TWP Natural Effect Hardwood Stain Review 4.9/5 (2)
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior IPE and hardwood decking. My TWP Natural Effect Hardwood and IPE Stain review is based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain tips. See here for more info about me.
  • TWP Natural Effect earned an overall score of 9.2 out of 10, making it the top-rated stain for IPE and exotic hardwoods.
  • TWP Natural Effect is a two-part system, requiring the Impregnating Stain followed by the Natural Effect Top Coat Step 2 for full protection.
  • The stain showed outstanding UV protection, retaining excellent color on IPE test boards even after 2 to 3 years of sun exposure.
  • At $99.99 per gallon, cost is the only drawback, though its longer lifespan compared to other hardwood stains justifies the price.
  • No peeling, mold, or mildew was found after multiple years of testing, and the stain showed zero color shifting over time.
  • Reapplication requires cleaning with the Gemini Restore-A-Deck Prep Kit, and one coat covers 200 to 300 square feet per gallon on exotic hardwoods.
TWP Natural Effect Hardwood Stains
TWP® Natural Effect utilizes state-of-the-art European waterborne technology and is designed to revolutionize exterior wood maintenance… …while at the same time significantly enhancing performance!
Spend more time enjoying your investment and less time maintaining it with TWP Natural Effect.
Natural Effect is superior to beautifying and protecting your exterior wood investment!
  • The #1 Rated Exotic Hardwood and IPE Stain (It can be used on all exterior wood types)…
  • A Water-Based Exterior Wood Finishing System…
  • Utilizing European Waterborne Technology…
  • Designed to Revolutionize Exterior Wood Maintenance, While Significantly Enhancing Performance…
IMPORTANT NOTE
  • TWP Natural Effect Impregnating Stain is part one of a two-part exterior system. Must be top-coated with TWP Natural Effect Top Coat Step 2 for ultimate protection in an exterior environment.
Testing for Exotic Hardwood Deck Stains
Exotic hardwoods such as IPE are extremely dense and difficult to penetrate. When stained, these wood types will always fade faster than other woods such as Cedar, Redwood, and Pine. Testing for exotic hardwoods will be changed to 1 year instead of 2 years.
How I Rated TWP Natural Effect Hardwood and IPE Stain
My TWP Natural Effect Hardwood and IPE Stain review contains an 8-step process and the final average score. Each step is on a scale of 1-10.
  1. The appearance of TWP Natural Effect Hardwood and IPE Stain after Application
  2. Preventing UV Graying
  3. Peeling or Wearing
  4. Cost Per Square Foot TWP Natural Effect Hardwood and IPE Stain
  5. Preventing Mold and Mildew
  6. How Easy Was the Application
  7. Color Shifting
  8. Ease of Reapplication
  9. TWP Natural Effect Hardwood and IPE Stain Final Score
8-Step Review of TWP Natural Effect Hardwood and IPE Stain
1. Appearance After Initial Stain Application: 10
We used the Chestnut color on a section of IPE test boards. This color had a nice, rich, reddish brown and really made the IPE wood stand out. The stain was applied evenly with no blotchiness and 100% penetrated the wood grain. Adding the TWP Natural Effect Top Coat (Step-2) gave an added boost and made it “pop” with a slight satin sheen.
2. Preventing UV Graying at 1 Year Mark: 10
The TWP Natural Effect Stain has the best color retention we have seen for any stain tested on IPE wood. The test was done in 2021; to this day, the stain still retains excellent color on the IPE wood. The IPE test boards were fully exposed and in the sun for about 60-70% of the day.
3. Wear/Tear and Peeling: 10
The TWP Natural Effect Stain stain showed no signs of peeling on the wood, even after 2-3 years.
4. Cost Per Square Foot: 5
TWP Natural Effect Stain costs $99.99 per gallon. This is the only negative we could find about this stain. Considering that the TWP Natural Effect Stain will last twice as long as other IPE and hardwood stains is worth the extra cost.
After years one and two, we have not found any mold or mildew on the TWP Natural Effect Stain stain.
6. Ease of Application: 9
The TWP Natural Effect Stain is easy to apply. Being water-based, it was slightly harder to spread than an oil-based stain. We used a flooring brush for the entire area, and there was no need to back-wipe.
The TWP Natural Effect Stain did not darken in color at the 1 or 2-year mark.
8. Difficulty of Reapplication: 10
The TWP Natural Effect Stain must be cleaned with the Gemini Restore-A-Deck Prep Kit to remove dirt and grime.
Overall Score TWP Natural Effect Impregnating for Hardwoods Stain at 1 Year Period: 9.2
TWP Natural Effect Stain is the first TWP-branded stain suggested for IPE and other Exotic Hardwoods. As all TWP exterior coatings are excellent, we expected good results, and we were not disappointed. If you want the best UV protection for an IPE/Hardwood Stain, then TWP Natural Effect would be the top choice.
$110.00
Purchasing Info: TWP Natural Effect for Hardwoods
Cost: $99.99 per Gallon
Stain Type: Semi-Transparent – Water-Based Impregnating Stain for Hardwoods
Available Colors: Teak, Walnut, Mahogany, Black Ebony, Chestnut, Dark Walnut
Coats Required: 1 coat for most hardwood decking surfaces
Coverage Per Gallon: 200-300 sq. ft for Exotic Hardwoods
Dry Time: 2-6 Hours
Cleanup: Water
Deck Wood Type: IPE Hardwood
Deck Square Footage: Test boards
UV Exposure: 60% Shade 40% Sun
Chesnut
2 Comments
Tripp Flythe
Tripp Flythe
So if I’m understanding this right it’s not really $100/gallon; you have to add another $120/gallon for the Step 2 topcoat. I’ve got some cumaru decking that I’ve put Armstrong Clark on before as well as new, unstained cumaru decking. If I want to use this new TWP Natural Effect on the new and old decking, can I just use the same RAD strip/brighten for the new and old decking? Or would it be better to use the clean/brighten on the new stuff and strip/brighten on the old decking? At $220/gallon, this stuff better last for years on my cumaru decking.
2
