🏆 Top Deck Stain Picks Summary
- Best Overall: TWP 100 or 1500 Series
- Best for Old Decks: Armstrong Clark
- Best Budget Option: Restore-A-Deck
- Best Penetrating Oil: CUTEK Extreme
| Product | Type | Durability | Ease of Maintenance | Key Strength | Best For |
| TWP 100 | Semi-Transparent (Oil) | 2–3 Years | Easy | Proven performance, deep penetration | Most decks |
| TWP 1500 | Semi-Transparent (Oil, Low VOC) | 2–3 Years | Easy | Better VOC compliance, similar performance to TWP 100 | VOC-restricted states |
| Armstrong Clark Wood Stain | Semi-Transparent (Oil) | 2–3 Years | Easy | Excellent oil penetration + conditioning oils | Dry, aging wood |
| Restore-A-Deck Wood Stain | Semi-Transparent (Water-Based) | 2–3 Years | Very Easy | Simple prep system + easy recoat | DIY homeowners |
| CUTEK Extreme | Penetrating Oil | 2 Years | Very Easy | Deepest penetration, no film buildup | All Wood types |
| Defy Extreme | Semi-Transparent (Water-Based) | 1–3 Years | Moderate | Strong UV resistance with zinc nano-particles | Sunny/high UV areas |
- Best Overall Deck Stain: TWP 100 Pro Series — A deep-penetrating, oil-based semi-transparent stain that offers excellent durability, easy maintenance, and consistent performance for up to 3 years.
- Best Semi-Transparent (Water-Based): Restore-A-Deck Semi-Transparent Wood Stain — A user-friendly, UV-resistant stain that can be applied to damp wood, allowing prep and staining in one day.
- Best Oil-Based Alternative: Armstrong Clark Wood Stain — A penetrating oil formula that conditions aging wood while providing long-lasting protection and easy reapplication.
- Best for VOC-Restricted States: TWP 1500 Series — An EPA-registered preservative with strong UV and mildew resistance, ideal where traditional oil-based stains are limited.
- Best for UV & Mildew Resistance: Defy Extreme Wood Stain — A water-based formula enhanced with zinc nano-particles for superior UV protection and mildew resistance.
- Best Semi-Solid Stain: TWP Pro Series Semi-Solid — Offers richer color, excellent UV blocking, and better coverage while still allowing some wood grain visibility.
- Best Solid Color Stain: Restore-A-Deck Solid Color Stain — A durable, breathable coating that resists peeling and works well for older or heavily weathered decks.
- Best Deck Resurfacer: Gulf Synthetics Deck Revive — A thick resurfacing coating designed to restore heavily worn or damaged wood surfaces.
*Free Shipping Included
✅ How I Rate Deck Stains
- Durability in real-world conditions
- Ease of application and maintenance
- Resistance to peeling and wear
- Overall long-term performance
- Wear and tear after 2 years
- Oil-Based:
- Deep penetration
- Easier maintenance
- Water-Based:
- Better UV color retention
- Faster drying
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
3. Defy Extreme Stain
Type: Oil-Based Semi-Transparent- Durability: 2–3 Years
- Maintenance: Easy recoat, no stripping needed
- Best For: Most decks (pressure-treated, cedar)
- Why It Stands Out: Deep penetration and consistent long-term performance without peeling
My Test Deck Stats
Deck Square Footage: 2100
Consumer Star Ratings:
- Type: Water-Based Semi-Transparent
- Maintenance: Very easy, simple prep system
- Best For: DIY homeowners and quick projects
- Why It Stands Out: Can be applied to damp wood, allowing prep and stain in one day
My Test Deck Stats
UV Exposure: 50% Full Sun
- Type: Oil-Based Semi-Transparent
- Maintenance: Easy reapplication
- Best For: Older, dry, or weathered wood
- Why It Stands Out: Contains conditioning oils that help restore dried-out wood
My Test Deck Stats
Deck Square Footage: 600
- Type: Semi-Solid (Oil-Based)
- Durability: 3 Years
- Maintenance: Moderate
- Best For: More color coverage with strong UV protection
- Why It Stands Out: Rich color options while still allowing some wood grain to show
My Test Deck Stats
When Tested: August 2023
Deck Square Footage: 800
UV Exposure: Deck in full sun
- Type: Oil-Based Semi-Transparent (Low VOC)
- Maintenance: Easy
- Best For: VOC-restricted states
- Why It Stands Out: EPA-registered preservative with strong UV and mildew resistance
My Test Deck Stats
Deck Wood Type: Cedar
Deck Square Footage: 400
- Type: Water-Based Transparent
- Durability: 1.5–2.5 Years
- Maintenance: Easy
- Best For: Maintaining a natural, “bare wood” appearance
- Why It Stands Out: Unique formula designed to preserve the natural color of new wood while still offering UV protection
My Test Deck Stats
Stain Color Used: Chesnut
- Durability: 2 Years
- Best For: High UV and mildew-prone areas
- Why It Stands Out: Zinc nano-particles provide superior UV protection and mold resistance
My Test Deck Stats
Stain Color Used: Cedartone
- Durability: 1-2 Years
- Best For: DIY users and quick, forgiving applications
- Why It Stands Out: Extremely easy to apply with no back-brushing needed, but shorter lifespan than higher-end penetrating stains
My Test Deck Stats
- Type: Penetrating Oil
- Maintenance: Very easy (clean and reapply)
- Best For: Exotic hardwoods (Ipe, teak) all wood types
- Why It Stands Out: Extreme penetration with no film buildup, making long-term maintenance simple
Scott’s Pro Tips: Although CUTEK® Extreme is more expensive than many penetrating oils, the performance was very solid. There was no peeling or significant wear, and the coating should be easy to maintain, as it fades naturally and can be refreshed without stripping.
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Stain Color Used: Walnut
Semi-Solid Deck Stain Review
- Consumer Star Ratings:
Best Deck Stain for Old Wood
- For new pressure-treated wood, wait until the wood has weathered and is able to absorb stain (typically a few months), then prep and stain.
- For older pressure-treated decks, proper cleaning and brightening will restore the wood and allow for better stain penetration.
- If you want to maintain cedar’s natural look, use a lighter or natural-tone stain.
- If you want longer UV protection, choose a slightly darker tint, as it will hold color longer.
- Wood Condition: New, weathered, or heavily worn
- Desired Look: Natural grain showing vs solid color
- Maintenance Preference: Easy recoat vs long coverage
- Climate: Sun exposure, moisture, temperature swings
✅ Deck Stain Types Explained
- Transparent/Clear Sealers: Natural look, less protection
- Semi-Transparent Stains: Best balance (most recommended)
- Semi-Solid Stains: More color, moderate maintenance
- Solid Color Stains: Maximum coverage, higher maintenance
Transparent Stains
Solid (opaque) Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
- Film-forming coatings on older decks
- Over-applying stain
- Choosing based on color alone
- Skipping prep
- Not preparing your deck: Failing to clean your deck or remove old, flaking, or peeling stain from your boards can prevent a fresh coat of stain from adhering properly. See my Deck Cleaning Guide for best results!
- Over-applying stain: You may think more stain equals more protection from moisture, mildew, and sun damage, but that’s not always the case. Too much stain can prevent the product from penetrating your deck boards. As a result, it may form a film on top of the wood that peels or flakes off over time. See my How to Stain a Deck tips for the best results.
✅ Best Deck Stain FAQs
Quick Tip:
What is a deck stain?
⏳ Durability & Maintenance
🎨 Appearance & Color
🛠 Application & Usage
🆕 New Deck Questions
- Smooth wood: Wait ~3 months
- Rough wood: Can stain once clean and dry
- Kiln-dried wood: Wait 1–2 months
- Deck Location: Michigan
- Wood Type: Cedar
- Mold/Mildew?No
We built two decks last spring. Waited until summer to apply Duckback Superdeck 2010 Natural per instructions. We had pressure washed and let the deck dry thoroughly. Looked good. In the fall we were away and the leaves stained the deck badly. We thought the coating would prevent that. We have pressure washed twice and have much of the leaf stains out but the overall deck is not as bright as it was. I’l like to keep the color as close to natural as we can, but I want some pigment to protect from UV.
Virgina
full midday, partial morning and afternoon
pressure treated pine
no mold or mildew
18″ to 3′ off the ground
Duckback Superdeck 2012 Natural
Try TWP Honeytone or Armstrong Clark in Amber. Strip and brighten the wood for prep to remove the Super Deck.
Looking to find what the stain, sealer to use on outdoor oak wood furniture that waterproofs as well. Live in California. Wood is bare. No prior stain used. Furniture will be in full sun and some in partial shade. Furniture we used to have had Penofin on it and we had a problem with mold and mildew on ones that were in shade. Can you please help
Defy Extreme or Restore A Deck Wood Stain.
Deck Location State: Ohio
Full Sun, Partial Shade
Wood Type: Not sure…currently painted gray with white trim
Mold or Mildew Issues: No
Reason for Previous Stain Failure: I don’t like the color, like the natural look better. We just moved into the house. Not sure when it was painted.
Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): Don’t know?
thanks!!
If painted, you will need to sand it all off the get back to a natural looking stain. Stain strippers will not remove a paint fully. Once sanded, brighten all the wood. Then try a penetrating coating like the TWP 1500.
installed Siberian larch on exterior deck. location SE Massachusetts, full sun. No treatments yet but want to brown it slightly and protect it. Best stain recommendations? The old decking was PT and was old and not maintained over the years so really doesn’t help much. No mold issues.
Try the Armstrong Clark in Natural Oak. See this about new wood tips: https://www.deckstainhelp.com/staining-a-new-deck/
Deck Location State: Chicago, IL
Full Sun, Partial Shade, Full Shade: Full Sun. Deck + pergola
Reason for Previous Stain Failure: New deck Summer ’17, no previous stain. We want to do it right the 1st time.
Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): Just a water seal for over winter bc we couldn’t agree on a stain color. We want semi-solid, light tone.
Use Armstrong Clark in a semi-solid color. Make sure to prep well first and remove the water sealer.
I need to restain my deck and want to find something that should last a few years. I don’t mind staining the deck but the rails are ridiculous. Here is a picture. The the deck faces southeast.
Prep by stripping and brightening the wood. Stain with Restore A Deck Wood Stain or the Armstrong Clark Stain brands.
This is a great site with a lot of tools for research but I’m not confident about choosing a brand. The deck is two years old and this will be the time this deck has been stained. It receives 4-6 hours of sun a day for most of the deck but one part receives around 8 – 10 hours. Mold seems to be the biggest issue and the one part of the deck that is exposed more to the sun and weather has a noticeable difference in us fading.
Deck Location State: Georgia
Partial Shade
Mold or Mildew Issues: Yes
Hi Tristan, for this deck with a decent amount of sun and some mildew issues, try the Defy Extreme Stain or the TWP 100 Series. Make sure to prep with a deck cleaner and a wood brightener.
Thank you for the help.
Looking for the best deck stain for my area:
Deck location state: Pennsylvania
Partial Shade
Reason for previous stain failure: New deck, waited one year and stained, peeled within year. Pressure washed and stained again, peeled worse within 6 months.
Previous stain brand and type: Behr Premium Transparent Weather Proofing.
Would appreciate any help you can give as we would like to strip or sand off as much as possible and start over.
Thanks so much,
Behr is a stubborn stain to remove. Strip off as much as possible and then sand if needed to remove the rest. Once removed, apply a wood brightener to all. For the new stain, use a penetrating coating like the Armstrong Clark or TWP 1500 Series so you will not have the same issues of peeling and your reapplication will just be a clean and recoat when needed.
Can you suggest a good stripper for this job and do you have a recommendation for a specific wood brightener? Thanks for your help!
Use Restore A Deck Stripper and Brightener Kits.
Can you suggest a good stripper and wood brightener to use for this project? thanks
Hey there, great site, thanks for all the info. I’d love a recommendation for a deck stain! I checked Consumer Reports extensively but their top picks are pretty widely panned by their user reviews for chronic peeling, and aren’t even on your list (Olympic Elite Advanced Stain + Sealant / Behr DeckPlus). Your top pick looks good but I’d rather go with something with very low VOCs, <100 if not <50. I'd also prioritize a good value over peak performance, factoring in longevity.
Northern Vermont
Full Sun in Afternoon, shaded by house in the morning
Wood Type: Not sure but would guess cedar
The reason for Previous Stain Failure: Faded and peeled significantly, but not sure when it was last stained.
Previous Coating? Previous owner did it years ago, so not sure, but looks like a solid orange-y stain.
Armstrong Clark or Restore A Deck Wood Stain. Both are below 50 VOC. Issue is you will need to sand off the solid stain to use either of those as they are penetrating semi-transparent.
1) Location of deck is St Louis
2) Partial sun in the morning and evening. Full sun during most of the day.
3) The wood is pressure treated deck boards. Unsure of specific species
4) I have seen algae growing on the North side of the house, but the deck is on the east and south sides of the house. Short answer, mold/mildew environment is present.
5) New deck, no previous stain applied. Deck is approximately 1 year old.
6) see number 5
Additional information: this deck is a wrap around facing east and south. East deck is covered and screened in. South is uncovered. I would like to use the same color or stain on both, if practical. But open to alternatives.
Thank you so much for this service.
Hello, for prep, make sure to clean and brighthen the wood. For the stain, try Armstrong Clark or TWP 100 Series.
Last Year My Husband painted our deck. The paint is peeling and I have noticed black spots on some of the wood. What do we need to do to restore and protect the wood because I guess that is mildew. At this point maybe we just need to buy new wood, what would you suggest?
Post a picture please. You may need to power sand it all off or replace the wood and start over.
We have a new pressure treated fir deck. One year old. Ready to prep and stain.
This site has been great source of information, but I want to avoid the multitude of issues that have been exposed in this site.
Deck Location State: New York
Full Sun, Partial Shade, Full Shade: Full Sun 6-8 hours daily.
Wood Type: Pressure Treated Fir
Mold or Mildew Issues: Possible some spots mildew
Reason for Previous Stain Failure: none, new deck
We will have a professional stain our deck. Prep will involve low pressure power wash, brightener.
1. Is prep adequate for this deck to ensure the best results?
2. Any issues using super deck exotic hardwood stain even though this is a pressure treated deck? Unfortunately this stain is not reviewed by your site. Should I ask that highly rated stain like twp 1500 be used?
3. A second coat is recommended 18 months out, what prep should I expect for that. I am hoping I do not have to strip a stain such as this.
1. Use a cleaner first followed by a brightener while pressure washing.
2. Super Deck turns dark brown or black in less than a year. Hardwood version is the same as the other version, just a different label. https://www.deckstainhelp.com/sherwin-williams-superdeck-stain-review-2017/
3. Clean and recoat will be your prep when penetrating stain like the TWP 1500 Series.
Thanks for succinct recommendations.
While I am here, what do you think about staining the underside of the deck?
No need unless you are doing it for appearance reasons. https://www.deckstainhelp.com/staining-undersides-of-deck-boards/
I recently bought a home with a redwood deck. The house is only 2 years old and we are not sure what was put on it but it is flaking off. We also are not sure what type of wood it is. We live at 8400 ft with lots of direct sunshine on it. What would be the best way to prep and what product should we use on it?
Woodland Park, CO, Full Sun, not sure on wood type, no wood or mildew, not sure on what was used, stain flaking off.
I do not think a stripper will fully remove this. This is what we would do:
1. Strip off as much as you can.
2. Sand off the rest.
3. Brighten all wood when done.
4. Stain with TWP 100 Series or Armstrong Clark.
What should you brighten it with?
Try Restore A Deck Stripper and Brightener Kits.
Hello- Looking for an appropriate deck stain for:
Deck Location State: California (Auburn)
Full Sun, Partial Shade, Full Shade: Partial Shade to full sun in late afternoon
Wood Type: Heart Redwood
Reason for Previous Stain Failure: Peeled and lost its water resistance and rich oil color within a couple months
Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): Behr Penetrating oil wood finish Transparent Clear
Looking for clear coat, oil based recommendation.
Armstrong Clark or TWP 1500 series. Make sure to remove the Behr fully first.
Hi there,
I’m getting ready to help a friend stain his deck. The previous stain was applied 3 years ago. I asked the homeowner what kind/brand was used and he didn’t know. The previous stain was applied on a hot day and quickly started flaking off. I’m not even sure if it was an oil/water based product but on inspection the previous stain didn’t seem penetrate the deck boards, possibly a water based stain? The deck is a well aged pressure treated pine deck. The location of the deck is in Maryland and the deck receives sun all throughout the day. I plan on stripping and power washing the old product off as best as possible with the help of a stain remover/ conditioner. What products do you recommend for stain remover, wood brightener and stain? Should I go with oil or water based product? The homeowner said he wants a semi-transparent stain in the lighter brown tones.
I appreciate your help with the job ahead of me. BTW I see some good reviews of Restore-a-deck are they that good, I know of Defy products and TWP seems good too. Also i need recommendations for stripper and whatever products to ready the wood. Its all confusing for me and I could use some insight.
Thanks for you time!
Try the Restore A Deck Products for prep. You may need to sand some as well to get it all off. For a lighter brown, look at Natural Oak in Armstrong Clark. The other brands have colors that are more dark brown.
Full and hot AM-Early afternoon sun
Wood type: unknown, but I’m guesisng cedar
Some mild mildew on rails
No previous stain, deck is a year old.
Thanks for recommendation!
Hello, for the prep, clean and brighten the wood. As for the stain, try the Armstrong Clark or Restore A Deck Wood Stain.
We applied Armstrong Clark Semi-Solid Sequoia stain in June 2016 on the deck over 1,000 sq. We prepared our old deck by sending, power washing, and let it dry for several days. Than we applied only one coat of the stain. The deck is on the South side and we live in Michigan. Since beginning stain was coming off, sun or rain, so when we come inside it was all over white tile dark foot prints. We contacted Armstrong, they recommended to apply over Natural Tone Armstrong stain, which we did in the summer 2017. No improvement. Any recommendations would be appreciated. Do we need to remove (strip/dissolve) the existing stain? if yes, what product to use? Do we need to send it again? Would you recommend water based semi-solid or solid stain or pain? Thank you for all recommendations.
Sorry to hear about the issue. Sanding was most likely the issue. We rarely if ever suggest sanding as the prep as it reduces the stain’s ability to soak deep into the wood. You always want the wood as porous as possible.
At this point, it would be best to start over. The Restore a Deck Stripper/Brightener kit with pressure washing will remove it down to the bare wood.
For the new stain, try a semi-transparent water-based stain like the Restore A Deck Wood stain or Defy Extreme. If you want a solid color stain, try Flood Solid Stains.
There are no decent “semi-solid” water-based stains that we know of.
Thanks for the answer, our deck is pretty old, because we were considering using solid stain to cover it.
Hi there! I have a relatively new cedar wood deck. It was built in October 2016 and stained with a clear penofin last spring (2017). The deck seemed to be sticky even after a few weeks and having gone through a winter, now looks very dirty. I plan to have it power washed, but am thinking it will need another coat of stain to protect it, but not sure what to use and/or if it will need the previous stain removed. Appreciate any advice. Here are the responses to the 6 questions:
1.Deck Location State: Illinois
2.Full Sun, Partial Shade, Full Shade: Partial Shade
3.Wood Type: Cedar
4.Mold or Mildew Issues: Not currently
5.Reason for Previous Stain Failure: Sticky and seems very dirty
6.Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): Penofin (clear, from Sherwin Williams)
Penofin turns black or dark brown after 6-12 months. One reason we do no tlike it. Prep with the Restore-A-Deck Stripper/Brightener kit so all of the Penofin is removed. It has to come off. For the the new stain, try the TWP 1500 or the Restore-A-Deck Wood Stain.
A very helpful website you have! Looking for a stain that balances protecting wood from elements while allowing the natural beauty of wood to be seen.
To answer the six questions:
Sun/Shade: Full sun in summer and full shade in winter along with snow/rain on deck for several weeks
Wood Type: Red Cedar (6 years old)
Mold/Mildew Issues: Mild
Reason for previous stain failure: Water base product at the time the VOC laws were coming into effect and
oil base was not available. Stain peeling every year
Previous Stain Brand/Type: Sikkens (newly created d/t VOC laws) transparent water based. They have
since got rid of this product
We will have our deck sanded down to new wood, will use a wood cleaner, do a light pressure wash, apply a wood brightener, and then stain last.
What do you suggest for a stain?!! Complication is, what is available in Canada!
Liz
For Canada, use the TWP 200 Series or Armstrong Clark.
Deck Location State: California mountains, near Yosemite
Full Sun, Partial Shade, Full Shade: Varies time of year, but about 50/50 shade/sun
Wood Type: Redwood
Mold or Mildew Issues: Not sure, but probably not
Previous Coating? Brand new deck. Really want to preserve the natural color and want to stain as soon as practical
Thanx!
See this about new decks: https://www.deckstainhelp.com/staining-a-new-deck/
Thanks for all your help (and the great information and advice. ). Very worthwhile and informative.
You are welcome!
How does Penofin semi transparent redwood waterproof stain compare with TWP 100 and Armstrong Clark ratings?
Penofin has issues with turning black or dark in color. Lots of bad feedback: https://www.deckstainhelp.com/penofin-ultra-red-label-wood-stain-review-2014/
Thanks you guys. Great info.
So last questions if I may. Can I order the TWP from your group. Thought I saw that your a dealer too.
Also I have about a 700sf deck. Would 5 gallons suffice or? Would you recommend 2 coats for initial application? ( older deck with some new boards).
And do you recommend using the brightener before we apply the stain ? ( we’ve already prepped it chemical stripper, pressure wash and sanding).
We do not sell from this site or promote any one sales channel. Best to check with the manufacturer on how or where to purchase.
You will need two coats applied wet on wet. About 6-7 gallons for the two coats and 700 sq. feet. Yes on the brightener.
I live in New England and have a wrap around covered porch with pressure treated pine. We have cold winters and hot/humid summers.
Questions:
1. Would the Restore a Deck product work well for the weather in my area or are TWP or Armstrong Clark products better?
2. Would you still recommend brightening the wood even though it’s fairly new?
3. This might be a stupid question, but the product information stamps on the wood from the lumber yard should be sanded off prior to staining, correct?
1. Any of those brands would work well and would be easy to maintain every 2-3 years or as needed.
2. You have to clean and brighten for the prep. See this about new wood: https://www.deckstainhelp.com/staining-a-new-deck/
3. See this about stamps: https://www.deckstainhelp.com/how-to-remove-the-ink-stamps-from-new-decking/
Look at the Restore Class Action Lawsuits on Restore before you purchase. I had my deck done in Restore and not only did it rot my wood it would get so hot you had to wear shoes on the deck. I had to tear the deck down and I am included in this lawsuit.
Restore A Deck Products are not the same as Rustoleum Deck Restore.
My contractor is recommending that we put a sealer on the deck before staining. ( he’s from another country and it might be a language/ semantics thing). Could he mean the prep/brightener step many recommend. I’m under the impression that oil based stains are both a sealer and stain in one. Is that correct?
Also any idea where I’d get TWP stain around the Seattle area?
I was going to go with Ready Seal but having concerns on your comments about sealing issue and paraffin base. I know your not keen on Ready Seal because of this issue and UV. My deck is filtered morning sun and mostly partial afternoon shade.. also I’m going with a rustic or redwood color not a lighter stain.
(Up here in the NW I’m much more concerned about moisture). I do know Ready Seal, soaks into the wood perhaps more than any other stain.. would that be a consideration or a seal on top like TWP be better for this environment?
A specialty pain store, that carries 4-5 different stains including Calbot said this product was ‘head and tails’ better than any of them and he’d done his deck last summer with great results. Thoughts??
Deck Stains are sealers. You cannot seal the wood before applying a deck stain. The sealer will repel the stain, creating issues. You also cannot seal on top of a deck stain.
TWP is a penetrating stain like Ready Seal but it actually cures and seals the wood while the Ready Seal does not. Do you know what Avon Skin So Soft Mosquito Repellent is? It is basically the same paraffin oil as Ready Seal, the Ready Seal just has some tint added.
1. Deck Location State: Charlotte, NC
2. Shade in the AM, Full sun in the afternoon
3. Pressure treated
4. No Mold or Mildew Issues
5. The reason for Previous Stain Failure: Dogs. We have two dogs, including a 100lb+ German shephard who is hard on everything. They’ve scratched the paint down to the wood.
6. Previous Coating – Paint
I’m looking to remove the paint, clean the deck and refinish with a better stain. What is your recommendation for a stain that will hold up for a reasonable time against large dogs?
Only way to remove a paint is to power sand it all off. Once fully sanded, finish the prep with a deck cleaner and a wood brightener. Penetrating stains are the best for wear. Try one of these: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
Deck Location State: Upstate New York
Full Sun
Wood Type: Cumaru (similar to IPE but not as hard) and new “Philippine mahogany” (meranti) on the smaller hot tub surround (I was too lazy to have more Cumaru shipped).
Mold or Mildew Issues: Yes, the primary concern with the Cumaru.
Reason for Previous Stain Failure: some blackening due to mildewing
Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): Messmer’s UV PLus.
Cumaru installed in 2012 and new lower meranti deck in the background is from last year and will be refinished also to match. Cumaru has been cleaned most years and re-oiled. Last year cleaned with Thompson’s cleaner with percarbonate. Will use your recommended brands this year and use a brightener.
Thanks for your advice.
Hello, you need to remove this and that will take a stain stripper and pressure washing. Brighten after to neutralize. Stain with Armstrong Clark in one of their 3 hardwood colors or possibly the Restore A Deck Wood Stain. We have had good test results with the RAD Stain on IPE which is similar to Cumaru.
I was staining my cedar pergola and got the stain splatters on my concrete patio–how to I remove the stain from the concrete?
Not easy and sometimes impossible to remove from concrete. How depends on the brand and type of stain that was used?
It is Super Deck, oil base
Try a graffiti remover cleaner from the local paint store and a stiff scrubbing brush.
Do you recommend Baker’s Gray Away Wood seal? I have never heard of it before.
We have tested it and we did not like it. It is a thinned version of TWP
I have a semi in ground pool made out of red cedar, the semi transparent sealer stain that I used is pealing off. What would be the best product? Exposure to 100% sun and pool water chlorine.
Make sure to remove the current stain first and then try the Defy Extreme or Armstrong Clark wood stains.
Deck in Northen New Jersey
Deck faces east, gets full late morning to early evening
Over the year has received a lot of rainfall and good amount of snow fall (very wet at times)
Pressure Treated wood, 1 year old
Was stained initially with Defy Semi-transparent stain
Stain is starting to lighten in color, and fade
Looking to remove current remaining stain, and use an oil-based semi transparent stain this time around.
Can you give me a recommendation of the stain, along with a stripper/brightner that would specifically work in removing the Defy stain?
Thank You,
Amado
Use Restore A Deck Stripper/Brightener kit for prep. For the stain, TWP 1500 Series or Armstrong Clark.
I live in the Seattle Wa area. Deck is older but actually is in good condition. Just replaced about 7-8 boards, and stripped and sanded off the absolutely terrible rustoleum 10x product.
Any advice is much appreciated.
Use a penetrating semi-transparent stain so you do not have any issues with peeling. Any of these will work: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
Deck location state: Florida (north FL)
Partial Shade
Wood Type: pressure treated pine
Mold or Mildew: Yes
We live in a 2 story house. The upper level has a screened-in deck area (enclosed on 3 sides by the house – the side overlooking the back yard is screened — it is very protected from the elements and the wood is in good shape –built in 2000). We are removing the screen and extending the deck 18 feet. We are also redoing the stairs. We are exploring 2 options regarding the addition: 1) build out from the existing deck or 2) build over the existing deck so all wood is new and eliminate any transition from old to new. In addition to staining questions, do you have any thoughts on these 2 construction options? What deck stain would you recommend in either scenario? Do you recommend a semi-transparent, semi-solid, or solid? We will not be doing the staining ourselves and will most likely hire someone in the future to keep the deck in top shape.
Best to make it all new. It will look better. See this about new wood: https://www.deckstainhelp.com/staining-a-new-deck/
Use a semi-transparent.
I am staining a deck with a new level and an old level. My questions are:
1- should I stain the newly stripped and sanded old section now or wait to stain it a few months until I stain the new section?
2- Will a darker stain be best choice to match the old and new sections as closely as possible?
– Thanks!
Wait for a few months and prep: https://www.deckstainhelp.com/staining-a-new-deck/
A semi-solid color will cover better. Try the Armstrong Clark.
I live in Pueblo CO. I have a fence, my guess is cedar. The fence is old for the most part with some new replacement wood. Has been stained with different products in the past by previous owners and I will only be treating one side of the fence. What would be your suggestion?
Try the Restore-A-Deck Stripper/Brightener Kit for the prep.
Stain with Armstrong Clark or TWP stains.
Deck Location State: NC
Partial shade
Mold or Mildew: Yes
Reason for Previous Stain Failure: Unsure that it was ever stained. Moved into the house in 2016 and deck was already weathered and gray.
Previous Stain: Uncertain that there was ever stain on it. Best guess, it’s been several years since any kind of maintenance was done. I’ve recently replaced split, chipped, sapping boards.
Prep with a deck cleaner followed by a wood brightener. Stain with TWP 1500 or Defy Extreme Stains.
What can I use on a 1st generation trex composite deck. ?
How does the oil based products from Sherwin Williams compare? They are having a 40% off sale later this month and that could be a good savings. But I live in high humidity and the deck gets Lots of hot sun.
The SW oil based is just the Super Deck. Not fans: https://www.deckstainhelp.com/sherwin-williams-superdeck-stain-review-2017/
Deck in cincinnati, ohio
Deck faces West and gets full sun in the afternoon
Pressure treated wood
No previous stain as less than a year old.
We are looking for a semitransparent or semi solid stain. What do you recommend?
Armstrong Clark or the Restore-A-Deck Wood Stain. Make sure to prep first with a deck cleaner and a wood brightener.
i have a new deck on a fresh water pond in the Gulf Coast of Texas. what would you recommend as a deck treatment? i would like a colored treatment that lasts a very long time. thank you
Brenda, see this about new wood: https://www.deckstainhelp.com/staining-a-new-deck/
I built a redwood fence around my pool equipment , so it’s not very large. It’s about a month old. I can wait a few months to stain it, if recommended.
Deck Location State: Southern California, 3 miles from the beach
Full Sun, Partial Shade, Full Shade: Full Sun south side, partial sun west side.
Wood Type: Smooth redwood
Mold or Mildew Issues: Maybe, sprinklers hit a part of it
Reason for Previous Stain Failure: No previous stain
Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): No previous stain
I want a medium brown shade, definitely not orange. Your help is greatly appreciated. Your site is extremely informative. Thank you
Try Rustic Brown by Armstrong Clark or Dark Walnut by Restore-A-Deck Wood Stain. Clean and brighten lightly for prep.
I have a deck that was installed in June 2017. To answer your questions from above:
Deck location- Pennsylvania
Full Sun
Mold/Mildew is very minor
For #5 and #6- never been stained.
I’m wondering what stain brand you recommend and it also looks like I should clean the wood first with a wood cleaner and wood brightener, correct?
Yes on the prep. Try the Armstrong Clark or the Restore A Deck Wood Stains.
Thanks. I think I will go with Restore products. And a few more questions:
Are you supposed to clean the spindles too? And when applying the deck cleaner, is it necessary to rinse off with a power washer or can I rinse off with a garden hose?
Maue sure you are using the Restore-A-Deck Wood Stain and not Restore products by Rustoleum. Yes you have to clean and brighten all. Pressure washing is the best and easiest way.
Welcome!
I just wanted to add something. My deck gets full sun exposure from around noon on and it gets really hot. (A lot of reflecting off the aluminum siding and windows really heats it up). Anyway, as far as the two types of stain you recommended, would the water based Restore a Deck or oil based Armstrong Clark be better in such a hot sun? Thanks again.
Same. No difference.
Great, thanks again.
I’m working on a new fence 6 foot tall cedar 300 feet long I will house my llamas in. From what I have read I should wait a few months to add any stains correct? I was thinking I would go with the TWP 1500 series cedartone but would like to know if I am on the right track. Any pre-prep work needed for new cedar fence?
Fence Location State: Idaho 2300 feet elevation dry climate.
Full Sun, Partial Shade, Full Shade: Full sun on the rough cut side, partial shade on the smooth side
Wood Type:Cedar
Mold or Mildew Issues: Unknown
Reason for Previous Stain Failure: New install
Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): None
Thanks for a great web site 🙂
Staining now or in a few months depends if the wood on the fence is smooth or rough sawn cut? See this for more info: https://www.deckstainhelp.com/staining-a-new-deck/
We replaced the floorboards and spindles last year with pressure treated pine and used Olympic elite woodland oil in kona brown. The spindles look ok but the floor is fading and I think the color is too red. Do I have to strip, wash, and sand? And can I only do the floor and not spindles? What stain and color would be good for a little more brown rather than red? I do like the wood grain look but I’m guessing I’d have to go darker…? Thanks for any advice! I am in MA with snow and deck has sun until about 2pm..no mildew
Yes if switching brands you need to strip all. After removal, try the Armstrong Clark in Rustic Brown or the TWP 1503 Dark Oak.
will above recommend brands work on old style composite decks
Sorry but no, I do not think they work on composite decking.
I replaced the deck boards on a ground level deck with pressure treated pine 18 months ago. Was not able to stain last fall due to high moisture content in deck boards. Location is heavily wooded lot in NE Wisconsin close to Lake Michigan. Deck wraps around house on N E and W sides. Lot is moderately wooded and N and E get no direct sun light, south side gets about 3 hours direct sunlight/day. Already noticed some mold/ mildew on north side this spring. Looking for staining / preservation recommendations
Try TWP 100 Series or the Defy Extreme Wood Stains. Both do very well in your climate and with mildew potential.
My deck is about 2 yrs. old and never stained. The questions you ask for the type of stain pertaining to living area is as follows:
Location is: Texas, a lot of rainfall recently, mostly Full sun
Wood used: Treated, No mold/mildew yet
Previously stain: None
Would like to get an excellent stain to preserve and last for years on such an expense to my mobile home. Looking for expert advice, please.
Hello, for the prep, use a deck cleaner and a wood brightener. For the stain, try the Armstrong Clark or the Restore A Deck Wood Stain.
We have a cedar fence that is relatively new ( under a year old) in Houston, Texas. It was stained but not sealed so unfortunately after all the rain and hurricane Harvey, it immediately started to grey and darken where water was ( we did not flood) We want to clean it and start all over to properly seal with semi transparent stain… considering our climate and the 6 recommendation, which would be the best to go with and stick with for years to come? Thank you for any help
Amy
TWP 100 Series or the Restore A Deck Wood Stain.
Deck Location State: Massachusetts
Wood Type: Mahogany (deck is 5 years old)
Reason for Previous Stain Failure: UV/rain/general wear
Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): Cabot Australian timber oil
Strip and brighten the wood for prep. Stain with Armstrong Clark in one of their 3 colors for hardwoods: Mahogany, Amber, Black Walnut.
Fence Location State: NW Georgia
Full Sun
Mold or Mildew Issues: None yet.
Fence is only 6 months old.
I used TWP 100 before on a porch but I hate to spend $700+ on stain and cleaner for this one. The fence is around 2400 sq feet counting both sides. I have family at Ace Hardware and can get deals on Flood or Cabot brand products.
What stain should I go with?
TWP. You get what you pay for.
