- DEFY Marine Seal Wood Cleaner mixes per dilution instructions for correct strength and coverage.
- DEFY Marine Seal Wood Cleaner applies with a pump sprayer, stiff brush, or mop for even distribution.
- DEFY Marine Seal Wood Cleaner should sit 10-15 minutes to penetrate and lift stains before scrubbing.
- DEFY Marine Seal Wood Cleaner requires scrubbing stubborn stains with a stiff brush, then rinsing thoroughly with clean water.
- DEFY Marine Seal Wood Cleaner requires wood to dry completely before staining; follow with DEFY Marine Seal Wood Dock Stain.
- DEFY Marine Seal Wood Cleaner removes dirt, mildew, algae, and weathered graying, preparing wood for sealing.
✔ Boat Docks & Piers
✔ Lakeside Decks & Patios
✔ Wood Bridges & Walkways
✔ Canoe & Kayak Racks
Defy Exterior Wood Stripper
