🏆 Top Deck Stain Picks Summary
- Best Overall: TWP 100 or 1500 Series
- Best for Old Decks: Armstrong Clark
- Best Budget Option: Restore-A-Deck
- Best Penetrating Oil: CUTEK Extreme
| Product | Type | Durability | Ease of Maintenance | Key Strength | Best For |
| TWP 100 | Semi-Transparent (Oil) | 2–3 Years | Easy | Proven performance, deep penetration | Most decks |
| TWP 1500 | Semi-Transparent (Oil, Low VOC) | 2–3 Years | Easy | Better VOC compliance, similar performance to TWP 100 | VOC-restricted states |
| Armstrong Clark Wood Stain | Semi-Transparent (Oil) | 2–3 Years | Easy | Excellent oil penetration + conditioning oils | Dry, aging wood |
| Restore-A-Deck Wood Stain | Semi-Transparent (Water-Based) | 2–3 Years | Very Easy | Simple prep system + easy recoat | DIY homeowners |
| CUTEK Extreme | Penetrating Oil | 2 Years | Very Easy | Deepest penetration, no film buildup | All Wood types |
| Defy Extreme | Semi-Transparent (Water-Based) | 1–3 Years | Moderate | Strong UV resistance with zinc nano-particles | Sunny/high UV areas |
- Best Overall Deck Stain: TWP 100 Pro Series — A deep-penetrating, oil-based semi-transparent stain that offers excellent durability, easy maintenance, and consistent performance for up to 3 years.
- Best Semi-Transparent (Water-Based): Restore-A-Deck Semi-Transparent Wood Stain — A user-friendly, UV-resistant stain that can be applied to damp wood, allowing prep and staining in one day.
- Best Oil-Based Alternative: Armstrong Clark Wood Stain — A penetrating oil formula that conditions aging wood while providing long-lasting protection and easy reapplication.
- Best for VOC-Restricted States: TWP 1500 Series — An EPA-registered preservative with strong UV and mildew resistance, ideal where traditional oil-based stains are limited.
- Best for UV & Mildew Resistance: Defy Extreme Wood Stain — A water-based formula enhanced with zinc nano-particles for superior UV protection and mildew resistance.
- Best Semi-Solid Stain: TWP Pro Series Semi-Solid — Offers richer color, excellent UV blocking, and better coverage while still allowing some wood grain visibility.
- Best Solid Color Stain: Restore-A-Deck Solid Color Stain — A durable, breathable coating that resists peeling and works well for older or heavily weathered decks.
- Best Deck Resurfacer: Gulf Synthetics Deck Revive — A thick resurfacing coating designed to restore heavily worn or damaged wood surfaces.
*Free Shipping Included
✅ How I Rate Deck Stains
- Durability in real-world conditions
- Ease of application and maintenance
- Resistance to peeling and wear
- Overall long-term performance
- Wear and tear after 2 years
- Oil-Based:
- Deep penetration
- Easier maintenance
- Water-Based:
- Better UV color retention
- Faster drying
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
3. Defy Extreme Stain
Type: Oil-Based Semi-Transparent- Durability: 2–3 Years
- Maintenance: Easy recoat, no stripping needed
- Best For: Most decks (pressure-treated, cedar)
- Why It Stands Out: Deep penetration and consistent long-term performance without peeling
My Test Deck Stats
Deck Square Footage: 2100
Consumer Star Ratings:
- Type: Water-Based Semi-Transparent
- Maintenance: Very easy, simple prep system
- Best For: DIY homeowners and quick projects
- Why It Stands Out: Can be applied to damp wood, allowing prep and stain in one day
My Test Deck Stats
UV Exposure: 50% Full Sun
- Type: Oil-Based Semi-Transparent
- Maintenance: Easy reapplication
- Best For: Older, dry, or weathered wood
- Why It Stands Out: Contains conditioning oils that help restore dried-out wood
My Test Deck Stats
Deck Square Footage: 600
- Type: Semi-Solid (Oil-Based)
- Durability: 3 Years
- Maintenance: Moderate
- Best For: More color coverage with strong UV protection
- Why It Stands Out: Rich color options while still allowing some wood grain to show
My Test Deck Stats
When Tested: August 2023
Deck Square Footage: 800
UV Exposure: Deck in full sun
- Type: Oil-Based Semi-Transparent (Low VOC)
- Maintenance: Easy
- Best For: VOC-restricted states
- Why It Stands Out: EPA-registered preservative with strong UV and mildew resistance
My Test Deck Stats
Deck Wood Type: Cedar
Deck Square Footage: 400
- Type: Water-Based Transparent
- Durability: 1.5–2.5 Years
- Maintenance: Easy
- Best For: Maintaining a natural, “bare wood” appearance
- Why It Stands Out: Unique formula designed to preserve the natural color of new wood while still offering UV protection
My Test Deck Stats
Stain Color Used: Chesnut
- Durability: 2 Years
- Best For: High UV and mildew-prone areas
- Why It Stands Out: Zinc nano-particles provide superior UV protection and mold resistance
My Test Deck Stats
Stain Color Used: Cedartone
- Durability: 1-2 Years
- Best For: DIY users and quick, forgiving applications
- Why It Stands Out: Extremely easy to apply with no back-brushing needed, but shorter lifespan than higher-end penetrating stains
My Test Deck Stats
- Type: Penetrating Oil
- Maintenance: Very easy (clean and reapply)
- Best For: Exotic hardwoods (Ipe, teak) all wood types
- Why It Stands Out: Extreme penetration with no film buildup, making long-term maintenance simple
Scott’s Pro Tips: Although CUTEK® Extreme is more expensive than many penetrating oils, the performance was very solid. There was no peeling or significant wear, and the coating should be easy to maintain, as it fades naturally and can be refreshed without stripping.
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Stain Color Used: Walnut
Semi-Solid Deck Stain Review
- Consumer Star Ratings:
Best Deck Stain for Old Wood
- For new pressure-treated wood, wait until the wood has weathered and is able to absorb stain (typically a few months), then prep and stain.
- For older pressure-treated decks, proper cleaning and brightening will restore the wood and allow for better stain penetration.
- If you want to maintain cedar’s natural look, use a lighter or natural-tone stain.
- If you want longer UV protection, choose a slightly darker tint, as it will hold color longer.
- Wood Condition: New, weathered, or heavily worn
- Desired Look: Natural grain showing vs solid color
- Maintenance Preference: Easy recoat vs long coverage
- Climate: Sun exposure, moisture, temperature swings
✅ Deck Stain Types Explained
- Transparent/Clear Sealers: Natural look, less protection
- Semi-Transparent Stains: Best balance (most recommended)
- Semi-Solid Stains: More color, moderate maintenance
- Solid Color Stains: Maximum coverage, higher maintenance
Transparent Stains
Solid (opaque) Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
- Film-forming coatings on older decks
- Over-applying stain
- Choosing based on color alone
- Skipping prep
- Not preparing your deck: Failing to clean your deck or remove old, flaking, or peeling stain from your boards can prevent a fresh coat of stain from adhering properly. See my Deck Cleaning Guide for best results!
- Over-applying stain: You may think more stain equals more protection from moisture, mildew, and sun damage, but that’s not always the case. Too much stain can prevent the product from penetrating your deck boards. As a result, it may form a film on top of the wood that peels or flakes off over time. See my How to Stain a Deck tips for the best results.
✅ Best Deck Stain FAQs
Quick Tip:
What is a deck stain?
⏳ Durability & Maintenance
🎨 Appearance & Color
🛠 Application & Usage
🆕 New Deck Questions
- Smooth wood: Wait ~3 months
- Rough wood: Can stain once clean and dry
- Kiln-dried wood: Wait 1–2 months
- Deck Location: Michigan
- Wood Type: Cedar
- Mold/Mildew?No
Northwest Arkansas
Covered deck/stairs area sun 3/4 of the day full sun
cedar/treated lumber
slight mold/issues
just bought house deck cedar was done (unknown product) treated wooed decking not done at all
unknown previous coating to none applied
There is an old coating on the wood. Strip and brighten this for the prep. It will be an easy strip. Stain with TWP 100 Series or the Restore-A-Deck Wood stains.
DO YOU NOT RECOMMEND ARMSTRONG-CLARK?? sorry about the caps
You could use the AC as well.
Thanks for your help I have ordered samples from each company, have a great day
New York
Full afternoon sun
Treated lumber 30 years old
no
normal wear not done for 3 years
Olympus Semi-transparent
Strip and brighten for prep and stain with TWP 1500 Series or Defy Extreme Stains.
What should I use to strip the deck? can you brighten the same day? Can you strip and brighten if it rained last night?
Try the Restore A Deck Stripper/Brightener Kits.
Best stain for my deck
Atlanta Ga
Pressure wood
No mold
Installed 9months ago
Full sun
TWP 100 Series or Armstrong Clark.
I live in Des Moines Iowa. Which retail stores sell the TWP 1500 and the Armstrong? Also, for an older deck that is partly shaded and prone to mildew, would you want an oil based vs water based stain?
Check with manufacturers with help locating. Either water-based or oil-based will work as long as they are penetrating coatings.
We have a fence and pergula that need to be re-stained.
1. Location State: Colorado
2. Full Sun
3. Wood Type: Natural Cedar for both the fence and pergula
4. No mold or mildew issues
5. We hadn’t re-stained it for a few years so really just old but the color faded quite a bit early on.
6. Fence had Olympic Semi-Transparent Cedar Naturaltone and Pergula had Penofin Western Red Cedar
We would like to use the same stain on both the fence and the pergula. Something that shows the natural wood color but a slightly darker stain than the naturaltone provided.
Hello, for the prep you will need to strip and brighten all the wood. Use the Restore A Deck Stripper Kits. For the new wood stain, try Armstrong Clark or TWP 100 Series.
Minnesota
Morning full sun, afternoon shade
Cedar tone green treat
No mold
Never stained, 3years old
Clean and brighten the wood for the prep and stain with TWP 100 Series or Armstrong Clark.
Deck Location State: upper Minnesota
Full Sun, Partial Shade, Full Shade: Full east Sun in Am, Shade in Afternoon on the back deck. On the side sun all day.
Wood Type: treated
Mold or Mildew Issues: No
The reason for Previous Stain Failure: have not stained yet one yr old
Previous Coating? we were thinking cabot semi-solid stain
If you want a semi-solid, look at the Armstrong Clark. Much better than Cabot.
Pine deck in Missouri 7 months old. In the sun Most of the day.No mold or mildew. Has not been stained. Want to use semi transparent stain. What’s best to start life out with? I should also add this is by a pool.
Clean and brighten the wood for the prep and stain with TWP 100 Series or Armstrong Clark wood deck stains.
1. Massachusetts
2. Full sun a.m., shade from mid-afternoon on
3. Pressure-treated wood installed 24 years ago
4. No mold/ mildew
5. Peeled quickly, and continues to. Showed wear in traffic areas, especially from dog, within a couple of months of application. Done 4 years ago.
6. BEHR Premium
Start by removing the Behr. Strip, pressure wash, power sand if needed, and brighten when done. Once prepped, try the Armstrong Clark wood stains.
What is the best deck stain for my deck: 1. Oregon; 2. Full sun; 3. Pressure treated Douglas Fir; 4. Mold and mildew issues; 5. No previous stain
Make sure to prep with a deck cleaner and a wood brightener. Stain with TWP 100 Series or Restore-A-Deck Wood Stains when dealing with mildew issues.
Hi
We have a deck that we are looking to redo this summer.
1. Deck Location State: Manitoba, Canada
2. Full Sun, Partial Shade, Full Shade: Full Sun in Am, partial Shade in Afternoon
3. Wood Type: appears to have been treated wood
4. Mold or Mildew Issues: No
5. The reason for Previous Stain Failure: Dried Blotchy and Peeled after first Winter.
6. Previous Coating? A semi transparent stain. Can’t remember the brand name
Thanks in advance!
The current stain will need to be fully removed first. Stripping and or sanding will be needed. Brighten all the wood after. After the prep, stain with Armstrong Clark or TWP 200 Series.
Can I get any of the top rated stains in Ontario?
Not sure, Best to call the stain manufacturers directly.
I think this is the best information i could ever get. I have a new redwood deck installed last fall and let set in snow all winter, Its in northern California at 7000 ft, facing east, sun comes over trees and has full sun from 9-1, no previous anything put on it. I’ve asked questions before and thant you for answering those.
Hello, clean and brighten the deck for the prep. Stain with Armstrong Clark or TWP 1500 Series.
We live in NE Pennsylvania. Our deck is about 20 years old and mostly in the shade. What is the best stain to use?
Try the TWP 1500 Series or Armstrong Clark.
Just bought a cabin, and I’m replacing the deck.
Deck Location State: Pacific Northwest states, willing to drive for the best product.
Partial Shade in the woods with some annual snow.
Wood Type: Old redwood, (soon to be) new redwood.
Mold or Mildew Issues: Not sure – guessing no. Dry mountain climate.
Reason for Previous Stain Failure: Still looks OK, but only 1 year old.
Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc.): Behr solid color water-proof wood stain
Rod, see this about new wood: https://www.deckstainhelp.com/staining-a-new-deck/
Glad to have discovered this site. The below is actually for wood paneling we have up on one side of the house:
– Location: Northern Virginia
– Full sun in afternoons
– Mahogany paneling
– Seeing mold/mildew issues
– Paneling installed in fall 2015 and stained with Sherwin Williams oil-based transparent exterior deck stain, “natural” color. Restained in spring 2017 with the same stain, only “redwood” in color
Based upon other posts here, thinking we use the Restore-A-Deck treatment then go to a different stain?
Yse on the prep. Use the RAD Stripper/Brightener Kit. Stain with Restore A Deck Wood Stain or Defy Hardwood Stains.
l. Location: Massachusetts
2. Full sun on part in afternoon; otherwise shade–it’s a covered porch, but steps are exposed
3. Cedar
5. Rained too soon after–but also a few years ago
6. Previous–unknown
thanks!
How to prep and what stain to use depends on the stain type that is on the deck now. Please post a picture or two.
Unsure of type of wood but it was both stained and has been painted. We have power washed it twice as well as sanded it down but there is still some dark brown paint remnants on there. We live in South Dakota so there is a lot of weather changes. What type of stain will withstand our winter conditions and very humid summers? I’m also hoping for something that will look okay and blend well with some darker brown paint that will not come off.
You cannot blend with pain when using a semi-transparent stain but you can cover this with a solid color stain. Try the Flood Solid Stains.
Deck Location State: Northern Ohio
Full Sun, Partial Shade, Full Shade: Partial Sun
Mold or Mildew Issues: in some areas
Reason for Previous Stain Failure: Added on to the deck last year, have not treated yet. The original part of the deck is done with a red paint (?) that is peeling off. I would like to do the deck in a solid color. Suggestions?
Try the Flood Solid Stains or the Gulf Deck Revive.
Deck location: Matlock, MB Canada
Full sun most of the day, partial shade the rest
Pressure treated SPF
Some dark/black spots from trees overhanging the deck
No previous stains, used Thompson Water Seal a couple of years ago, deck built in 2008 from cedar tone ptw and has faded and started to splinter. Looking for some advice for brightening and semi transparent stain. Some of the products you recommend aren’t available locally, but will order from the States if you suggest that’s the way to go!
Use TWP 200 Series or Armstrong Clark for the stain. Prep with Restore A Deck Products.
1. Redwood deck is a little over 2 years old.
2. It was treated with SuperDeck Log Home Oil Finish (Amber Hue) when new.
3. There are graying and black spots in exposed areas.
5. There is no obvious evidence of previous oil finish.
6. Do I need to strip & brighten or can I get away with just power wash?
7. What stain do you recommend (want to preserve original appearance)?
Strip and brighten will be needed. Very easy to remove the Super Deck. Try Restore-A-Deck Wood stain or TWP Stains.
We are currently staining our deck that is at least years old. We used SherwinWilliams Super Deck Solid stain and are pretty happy with the results.
My question is this. We wanted to add a second coat to the part of the deck that gets full sun today but weather report shows rain for tomorrow. Should we apply the second coat today or can we wait until the weather is dry?
Wait to be safe.
Thank you. 🙂 happy Friday
Deck Location State: Wisconsin
Mold or Mildew Issues: Yes
Reason for Previous Stain Failure: Peeled
Previous Stain: Re Store liquid armor deck resurfacer
Put the Restore on brand new deck hoping it would be best for preventing splinters in all the little feet that would be running on it. That summer it was beautiful, but after the first winter and since it’s been peeling and looks terrible. We are currently pressure washing of flaking paint & then sanding down to clean wood. I think I’d prefer a stain this time, but really the biggest issue is I don’t ever want to have to sand it down to repaint/ stain. So I’m looking for something that won’t flake.
Penetrating semi-transparent stain. Try TWP 100 Series or Armstrong Clark.
I saw TWP has a low VOC version. How does that compare long term? Or in general?
The TWP 1500 Series lasts about the same as the TWP 100 Series in our experience.
Thank you for the all help! We never want to and this silly deck again!! ❗ ❗
I have another deck in similar weather/ site conditions that also needs to be re stained. We used Ducksback Superdeck semi-transparent before. What would you recommend to use now? Do we have to stay with the same brand/ ect? How does the Ducksback compare to the TWP 100?
Thank you again! 🙂
TWP is a better brands and does not turn dark or black like the Super Deck can. Strip and brighten for the prep and switch to TWP.
I have a year old roof top pressure treated deck in Philadelphia. The deck is made of pressure treated and is in full sun all day and has never been stained. What do you suggest?
Clean and brighten for the prep. Armstrong Clark in a semi-solid color when in full sun.
I live in central Colorado. Three years ago I did my deck with Behr Premium weatherproofing semi-transparent all-in-one wood stain and sealer. It looked great for a while but this deck is old and hadn’t been taken care of when I moved in so it didn’t seem to hold very well. It started pealing after the first year. Is there anything that works better or does it just need to be done every other year?
Yes there are better stains: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
To be able to use one of those brands, you will need to strip and sand off the Behr stain.
Deck Location State: Central Illinois
Mold or Mildew Issues: in some areas especially on uprights.
Previous Stain Brand and Type of stain: Behr Premium Weatherproofing Solid Wood Stain No. 5013
Deck has been up for many years. Seems like every year I have to touch up the spots that peal and every 3-4 years I need to power wash and paint entire deck. Working with Behr and they say I moisture test my wood. Testing between 7.4 and 9.6. Considering moving to their Deck Over stain that is suppose to fill in cracks and last longer but not read great reviews. Be willing to strip whole deck and start over if needed but has to be an easier way. Thanks.
You will not be able to strip this. The only true way to fix the peeling issues is to sand off the solid stain and then choose a penetrating semi-transparent: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
Thank you for all your information. Our products have arrived and we will able to start our project hopefully this weekend. I do have one more question we have an oak front door. I gets all the sun. Is there a stain and sealant that protects wood from the sun better than others?
Sorry but door coatings are not the same as deck stains.
1. Deck location state: Indiana
2. Full sun
3. Pressure treated
4. Mild mold and mildew
5. This will be the first time the deck has be stained. It is 2 years old.
Clean and brighten for prep and stain with Restore A Deck Wood Stain or Armstrong Clark.
What are the best deck stains for my deck?
1) Location – southeast Ohio, Hocking Hills, in a heavily wooded setting
2)sun exposure – south-facing, Partial shade
3) Wood type – pressure treated pine
4) Mold/mildew issues? – Yes
5) Previous brand/type – Wolman, semi-transparent
Strip and remove the Wolmans first. Brighten when done. Defy Extreme or Restore A Deck Wood Stains.
1. Deck Location State: West Virginia
3. Wood Type: pressure treated
4. Mold or Mildew Issues: Yes
5. Reason for Previous Stain Failure: Peeled but areas of it will not come off (wanted to go with solid to cover those areas up)
6. Previous Stain Brand and Type of stain: unsure of brand but solid
Try the Flood Solid Stain.
Deck Location State: Northern Wisconsin
Previous Stain Brand and Type of stain Solid Sherwin Williams
Deck has been up for many years. Also have a wood dock at the lake that is pealing badly. Want something that will last more than a year. Solid Stain probably. What kind of prep work is best to get best results.
Pressure wash and sand to remove all the peeling stain. You can leave the intact stain that is not peeling. Once prepped, try the Flood solid stains to cover the coating you have.
Best stain? Thank you
1 = Southern New Hampshire
2 = half shade half sun
3 = mahogany
4 = yes
5 = turning grey in places
6 = don’t know?
Hi Tim,
Look at these two brands for the mahogany. Defy Hardwood Stains or Armstrong Clark in one of their hardwood colors.
Installed a new pressure treated deck last summer. Let it sit to “cure” or dry.
1=Captial Region – NY
2= Morning to Mid day Sun
3= Pressure Treated
4 = no
5= no previous stain/sealer
6= none
I want to seal it since my wife cannot decide on a color stain. If I use clear now, can I stain it in the future?
What is the best clear sealer for current conditions?
How should I prep the deck before sealing?
If you use clear now you will need to strip before applying a stain later. Best clears are TWP Clears or Defy Extreme Clear. Clean and brighten the wood for the prep.
You would be much better off using a semi-transparent stain instead of a clear sealer: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
Best semi transparent stain to use.
1 = NS Canada
2 = Full afternoon sun
3 = pressure treated pine
4 = yes
5 = turned dark grey in places
6 = thompson’s clear water sealer
Prep well and try Armstrong Clark or TWP 200 Series.
Deck Location State: sw mo
Full Sun, Partial Shade, Full Shade: Full Sun, shade, and partial sun
Wood Type: Pressure Treated Pine yellow wood
Mold or Mildew Issues: yes
Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): Vallhalla wood preservative.
We rebuilt our front deck in 2013. In 2014 we used a product called Valhalla wood preservative. We don’t think it is protecting the wood and do not want to use it again. Last year 2017 We rebuilt the back deck. We now want to try and make the decks look about the same color. What stain would you recommend and what prep do we need to do.
The vertical boards in the picture are the older deck the horizontal boards are the newer deck
Strip and brigthen the older deck. Clean and brighten the newer wood. Try Restore A Deck Prep Kits.
Stain with TWP 100 Series or Restore A Deck Wood Stains.
Curious what you think of the following:
-Sansin stain – Deckbuilder’s “great stain shootout” listed it as #1
-Eco wood treatment – it’s advertised as a “set it and forget it” type of product.
Sasin: that article is dated and was written but someone who has not updated their blog in 3+ years. Not much feedback from it on our our site and we never personally used it.
Eco Wood: Gimmick product. Does not really do anything for the decks appearance or protection from UV graying.
1.Our deck is in Grand Rapids Michigan. 2. Faces East large oak and maple tree partial shade. 3. Fresh mill cut white cedar put down last fall and aged through winter, so 4. no mold or mildew issues. 5. New deck. 6. Used Rymar Sandstone semi transparent stain on old deck for years and loved the color and product, but the color is no longer available. What do you recommend for best deck stain replacement and want the application to be done well by a professional. We want to have natural gray-brown weathered natural look with some grain showing. ( I did a quick look at Silkins colors maybe 205 Quail, 205 Willow, 520 Fog but don’t know anything about comparing stain brands. Photo of deck attached. Any suggestions for stain brands would be appreciated and also a name or two for good stain pros who would work in Grand Rapids. Thank you. You have a great web site.
I am sorry but we do not know of any quality penetrating semi-transparent stains that come in a natural-gray-brown color. Browns yes, but no taupe/brown colors.
Help….new homeowner, first time woodeck owner with carpenter bee damage. Exterminator coming in the next week. Husband wants to DIY the repairs and protection, but we dont know where to begin for how to best proect it going forward.
Deck Location State: West TN
Full Shade due to wooded surrounding wraps NW Deck/porch to NE screenelevated sunporch.
Wood Type: unknown/assuming a pressuretreated pine? Home was built in 2008
Mold or Mildew Issues: slight
The reason for Previous Stain Failure: unknown. Just purchased the home Feb 2018.
Previous Coating? I can see there was something, but don’t know specs. Look like a solid paint?
Might be best to cover all with a solid color stain as the current coating cannot be stripped off. try the Flood solid stains.
Hi, I am putting in a new redwood deck in partial sun in northern CA (down to 35 in the winter, up to 100+ a few times in the summer, 15″ of rain per year, otherwise a medium-dry climate).
Want to preserve as much natural redwood color while still giving UV protection. Fair amount of foot traffic with 2 boys.
Also, do you recommend finish on the underside of the deck before installing? The wood has already seasoned for about 1 month.
Thanks! Vince
See here for new wood tips: https://www.deckstainhelp.com/staining-a-new-deck/
No need to stain undersides nor can you prestain wood.
Our deck is cedar and two years old. When built, I stained with Sikkens Proluxe. It has pealed in spots. I have cleaned and sanded the bad spots. What product should I use to refinish the surface?
Hello, you have to strip and or sand to remove all as you cannot coat over this with a different brand of stain. Brighten after the prep and stain with TWP stains.
Deck Location State: Washington (Seattle)
Full Sun, Partial Shade, Full Shade: Full Sun all day – rooftop deck
Wood Type: Cedar
Mold or Mildew Issues: Not really, but underneath a drain yes (one small spot)
The reason for Previous Stain Failure: Dried Blotchy and Peeled after 3 months
Previous Coating? If so brand name and type of stain (Transparent, Semi-transparent, Semi-solid, Solid Stain): Thompson’s WaterSeal Pre-Tinted
Hi there – any advice would be super helpful please! New house with a rooftop deck that the builder painted improperly and most likely while wet. We have stripped it with a light pressure washer and stain remover (JoMax stripper). We’re planning on sanding the deck afterwards just to smooth it out and remove some hard stains – do you recommend we do this by hand (say 80 grit?) or maybe a drill bit attachment? Or some other way? We have a total of 400sq ft. so I’m def not looking forward to this part :). Secondly, what stain / product do you recommend for wet Seattle weather that is going to last more than 3 months before it peels? Would love something that we can reapply every 1-2 years at least.
THANK YOU!
80 Grit at max. Hand sander or palm sander. You want a penetrating stain. TWP 100 Series or Armstrong Clark.
Thanks so much! One more question, we have some wood discoloration, do you recommend we do a wood brightener as per your other post? And any suggestions on what kind?
Not sure if it will help or not but it would not hurt to try. Does not matter on brand.
What is the best stain for the Midwest in a wooded area and a yard with trees? The winters are fierce and the deck is in direct sun and open to the winter elements. It has been power washed. Now we will clean it. I am wondering about stain and sealant. Mold and mildew are issues.
Armstrong Clark or TWP wood stains.
Deck location: SW Pennsylvania
Partial shade in AM and full sun in afternoon
Wood: Pressure treated pine
Some mold/mildew in spring
Reason for previous failure: Not sure. Looks dull and some peeling of stain
Previous coating: Used Sikkens Cetol for the last 20 years which was great. Last year when we put on what we thought would be the same product, we were very disappointed. It never looked the same and was not as glossy as before. We were told that PPG bought Sikkens and changed the stain. It was a 2 step process at first but then only had to put on top coat every 2-3 years. Is there another product available that would look and work as good as the old product did? Do we need to sand off the old stain and start again? Do you have another suggestion?
After removal by stripping and or sanding of the old coatings, try TWP 1500 or Armstrong Clark. They are what Sikkens used to be. Brighten the wood as well after the prep but before staining.
Phoenix, Arizona
Full Sun
Wood Type: 2″ Treated Canadian Spruce Pine Fir
Trailer deck was built in Texas and shipped to Arizona in September 2017.
My biggest concern (more than looks) is durability/longevity. Can’t be too slick as also transports quads, and can’t stain clothes when kneeling on the deck. My biggest concern is the sun. Should I just paint it, and touch up the inevitable and continuous chips and scrapes?
Thank you so much for your time
Clean and brighten for the prep and stain with a penetrating stain like the Restore A Deck Wood Stains.
Deck Location State: SW Iowa
Full Sun, Partial Shade, Full Shade: Full Sun in Am, Shade in Afternoon/Evening
Wood Type: I’m not much of a “wood guy” and wasn’t the homeowner when the deck was installed. I’m hoping you can tell me from the pictures.
Mold or Mildew Issues: Minimal green mildew on the surface (this was removed when I pressure washed). Included a picture of below the deck as well to get your opinion.
The reason for Previous Stain Failure: old and needed replaced (see pictures of stairs)
Previous Coating? No idea as I’ve only owned the home for approx a year.
Narrative: Last night I pressure washed what I could before the sunset I intend to finish today. If you look at the pictures, you can see a “before / after” if you look at the stairs as I haven’t gotten there yet.
I plan on using Behr no 63 (as the previous owner left this, and you can’t beat free…) after I’m completed with pressure washing, unless you suggest something else. I then intend to sand it all, then put on stain/sealer. I didn’t think I needed a sealer as most of the current stain came off with the pressure washing and I’m hoping the Behr no 63 takes the minimal remainder off.
Also, I intend to put on brackets on the railings as the 45-degree nails aren’t holding very well. Any issue here?
You will need to strip and brighten for this prep so all of the old stain is removed. The Behr Cleaner cleaner will not remove the coating fully. Do not use Behr Stains. Horrible reviews: https://www.deckstainhelp.com/behr-deck-stain-review/
As for the stain, try the TWP 100 Series or Armstrong Clark.
Thanks! Do you have a stripper/brightener you’d recommend?
The Restore A Deck Stripper and Brightener Kits.
Also, any insight on sanding? My intent was to get rid of all splinters.
See this for tips: https://www.deckstainhelp.com/how-to-sand-your-wood-deck/
I live near Topeka Ks. and have a 16′ X 20′ upper deck on the rear of my house. It is a covered deck and need a recommendation as to a good semi-solid stain to use.
Armstrong Clark in one of their semi-solid colors.
1. Eastern Oregon
2.Full afternoon sun (facing west)
3.Cedar
4.No (dry side of the state)-Cold long winters
5.No stain applied
6. Brand new Pergola, 10 months drying cycle
Clean and brighten the wood for the prep. Stain with TWP Stains or Armstrong Clark.
10 ft X 32 ft treated porch floor facing south newly installed in September 2017, no stain or oils…allowed to weather for a while…went through heavy winter snow from Nov 2017 to present (05/20180…I NOW WISH TO STAIN AND SEAL (POLY?)…any recommendations for proper treatment, stain, sealer etc?
George
Somerset, WI 54025 (Brrrr)
Clean and brighten the wood with Restore A Deck Kits. Stain with TWP or Armstrong Clark.
You cannot put a poly on outside wood: https://www.deckstainhelp.com/apply-polyurethane-to-a-deck/
Deck location: Nebraska
West facing – partial sun am, full sun PM
Wood type: pine – 10 years old
Mold or mildew: no
Reason for previous stain failure: had a contractor clean and restain deck about 2 years ago. Follow manufacturer’s directions, even sent pictures through out process, within 6 months the stain was peeling. Manufacturer repaid us cost of stain.
Previous coating: Cabot acrylic exterior neutral base
Need to redo, what should I use?
Sand off the Cabot fully. Clean and brighten after. Stain with a penetrating coating so it does not peel: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
Looking for a recommendation for a cedar deck. 5 years old, recently power-washed and sanded. Wood in excellent shape, looks almost new. Would like to use a transparent stain, but understand that semi-transparent may be what is recommended, so would like something as close to the yellow-ish cedar color as possible.
Deck Location State: Seattle, WA
Full Sun, Partial Shade, Full Shade: Full sun after 11:00 a.m., except for stairway, which gets little to no sun.
Wood Type: Cedar
Mold or Mildew Issues: No – but has moss issue on stairway.
Reason for Previous Stain Failure: Turned dark in color quickly
Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): Penofin Blue Label, Western Red Cedar
Use TWP 100 Series in Honeytone or Restore-A-Deck Wood stain in Natural. Neither will turn dark like the Penofin.
