TWP 200 Series Wood Stain Review 4.7/5 (5)
TWP 200 Series Review
TWP 200 Series Wood Stain Review for 2026
  • TWP 200 Series uses paraffin oil to penetrate deep into wood fibers, restoring flexibility and preventing peeling on exterior surfaces.
  • Expect the final cured color to take up to 30 days, as TWP 200 applies darker than the swatches before lightening to the correct shade.
  • UV protection scored a 9 out of 10, with very little color fading observed at the two-year mark on a full-sun cedar deck.
  • Reapplication is straightforward using the Gemini Restore A Deck Kit, with no stain stripper needed due to light, even fading over time.
  • TWP 200 Series is the only TWP product approved for use in Canada and is VOC compliant in all US states.
TWP 200 Series is a semi-transparent oil-based penetrating finish designed to extend the life of exterior wood such as decking, cedar shake siding, and shingles. Containing a paraffin oil, the TWP 200 series penetrates wood extremely well. Paraffin oil is a “non-drying” oil that enhances the wood cell’s structural stability. This greatly improves the wood’s life and appearance.
The penetrative portion of the product absorbs into aged and porous wood, adding bulk to aged and brittle wood fiber.  This restores lubricity and flexibility to brittle shingles.  The TWP 200 Series complies with all current Canada, US federal and state VOC (volatile organic compounds) regulations.
The TWP 200 Series was designed for shakes and shingles but can be used for all exterior wood surfaces such as decking, fencing, log homes, cedar framed homes, etc.
NOTE For Canadians The TWP 200 Series is the only TWP product allowed to be used in Canada according to TWP and the VOC laws of your country.
TWP Wood Stains – 200 Series Review
TWP 200 Series Wood and Deck Stain Scores (1-10)
– We have only used the TWP 200 Series a handful of times throughout the years. It is an excellent stain and on par with the TWP 100 and 1500 Series. In some ways, it is even better with UV protection than the other two. The main reason we have not used it more is due to the final color curing. This can take up to a month to reach the final color but usually only takes a week or two. The product goes on darker than the color swatches but always cures and lightens to the correct color. It just takes time, so if you use the TWP 200 Series, you will need some patience. After the product reaches, its final cured color, it is a very rich color that highlights the natural tones of the wood. It does not mask or hide the grain at all.
TWP 200 at 1 Year
Preventing UV Graying at 2 Year Mark: 9
– The 200 Series has excellent UV protection. Very little color fading after 2 years. We attached a picture of the 200 Series at the 1-year mark. This shows an outdoor rug that had not moved for 1 year. There was little to no color fading when the rug was pulled back.
Wear/Tear and Peeling: 9
– The 200 is a paraffinic oil, which means it is a non-drying oil. Paraffinic oils will dive deep into the wood grain so they are not prone to peeling or wearing.
Cost Per Square Foot: 7
– $215 per pail. The coverage is decent at about 200 sq. feet per gallon on the test cedar deck. We only used about 3-4 gallons total for the deck, railings, and steps.
Preventing Mold/Mildew/Algae: 9
– No mildew but a small amount of green algae.
Ease of Application: 7
– The only slight negative to the 200 Series is the dry time with the application. It applies similarly to other oil-based stains, but the final drying can take a few days, maybe longer. This happens because it takes time for the paraffin oil to fully soak into the wood grain. The older the wood, the quicker it seems to dry. Rain does not seem to harm the stain if it has not fully dried yet. You will just have to be patient with the TWP 200 Series if applied to a deck. Stay off until fully dried.
– The TWP 200 did not darken from mildew or UV discoloration.
The Difficulty of Reapplication: 8
– Reapplication will be as easy as using their Gemini Restore A Deck Kit. One of the kits will be enough to clean and brighten the deck for reapplication. No stain stripper will be needed to remove as the TWP 200 has faded lightly and evenly over the last few years.
Overall Score TWP 200 Series Stain at 2-Year Period: 8.25
– We like the 200 Series, but normally use the 100 or 1500 as it is more readily available. It has great UV protection and does not peel. The only slight issues are the dry time and final color curing.  This is a non-issue for vertical wood, but you will have to wait until dry for horizontal decking.
$67.99
$254.95
5.00out of 5
TWP Help? Search Google: TWP Stain Help
Direct Link: TWP 200 Series
Cost: $219 per 5 Gallon Pail. $45.99 per gallon.
Stain Type: Registered Wood Preservative by EPA. Oil-based Semi-Transparent
Available Colors: 200 Clear, 201 Cedartone, 202 Redwood, 203 Cedar Gold, 205 California Cedar, 206 Russet Brown, 207 Butternut, 210 Slate Gray
Coats Required: 1-2 Coats. Applied “Wet on Wet” Only 1 Coat for new smooth wood.
Dry Time: 12-120 Hours. The final color can take up to 30 days
VOC Compliant: 250 Compliant in all US States and Canada
Deck Wood Type: Cedar
Deck Square Footage: 400
UV Exposure: Deck in full sun
TWP 203 Cedar Gold
TWP 00 Series Deck Stain Photos
37 Comments
Dan
Dan
2 months ago
I’m looking to use this product for an untreated pine tongue and groove ceiling for an outdoor covered patio. It won’t be exposed to the elements other than being outside in both and cold climates.
Would you suggest the 200 or 1500 ? I’m looking for the least amount of maintenance.
Ilija Lukić
Ilija Lukić
5 months ago
How difficult is it to apply TWP 200 Series stain to deck under covered front porch with 2 steps vs applying TWP 1500 Series? Which would be a better choice? Deck is 11 years old and I have used other products in the past and it’s in very good shape. It has been professionally cleaned and stripped and sanded.
Debbie Bennett
Debbie Bennett
Hi Scott, do you know anything about the Dulux solid 100% acrylic stain for decks? it says protects from moisture and sun damage. looking for the next best option if I cant buy twp 200 stain that you suggested would be best for my new dec Thanks and sorry for the second e mail
Debbie Bennett
Debbie Bennett
thank you cant order twp 200 in canada. no dulux paint sore supplies it
Debbie Bennett
Debbie Bennett
Hi Scott, i had asked you about the twp200 semi transparent but it is not sold in Canada as they have mentioned on their site that they do. I inquired and the cost to ship is $170.00. Do you happened to know any stores in Canada that sell this stain. I called a dulux store and they are not able to buy anywhere in Canada either.
Julie
Julie
What stain color was used in the carpet fading comparison photo?
aMIR
aMIR
I have power washed and used brightener for my deck, but some spots still look darker or have a tone of green/grey when it gets wet (or after rain). Please see the attached photos for dry and wet conditions. I guess if I apply the stain the end product looks similar to the wet condition (?) What is your recommendation for the best choice of (not-so-dark) colour for a semi-transparent twp200?
Ruby Degenaar
Ruby Degenaar
Hello, I live 2 hrs north of Toronto, Ontario, in Canada. I’m just starting to stain my deck with your TWP 200 series stain which is going on beautifully. One question, should I apply a 2nd coat of stain to my deck and if so how long after I have applied the first coat of stain? My deck is very old. One more question, I’ve replaced some of the boards with pressure treated wood. Should I wait a year before staining this wood?Thanks for your help
Tyler Childerhose
Tyler Childerhose
What would you recommend for me living in Ottawa Canada? From what I can see the Armstrong Clark. Just not sure about winters.
Don
Don
What semitransparent stain/sealant would you recommend for new batten board siding and new redwood decks located in Flagstaff, AZ. One deck will be covered the other in the sun? What looks great with minimum maintenance?” Ready Seal” was recommended by my friend and our contractor recommended “Cabot”. Your reviews on TWP100 have me interested in it! I am looking forward to your comments.
Sam
Sam
I’m putting up rough cut cedar shakes right now on my porch. I’m really liking the look for my siding choice but I need to pick a stain and color to have for it. Seems obvious I should go with TWP 200, since it’s a good brand stain and this series is developed specifically for shakes and shingles. What I’m stuck on now is what color? Does anyone have experience on what color looks best on cedar shake siding? Thanks.
Sam
Sam
Thanks, I’m getting samples sent out.
Jason
Jason
Hi, what solid stain do you recommend? Does TWP carry any solid stain? And also is it true that only solid stain peels? The stain peels on our deck and I do not know what the previous owner used so I am guessing it was solid stain because it peels. But from review it seems even semi transparent stain peels. We are planing to do a power wash then stain with the closest color we can find. In this case, suppose the old stain is solid stain. what option do we have? If TWP does not offer solid stain is Sherwin Williams any good? Thanks.
Suzy T
Suzy T
Hi, I am in Canada and I cannot find any oil-based stains here. Do you know if I order from the US and have it shipped, will there be any issues with the VOCs of the TWP 200 for Canada? I may try and ship it to NY and pick it up to save on the shipping costs.
Ak Decor
Ak Decor
I READ THIS AFTER I GOT SUSPICIOUS: DeckStainHelp.com and other sites are fake review sites that only recommend products from “Defy” and “TWP”. Many people are fooled by it. It even has a forum where “Administrator” replies to all of the messages and tells people to buy TWP or Defy. Any posts that point out that it’s all a sham are deleted.
Suzy T
Suzy T
Not sure what the issue is? You advice and help is very much appreciated!
Ak Decor
Ak Decor
I can’t find either of the (allowed in Canada) two top rated deck stains on your site in any of the stores in the province of British Columbia, Canada. I can get it on line from the USA but do not want do this. can you suggest an alternative brand available in BC? Thx. Ak D
Ak Decor
Ak Decor
Hi, I live in Port Moody BC, Canada. It is pretty much a rain forest. Rains more than average in Port Moody compared to other areas in the lower mainland. Need to restrain, exposure is full sun and full rain depending on Mother Nature. I am taking your expert advice and going with the TWP brand. I believe you scored it as the best stain semi transparent stain. Would u recommend TWP200 series or the TWP. 1500 for my needs.
SimonH
SimonH
HI, I’m trying to figure out the best stain for a 2 year old pressure treated cedar deck. We are fine with it going the gray colour (don’t really want a coloured stain) – this is all about protection and making the deck last. slime/mildew protection are important as we are in southern ontario. Which would be better: ‘restore – a – deck’ in natural or TWP200 in clear? Thanks
37
