hardwood earns a 6 out of 10 overall — pulled up by its excellent initial appearance, penetration ability, and reasonable coverage, and pulled down significantly by its UV failure, mold issues, and the manufacturer’s own recommendation of 3 to 6-month reapplication intervals on IPE. Our second review performed worse than our 2008 to 2009 first review, which may reflect differences in UV exposure and wood type between the two test surfaces. The results with Penofin are consistent with what we have observed on client decks and with the pattern of online complaints about the product’s darkening issue. There are better options for IPE.
Penofin Hardwood Stain — Customer Photo Gallery
Penofin Hardwood Product Information
Help or Questions Search: Penofin Stain
Cost $69.99 per gallon / $349.99 per 5-gallon pail
Stain Type Semi-Transparent — Rosewood Oil-Based
Available Colors Natural
Application Temperature 45°F to 95°F
Coats Required 1 coat
Coverage Per Gallon 300 to 400 sq. ft. on exotic hardwoods
Application Tools Sprayer, pad, brush, or roller
Dry Time 4 to 12 hours
Cleanup Mineral spirits
VOC Compliance 250 g/L compliant in all 50 states
Manufacturer Penofin
Test Deck Stats
  • Wood Type: IPE exotic hardwood decking
  • Square Footage: 300 sq. ft.
  • UV Exposure: 60% shaded, 40% full sun, south exposure, high elevation
  • Test Duration: 1 year
  • Color Used: Natural
All results are from our first-hand testing as wood restoration contractors. Results may vary based on wood type, UV exposure, and weathering conditions.
IPE and Exotic Hardwood Staining: What You Need to Know
Penofin Hardwood stain is designed specifically for IPE and exotic hardwoods, and understanding the unique challenges of these wood species is essential before choosing any stain product for this application.
Why IPE Is Difficult to Stain
IPE is one of the densest hardwoods used in outdoor decking, with a Janka hardness rating of approximately 3,510 lbf — more than three times harder than pressure treated pine. This extreme density means stain penetration is inherently limited, and even the best-performing hardwood stains fade faster on IPE than on cedar, redwood, or pine. This is a characteristic of the wood, not a failure of any specific product. Any stain applied to IPE in full sun will require more frequent maintenance than the same stain on a softwood deck.
New IPE: Wait Before Staining
New IPE lumber contains natural oils that must partially release before any stain can penetrate adequately. Wait a minimum of 3 months before staining new IPE, and longer if the lumber still feels oily to the touch. Some contractors wait 6 months on new IPE in warm climates. Use the water droplet test to confirm readiness — if water beads on the surface, the wood is not ready for stain regardless of how long it has been installed.
Prep Is Critical on IPE
Proper prep on IPE requires a deck cleaner followed by a wood brightener applied with a stiff brush and rinsed with a pressure washer at 1,500 to 2,000 psi. If there is any existing stain on the surface, use a dedicated deck stain stripper first. Brightening opens the dense grain as much as possible and is the single most important factor in getting any stain to penetrate adequately into IPE. Skipping the brightener step on IPE is the most common reason hardwood stain fails within the first season.
Annual Maintenance Is the Reality for IPE
No stain currently available will last more than one to two years on IPE in significant sun exposure. Annual cleaning and recoating is the realistic maintenance expectation for a stained IPE deck, regardless of the product used. The best hardwood stains — TWP Natural Effect, Armstrong Clark Hardwood, and Restore-A-Deck Exotic Hardwood — extend the maintenance interval and deliver better color retention at the one-year mark than Penofin, but none of them eliminate the need for annual attention on IPE.
How to Apply Penofin Hardwood Stain on IPE: Step-by-Step
Applying Penofin Hardwood stain correctly on IPE requires thorough prep and careful application to get the best possible result from this formula. Here is the process based on our testing.
  1. Strip and Brighten the WoodIf there is any existing stain on the IPE surface, use a quality deck stain stripper first. Even if the previous stain appears mostly worn away, residual product in the grain will prevent proper penetration. After stripping, apply a wood brightener to open the IPE grain and neutralize the wood pH. Scrub with a stiff brush and rinse thoroughly with a pressure washer at 1,500 to 2,000 psi. Allow a minimum of 48 to 72 hours of drying time before applying Penofin.
  2. Check Weather ConditionsApply Penofin Hardwood when temperatures are between 45°F and 95°F. Avoid application if rain is forecast within 24 hours. Unlike most competing hardwood stains, Penofin’s oil base makes it moderately sensitive to application in direct hot sunlight — early morning or overcast conditions are preferred on IPE to ensure the formula has time to penetrate before the surface dries.
  3. Plan for the OdorBrazilian Rosewood Oil has an extremely strong odor during application. Apply Penofin in a well-ventilated area and consider eye protection. The smell dissipates after the stain cures but is intense during and immediately after application. Inform any neighbors or household members before starting the project.
  4. Apply One Coat OnlyApply Penofin Hardwood with a stain pad, brush, roller, or sprayer. Apply only one coat — IPE will not accept a second coat due to its density, and attempting to apply a second coat will result in excess product sitting on the surface that cannot cure. Work 2 to 3 boards at a time running the full board length. Apply a thin, even coat and do not over-saturate.
  5. Back-Wipe Any ExcessWithin 20 to 30 minutes of application, back-wipe any areas where Penofin has not fully absorbed into the IPE surface. Excess product left on dense IPE will remain tacky and may not cure properly. Use a clean dry cloth or brush to remove any pooled stain, particularly in end-grain areas and tight board gaps.
  6. Allow Full Dry TimePenofin Hardwood dries to the touch in 4 to 12 hours depending on temperature and humidity. Keep foot traffic off the deck for 24 hours. Full cure takes approximately one week. Avoid power washing or heavy cleaning for 30 days after application — and keep in mind that Penofin recommends reapplication every 3 to 6 months on IPE if you want to maintain color.
Penofin Hardwood vs. Competing IPE and Exotic Hardwood Stains
Penofin Hardwood stain competes directly with TWP Natural Effect, Armstrong Clark Hardwood, and Restore-A-Deck Exotic Hardwood in the exotic hardwood and IPE stain category. Here is how they compare based on our hands-on testing of all four products.
Feature Penofin Hardwood TWP Natural Effect Armstrong Clark Hardwood Restore-A-Deck Exotic
Stain Base Brazilian Rosewood Oil Water-Based (European Waterborne) Modified Oil-Based Water-Based
Price Per Gallon ~$70 ~$100 ~$50 ~$46
Coverage on IPE 300–400 sq. ft. 200–300 sq. ft. 200–300 sq. ft. 250–350 sq. ft.
Initial Appearance Excellent (10/10) Excellent (10/10) Very Good (9/10) Good (8/10)
UV Protection at 1 Year Very Poor (1/10) Excellent (10/10) Very Good (8/10) Very Good (9/10)
Mold Resistance Poor (4/10) Excellent (10/10) Good (8/10) Excellent (10/10)
Color Stability Very Poor — fades and darkens Excellent — no darkening Good — minimal fading Good — minimal darkening
Reapplication Frequency on IPE Every 3 to 6 months Every 12 to 24 months Every 12 months Every 12 months
Reapplication Prep Strip required Clean and brighten Clean and brighten Clean and brighten
Application Odor Very strong — eye watering Low odor Mild Low odor
Same-Day Prep and Stain No No No Yes
Overall Score (1 yr) 6.0 / 10 9.2 / 10 8.5 / 10 8.63 / 10
The comparison is stark. TWP Natural Effect leads all four products with a 9.2 out of 10 overall score, perfect scores in UV protection, mold resistance, and color stability, and the longest reapplication interval of any hardwood stain we have tested on IPE — though it carries the highest per-gallon cost at $99.99. Armstrong Clark Hardwood and Restore-A-Deck Exotic both significantly outperform Penofin at a lower price per gallon. Penofin’s only meaningful advantage in this comparison is its exceptional initial appearance score and its higher coverage rate on IPE — neither of which compensate for failing UV protection and a manufacturer-recommended 3 to 6-month recoat cycle.
Penofin Hardwood Stain — Frequently Asked Questions
Does Penofin Hardwood work on IPE?
Penofin Hardwood can be applied to IPE and does penetrate the dense wood fiber better than most standard deck stains. The formula uses Brazilian Rosewood Oil specifically to address the penetration challenges of exotic hardwoods. However, UV protection on IPE in full sun is very poor — in our one-year test, the stain had lost most of its color by the six-month mark. Penofin’s own representatives told us the product requires reapplication every 3 to 6 months on IPE to maintain color, which is an impractical maintenance schedule for most homeowners. For IPE decks, TWP Natural Effect, Armstrong Clark Hardwood, or Restore-A-Deck Exotic Hardwood all deliver significantly better one-year performance.
Does Penofin Hardwood work on cedar or pressure treated wood?
Penofin Hardwood is formulated specifically for dense exotic hardwoods and is not the recommended Penofin product for cedar or pressure treated pine. Penofin makes a separate product line for softwoods. The hardwood formula’s penetrating characteristics are calibrated for the density of IPE and similar species — applying it to more porous softwoods like cedar or pressure treated pine would result in over-penetration and very rapid UV fade. If you have a cedar or pine deck, see our recommendations for semi-transparent oil-based stains suited for those species.
Why does Penofin stain turn black?
Penofin turning black or dark brown is one of the most commonly reported issues with this product and matches what we observed in our own testing. The darkening has two causes. In sun-exposed areas, UV degradation depletes the pigment quickly and the bare wood grain begins to oxidize and gray. In shaded or covered areas, mold growth embeds into the remaining stain, causing the characteristic black discoloration. The Brazilian Rosewood Oil base can promote mold growth in low-light or high-moisture areas. This darkening issue is not unique to a single batch or color — it is a consistent pattern across multiple reviews and customer reports, which is why we cannot recommend Penofin for IPE decks that have any shaded sections.
How long does Penofin Hardwood last on an IPE deck?
Based on our one-year test and Penofin’s own guidance, Penofin Hardwood lasts approximately 3 to 6 months on IPE in full sun before significant color loss occurs. In shaded areas, the stain may retain some color longer but is prone to mold darkening. Even under ideal conditions, plan for reapplication at least once per year on IPE and potentially twice. This is a significantly shorter maintenance cycle than competing hardwood stains — Armstrong Clark Hardwood and Restore-A-Deck Exotic both last approximately 12 months on IPE before recoating is needed, and TWP Natural Effect has shown color retention beyond 24 months in our testing.
Do you need to strip Penofin before reapplying?
Yes — in most cases, stripping is required before reapplying Penofin on IPE. Because the stain darkens significantly and can develop mold in the remaining finish, applying a fresh coat over the existing material would seal in the darkened or contaminated layer and produce poor color results. Use a quality deck stain stripper such as Restore-A-Deck Stain Stripper, follow with a wood brightener, rinse with a pressure washer at 1,500 to 2,000 psi, allow 48 to 72 hours to dry, and then reapply. If you are switching from Penofin to a different brand, stripping is always required before applying a new product.
22 Comments
Jen
Jen
I stained our 1 year old deck last spring. Looked great. One year later and the stain is peeled off like it was painted.
Not excited by this product. I wore a respirator also. Very strong fumes
Michael McKenna
Michael McKenna
Hi, Could anyone please tell me what is the best UV oil to use for composite decking?
Much appreciated.
Catherine Kellington
After using my deck is very slippery how to fix.
Erik
Erik
Never using this product again. It stinks to high heaven on application to the point where you need a respirator when applying it. The smell permeated into my kitchen for extra fun. If you must use Penofin, I recommend it. The curing process IS NOT complete in a few days and in places like Seattle, IN NO WAY SHAPE OR FORM is it dry enough to walk on after 24 hours. I applied it EXACTLY as instructed, and the deck still smelled after 2 weeks. The color fades quickly as well. I also had mold and black spots which had to be power washed. This was tedious because my rails are cedar and one needs to be extremely careful or you’ll chew up the railings.
Jim Weiler
Jim Weiler
I’ve been using Penofin Hardwood Stain (brown can) on a mahogany deck in MA for 8 years. I did not apply the 2 step annual cleaner and brightener process for the first 5 years or so, just did a power wash and restain every year. The deck got blacker each year. Extremely slippery mold coating the one time I skipped the annual restain. I’ve applied the 2 step program for 3 years now. You really have to have a strong solution of the cleaner to get any black off. I started sprinkling the powder onto the wet wood directly and mixing it up on the wood with a rubber glove. Then with a power wash (the Karcher circular wand strong blast, not the foot wide deck washer attachment) the black comes off. But you cannot use the same can next year after you open it because the volatile hydrocarbons evaporate, the can actually shrinks and if you apply the year old but normal looking stain you will have gummy streaks and bumps all over the wood. So every year now I throw away a half full can that costs $60. I also have to wipe it twice after applying, waiting the 30 minutes or so they recommend, but then I have to wipe it 12 hours later to remove the widespread ‘extractive bleeding’ so there aren’t shiny streaks on the surface. And I apply a very thin coat, almost not covering the wood. So I’m going to try Australian Timber Oil that a friend uses on their mahogany deck. Seems like far less work and cost for similar result.
Robert
Robert
Which stain is best to give it a more brown color
Mike W
Mike W
The worst product we have ever used. Deck turned black. Mfg rep came back and stripped it. He then restrained it. By the next spring it had turned black again. Use at your own risk.
Stefan B
Stefan B
It is an OK product, highly overrated.
1) Although it brings out the natural grain, even the transparent version has has too yellow color to it, looking artificial on oak or acacia.
2) the smell is very pungent, hope it subsides
3) The oil separates fast from spirit during application so you have shake it often.
Not sure how long will it last, but certainly dissapointed with its performance. Not sure who are the people who gives it glowing review
Robin
Robin
Had our porch redone with mahogany railings in April and are ready to treat/stain. Were gung-ho on Cabot Australian Timber Oil in Mahogany Flame color until reading about problems with the new low voc formulation. Opinions on TWP for mahogany railings? Color choice that would restore the original mahogany? Thanks!
I am applying this on Brazilian Mahogany which is on the ceiling of my covered porch. The oil brings out a brilliant hue which enhances all the color variations in the wood. I applied an initial coat about a year ago and have noticed that the wood was slightly drying out but still maintaining its color. I just put another coat on and restored its brilliance. It goes on super easier and the wood looks amazing after it is coated. I am planning to brush more oil on it every 2 years.
I am sure this is not your typical application for the wood since it is on a ceiling but it is exposed to winter months in the USDA zone 5 & 6 in this area.
I would highly recommend this oil.
Pro's:
-Goes on smooth
-Makes wood look brilliant
-Oil penetrates the wood
Con's:
-It does smell very strong
droberts
droberts
12 years ago
One year in with Penofin on a ipe deck. Three applications and the decking is beginning to look dirty. It gets full sun and does not appear to be mold. My hunch is that Penofin resins are getting baked in the heat. Does not look pretty. Not sure about this stuff…..
GarSharMo
GarSharMo
12 years ago
We stained our 660 square ft. deck a couple of weeks ago using this product and have several areas that are still "tacky". Except for a couple of day of rain, we've had bright sunshine, temperature in the 80's so disappointed with this "issue", but overall very pleased with he results. Took us an afternoon to get the job done, and used less stain when compared to the Benjamin Moore product we used previously. The area that's the most "tacky" is a somewhat shaded area where we typically pull out our gas grill, so I need to resolve the problem, quickly. Suggestions..?
Pete the painter
Pete the painter
7 months ago
Yes… Contaminated rags or drop cloths will burst into flames even if not in direct sunlight. You will need to soak the wiping cloths in water. I suggest putty them in a sealed ziplock bag filled with water. Then you can dispose of them. Tricky stuff in that regard. I’ve been painting for 50 yrs, only time rags caught on fire was from this product.
22
