🏆 Top Deck Stain Picks Summary
- Best Overall: TWP 100 or 1500 Series
- Best for Old Decks: Armstrong Clark
- Best Budget Option: Restore-A-Deck
- Best Penetrating Oil: CUTEK Extreme
| Product | Type | Durability | Ease of Maintenance | Key Strength | Best For |
| TWP 100 | Semi-Transparent (Oil) | 2–3 Years | Easy | Proven performance, deep penetration | Most decks |
| TWP 1500 | Semi-Transparent (Oil, Low VOC) | 2–3 Years | Easy | Better VOC compliance, similar performance to TWP 100 | VOC-restricted states |
| Armstrong Clark Wood Stain | Semi-Transparent (Oil) | 2–3 Years | Easy | Excellent oil penetration + conditioning oils | Dry, aging wood |
| Restore-A-Deck Wood Stain | Semi-Transparent (Water-Based) | 2–3 Years | Very Easy | Simple prep system + easy recoat | DIY homeowners |
| CUTEK Extreme | Penetrating Oil | 2 Years | Very Easy | Deepest penetration, no film buildup | All Wood types |
| Defy Extreme | Semi-Transparent (Water-Based) | 1–3 Years | Moderate | Strong UV resistance with zinc nano-particles | Sunny/high UV areas |
- Best Overall Deck Stain: TWP 100 Pro Series — A deep-penetrating, oil-based semi-transparent stain that offers excellent durability, easy maintenance, and consistent performance for up to 3 years.
- Best Semi-Transparent (Water-Based): Restore-A-Deck Semi-Transparent Wood Stain — A user-friendly, UV-resistant stain that can be applied to damp wood, allowing prep and staining in one day.
- Best Oil-Based Alternative: Armstrong Clark Wood Stain — A penetrating oil formula that conditions aging wood while providing long-lasting protection and easy reapplication.
- Best for VOC-Restricted States: TWP 1500 Series — An EPA-registered preservative with strong UV and mildew resistance, ideal where traditional oil-based stains are limited.
- Best for UV & Mildew Resistance: Defy Extreme Wood Stain — A water-based formula enhanced with zinc nano-particles for superior UV protection and mildew resistance.
- Best Semi-Solid Stain: TWP Pro Series Semi-Solid — Offers richer color, excellent UV blocking, and better coverage while still allowing some wood grain visibility.
- Best Solid Color Stain: Restore-A-Deck Solid Color Stain — A durable, breathable coating that resists peeling and works well for older or heavily weathered decks.
- Best Deck Resurfacer: Gulf Synthetics Deck Revive — A thick resurfacing coating designed to restore heavily worn or damaged wood surfaces.
*Free Shipping Included
✅ How I Rate Deck Stains
- Durability in real-world conditions
- Ease of application and maintenance
- Resistance to peeling and wear
- Overall long-term performance
- Wear and tear after 2 years
- Oil-Based:
- Deep penetration
- Easier maintenance
- Water-Based:
- Better UV color retention
- Faster drying
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
3. Defy Extreme Stain
Type: Oil-Based Semi-Transparent- Durability: 2–3 Years
- Maintenance: Easy recoat, no stripping needed
- Best For: Most decks (pressure-treated, cedar)
- Why It Stands Out: Deep penetration and consistent long-term performance without peeling
My Test Deck Stats
Deck Square Footage: 2100
Consumer Star Ratings:
- Type: Water-Based Semi-Transparent
- Maintenance: Very easy, simple prep system
- Best For: DIY homeowners and quick projects
- Why It Stands Out: Can be applied to damp wood, allowing prep and stain in one day
My Test Deck Stats
UV Exposure: 50% Full Sun
- Type: Oil-Based Semi-Transparent
- Maintenance: Easy reapplication
- Best For: Older, dry, or weathered wood
- Why It Stands Out: Contains conditioning oils that help restore dried-out wood
My Test Deck Stats
Deck Square Footage: 600
- Type: Semi-Solid (Oil-Based)
- Durability: 3 Years
- Maintenance: Moderate
- Best For: More color coverage with strong UV protection
- Why It Stands Out: Rich color options while still allowing some wood grain to show
My Test Deck Stats
When Tested: August 2023
Deck Square Footage: 800
UV Exposure: Deck in full sun
- Type: Oil-Based Semi-Transparent (Low VOC)
- Maintenance: Easy
- Best For: VOC-restricted states
- Why It Stands Out: EPA-registered preservative with strong UV and mildew resistance
My Test Deck Stats
Deck Wood Type: Cedar
Deck Square Footage: 400
- Type: Water-Based Transparent
- Durability: 1.5–2.5 Years
- Maintenance: Easy
- Best For: Maintaining a natural, “bare wood” appearance
- Why It Stands Out: Unique formula designed to preserve the natural color of new wood while still offering UV protection
My Test Deck Stats
Stain Color Used: Chesnut
- Durability: 2 Years
- Best For: High UV and mildew-prone areas
- Why It Stands Out: Zinc nano-particles provide superior UV protection and mold resistance
My Test Deck Stats
Stain Color Used: Cedartone
- Durability: 1-2 Years
- Best For: DIY users and quick, forgiving applications
- Why It Stands Out: Extremely easy to apply with no back-brushing needed, but shorter lifespan than higher-end penetrating stains
My Test Deck Stats
- Type: Penetrating Oil
- Maintenance: Very easy (clean and reapply)
- Best For: Exotic hardwoods (Ipe, teak) all wood types
- Why It Stands Out: Extreme penetration with no film buildup, making long-term maintenance simple
Scott’s Pro Tips: Although CUTEK® Extreme is more expensive than many penetrating oils, the performance was very solid. There was no peeling or significant wear, and the coating should be easy to maintain, as it fades naturally and can be refreshed without stripping.
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Stain Color Used: Walnut
Semi-Solid Deck Stain Review
- Consumer Star Ratings:
Best Deck Stain for Old Wood
- For new pressure-treated wood, wait until the wood has weathered and is able to absorb stain (typically a few months), then prep and stain.
- For older pressure-treated decks, proper cleaning and brightening will restore the wood and allow for better stain penetration.
- If you want to maintain cedar’s natural look, use a lighter or natural-tone stain.
- If you want longer UV protection, choose a slightly darker tint, as it will hold color longer.
- Wood Condition: New, weathered, or heavily worn
- Desired Look: Natural grain showing vs solid color
- Maintenance Preference: Easy recoat vs long coverage
- Climate: Sun exposure, moisture, temperature swings
✅ Deck Stain Types Explained
- Transparent/Clear Sealers: Natural look, less protection
- Semi-Transparent Stains: Best balance (most recommended)
- Semi-Solid Stains: More color, moderate maintenance
- Solid Color Stains: Maximum coverage, higher maintenance
Transparent Stains
Solid (opaque) Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
- Film-forming coatings on older decks
- Over-applying stain
- Choosing based on color alone
- Skipping prep
- Not preparing your deck: Failing to clean your deck or remove old, flaking, or peeling stain from your boards can prevent a fresh coat of stain from adhering properly. See my Deck Cleaning Guide for best results!
- Over-applying stain: You may think more stain equals more protection from moisture, mildew, and sun damage, but that’s not always the case. Too much stain can prevent the product from penetrating your deck boards. As a result, it may form a film on top of the wood that peels or flakes off over time. See my How to Stain a Deck tips for the best results.
✅ Best Deck Stain FAQs
Quick Tip:
What is a deck stain?
⏳ Durability & Maintenance
🎨 Appearance & Color
🛠 Application & Usage
🆕 New Deck Questions
- Smooth wood: Wait ~3 months
- Rough wood: Can stain once clean and dry
- Kiln-dried wood: Wait 1–2 months
- Deck Location: Michigan
- Wood Type: Cedar
- Mold/Mildew?No
TWP Natural Effect Top Coat 1 Gallon - Step 2
My home is on the California coast, wind, rain, full sun. Cedar shingles, mildew and mold in places. Used Superdeck semi transparent oil for 30 years. I noticed fading and blotching. What product would you recommend?
Strip and brighten for the prep and try TWP 1500 Series or Restore-A-Deck Wood stains.
What’s the Best Stain for My Deck?:
Deck location: northern CA – not coastal- (inland where summer temps are 100 degrees, winters are wet)
Exposure – full sun
Wood type – redwood. Brand new. Never been treated/stained with anything
Mold/mildew issues – minimal if any
Reasons for previous stain failure – none. Never been treated before. Just built
Previous stain brand – none
What type of solid stain is the best to use on our deck? Half of the deck is new pressure treated pine wood and the other half is also pressure treated with a solid stain which we are keeping since they are still quite good?
Deck Location State: Ottawa Ontario Canada
Full Sun, Partial Shade, Full Shade: Partial Sun
Mold or Mildew Issues: none
Reason for Previous Stain Failure: peeling
Previous Stain Brand and Type of stain: Solid stain.
Try the Flood Solid Stains.
My question is what product would you recommend for use on a Mahogany deck with full sun exposure in NH. and to strip the prior years Cabot ATO? Thanks, Bob
Use the Armstrong Clark In Mahogany color. You are corect the Cabot changed their formulas. As for stripping, try the Restore A Deck Stripper kit but you may need to sand as well.
Hi would I also need to use a deck brightener after stripping?
Thanks for your advice. As for the rails, they’ve never had any thing on them and only a couple months of exposure. What prep would I need for them?
Deck Cleaner and then a Wood Brightener.
Deck location: NH it gets full sun, wood type is mahogany(3 yrs old). The railings I take off each Fall for easier snow removal. Last year I used Cabot ATO and it’s not the same product I used 15 years ago. Uneven coat noticed after 2 months and poor water protection.
What are the best stain options for my deck?
1.Deck Location State: Illinois, Chicago suburbs
2.Full Sun, Partial Shade, Full Shade: Full Sun most of the day
3.Wood Type: Cedar
4.Mold or Mildew Issues: No
5.The reason for Previous Stain Failure: New deck installed 7 months ago, no previous stain.
6.Previous Coating? If so brand name and type of stain (Transparent, Semi-transparent, Semi-solid, Solid Stain): None
Would like a semi-trans so we can still see the grain.
Thanks much for your help.
Pat
Deck Location State: Connecticut
Full Sun, Partial Shade, Full Shade: Full Sun for at least several hours a day, mostly at noon, but part of the deck gets full shade since it wraps around the house.
Wood Type: Pressure Treated Pine, probably.
Mold or Mildew Issues: Yes in spots. Especially when the shrubs grow in too close.
Reason for Previous Stain Failure: Peeling.
Previous Stain Brand and Type of stain. Not sure but something solid. The previous owners painted and 2 years later it’s all coming off.
We’re planning to have a professional power wash, sand and paint our deck this summer. He recommended Behr Deckover but after reading all of the reviews, including on this site, I’m not so sure it’ll work. Our goal is to have something that’ll ensure high traffic from our dogs. Pretty soon they’ll both be at 150lbs.
Try the Gulf Deck Revive: https://www.deckstainhelp.com/gulf-synthetics-deck-revive-review-2015/
Deck Location State: Central Alberta, Canada
Full Sun, Partial Shade, Full Shade: We have several levels and areas of the deck located to the north and east of the house
Wood Type: Pressurized wood but unknown, see image attached with extra wood stored below the deck.
The reason for Previous Stain Failure: Peeled after first Winter.
Previous Coating? If so brand name and type of stain (Transparent, Semi-transparent, Semi-solid, Solid Stain): Olympic Maximum Stain + Sealant for the floors; SICO Exterior Latex Semi-Gloss Primer + Paint for the railing and verticals .
Images show the paint condition after 3 years but started already already after first winter, see images. Deck is estimated 10 to 15 years old, had solid paint on before we painted it. The old paint was mostly removed.
Thank you for your help!
You will need to paint again with a solid color stain unless you want to sand it all off?
can you give me both options and also the recommended products for each? Thank you.
If you use a solid color stain, try the Flood Solid Stain. If you sand it off, use a penetrating semi-transaparent like Armstrong Clark.
Hi. I am looking for a high-rated pigmented deck stain product. I have used Sherwin Williams. Am not happy with it.
Help appreciated.
Any of these top 6 would work as they are all penetrating semi-transparent wood stains. Make sure to fully remove the SW first.
thank you for your quick response! i wasn’t sure if all those brands did not offer color stains. i know Behr does.
I have rental property and the deck needs some TLC.
Located: Georgia
East facing/full sun
Pressure treated wood
Previous stain unknown
What is the best option with lowest maintenance?
Prep with Restore A Deck Cleaner/Brightener kits and stain with TWP 100 Series or Armstrong Clark.
thank you
I am building a small barn central California lots of sun. I have 2×6 TnG kiln dried pine walls and lots of them. Considering outlast q8 timer oil or Thompson’s teak timber oil but heard reviews that this turns too dark. I want longevity not that peeling topcoat. Help recommendations? Thanks
TWP 1500 Series or Armstrong Clark.
Deck Location State: Utah
Full Sun, Partial Shade, Full Shade: Partial shade (north side of house)
Wood Type: Cedar
The reason for Previous Stain Failure: Dried Blotchy and Peeled after first Winter.
Previous Coating: Thompson Water Seal Semi-Transparent
Prep by removing the Thompsons. Strip and sand. Brighten all after. Stain with Armstrong Clark or TWP 100 Series.
Deck location: West Michigan
Upper level deck with staircase and railing. North side of house, full sun, full shade under eaves, no mold issues but some algae under overhang, several trees
Built in 1990 – pressure treated wood that was treated every 2-3 years with CW-F UV clear finish until 2010 then nothing with exception of a few power washings. I have found a locally-owned company who comes highly recommended to restore it. They hand-brush everything using Sherwin Williams semi-transparent oil-based Superdeck. I would prefer a natural finish but they are recommending a stain for longer lasting results. Although this product doesn’t rate as high as others, what are your thoughts on using it and whether I should go clear or use a stain? If I go with a stain, how much effort would it take to go back to natural in a year or two or change product?
Clear has no UV protection. You need a stain for this. We do not like Super Deck. Turns black or dark brown in color. Easy to remove though if ever needed. Just strip and brighten.
What product would you recommend for this deck?
TWP 100 Series. Your contractors will like it better as well.
Hi..
New Deck installed aug 2017..love the idea of bringing indoor floor color outdoors.
We have selected color and purchased qt of Cabot® Sunlit Walnut Gold Exterior Finish Oil-Based Stain to sample color. this to compliment hardie english tudor style siding artic white/chestnut brown timber :hmm: :hmm: :hmm:
Deck Location State: Chicago, Illinois (few 3mi west of lakefront)
Wood Type: Pressure Treated Pine Ac2 copper infused
Reason for Previous Stain Failure: none
Previous Stain Brand and Type of stain: new deck
We would like to use Cabot® Sunlit Walnut Gold Exterior Finish Oil-Based Stain but am I correct in thinking that this will not wear properly on new deck.
As this appears to be a new formulation, i can not find any reviews on application on new deck, but it seems that bare new (in my case PT (Weathershield brand) wood from Home Depot) is the best surface to start with.
My dream to have easy care, not use solid or chalky semi trans. willing to clean and brighten.
My reality if this is not easily doable to get this look, what are suggestions to get us in the ballpark…
Many thanks,
Mrstoni
The Cabot Gold is a filming product that dries and leaves a shine on top of the wood. This is not a good idea. It will be prone to peeling and uneven wearing. See this for tips on new wood: https://www.deckstainhelp.com/staining-a-new-deck/
Thank you so much. now gotta find a rich color match in a stain. the top 3 recommended oddly enough not available at home depot or menards nevertheless thanks and best to my fellow deck mates
None of the top brands will ever be found in a big box store nor will a big box store ever sell a top product. There is a reason behind this and it is called “cheapening” the products at the big box stores. They do it all the time and for many different brands of products, not just deck stains.
https://www.deckstainhelp.com/deck-stain-quality-at-lowes-or-home-depot/
pardon delay … aren’t you just awesome!!! We will order online and wait.
:smile: :grin:
Looking for best stain recommendation!
Minnesota
Full afternoon sun (and snowy winters obviously!)
It is a newly built deck, pressure treated pine.
Not sure if it matters, but part of the deck is higher and part is a wood deck patio, so near the ground. Thanks!
1. Central Pennsylvania
2. Partial shade all day due to trees
3. Treated pine
4. Mold and mildew
5. It’s been years since we have done anything to the deck other than power wash
6. Almost 10 years ago: Calbot transparent oil
It needs it! Clean and brighten for the prep to retore the wood. Stain with Armstrong Clark or Restore-A-Deck Wood Stains.
I have a very large older redwood deck(prob 15 plus years)the wood is in surprisingly good shape and in the past I’ve been able to retore it with goood results. However the stain ive used in the last few years hasnt help up well at all. (Olympic brand) Its been power washed by the previous owner and has some deeper grooves. I have previously stained it with a semi-trasparent stain and it has faded, peeled, and turned dark/grey after about a year. I have been staining it every other year and I went a bit heavy on the stain in the past and some old stain is still present. Today used a cleaner to clean and to lighten the grey/mildew areas. I will sand in a few days to get as much of the remaining stain off and then hope to use the most durable product available to re-stain. The deck looks great with a semi-transparent stain and i like the color in the photo on this page. I live in Nevada near Cali border. , The deck gets full sun, sees hot temps, and is fully exposed to the elements.
That is TWP 101 Cedartone in the above picture. You can use this in NV.
What is the best stain for NW corner of WA state with full morning sun, early afternoon? Just pressure washed & replacing old boards with treated ones.
Tyr the TWP 100 Series or Armstrong Clark.
Deck Location State: Ohio
Wood Type: Unknown (previous owner installed)
Reason for Previous Stain Failure: Began to peel in heavy traffic areas / heavy sun areas.
Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): Pittsburgh Ultra Advanced Semi-Transparent
Strip and sand for the prep. Brighten all after. Stain with TWP 1500 or Armstrong Clark.
Any recommendations on sanding? I have a hand held “sheet” / “palm” sander that I could use, but this is unfortunately going to be around 1200sqft of horizontal deck boards / stairs. A awful lot of on your knees work. If no other option exists however it’ll be done!
Strip first. If it all comes off, no need to sand. Do you know if the Pittsburgh was oil or water-based?
It states on the front neutral base however the stain canister also says latex and acrylic, which I believe is normally water based ?
Yes, correct. That also means it will be hard to strip. You may need to rent a drum sander. See how much comes off first with the stipping before deciding on what to sand with.
What’s the best stain for southern NH, a deck with full morning sun and partial afternoon sun. Just bought the house over the winter, deck looks like it was pressure washed.
Prep this wood first by using a deck cleaner and then a wood brightener. Stain with TWP 1500 Series or Defy Extreme Stain.
We used Behr deck restore and it bubbled and peeled and they said we must not have prepared the surface correctly. Well we did and we used the cleaner and it is a mess. We now have to power wash and clean and sand the deck. If we cannot get all of the paint off what product do you recommend to paint it that will cover the cleared area and the not entirely clear area
You will need to sand it all off as nothing can be applied on top of it to fix the issues with peeling.
State: Georgia
Mostly Shade
Some mold
Deck has not been stained in 10 years
Not sure what type of stain was used before
The pictures were taken after a week of rain and the deck is still a bit wet.
Hello, prep with the Restore A Deck Products and stain with TWP 100 Series or Restore A Deck Wood stains.
We have a 3 year old cedar dock on an inland lake in Upper Michigan. Full sun in the summer, under snow banks in the winter. Mildew and moisture are a concern. We stained it when it was brand new, but now it looks weathered and greyish in color. We have power washed it already and are ready to treat it with something that gives it the fresh cedar look.
Try the TWP 100 Series.
state: colorado
full sun
no mold
we just purchased the house so im thinking it is some sort of redwood or cedar deck boards. The deck has not been stained in probably 3-4 years. I do not know what it was previously stained with.
Strip and or sand for the prep. Brighten after when done removing the coatings. Looks like multiple layers so may be hard to remove, but it has to come off. Stain with Armstrong Clark or TWP 100 Series.
Roof top deck, full sun
Wood Type: pressure treated pine
New deck floor, installed 18 months ago, no stain
Old railing, has some left overs of BEHR Premium DeckOver. The product started to peel 6 months after the application
For the floor, clean and brighten for the prep. Stain with Armstrong Clark or TWP 1500 Series. For the railings, you will need a solid color stain to cover the Behr. Try Flood Solid Stains.
What Flood stain do you recommend?
I see Flood FLD822-01 Pro Series Solid Color Stain
Flood FLD825-01
Flood FLD390 1G SWF-SOLID
The prices are rather different
Flood SWF-SOLID or Pro Series Solid Color Stain
We have just power washed and stripped our 30-year old deck. We are almost ready to stain – if this rain ever stops. We are in NE Pennsylvania. The deck gets 80% sun in summer and 20% sun in winter. We do not want a painted look. What stain would you recommend? Thanks.
I will look into these. Thank you!
Hello. I have used the Ready Seal in the past. I am considering a switch in brands. What would be the benefits if any if I switched? How to prep?
Ready Seal is a decent stain but does have a tendency to fade quicker than some other brands. The reason is that Ready seal is a paraffin based stain and does not actually cure. Switching brands may give you an extra 6-12 months over the Ready seal when it comes to UV protection. To switch, use a stain stripper and pressure washing to remove any remnants of the RS. Brighten when done. Ready Seal is very easy to strip off so no issues there.
Pennsylvania
Full afternoon sun (and snow)
Unsure of wood type and age
Wood is starting to crack some
some green stuff (algae? it’s been a WET spring)
unknown stain, hate the color of it
What type of stain is it? Please post a picture.
I am having a new porch built as I write this. How long should I wait before I apply a water sealing stain? I live in south Louisiana
Hi Jane, see this about new wood: https://www.deckstainhelp.com/staining-a-new-deck/
What stain would you recommend for a summer cabin, either clear or semi transparent for protection. Also I would like something I do not have to apply every year.
full sun for 75% of the day
wood type: new pressure treated hem fir, unless you have a recommendation
mold or mildew: yes
I would replace the existing deck with the new lumber
Is there a current coating on the cabin? If so, it will need to be stripped or removed first. Once prepped, try the TWP 1500 Series.
For the new deck, see this for tips on new wood: https://www.deckstainhelp.com/staining-a-new-deck/
Washington state
Full sun
Not sure what type of wood
Yes
Peeled quickly
Thompson’s waterseal
You will need to sand and strip to remove the Thompsons. Once removed, try the TWP stains.
The whole deck stain industry BS. After having 1000sqft+ of redwood decks for the last 20 years I’ve come to the conclusion that most of the websites and “experts” are tools for the manufacturing companies. In the end… I’m back to $20/gallon Thompson’s as my reliance upon the experts as well as customer reviews has not turned up a product that warrants paying more. They all fade, they all fail. Nano particles, paraffin, penofin, this oil, that oil it’s all BS. One brand that gets touted on one website gets trashed on another, or at least users tell the truth… They all fail in the first year. So, why bother spending big bucks and countless hours searching and then spend hundreds more dollars on say Cabot, or SuperDeck or Defy or on and on and on. Put a basic, inexpensive brand on that has been around for decades and call it a day. Because even if you decide to use one the “experts” choices there is very high probabability that unless you are in say, Michigan that you cannot buy it without having to either order it online or drive out of your local neighborhood. And, before the creators of this advertising website take my post down, please at least have the balls to fess up to the fact that in some manner, no matter how convoluted the money trail may be… you are making money off touting RestoreADeck products and / or the others. Or, show us the science and testing behind the scenes, all of it.
Really? :roll:
This site is geared to help people and offer advice to use if they want to or not. Your comments and assumptions are to put nicely, “uneducated”. Normally we would not bother to respond but this is fairly easy.
-The industry is not BS. A quality deck stain will easily last 2-3 years if prepped and applied correctly. Our expertise comes from 25 years restoring decks and offering advice.
-Thompsons is useless. Have fun doing it every 6-12 months.
-Of course, all stains fail eventually. We do not lie to consumers and make ridiculous claims like some stain brands do. We do the opposite and give realistic ideas as to how long it will last using a quality brand. 2-3 years is at the most on a quality deck. We also suggest brands that are “easy” to redo as needed as nothing lasts forever.
-They do not all fail in the first year. Do you really think the 10s of thousands of people who have asked questions on this site and the millions who read it annually would agree with you and that our advice in invalid?
-The products we suggest can be found in local stores. Some on a national scale and some regional.
As for “Who We Are?” we have never, ever shied away from where our advice and expertise comes from. In fact, this is found in the very first article on the homepage. We have always been fully transparent with this site, why we do it, and our history in the business.
If you would have ever asked us a question as to “What is the Best Deck Stain” for me, we would have helped and offered our advice on how to prep and what would be a good option for your environment but instead you felt the need to resort to inaccurate comments and slander this website.
Anyways, hope you enjoy doing your deck every 6-12 months with the Thompsons!
Deck Location State: Missouri
Full Sun, Partial Shade, Full Shade: Full morning and early afternoon sun
Wood Type: Cedar
Reason for Previous Stain Failure: Large hail storm within weeks of being done that caused circle spots and peeling.
Previous Stain Brand and Type of stain (Solid, Semi-transparent, Transparent, etc): Thompson’s water seal semi-transparent
Remove the Thompsons first by stripping and sanding. Brighthen the wood when done. Stain with TWP 100 Series or the Armstrong Clark.
1. Deck Location State: North Florida (rain, heat and humidity – though not year round)
2. South facing – protected area with limited morning sun and primarily afternoon shade
3. Wood Type: Pressure treated Pine
4. Mold or Mildew Issues: Not yet! — new construction (still in the building phase)
I need some advice as to which brand, water base vs. oil etc. Deck builder has some concerns about using product that is unavailable locally – i.e. warranty issues if there is a problem. I am leery of what is available locally, especially after reading reviews on this site as well as others. Also, the builder would like to stain deck in 3 months or so of completion — is this okay?
After the wait and prep, try one of these brands: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
South Central Kansas
Deck on east side of house – full sun/shade in evening
Pine
No
No idea on previous products – if any
Deck is 10+. Just cleaned with outdoor bleach
Try the Restore-A-Deck Wood Stains or the TWP 100 Series.
Ohio
Full sun
Untreated Yellawood (sorry, unsure of spelling!)
No mold, but wood is very gray from elements (swingset is about 2 years old)
No stain, sealant ever applied
Thx for your help in choosing a stain plus sealant
Prep with Restore A Deck Cleaner and Brightener Kits. Stain with Armstrong Clark in a semi-solid stain.
1.New York, Upstate (winter a lot of snow and ice)
2.Shaded in morning full sun in afternoon 12-6 in afternoon
3. Pressure treated pine
4. No
5. We used a terrible product called Deck Over. Lasted one year and peeled. We removed this mess last year and now the deck is ready to be stained. The deck is very gray. I have ordered Deck and Wood Cleaner/Brightener 1 & 2 to prep the deck first.
6. Deck Over which is basically a thick paint (awful stuff)
Try TWP 1500 Series or Armstrong Clark wood stains.
Illinois
Full sun
cedar
no Mold
Behr stain
This is an older pool deck. Very faded
What would the Best stain be??
Also need it to not be hot on feet!!
THANKS
You will need to strip and sand to remove the Behr. Brighten all when done. Stain with Armstrong Clark or TWP 1500 Series.
1. Shenandoah Valley Virginia
2. Full sun a.m., shade afternoon
3. pressure treated pine
4.. some algae, some cracks
5. don’t know brand; semi-transparent stain
Prep correctly first. Sain with TWP or Defy Extreme stains.
1 Central Illinois
2 full sun in a.m., shade in afternoon
3. Cedar
4. Looks dirty. Cleaning removes stain with the dirt.
5. Not sure of the brand but think it was semi-transparent stain
Prep with the Restore A Deck Stripper/Brightener kit so all dirt and old stain is removed. Stain with TWP 1500 or Restore-A-Deck Wood Stains.
1} Michigan
2) full sun to shade in PM
3) treated pine, 25 yrs old
4) moss & algea
5 & 6) Sikkens SRD 5 – 6 yrs old
After sb
Scrub and hard power wash.
What’s better, preferred than Skikkens.
You will need to remove the Sikkens for the prep as you cannot apply another brand on top. Use the Restore-A-Deck Stripper and Brightener Kit. Once removed, try TWP 100 Series or Restore-A-Deck Wood Stains.
Deck in eastern PA
Eastern exposure-Fullsun AM and till mid afternoon
Cedar
No mold mildew
Peeled and blotchy from previous application of Zar Clear Wood Sealer last year
Will sand it off and apply ?????? Help!
After removal, try the Armstrong Clark or TWP 1500 Series.
Deck Location State: Northern Illinois
Full Sun, Partial Shade, Full Shade: Full Sun in Am, Shade in Afternoon
Wood Type: treated
The reason for Previous Stain Failure: Wore off in first year
Previous Coating? If so brand name and type of stain (Transparent, Semi-transparent, Semi-solid, Solid Stain): Thompson Semi-Solid
Strip and or sand to remove the rest of the Thompsons. Brighten all wood when done. Stain with TWP 1500 Series or the Armstrong Clark.
Southwest Ohio
deck is probably 25 or so year old pressure treated lumber.
On west side of house receiving no morning sun. Does receive afternoon sun.
Some mildew in shaded areas.
Does not appear to have ever been stained but I found a folder when I moved in indicating some type of treatment was applied in 2015 by a company called “Seal Smart”.
Never heard of “Seal Smart”. Prep by cleaning and brightening the wood. Stain with TWP 1500 or the Armstrong Clark.
Thanks for your help!!
Hi, we have built a new deck attached to an old deck. The old deck is about 10 years old and we don’t think it has ever been stained.
1. Close to New York state.
2. South facing. Full sun
4. No issues
5. &6. Has never been stained
See here about the new deck: https://www.deckstainhelp.com/staining-a-new-deck/
It will have to weather first. Prep all after the weathering and stain with TWP 1500 or Armstrong Clark.
Thanks. I forgot to mention that the new deck was 1 year old so we are good to go. Do you think I can use a spray applicator or should I stick to a paint brush?
Stain pad or brush.
Thanks. I have another question: I’m actually in Canada and could get the twp 200 instead of doing the journey to the states. (I find the shipping fees for Armstrong really expensive).
Would it be ok? It mentioned it is for older shingles, would it be fine on my one year old deck?
Thanks again
Sure. Just takes longer to cure and dry on a deck.
Southern Ohio
Shade in morning/ full sun noon – 7:00
PT lumber 3 years old
No mold or mildew, minor algae around furniture
No previous stain failure, 2 years since last staining, want a high quality semi-transparent or semi-solid
Sikkens Cetol SRD
Strip and brighten to remove the Sikkens. Stain with TWP 1500 or Armstrong Clark wood stains.
Brand new cedar pergola in western Washington state. Gets full sun. I’m hearing adding extra penetrol and linseed oil could be a good thing, to the semi-transparent stain (Cabot) that I bought. Plan to apply with wide brush. Thoughts?
Let it weather and properly prep before applying the new coating. Do not add “additives” to a deck stain. It will not help.
Thanks!👍
What is the best deck stain/sealant for a tigerwood deck, full sun (Texas sun, yikes!) on 2/3rds, roof over remaining, good condition, previously treated with Penofin penetrating oil finish. Didn’t fail, per se, just but has been several years and this Texas sun is unrelenting. Thank you so much!!
Strip and brighten to remove the Penofin. Stain with Armstrong Clark in a hardwood color or the Defy Hardwood stains.
Our deck was built in 2002 and first stained in 2009. It’s time to be re-done.
1. Location state: NW Lower Michigan
2. North facing. 80% sun in the summer. Much less during winter months.
3. Wolmamized pine.
4. Algae, especially in shade dominated areas.
5. The previous stain reached the end of its life span.
6. Previous stain … Cabot oil-based semi- transparent (not sure about the semi-transparent part)
Looks like a semi-solid and not sure if it can be stripped. Too thick in areas, almost like a solid stain. Try stripping and pressure washing to remove as much as possble. Sand if needed to remove the rest. Brighten all after. Stain with TWP 100 Series or Armstrong Clark.
We have decks that need to be redone:
1. Location State: Memphis, TN
2. Mostly shade, a few areas get sun from 11am-2pm
3. Wood Type: Cedar (I think, looks like standard deck wood)
4. yes, mold and mildew issues
5. skipped using the wood brightener and could tell by the end of summer mold was coming back through. Color faded and can barely see it now, no flaking or wear patterns
6. Used Behr water based semi-transparent stain 2-3 years ago,
Strip, pressure wash, sand if needed, and brighten for the prep. Stain with Restore-A-Deck Wood Stain or Defy Extreme.
Thank you so much! I am struggling with whether to use another water based or go with oil based this time, I have read so much on this site that I am feeling a bit overwhelmed and thinking I should do touch ups every other year so they don’t get so bad again. Is one preferable (oil vs water) for easy touch ups in the future?
What a job this has become! I have so much to do I hired a company to do the initial makeover. I don’t think it has been as easy as they thought. They have cleaned the decks and are now trying to strip it and power wash it but it isn’t going as well as expected.
Though they were pro defy products before we started, they are now suggesting to go back with a behr product (which is the original product we used) and want me to do a solid stain. From all that I have read i do not want to begin that nightmare, and I feel that they just don’t want to put any more labor into it.
So my question is, can I get decent results if I go back with a behr semi transparent stain if they cant remove all the old one, and if so, can I apply a darker shade?
Here are pictures after cleaning, stripping and power washing.
Don’t use Behr again. It will repeat the issues. If you cannot get it all off, a solid will cover the rest. We like the Flood Solid Stains when we use them.
Bless you, I didn’t want to use behr and the solid stains worry me. I am going to try and push for sanding before we give up but If we have to go that route I will look into the Flood stains.
We are on our 3rd coat of stripper and pressure washing, here are some pictures after the 2nd stripper and at the beginning of the 3rd. The deck is definitely aged and will need some light sanding from all the frays power-washing left behind. I have my flood solid stain picked out for the railings but am still having to be persistent with the contractors not to use it on the horizontal surfaces.
My question is this, I believe we finally have it clean enough (after the 3rd round is completed and sanded) to put a semi-transparent stain on it, but is it clean enough to go with oil based this time or should we stick with latex? Flood makes both so I can stay with the same product. I am hoping next time I post to this site it is with pictures. :)
Good to go with oil-based.
uuggg………The PPG store manager is suggesting flood semi-opaque for the horizontal surfaces since the wood is so old and there are many color variations in it, he thinks it will give a more even coverage but I am worried it is similar to the solids (though it is still oil based unlike their solids). He assures me they arent but hey, I have been through a lot to get to this point. Still going with the Flood solids for the rails.
Thoughts?
Almost there!
Don’t use the Flood Semi-solid.
Ok, the color I picked can be matched in the semi-transparent, but does that just mean they add more pigments which then makes it a semi-solid? If so, I will just find a more suitable color in the semi-transparent and go with it.
