🏆 Top Deck Stain Picks Summary
- Best Overall: TWP 100 or 1500 Series
- Best for Old Decks: Armstrong Clark
- Best Budget Option: Restore-A-Deck
- Best Penetrating Oil: CUTEK Extreme
| Product | Type | Durability | Ease of Maintenance | Key Strength | Best For |
| TWP 100 | Semi-Transparent (Oil) | 2–3 Years | Easy | Proven performance, deep penetration | Most decks |
| TWP 1500 | Semi-Transparent (Oil, Low VOC) | 2–3 Years | Easy | Better VOC compliance, similar performance to TWP 100 | VOC-restricted states |
| Armstrong Clark Wood Stain | Semi-Transparent (Oil) | 2–3 Years | Easy | Excellent oil penetration + conditioning oils | Dry, aging wood |
| Restore-A-Deck Wood Stain | Semi-Transparent (Water-Based) | 2–3 Years | Very Easy | Simple prep system + easy recoat | DIY homeowners |
| CUTEK Extreme | Penetrating Oil | 2 Years | Very Easy | Deepest penetration, no film buildup | All Wood types |
| Defy Extreme | Semi-Transparent (Water-Based) | 1–3 Years | Moderate | Strong UV resistance with zinc nano-particles | Sunny/high UV areas |
- Best Overall Deck Stain: TWP 100 Pro Series — A deep-penetrating, oil-based semi-transparent stain that offers excellent durability, easy maintenance, and consistent performance for up to 3 years.
- Best Semi-Transparent (Water-Based): Restore-A-Deck Semi-Transparent Wood Stain — A user-friendly, UV-resistant stain that can be applied to damp wood, allowing prep and staining in one day.
- Best Oil-Based Alternative: Armstrong Clark Wood Stain — A penetrating oil formula that conditions aging wood while providing long-lasting protection and easy reapplication.
- Best for VOC-Restricted States: TWP 1500 Series — An EPA-registered preservative with strong UV and mildew resistance, ideal where traditional oil-based stains are limited.
- Best for UV & Mildew Resistance: Defy Extreme Wood Stain — A water-based formula enhanced with zinc nano-particles for superior UV protection and mildew resistance.
- Best Semi-Solid Stain: TWP Pro Series Semi-Solid — Offers richer color, excellent UV blocking, and better coverage while still allowing some wood grain visibility.
- Best Solid Color Stain: Restore-A-Deck Solid Color Stain — A durable, breathable coating that resists peeling and works well for older or heavily weathered decks.
- Best Deck Resurfacer: Gulf Synthetics Deck Revive — A thick resurfacing coating designed to restore heavily worn or damaged wood surfaces.
*Free Shipping Included
✅ How I Rate Deck Stains
- Durability in real-world conditions
- Ease of application and maintenance
- Resistance to peeling and wear
- Overall long-term performance
- Wear and tear after 2 years
- Oil-Based:
- Deep penetration
- Easier maintenance
- Water-Based:
- Better UV color retention
- Faster drying
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
3. Defy Extreme Stain
Type: Oil-Based Semi-Transparent- Durability: 2–3 Years
- Maintenance: Easy recoat, no stripping needed
- Best For: Most decks (pressure-treated, cedar)
- Why It Stands Out: Deep penetration and consistent long-term performance without peeling
My Test Deck Stats
Deck Square Footage: 2100
Consumer Star Ratings:
- Type: Water-Based Semi-Transparent
- Maintenance: Very easy, simple prep system
- Best For: DIY homeowners and quick projects
- Why It Stands Out: Can be applied to damp wood, allowing prep and stain in one day
My Test Deck Stats
UV Exposure: 50% Full Sun
- Type: Oil-Based Semi-Transparent
- Maintenance: Easy reapplication
- Best For: Older, dry, or weathered wood
- Why It Stands Out: Contains conditioning oils that help restore dried-out wood
My Test Deck Stats
Deck Square Footage: 600
- Type: Semi-Solid (Oil-Based)
- Durability: 3 Years
- Maintenance: Moderate
- Best For: More color coverage with strong UV protection
- Why It Stands Out: Rich color options while still allowing some wood grain to show
My Test Deck Stats
When Tested: August 2023
Deck Square Footage: 800
UV Exposure: Deck in full sun
- Type: Oil-Based Semi-Transparent (Low VOC)
- Maintenance: Easy
- Best For: VOC-restricted states
- Why It Stands Out: EPA-registered preservative with strong UV and mildew resistance
My Test Deck Stats
Deck Wood Type: Cedar
Deck Square Footage: 400
- Type: Water-Based Transparent
- Durability: 1.5–2.5 Years
- Maintenance: Easy
- Best For: Maintaining a natural, “bare wood” appearance
- Why It Stands Out: Unique formula designed to preserve the natural color of new wood while still offering UV protection
My Test Deck Stats
Stain Color Used: Chesnut
- Durability: 2 Years
- Best For: High UV and mildew-prone areas
- Why It Stands Out: Zinc nano-particles provide superior UV protection and mold resistance
My Test Deck Stats
Stain Color Used: Cedartone
- Durability: 1-2 Years
- Best For: DIY users and quick, forgiving applications
- Why It Stands Out: Extremely easy to apply with no back-brushing needed, but shorter lifespan than higher-end penetrating stains
My Test Deck Stats
- Type: Penetrating Oil
- Maintenance: Very easy (clean and reapply)
- Best For: Exotic hardwoods (Ipe, teak) all wood types
- Why It Stands Out: Extreme penetration with no film buildup, making long-term maintenance simple
Scott’s Pro Tips: Although CUTEK® Extreme is more expensive than many penetrating oils, the performance was very solid. There was no peeling or significant wear, and the coating should be easy to maintain, as it fades naturally and can be refreshed without stripping.
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Stain Color Used: Walnut
Semi-Solid Deck Stain Review
- Consumer Star Ratings:
Best Deck Stain for Old Wood
- For new pressure-treated wood, wait until the wood has weathered and is able to absorb stain (typically a few months), then prep and stain.
- For older pressure-treated decks, proper cleaning and brightening will restore the wood and allow for better stain penetration.
- If you want to maintain cedar’s natural look, use a lighter or natural-tone stain.
- If you want longer UV protection, choose a slightly darker tint, as it will hold color longer.
- Wood Condition: New, weathered, or heavily worn
- Desired Look: Natural grain showing vs solid color
- Maintenance Preference: Easy recoat vs long coverage
- Climate: Sun exposure, moisture, temperature swings
✅ Deck Stain Types Explained
- Transparent/Clear Sealers: Natural look, less protection
- Semi-Transparent Stains: Best balance (most recommended)
- Semi-Solid Stains: More color, moderate maintenance
- Solid Color Stains: Maximum coverage, higher maintenance
Transparent Stains
Solid (opaque) Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
- Film-forming coatings on older decks
- Over-applying stain
- Choosing based on color alone
- Skipping prep
- Not preparing your deck: Failing to clean your deck or remove old, flaking, or peeling stain from your boards can prevent a fresh coat of stain from adhering properly. See my Deck Cleaning Guide for best results!
- Over-applying stain: You may think more stain equals more protection from moisture, mildew, and sun damage, but that’s not always the case. Too much stain can prevent the product from penetrating your deck boards. As a result, it may form a film on top of the wood that peels or flakes off over time. See my How to Stain a Deck tips for the best results.
✅ Best Deck Stain FAQs
Quick Tip:
What is a deck stain?
⏳ Durability & Maintenance
🎨 Appearance & Color
🛠 Application & Usage
🆕 New Deck Questions
- Smooth wood: Wait ~3 months
- Rough wood: Can stain once clean and dry
- Kiln-dried wood: Wait 1–2 months
- Deck Location: Michigan
- Wood Type: Cedar
- Mold/Mildew?No
Would love your recommendation
We live in Iowa
Full Sun
Kumaroo
No mold or mildew
Doesn’t last a full season
Wolman E.H.T.
Hi Mary, start by removing the Wolmans EHT. Once removed try the Defy Hardwood Stain or Restore A Deck Wood Stain. Your wood type (Cumaru) requires an annual application.
We bought a home with cedar deck built in July 2016. Not sure on the stain the old home owner use, it is pretty light and is needing staining this summer.
1) Deck location: Colorado Springs, CO (6,800 ft. elevation)
2) Full sun
3) Wood type: Cedar
4) Mold or Mildew Issues: None
5) Reason for previous stain failure: Just fading away, not grey yet
6) Previous stain Brand & Type of Stain: Not sure, old owner, but sure it was built in June/July 2016
Would you please email with a suggestion for the best stain possible.
Thx.
Prep by stripping and brightening to remove the current stain. For the new stain, use TWP 100 Series or Armstrong Clark.
best deck stain for: Deck location State: Upstate New York;
Full shade in the morning, full sun in afternoon;
Wood type: pressure treated (not sure of wood, just know it’s pressure treated – nothing fancy)
Mold and mildew issues;
Previous stain did not fail, just ten + years old and needs to be redone;
Previous stain was Cabot; semi-transparent on deck, opaque on spindles and rails.
Also, what is the best way to get the old stain off the spindles. I have started pressure washing just to see how easy deck will clean up. Old stain is coming off well on deck, but the stain on the spindles is not stripping off well with the power washer alone. Will a stripper work well on the spindles as well as the deck. I would like to use a penetrating stain so when it comes time to do the deck again, the job will be somewhat easier to do. I like the look of the Armstrong stain in Rustin Brown in the picture posted on your site. Any suggestions along those lines.
Thanks for your help
The only way to get the opaque stain off the spindles is to power sand. You can use the stripper on the flooring to remove the semi-transparent. The Armstrong Clark would work well for this.
I need some advise. Our ceiling of our covered outdoor area is cedar. We noticed it was turning black in many areas. We assumed this was mold and cleaned it with two different cleaners. One cleaner started turning some of the wood white. The other cleaner did not bother the stain and did remove a lot of the black mold or mildew. There is still some we just used a water hose to remove cleaner and did not pressure wash. What should be our next steps to complete the job? We were told to use a water acrylic base stain to keep the mold away. Do not know if this is true. What products should we use.
Is it evenly cleaned now and did you remove all of the previous coating? You will need to remove the current coating if switching brands. Once prepped correctly, use Restore A Deck Wood Stain or Defy Extreme for this.
Im not sure if all the previous coating is gone. I was planning on sanding it with a palm sander but it won’t get the joint of the tong and groove is there something I can use that would make this easier. We are in central Alabama where the humidity is high in the summer and no direct sunlight hits the ceiling. The last product we used was a oil based stain and sealant and that was a couple of years ago. Last weekend I cleaned it with a water, bleach and Jo Max house mold and mildew cleaner. When I rinsed it off and it dried it left white places on the wood. I understand that oil based products will feed the mold and water based products will peel. How can I fix this mess and keep the mold off of it.
Strip and brighten all for the prep to make sure you have all the stain removed and it is even in color. Not all water based stains peel. The Defy Extreme and RAD stain are penetrating coatings so they are not prone to peeling.
strip the wood with a sander and then brighten with what product? I know I am asking for detail but I want to be sure I do this right.
Strip with a stain stripper. Use Restore A Deck Stripper/Brightener Kits.
Do we need to just stain or do we need a sealant also?
Deck stains are sealers as well. You also cannot apply a sealer over a deck stain.
1. Deck Location State: Minnesota
2. Full Sun, Partial Shade, Full Shade: Full Sun until late in the day during summer.
3. Wood Type: Cedar
4. Mold or Mildew Issues: some spots on old rail posts
5. The reason for Previous Stain Failure: Peeled after first Winter.
6. Previous Coating? If so brand name and type of stain (Transparent, Semi-transparent, Semi-solid, Solid Stain): Sikkens Cetol SRD translucent wood finish
Previous attempt 5 years ago, sanded horizontal surfaces to bare wood and applied one coat per manufactures instructions. Pealed after first winter.
The deck surrounds a salt water pool.
I plan to use wood stain remover on the railings and sand the horizontal surfaces again. Then clean with a deck cleaning product.
What type of stain would you suggest?
Strip all and brighten after. Do not sand. Sanding reduces the ability for a stain to soak in and could lead to peeling issue. Stain with Armstrong Clark or TWP 100 Series.
Deck location, western WA -Seattle. Partial sum, not cedar, toms of rain, pollen, turns green after so much rain. Deck is ok, older and multiple varieties of water based stains used over the years, so uneven stain. We want a red cedar color. Semitransparent didnt look very good when we used it two years ago.
Do you want a solid color stain?
Usually I wouldn’t like, but I think there has been some on there before – or maybe it was maybe semi solid. Does solid look just like paint?
Solid looks like a paint. If you want to use a penetrating semi-transparent, you will need to remove all of the current stain done to the bare wood. This will require stripping and most likely sanding to get all of the old layers off.
We power washed – sounces like solid is best then. Will it penetrate? I don’t want peeling:) can you recommend a red cedar color? Also our rails look ok. I don’t want solid on them. OleaE recommend products and thanks
For solid stains, we like the Flood brand. Comes in any color you like.
I would love your direction:
Vermont
Part Sun/Shade, Strong Lake Winds/Snow/Ice
No mode or mildew issues
Primarily Tigerwood, IPE outline
2 years old, mild use
Cleaned and Treated IPE oil at install and annually last year.
Greys within a couple months.
Any product or new approach recommendations???
Defy Hardwood Stain or the Restore A Deck Wood Stain. Here is a picture of IPE test deck that was done 7 months ago with the RAD Stain in Light Walnut. Still holding color.
Replaced deck floor and railing with pressure treated pine. We have an existing pergola we would like to stain also.
1. Deck Location State: Chesapeake, Virginia
2. Full Sun, Partial Shade, Full Shade: Full Sun past noon (west side of house)
3. Wood Type: Pine
4. Mold or Mildew Issues: No
5. Reason for Previous Stain Failure: New installation
6. Previous Stain Brand and Type of stain: None on floor, unknown on pergola
Hi Jon, see this about new wood: https://www.deckstainhelp.com/staining-a-new-deck/
Can you help me choose a stain or sealer?
Our deck is only a year old but the boards are starting to splinter up and loose natural color
Deck Location State: Southern Arizona
Full Sun, Partial Shade, Full Shade: Full Sun and partial shade
Wood Type: Redwood
Reason for Previous Stain Failure: Sun exposure is killing our wood
Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): Sealed with Thompson’s
We would suggest the Armstrong Clark in a semi-solid color for this deck. It wil help with the sun damage. Clean and brighten for the prep.
Thank you I’ve been going back and forth between what brand to get and Armstrong was one of my picks!
One more quick question…What semi solid color would look best to you on this deck? Our house is dark grey I tend to like the Oxford brown or Sequoia…any advice there?
Either would look good!
1. Deck Location State: Central Wisconsin
2. Exposure: Full Sun throughout the day
3. Wood Type: Pine, Above Ground AC2® Green Pressure Treated Thick Deck
4. Mold or Mildew Issues: No. May see some snow during winter months, but plan on shoveling off during
heavy snowfalls >2″
5. Reason for previous failure: None, New construction with wood stickered and air dried with tarp on top
for 6 months
6. Previous coating: None
Looking for a cedar tone semi transparent or semi solid that stains and seals in one if we can. We are open to sealing separately if needed and it would improve longevity and reliability. Have two large breed dogs and two 4 year olds with traffic in certain areas daily in warm months.
Would prefer to see wood grain, but want this look if possible.
The picture is of Defy Extreme Cedartone. You will need to weather this wood and prep before applying. See here for tips: https://www.deckstainhelp.com/staining-a-new-deck/
Hi there. I did notice that watermark when I grabbed the pic from the net. However, I just was wondering if there are additional products that might give the same effect and work better per say. Just curious. I’m not beholden to the Defy, but if you would have recommended something different I would certainly appreciate the feedback. Thanks.
TWP 101 Cedartone or Armstrong Clark in semi-cedar would work as well.
Are these all paraffin based by chance, as opposed to the Defy being water based? I’m a bit hesitant to go with a water based product, so that would be helpful as well.
Secondly, the wood has been stickered and allowed to weather and dry for 7 months or so…so not sure that step is needed unless you insist upon so. I could see cleaning it up, but it’s been sitting long enough and is quite dry and remarkably clean, as a tarp was put on top when I originally stickered it.
No, they are not paraffin based but they are oil based. Has to weather outside after install. This is not the same as “drying”. Sitting under a tarp will not work.
Any comments on Wolman F&P Cedar tone???? I’ve read some good reviews on it, but would like your opinion. This is not the same model stuff as your review on this site for the DuraStain (water-based), as it’s a different product.
Average product now. Used to be a good product years ago before they changed formulas.
How about PPG Proluxe SRD or DEK stain? I think PPG bought the Sikkens formula recently, but wondering if you have any experience with either one. Any comments or input is appreciated.
That is Sikkens, relabeled: https://www.deckstainhelp.com/sikkens-srd-wood-stain-review/
1. Holden, MA
2.Full sun
3.pressure treated pine
4. No
5.Just replaced all floor boards last fall. Uprights are painted with the reddish brown stain and will be redone to match floor.
6. not sure
Try TWP 1500 or Armstrong Clark. The verticals with the old stain will need to be stripped or sanded to the bare wood.
Need a stain recomendation
Location State: Fence in Houston, TX
Full Sun, Partial Shade, Full Shade: Mixed but mostly partial shade
Wood Type: Vertical cedar pickets on treated pine posts
Mold or Mildew Issues: Yes in the shaded areas
Previous Coating? None, new fence, installing now
Rough sawn wood or smooth? Makes a difference as to when you can stain. Now or in 3-6 months.
The cedar pickets are rough. The pine is smooth.
You will need to wait 3-6 months for natural weathering and then prep with a cleaner and wood brightener before applying the stain.
Thanks. Which one would you recommend given my set of circumstances?
Which stain do you recommend for my application and climate?
Sorry. Try TWP 100 Series or the Armstrong Clark Stains.
Deck Location State: Texas Gulf Coast
Full Sun, Partial Shade, Full Shade: Partial Shade/Full Sun
Reason for Previous Stain Failure: N/A
Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): N/A
Hi Gary, try the Restore-A-Deck wood stain or the Defy Extreme Stains.
good morning–we are installing a new cedar fence in central nh soon –we want a solid dark forest green paint effect so it will simulate the natural evergreen environment we live in–we do not want any grain showing through the application of stain–how long should we wait to apply stain and what stain product will give us the solid effect we want and will last longest? thank you –karen in nh
Is the wood rough sawn or smooth? Use Flood Solid Stains.
Deck Location State: Virginia Beach, Virginia (10 miles from the ocean)
Full Sun all day
Wood Type: Pressure treated
The reason for Previous Stain Failure: No previous stain
We have a dog
We have 3 decks that we have replaced over the past 3 years, all about 4 feet away from our chlorine pool. All different ages the newest completed 2 weeks ago.
We are looking for a semi-transparent stain in the gray family preferably.
Try Driftwood Gray by Armstrong Clark. Make sure to prep properly first.
Coastal Maine
Snow, ice, and summer moisture
Front deck gets moldy partial light and is pressure treated
Back deck is cedar, full sunlight and moss grows under decking.
Hi Judith,
Prep with Restore-A-Deck products and stain with TWP 1500 Series or Defy Extreme Stains.
Accidentally posted my last comment before I was finished!
Some additional clarification:
We are located on the Olympic Peninsula in Washington state.
An additional note about the type of wood: Might also be pine that was stained to look like cedar.
We prefer to be able to see the grain of the wood and don’t want it to look “painted”, however we want to make sure we can preserve the more weathered parts as best we can.
We did try a small sample of Cabot Semi-Solid Deck and Siding stain on a small section of the verticals, per a recommendation from a local paint store and we didn’t like it. It was too opaque for our liking and did not show enough of the grain as we had hoped (also was way darker than the sample in store)
It was also recommended to us to use something like Cabot’s Deck Corrector on the horizontals since the main deck is fairly weathered and to extend the life of our deck. Would like to know your recommendation. I attached additional pictures of the horizontals, one from the deck under the gazebo and also the main deck which is uncovered.
You will need to start by removing the current stain. The issue you will find is that the Gazebo floor is heavily coated and most likely cannot be stripped off. This is what we would do:
1. Strip and pressure wash off as much as possible form all wood.
2. Let dry and then sand where needed to remove the rest. Shoot for 95% or more removal.
3. Appy a wood brightener to all wood after.
4. Let dry and stain with a penetrating wood stain that is semi-transparent: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
Deck Location State: Washington
Full Sun, Partial Shade, Full Shade: Full sun, some shade for a few hours around lunch (there is a large spruce tree that shades it at certain times)
Wood Type: Cedar?
Mold or Mildew Issues: Yes, used Cabot wood cleaner to remove the stains.
The reason for Previous Stain Failure: wear/tear and not reapplied after appropriate time period.
Previous Coating? Yes, previous owners used Ace Wood Royal Deck and Siding Stain Semi-Transparent Oil in a custom color (I am assuming on the verticals) and then Flood CFW-UV Penetrating oil finish for Exterior Wood in Cedar.
We have only cleaned the deck so far and have not removed any previous coatings. We have a gazebo where there is some wearing on the exterior railings, but it’s not horrible and the floor area is in decent shape. The main deck that is uncovered has more wear along with the gazebo over our hot tub. There is also a railing with an arbor/bench that has some decent weathering/wear.
Just erected 8’x10′ Backyard Discovery cedar pergola:
1.Deck Location State: Arizona
2.Full Sun, Partial Shade, Full Shade: Full Sun 1/2 day, Full Shade 1/2 day
3.Wood Type: Chinese cedar
4.Mold or Mildew Issues: No
5.Reason for Previous Stain Failure: installation damage, tool marks, seams, adding more slats
6.Previous Stain Brand and Type of stain: manufacturer’s waterborne translucent latex
Need a stain recommendation, please.
Strip and brighten for the prep. Stain with Restore-A-Deck Wood Stain or Defy Extreme Stains.
Deck Location State: Indiana
Full Sun, Partial Shade, Full Shade: Full Shade heavily wooded area
Reason for Previous Stain Failure: Peeled; age- not sure when it was last stained as house is new to us but built in the 70’s
Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): Solid Stain unsure of brand
Definitely planning on using a solid stain but different color.
Try Flood Solid Stains. Pressure wash for the prep.
Deck location: Kentucky (northern)
Partial shade to full sun from noon to dusk
Pressure treated wood, never treated, 15 months old with some mold and oxidation spots
This will be our first time staining (we just purchased Behr Premium Solid Stain and after reading articles here I am now afraid to use it).
Thanks so much in advance!!
Do you want a painted solid stained look to the deck?
I like the look of both, the color we picked out complements our house nicely but I am most concerned with longevity and everything I’ve been reading is making me think that a solid stain won’t wear as well as a transparent to semi-transparent. One thing I’ve considered is doing a solid stain on the railings and a semi-transparent (like Defy Deck Stain) on the horizontal surfaces. I really don’t want to be in the situation where the solid stain is peeling and then we have to sand the entire surface to remove it. I really appreciate your response and help!
See this for tips on Two Toned Decks: https://www.deckstainhelp.com/advantages-to-having-a-two-toned-deck/
They look great. Use Flood solid stain for the verticals and a penetrating semi-transparent for the flooring. Defy Extreme or Restore A Deck Wood Stains.
We also have two large dogs and 3 kids so the deck will definitely get some wear!
Hello from sunny south Florida, love the site – tons of helpful info.
We have a new deck (11months old) pressure treated pine, appx 750 horizontal SQ FT & 200 SQ FT vertical. Going with a 2 tone flood solid stain color scheme (grey on horizontal, white on verticals). Question #1 do you recommend the flood wood cleaner? (I don’t need a brightener since it will be stained solid I assume) Question #2 I am going to use flood solid stain for the grey horizontal , but I do know what to use for the white horizontals? I have plenty of left over Behr marquee exterior paint in white – will this due for verticals? since the deck is stained solid it will have to be re-done every 2 or so years anyhow I assuming.
Thank you for any advice you can give.
Regards,
Hello, you want a solid color deck stain for both, not an exterior paint. Use the Flood Solid stains. Just use a deck cleaner. No need for the brightener since you are using solid colors for both areas.
deck location state: Oregon
partial shade
Mahogany wood
mold issues: yes
reason for previous stain failure: must stain every year
product used: Sun Frog (oil based product) in mahogany tone
Looking at Defy stain for Hardwoods, but not sure what color of stain for the mahogany deck.
Pls, give me your recommendations.
The Defy Hardwood would a better option for this and less chance of mildew. Use the Light Walnut color.
I unfortunately used Thomposn semi-transparent last season and it didnt make it a full calendar year. I will be stripping the deck and using brightener, but wanted your input on recommended product.
Deck Location State: Ohio, Columbus
partial shade east facing in wooded lot.
Wood Type: unknown, pressure treated
The reason for Previous Stain Failure: peeling and stain is garbage
Previous Coating? Thompsons Semi-transparent
Looks like a film forming solid stain (little to no transparency), not a semi-transparent in the pictures. I highly doubt this can be stripped off fully which means you will have to power sand to remove this. No stain stripper will work to effectively remove this well.
You are correct, the Thompsons is garbage. Fails and is a pain to fix. 😥
What is your recommended stain after removing old stain?
Armstrong Clark or TWP 1500 Series.
Thank you! Also, just an FYI. It is Thompsons Semi-transparent and not a solid. Thompsons refunded all my money, but now i have lots of work to remove their crappy product.
I know but it looks like a solid. Another reason it is a bad product and it peeled. Applies with little to no transparency and dries on top of the wood, hence the peeling.
Deck
Chicago
Morning and evening shade, full sun midday
Pressure treated wood, Penodin semi-transparent applied 6 years ago
Railings show mildew, deck
Trellis over hot tub
Partial sun morning and midday, shaded evening
Pressure treated, Penofin applied 6 years ago
Mildew
Any guidance would be appreciated. Thanks
Hi Eric, prep with a deck stain stripper and pressure washing. Brighten the wood after. Stain with TWP 1500 or Restore A Deck Wood Stains.
Live in San Diego, have a modest 900 sqft, 4 year old redwood deck with a 400 sqft swim spa in the center. Deck was done by a contractor using Home Depot Minwax Spar Urethane, oil-based. Am removing the current finish with 35 then 100 grit paper + an oscillating commercial sander. My problems are lots of heat/sun exposure during the spring-summer-fall, and modest rain/less sun during the winter. What finish would you recommend for this 4 year old deck with a dry surface, previously finished with Helmsman Spar Urethane?
Make sure and remove all of the Urethane and then use a penetrating semi-transparent like the Restore-A-Deck wood stain or the TWP 1500.
Many thanks,….I’m doing the sanding today with my spouse. I was thinking of the TWP 1500 when I noticed that TWP 100 couldn’t be shipped to California (like a thousand other products I could use for my home and yard !). But TWP 1500 is “ok” in San Diego County, according to the company shipping info. Lee Muth
Yes the TWP 1500 is allowed in CA.
1. Indiana
2. Morning shade, full sun rest of day
3. Pressure treated wood
4. No mold or mildew issues
New board installed 11 months ago.
Hello, for the prep, use a deck cleaner and then a wood brightener. Stain with Armstrong Clark or TWP 1500 Series.
“the best deck stains for my deck”?
1. Deck Location: Virginia
2. Full Sun
3. Pine
4. Not much mildew issue
5. Previous coating: 5 yrs ago: Olympic Clear maybe?
This is an easy prep. Use the Restore A Deck Stripper Kits for prep. Stain with TWP 1500 or Restore A Deck Wood Stains.
I have a deck and screened porch that needs to be restrained this year. After reading several things on your site I’m confused as to which stain I should go with and which brand deck stripper to use….Gemini or restore a deck
Deck Location State: NC
Wood Type: Pressure Treated wood
Reason for Previous Stain Failure: Stain wore off in some areas
Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): it’s either Olympic Maximum tinted waterproof sealant or Olympic water repellent deck stain
Thank you in advance for your assistance!
Gemini RAD is a cleaner, not a stain stripper. You need to strip this and it looks fairly thick. This means you may need to strip more than once and you may need to sand some as well. Use the RAD Stripper/Brightener Kit.
Stain with Restore A Deck Wood Stain or TWP 100 Series.
Ok, thank you. One more question will Defy Extreme work in my area?
Yes it should.
l. Washington. Seattle region.
2. Partial shade, some full shade
3. Cedar
4. Yes
5., 6. None. New structure.
Hello, please see this about new wood: https://www.deckstainhelp.com/staining-a-new-deck/
Deck Location State: Illinois – North
Full Sun, Partial Shade, Full Shade: Full Sun in Afternoon through evening – West facing
Wood Type: Unknown, Pine maybe?
The reason for Previous Stain Failure: It only lasts 1 year, then it peels.
Previous Coating? If so brand name and type of stain (Transparent, Semi-transparent, Semi-solid, Solid Stain): Unknown – semi transparent, red color.
Hello, make sure to strip and or sand to remove the current stain that is peeling. Brighten the wood after. For the new stain, try Armstrong Clark or TWP 1500 Series.
If I don’t want to restain, can you suggest a good cleaner? And are brighteners only for non-stained decks?
Brighteners are only for neutralizing a deck cleaner or deck stain stripper. If you clean, you have to stain as well.
I have an older composite deck floor with northern exposure. I have a difficult time removing the mildew. I could not get rid of the mildew stains, so I stained it last year with Defy Deck Stain for Hardwoods (rest of my deck is pressure treated pine. It looks better but the mildew stains are still evident even though I bleached them several times. Can you suggest something that would help? Thanks!
You cannot clean mildew off that is under a deck stain.
What are the best stains for my deck?
State: Indiana
Partial sun, very Partial sun
algae is a problem, very high humidity in summer
Pressure treated pine
Algae returned after 6 months
Used Cabot Clear on it last
Strip and brighten for prep. Stain with Defy Extreme or Restore A Deck Wood Stain.
Full sun in the high dessert of nevada snow and freezing temps and on Doug fir what will be my best choice to make the wood decking last the longest
Thanks David
Try Armstrong Clark in a semi-solid color to help with the full sun and vary temps.
Deck Location State: NY/NYC
Full Sun, Partial Shade, Full Shade: 1st set of decks Full Sun in Am shade PM,
2nd set Sun in PM shade AM
Wood Type: PTP
Previous Coating? None (decks were built 19 yrs ago but were never painted/stained – all decks have wood that has a decent amount of weathering on horizontal surfaces at this time)
Looking for the product(s) that will last the longest and would attempt to even out the wood surface due to natural weathering (could be two different products since there are two different sets of decks)
Thanks in Advance
Do a deep cleaning with Restore A Deck Cleaner/Brightener Kits. Stain with Armstrong Clark or TWP 1500 Series.
Hello, what is the best stain for my deck? Central California. No snow. Lots of sun. 12 inches of rain annually. Redwood deck. Thanks in advance.
Hi Joel, try TWP 1500 or Armstrong Clark stains.
Deck Location State: Idaho
Wood Type: Cedar
Previous Coating? If so brand name and type of stain: Solid stain, Behr Deckover
Is part of the problem that we are using a solid stain? I am not sure we can get it off completely to go to something else but would be open to the best option for longterm maintenance.
You are using the wrong type and brand of stain. The only way to fix this is to remove all of the Behr by power sanding down to the bare wood. Clean and brighten after the sanding. Use a penetrating stain after so it does not peel. Armstrong Clark or TWP stains.
I have a deck that is sort of a mess…it will most likely be replaced in the next 2-4 years depending on how the frame holds up. I have replaced 90% of the decking; have old railing that was previously stained. And unfortunately, the deck boards have variations in color due to the time frames that they were replaced.
1. Georgia
2. Full Sun
3. Pine
4. Yes, strangely
5. Remaining Previously stained surfaces stained with solid stain. Unknown brand 5 years ago
I’ll also be staining the underside of the deck and frame which hasn’t previously been stained. Initially, I was interested in Ready Seal due to ease of application and good reviews. Now, I’m on the fence because of the information on this site.
Thanks in advance.
Do you still have some solid stain left on the deck? If you do, you will need to remove that first by sanding. Once removed, you can use a penetrating stain like one of these: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
We are not fans of Ready Seal.
Deck Location State: Nebraska
Full Sun in afternoon facing north
Wood Type: Cedar
The reason for Previous Stain Failure: wears off deck floor
Previous Coating? TWP Semi Transparent
Prep with the RAD Kits and stain with the TWP again or try the Defy Extreme.
We have a wood balcony deck that is about 60 years old. It was covered in layers and layers of paint. We used a floor sander and took off all the paint. The wood is in good shape. Now we need to stain it. Does it need any additional prep in addition to the sanding?
Clean and brighten for the final prep.
In Alabama on a lake.
Afternoon Sun to part shade
Pressure treated pine 11 years old.
Have treated with transparent sealer once and semi transparent once. Both Olympic products from Lowe’s.
Yes we have mold and algae issues.
What will last the longest. These products also only lasts two years.
Would love environmental and human friendly products. We have a large area of steps and decking down to lake.
2-3 years is the max you will get. Try TWP 100 Series or the Restore A Deck wood stain.
Would a deck solid paint like Olympus Elite be a longer lasting option than a semi transparent stain? The can says 10 years.
As I mentioned nothing lasts more than 2-3 years on a deck. Saying 10 is a flat out lie and the solid paint will start to peel whithin the 2-3 years.
Deck paints are a pain. They eventually peel and are much harder to maintain.
What are the best deck stains for my deck? Answers to the six questions: 1 Montana 2 partial shade 3 red cedar 4 no 5 wears off easily 6 lifeline ultra 7.
Paul
Hi Paul, try the Armstrong Clark or TWP stains. Clean and brighten the wood for the prep.
Deck Location State: Missouri (Kansas City)
Reason for Previous Stain Failure: Peeled and turned dark in color
Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): Behr Solid
I was planning on sanding all the solid stain off. If I don’t stain right after sanding what steps would you recommend prior to staining. I will also have some boards to replace.
Clean and brighten after the sanding, prior to staining. Use a penetrating stain like the TWP 100 Series or the Restore-A-Deck Wood stain.
So after looking at my deck and how rough it is, I think I am going to just stick with solid stain. What would you recommend for solid stain and steps. I was planning on using a cleaner and power washing. Is there anything else you recommend doing?
Use Flood Solid Stain if you want a solid stain. Prep with a deck cleaner and pressure washing.
Thanks again for all your help.
Deck Location State: East Tennessee
Mold or Mildew Issues: no
Reason for Previous Stain Failure: Peeled, cracking, holding moisture under surface.
Previous Stain Brand and Type of stain Lowe’s ” deck restore”, not sure of exact name. no long have the containers.
The product you used before needs to be removed and that means full heavy duty power sanding. It cannot be stripped.
After removal, use a penetrating semi-transparent stain: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
Deck Location State: Baltimore, Maryland
Full Sun, Partial Shade, Full Shade: Full Sun in morning, Shade in afternoon
Wood Type: Mahogany
Previous Coating? If so brand name and type of stain (Transparent, Semi-transparent, Semi-solid, Solid Stain): I believe it was Messmer’s UV Plus for Hardwood, Natural; 3 years ago.
Great site you have. Above is my info. I’ll be using both Restore-A-Deck Stripper and Brightener to prep the deck. I’ve used a variety of different products, such as Penofin in previous years, but my once beautiful mahogany deck has never really been as nice as it was when brand new 15 years ago. It’s still in very good shape though. I look forward to your feedback and suggestions!
Sorry I don’t have photos.
Try Armstrong Clark in Maber or Mahogany Color or Defy Hardwood in Light Walnut.
1. Northern New Jersey
2.Full Sun in AM and Midday, Shade in Afternoon
3. Mahogany
4. No mold or mildew issues but some algae
5/6. Have tried many coatings, but last 7 years of treatment has been complete sanding and then marine varnish product. Looks great in covered porch area but within 2 years in fully exposed area experienced lots of peeling. Need to do entire area this year.
Your website is very thorough. Thank you! We have had a difficult time knowing the right treatment for the mahogany. The porch and deck wrap around. I’m sorry but do not know how to send photo. What do you usually recommend for restoring a mahogany deck?
Varnishes will always peel on decking. Mahogany needs a penetrating hardwood stain like the Armstrong Clark or Defy Hardwood Stain. You must remove the previous marine finish first and that will require sanding.
Thank you very much.
Of these two products, is there one that may have more longevity on the sun exposed decking?
No. About the same.
Hi, you will need to stick with a solid stain unless you want to power sand it all off as a stripper will not remove solid stains. Which would you prefer to do?
We’ve power washed it, but I don’t think we’ll be able to strip it. I think we’ll have to go with a solid stain.
Yep. Try Flood solid stains.
We have a cedar deck made of ‘new growth’ cedar, according to a company hired in the past to refinish our 5 year old deck.
They cleaned, brightened, sanded, then applied the stain. Looks great, but under a year, it starts to fade. Only one coat was applied, and he told me another should have been applied.
We live in San Antonio
Deck gets full sun for 4 to 6 hours to dappled shade. Fade factor is more in full sun area, but even in shade the are faded spots.
No mildew.
What can be done to where we do not have to completely redo the stain process every year?
What stain would be best for this area?
Strip and brighten for the prep. Try the TWP 100 Series or Armstrong Clark. Both should last about 2 years, maybe longer.
Hi
I’m looking to restain my cedar deck. It was sanded and stained same year as it was built which I realize was a mistake. I’m looking at restaining it with twp100 pecan stain and using Gemini Restore-A-Deck Kit. I was hoping i could get some advice on whether I have to sand it again with 80grit with floor sander and than use the Gemini kit and wait 3 days for it to dry than stain it? Thanks in advance for your help also the stain that was used the first time was Sikkens Proluxe Cetol Srd about 2 years ago which now looks awful it’s peeling and dirty. I live in the Michigan area
You have to remove the Sikkens first so stripping and or sanding to remove. If you sand, use 60-80 grit paper. After the sanding, do the final prep with the Gemini Restore Kit.
Thank you. Should I wait for a few nice days before I stain after using the Gemini? And is that what you would recommend to use for a cedar deck is the twp 100 product that hold up to over the winter?
Yes, let dry for 48 hours after the Gemini Kit. TWP 100 would work very well for Michigan.
Would you recommend using a stripper rather than sanding it? Also should I wait until May or June to redo to give the cedar time to dry? After using the Gemini should I wait for the deck to dry a few days before sanding
Stripping can be done but you may also need to sand as well. Does not matter when you do it. If use the Gemini, you do that after the sanding.
