TWP 100 Pro Series Wood & Deck Stain Review 2026 4.7/5 (93)
TWP 100 Series Review
🔹 Quick Verdict
  • Best For: Older decks, weathered wood, easy maintenance
  • Not Ideal For: New brand wood (needs 4+ months of weathering) or hardwoods.
  • Type: Penetrating oil-based stain
  • My Overall Rating: 8.63/10
TWP 100 Series Description
How I Rated TWP® 100 SERIES
  1. The appearance of TWP® 100 SERIES after Application
  2. Preventing UV Graying
  3. Peeling or Wearing
  4. Cost Per Square Foot
  5. Preventing Mold and Mildew
  6. How Easy was the TWP® 100 SERIES Application
  7. Color Shifting
  8. Ease of Reapplication
  9. TWP® 100 SERIES Final Score
8-Step Review of TWP 100 Series
3. Wear/Tear and Peeling: 9
4. Cost Per Square Foot: 8
5. Preventing Mold/Mildew/Algae: 9
6. Ease of Application: 9
5.00out of 5
5.00out of 5
5.00out of 5
More Info: TWP 100 Series
Dry Time: 2-12 Hours
Deck Square Footage: 700
UV Exposure: Deck in full sun
TWP Pecan 120
🔹 Pros and Cons
TWP 100 Pro Series – Pros
  • Excellent penetration into older and dry wood
  • Does not peel or flake due to its non-film-forming nature
  • Very easy to reapply with minimal prep
  • Enhances natural wood grain without creating a heavy surface coating
  • Proven track record over many years in real-world use
TWP 100 Pro Series – Cons
  • Color fades faster in full sun exposure
  • Not ideal for hardwoods like IPE or exotic woods
  • Limited availability in some states due to VOC restrictions
🔹 Best Wood Types for TWP 100
  • Cedar: Excellent penetration and enhances natural grain
  • Pressure Treated Pine: Works very well after proper weathering (3–6 months)
  • Redwood: Good absorption and natural look
Not Recommended For:
  • Hardwoods (IPE, Cumaru, etc.) – will not penetrate properly
  • Apply to clean, properly prepped wood
  • Do not over-apply
  • Apply thin, even coats
  • Back-brush if needed for uniform coverage
TWP 100 Maintenance Tips
  • Recoat every 18-24 months for decking, depending on sun exposure
  • No sanding or stripping is typically needed
  • Use a deck cleaner and brightener before reapplying
  • Apply a light maintenance coat before the stain fully wears off
🔹 Who Should Use TWP 100?
  • Your deck is older or has weathered wood
  • You want a stain that is easy to maintain long-term
  • You prefer a penetrating oil over a surface film
  • You do not want to deal with peeling or stripping in the future
🔹 FAQ Section
TWP 100 Pro Series – FAQs
How long does TWP 100 last?
Does TWP 100 peel or flake?
It performs well in full sun.
🔹 Final Thoughts on TWP 100
1.3K Comments
Jeff Devore
Jeff Devore
TWP 100 series stain
Pressure Treated Southern Yellow Pine
Used Gemini 2 part cleaner
Andrew
Andrew
Nemo
Nemo
Reply to  Andrew
Michael Bongiovanni
Michael Bongiovanni
Reply to  Andrew
Gary
Gary
Reply to  Andrew
Carrie kosenko
Carrie kosenko
Donald H. MacMullen
Donald H. MacMullen
Donald H. MacMullen
Donald H. MacMullen
Chris Charleston
Chris Charleston
donald h. MacMullen
donald h. MacMullen
TWP-101 Cedartone
John T. Lowe
John T. Lowe
14 hours ago
What’s your go to for staining a new deck with 5/4 deck boards?
Daniel R
Daniel R
8 days ago
i used several behr products on my deck, they have all peeled or worn. What can i do and use to fix it?
Jamie
Jamie
22 days ago
Recently stripped my PT deck
Previous stain was messmers UV plus. Impossible to get all stain out especially around knots. Is TWP semi a good choice for a new stain in this instance ?
Michael Tharp
Michael Tharp
7 months ago
I live in California. Probably not available right?
Annette Brown
Annette Brown
8 months ago
I bought the TWP 100 pro series in rustic and I am not liking it I thought it would be more brown is there anyway I can add too it to make it more brown?
MEGAN
MEGAN
10 months ago
We have a 5 week old deck (16×6 ft)in a wooded location with multiple black walnuts trees adjacent to the deck. The area is moist, cool and is mostly shaded by the black walnut trees. Our deck installer recommended treating the wood right away, not to wait 4-12 months. I am concerned that falling black walnuts will stain the deck, making it difficult to get an even stain coverage with semi-transparent stain next spring. What would you recommend? Thanks for your help.
Barbara Harcrow
Barbara Harcrow
11 months ago
I was thinking of buying the TWP 100 oil wood stain in clear for my teak deck, but it says that the clear does not have UV protection. I would like to keep the natural color of the teak. Do you recommend a different brand or a color that would not darken it? Also does the Gemini Restore A Deck Kit remove the old Penofin oil any better than the Restore-a-Deck. The RAD works better than others I have tried, but I am still having to scrub to remove the old oil. I have not used the stripper yet. That may be the route I have to go. I have about 1500 sq ft of decking and it is a big job. Thank you for any info.
Laura
Laura
I live in Central Oregon at 3000’ and have a new cedar fence completed in December 2024 that needs an oil based stain. I’ve heard Rodda performs well in the Pacific Northwest high desert.
We have used Sikkens (now ProLuxe) on our deck and been happy with it.
Would TWP do better?
thanks for your help
Laura
DANIEL
DANIEL
Hello!
What can I do to fill up cracks in my 25 year old pressure treated deck?
I used a coat of Cedar tone TWP-100 about four years ago (which is now faded) and want to improve this deck.
I may want to go over it all with a darker solid stain, too.
Is there some type of filler you would recommend?
1 9 10 11
1.3K
