Restore-A-Deck Wood Stain for Exotic Hardwoods Review 4.9/5 (2)
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior hardwood decking. My Restore-A-Deck Hardwood & IPE Stain review is based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain tips. See here for more info about me.
  • Restore-A-Deck Wood Stain earned an overall score of 8.63 out of 10 after one year of testing on IPE exotic hardwood boards.
  • One of the few stains that can be applied to damp wood, allowing you to prep and stain on the same day, saving significant time.
  • At the one-year mark, test boards showed no peeling, no wearing, and zero mold or mildew growth, a strong result for dense exotic hardwood.
  • Coverage on IPE and exotic hardwoods averages 250 to 300 square feet per gallon, with only one coat recommended.
  • Reapplication is straightforward since there is no peeling or film buildup; prep with the Restore-A-Deck Wood Cleaner before recoating as needed.
Restore-A-Deck Exotic Hardwood Stain Review
This is our initial Review of the Restore-A-Deck Wood Stain for Exotic Hardwoods such as IPE.  This review was one on IPE sample boards and was tested for 1 year from the date of application. The  Restore A Deck Wood Stain showed excellent Ipe color retention and showed no signs of wearing or peeling. This test was on brand new, unseasoned IPE and was done the same day as the prep. We waited 1 hour after prep to apply the RAD Stain while the wood was damp.
Note: Restore-A-Deck Wood Stain is one of the only stains we have tested that can be applied to dry or damp wood. Applying to damp wood allows you to prep and stain on the same day, saving you time.
Restore A Deck Wood Hardwood and IPE Stain Review
Restore-A-Deck Hardwood & IPE Stain Summary:
Restore-A-Deck Wood Stain is an advanced, water-based, semi-transparent stain formulation designed to penetrate deep into wood pores for maximum protection and longevity. It protects wood from harmful UV rays and damage caused by water penetration. Restore-A-Deck Hardwood & IPE Stain is safe to use, has a low odor, and is easy to clean up with soap and water. It is ideal for all wood types, including pressure-treated pine, cedar, fir, or redwood.
Recent advancements in water-based wood stain technology have allowed the active ingredients in the Restore-A-Deck Stain to offer better UV protection, excellent penetration into the wood grain, and the ability to apply to damp wood, all in beautiful semi-transparent colors that highlight the natural wood grain.
RAD Wood and Deck Stain will increase all exterior wood surfaces’ life, appearance, and durability. The easy-to-apply and maintain Eco-Safe formula allows you to finish faster and enjoy your exterior wood or deck for years.
Important Note: Testing for Exotic Hardwood Deck Stains
Exotic hardwoods such as IPE are extremely dense and difficult to penetrate. When stained, these wood types always fade faster than other woods such as Cedar, Redwood, and Pine. Testing for exotic hardwoods will be changed to 1 year instead of 2 years.
$53.99
How I Rated Restore-A-Deck Hardwood & IPE Stain
My Restore-A-Deck Hardwood & IPE Stain review contains an 8-step process and the final average score. Each step is on a scale of 1-10.
  1. The appearance of Restore-A-Deck Hardwood & IPE Stain after Application
  2. Preventing UV Graying
  3. Peeling or Wearing
  4. Cost Per Square Foot
  5. Preventing Mold and Mildew
  6. How Easy Was the Restore-A-Deck Hardwood & IPE Stain Application
  7. Color Shifting
  8. Ease of Reapplication
  9. Restore-A-Deck Hardwood & IPE Stain Final Score
8-Step Review of Restore-A-Deck Hardwood & IPE Stain
1. Appearance After Initial Stain Application: 8
The Restore-A-Deck wood stain color we used was the Semi-Transparent Light Walnut. After drying on the IPE wood, the initial appearance was a rich brown with a hint of red (see pictures below). The Restore-A-Deck Stain penetrated extremely well into the wood grain on our test deck. There is no surface film on top of the wood.
Restore-A-Deck Hardwood IPE Stain
2. Preventing UV Graying at 1 Year Mark: 9
Restore-A-Deck had minor fading at the 1-year mark for the IPE test boards. See the picture below at the 12-month mark.
Restore-A-Deck Stain on IPE after 9 months
Restore-A-Deck Stain on IPE after 12 months
3. Wear/Tear and Peeling: 9
At the 1-year mark, there was no wearing or peeling for the Restore-A-Deck Wood Stain on the IPE test boards.
4. Cost Per Square Foot: 8
We applied one coat to our IPE test deck. Coverage for the Restore-A-Deck Wood Stain on exotic hardwoods will average around 250-300 sq feet per gallon. Only 1 coat should be applied to exotic hardwoods.
5. Preventing Mold/Mildew/Algae: 10
Like other water-based deck stains, the Restore-A-Deck Wood stain will not promote mold or mildew growth. This is one of the main advantages of using a water-based coating. At the 1-year mark, the deck showed no signs of any mold or mildew.
6. Ease of Application: 9
As per our previous review of the Restore-A-Deck Wood Stain on PTP wood, our favorite aspect of the Restore-A-Deck Wood stain is the ability to stain and prep on the same day! We tested this by cleaning and brightening the wood with the Step 1 and Step 2 Restore A Deck Cleaner/Brightener Kit and applying the RAD stain 1 hour after the prep. The wood was visibly wet on a few areas of the deck and damp to the touch throughout. The coverage was better when applied to damp wood.
Restore-A-Deck Wood Stain 1 Hour After Prep
IPE Wood After Prep – Unstained
Restore-A-Deck Wood Stain On IPE.
Restore-A-Deck Wood Stain On IPE. Stained 1 Hour After Prep.
7. Color Shifting (darkening) after 1 Year: 8
As expected, there was minimal darkening for the Restore-A-Deck Stain or color shifting.
8. Difficulty of Reapplication: 8
The Restore-A-Deck should be easy to clean and reapply as needed as there was no peeling or wearing. Prep with the Restore-A-Deck Wood Cleaner first.
Overall Score Restore-A-Deck Stain on IPE Wood at 1 Year Period: 8.63
The Restore-A-Deck worked great on our IPE test boards. Restore-A-Deck for IPE will be an easy coat and recoat for exotic hardwoods that require annual maintenance. You will be able to enjoy your beautiful hardwood deck with the product.
$53.99
More Info: Restore-A-Deck Wood Stain
Cost: $47.99 per Gallon, $149.99 per 2.5 Gallon Pail, $219.99 per 5 Gallon Pail. Products ship free on their website.
Stain Type: Semi-Transparent – Water Based
Available Colors: Natural, Cedar, Light Walnut, Dark Walnut
Coats  Required: 1 Coat on Exotic Hardwoods and IPE.
Coverage Per Gallon: 250-350 sq. ft on Exotic Hardwoods/IPE
Dry Time: 2-4 Hours
Cleanup: Water
More Info: Product Data
Manufacturer: Restore-A-Deck
Deck Wood Type: IPE Exotic Hardwood
Deck Square Footage: IPE Test boards were used.
UV Exposure: 100% Full Sun
How Many Years Tested:  1 Year
Light Walnut
Restore-A-Deck Semi-Transparent Stain Photos
The Best IPE Hardwood Deck Stain Video – DeckStainHelp.com
69 Comments
Sheila Morrissey
Sheila Morrissey
3 months ago
Hi Scott! My IPE deck is in full sun. By the end of the summer season it looks pretty gray. Every May, for over 10 years, I have applied one coat of Penofin transparent Brazilian Rosewood oil after a good cleaning & powerwash. My deck and rails no longer have that beautiful natural wood color – this oil treatment leaves them looking almost black with no natural veining.
Have I ruined my deck over the years? Do you have any recommendations, such as, professional sanding and then applying your clean & brightener followed by the protective stain? I want to bring the IPE back to it’s natural color.
Thanks for your time – you were highly recommended by my friend Kerry!
Sheila M
Sheila Morrissey
Sheila Morrissey
3 months ago
Thanks for the quick reply. Do you recommend I wait until Fall (October) or next Spring? I live in the northeast where temperatures stay low until May!
Kerry Dunkling
Kerry Dunkling
4 months ago
Hi Scott. I have a question about applying RAD light walnut to my ipe deck. I cleaned and brightened yesterday, it looks great. I didn’t have time to put the stain on and today I’m worried about rain. Tomorrow looks great. Should I mist the deck down in the morning to dampen it before I begin staining? Am I correct that I need to put 2 coats on or is one coat good? If I do 2 coats do I have to wait between them and should I be worried about footprints on the what I have stained? I really appreciate all that you do for this community!
Kerry Dunkling
Kerry Dunkling
4 months ago
Thank you! You are the best and so helpful.
Karen
Karen
6 months ago
Just finished restoring our 20 year old ipe deck using the RAD stripper, brightener, and semi-transparent stain in light walnut and thought I would share a couple of pictures and comments. This deck had been treated previously 3 or 4 times over the years with Woodrich Hardwood Wiping Stain (oil based). We were not good about staying on top of yearly maintenance so after looking good for a year after staining, the deck would slowly lose its finish and grow a bunch of mildew, lichen, etc. We wanted to switch to a water based stain since it’s easier to work with than oil-based and we also hoped to get better resistance to mildew and other biological growth. We used the RAD stripper to remove the old stain. This was not a job for the faint of heart, we discovered! The RAD stripper is a good product but for our project, in order to lift the old stain effectively, we had to do a lot of manual scrubbing. Pressure washing (only) after applying the stripper and letting it dwell – even up to 45 min – did not remove our finish. The process we found to work reliably was to spray on the stripper (mixed strong at 1 cup powder per gal water), let dwell 10 min, scrub, apply more stripper, let dwell 20 more min, scrub again, then pressure wash off. We saw lots of suds when washing after the stripping process. A google search on the chemistry of deck stripping with sodium hydroxide shows that it breaks down stain resin into soap-like molecules, thus the suds when agitated by the pressure washing. We noticed that, after the first round of pressure washing, if we went back and pressure washed again more suds formed. We ended up pressure washing twice after stripping and I suspect that we could have pressure washed a third time (and a fourth, etc) and gotten more suds off even though the deck looked like bare wood at this point. We needed to move along though, so after two rounds of pressure washing we went on to the brightening step which was comparatively easy after the stripping step. We applied the brightener as directed, let it dwell 15 min, and pressure washed off. We did not see any suds formed when pressure washing after the brightener. After completing the brightening step, we took a rest day before applying the stain. I rinsed off the deck with a hose the morning of the day I was going to apply stain and I was surprised to get another round of suds! So I ended up washing down the deck with the hose for quite a while to get the pesky suds mostly (hopefully) gone. After letting the deck dry a few hours, I applied the stain which was an easy and pleasant task after all the prep. I used a 3″ brush for the railing and the RAD yellow deck brush for the floor boards (highly recommend). I… Read more »
20260320_134912-002-2
20260326_111046-002-2
Karen
Karen
6 months ago
Thanks for the recommendation. Would we go ahead and apply this product now on the newly stained wood, or wait to see what trouble spots develop? I noticed that some of the joists under the deck have some pretty heavy bio growth – green algae and lichen. Could I just spray this product on and wait for it to work or would it be better to scrape off what I can before spraying? I’m also curious about the role of water in the functioning of this product. The instructions say to apply to dry wood when no rain is expected for a number of hours, but that then natural rainfall will help it work over time. I use the hose quite a bit on my deck for washing things off, watering plants, etc. After the initial 12 hour dry period, can I resume normal hose use or do I need to be careful about it? Seems like the product needs some water long term to keep working, but is there such a thing as too much? Thanks for your advice!
Douglas
Douglas
11 months ago
Finally decided to apply stain to my 12 year old ipe deck. Never was stained, cleaned and brightened about every 2-3 years but nothing else. After much review went with RAD light walnut semi transparent. Did the cleaner and brightener then a wet on wet double application. Went very well and the overall result is great but my wife thinks it has too many “orange” tones now. I realize I can’t just repeat the process with a new color but my question is …will the orangish color soften a bit with time and secondly…would it be acceptable to wait 6 months then do the cleaner followed by the dark walnut stain on top? What do you think the result would be or do you have another suggestion. She thinks she’d like the wood to be a darker brown. Thanks in advance for any suggestions.
Karen
Karen
My 19 year old ipe deck has been stained with Woodrich hardwood wiping stain a few times over the years, last time probably 8 or more years ago. I would like to strip and re-stain with the RAD water based semi-transparent product. After researching the proper steps, my plan is to use the RAD stripper, pressure wash off, RAD brightener, rinse thoroughly with hose, sand a few rough spots, rinse away dust, let dry until no visible water is remaining, then apply the RAD stain. Please let me know if this sounds like the proper prep steps. My question is on application of the stain to ipe. The instructions on the container say to apply two coats about 30 min apart. But I have read in other posts that two coats should not be applied to ipe. For my project, would one or two coats be appropriate? Thank you!
Kerry Dunkling
Kerry Dunkling
I have just used RAD cleaner and brightener on my IPE deck. I used the power washer and am concerned about some variations on the wood. There was algae and a thick mold/scum that came off with high pressure on the power washer. I hope I didn’t hurt the wood. I’m planning to stain with RAD Light Walnut. Will these variations cause a problem with the stain? Thank you for your help! Kerry
IMG_8469
IMG_8468
Kerry Dunkling
Kerry Dunkling
You helped so much last year with our IPE deck that had grayed. I’d like to clean and stain again this year. A couple of questions…
1. Does it need to be done every year?
2. Do I need to strip or clean from last years RAD semi- transparent stain? Followed by the brightener.
3. Can I do 2 coats? If so, the deck is 40ftx12ft and I’m afraid the beginning will dry by the time I finish one coat.
4. Recommendations for what to apply stain with.
Thank you again for all your help and expertise!
Kerry
Kerry Dunkling
Kerry Dunkling
Thank you SO much!!
kathy
kathy
I did steps 1, 2 and 3 24hr ago on my ipe deck. I see a few spots I missed. What is the best way to cover these. Thanks for your help.
I have a hardwood deck that I did the full process process to 3 years ago (RAD stripper, brightener, and then the stain reviewed here). The stain is fading and the wood has lots of little cracks in it. I understand this should be done every year, and I’m gearing up to do this again. I’m not exactly sure what is necessary though. Can I just reapply a coat of the stain, or do I need to clean, bright, and then stain all again? Thanks!
Here are two pics of the worst areas as well as the general view of how things look. Thank you!
Reply to  Joe
Is there anything that can be applied after the stain that might help it last longer and/or help with all the miniature cracking?
Kerry Dunkling
Kerry Dunkling
We have a 3 year old Ipe deck that we let gray. We’ve decided to put a stain to bring it back to its original glory. We used Messmers’s A and B. It was still gray so we started sanding. It brought the color back but there is still gray that I can’t seem to get it out with the hand or belt sander. We probably should have rented a floor sander. When the wood gets wet the gray becomes much darker. Is there an easier way to remove the gray? Or do we have to live with it? We’ve ordered sample
of the restore a deck stain and wondering if that is the best option when to wood is finally prepped. I really appreciate you helping everyone! I feel like I’ve gone down the Ipe rabbit hole. Also, the deck faces west and gets beaten by the sun if that makes any difference. Thank you again for your help!!
Kerry
Kerry Dunkling
Kerry Dunkling
We did not power wash after Part A. We did Part A, then B. Then sanded, then power washed.
Kerry Dunkling
Kerry Dunkling
Here are the pictures.
Kerry Dunkling
Kerry Dunkling
Ok. Thank you so much! How much time after I do this do I have before I need to get the stain on? I just received samples today so I’ll need to figure out which one we like best. Do you have a recommendation? We really just want as clear as possible to let the natural color of the wood come through. Again, we really appreciate all your guidance!!
Kerry Dunkling
Kerry Dunkling
Thank you SO much!!! I’ll order it now. You have been SO SO helpful. I’ll follow up with pictures when it’s done.
Kerry Dunkling
Kerry Dunkling
Reply to  Kerry Dunkling
IMG_8469
IMG_8468
Bryan
Bryan
I’m planning to install a new fence out of Red Balau. It is denser than softwoods, but not to the level of Ipe.
Should I still let the wood weather prior to staining? What are the downsides to staining prematurely, as the fence is being I initially built?
Do you know why the recommendation from the lumber company (stain/oil immediately) differs from the directions of stain manufacturers?
Dianne C Williams
Dianne C Williams
my Grapa Gold deck is gray. What is the process for reviving it. Does it need to be pressure washed, then degreased, then stained?
Coleman Timberlake
Coleman Timberlake
We are installing a new Ipe deck that will be very close to the ground, about 10″ off of ground. Would it still be wise to not stain all sides of the wood or just do the top like you say for breathing? Thanks for your help.
Amanda Woodruff
Amanda Woodruff
We have a 16 year old Ipe deck (part in full sun, part covered) that we have been staining with Australian Timber Oil every few years. Some of it has come off completely, but some still has a lot of stain on it and I’d like to get it all off before I restain this year. Pressure washing didn’t help at all. It sounds like we should use RAD stripper and brightener. Do you prefer RAD for stain on Ipe as well? Or is Armstrong-Clark a better choice?
Andrew Tyrrell
Andrew Tyrrell
I completely restored a neglected dock this summer and applied messmers. Was very happy after application with the dark, wood grain appearance but it hasn’t already lightened significantly. I probably should reapply another coat this fall fall. Thinking RAD strippers plus this vs armstrong clark. What’s are your thoughts on other colors? If we like the darker look which color do you recommend?
Am I correct that I can strip and stain in the same day with these products? Need I wait in between? How much of a rain free window do I need?
pgerb
pgerb
Hi, love the site! I’m in the process of rebuilding a 100+ yr old porch. We’re ripping up the flooring, rebuilding the frame and replacing the flooring with kayu bau. It’s a covered exterior porch and I’m getting mixed reviews online. It sounds like all sides should be sealed but I’m also reading that you should wait 3 months to a year to seal. Can I seal all the sides but the top before installation then wait 3 months and seal the top? If so, what do you recommend for this type of wood? I was thinking about using RAD Natural semi-transparent on the edges and bottom. Then 3 months later, use the cleaner and brightener then finish sealing the top. Do you recommend doing something different or using another product?
pgerb
pgerb
Thanks! Any reason to not stain all sides? Is there a negative in doing it?
pgerb
pgerb
Jezerceg
Jezerceg
Hi, we just installed new garapa decking in Southern California. We picked this type of wood as we wanted very light color to match the flooring in the adjoining living space which is White Oak with white wash finish that almost look like natural oak color. If we are going to preserve the deck what would be the best option to retain the color on garapa without any yellowing or darkening. We purchased Ipe deck but the test color is way too brown. As you see in the image the color is very light and soft. I would hate to get this much darker or brown. I was thinking of clear penetrating sealer but this wood is very dense and not sure if this would work. What would be other options. Also we have few more days for finishing it off and still some time for the rest of the construction to end.
I would really appreciate all the help!
Stephen
Stephen
I have a Thermory Ash deck that I’ve stained with Cutek twice that does not retain its color even after a few months. Is this RAD stain recommended for thermal treated wood? What about Messmer’s Caribbean extreme?
nancy
nancy
we put in an ipe deck about 3 years ago. It was stained (or oiled – not sure the difference) when it was installed. It’s covered so it has retained a beautiful rich red/brown color. We were told we should oil it to maintain the color. Can you recommend a cleaner and an oil. Or are we supposed to restain it? I’ve noticed people mentioning oil and some mention stain and I’m unclear of the difference and which one we need. Thank you so much!
nancy
nancy
Thx. why a stain vs an oil? What’s the difference?
Curt
Curt
Is this the go-to stain for IPE now given you rate it highest? Seems much easier to apply than Armstrong
Warren
Warren
Have applied Messmer’s UV Plus for several years. After cleaning with Restore-A-Deck system, will this stain penetrate old oil stain?
Luara
Luara
Will this work for Mahogany decking?
69
