Why is My Deck Stain Peeling? 5/5 (1)
Why is my deck stain peeling?
Deck stain peels because it did not penetrate deeply enough into the wood. There are three main culprits:
  • Deck stain peels when it fails to penetrate the wood, often caused by using solid deck stains or clear sealers that form a surface film.
  • Overapplication of solid deck stains or semi-transparent stains can cause peeling within weeks or months of application.
  • Improper prep before staining prevents penetration into the wood, making peeling inevitable regardless of the product used.
  • Once peeling starts, the stain must be fully stripped and reapplied after proper cleaning, stripping, and spot sanding.
  1. The most common reason that deck stain peels is that a solid deck stain or clear sealer was used. These form a film over the surface of the deck that cracks and peels with wear.
  2. Overapplication of solid deck stains can cause peeling within a few months or even weeks. Semi-transparent deck stains can also peel when overapplied.
  3. The last reason that your deck may be peeling is improper prep before applying the stain. You must apply deck stain to a clean and prepared surface or it will not penetrate properly into the wood, causing peeling.
Once the deck stain peels it must be stripped and reapplied.
*Ships Free.
Makes 5-Liquid Gallons.
*Ships Free.
Removes Solid Stains.
How to apply deck stain with deck stain peeling?
peeling deck stainMake sure that you apply the deck stain with appropriate tools like brushes, sprayers, or deck applicators. Do not use too much stain and distribute it evenly. Rollers can work with solid stains, but they also make it easy to overapply and cause deck stain peeling.
How to prep deck with deck stain peeling?
Proper prep is important to ensure that the deck stain can penetrate and seal the wood. Proper deck prep includes stripping off the old stain, cleaning the deck, and spot sanding any stubborn spots. This should be done before staining so that it does not peel.
More information on how to stain a deck
0 Comments
