IPE Oil Hardwood Stain Review: Honest Test Results 3/5 (3)
Welcome to Deckstainhelp.com, your source for industry insights and tips on executing the perfect deck stain project. IPE Oil is a semi-transparent, oil-based hardwood stain formulated specifically for dense exotic woods like IPE, Tigerwood, and Cumaru. Please leave me a comment if you’ve used IPE Oil Hardwood Stains and the type of hardwood and brand of stain used.
Quick Answer: IPE Oil Hardwood Stain
  • Scored 7.38 out of 10 in our 1-year test on an 800 sq ft IPE deck in full sun
  • 70% color retention at the 1-year mark — decent for exotic hardwood but below Armstrong Clark's performance
  • IPE Oil is the same formula as Messmers UV Plus for Hardwood, relabeled with a browner tint
  • Covers 300+ sq ft per gallon on hardwood — only 1 coat is needed or recommended
  • At $74.99/gallon, it costs nearly as much as Armstrong Clark ($83.95) which scored better, and Restore-A-Deck ($52.99) offers stronger value
My Pro Tip: IPE Oil is Messmers UV Plus for Hardwood Stain, just relabeled with a slightly different “browner” color.
Note: See here for other exotic hardwood and Ipe Stain Reviews: Exotic Hardwood Stain Reviews
IPE Oil Deck Stain Rating
IPE Oil Hardwood Stain ReviewIpe Oil™ Hardwood Deck Finish is the best solution for your hardwood deck. Ipe Oil™ Hardwood Deck Finish will penetrate the densest of exotic hardwoods, protecting and conditioning while at the same time maintaining a completely natural appearance.
IPE Oil Stain provides excellent penetration into naturally dense woods to provide adequate water and UV protection. IPE Stain is recommended for woods such as Tigerwood, Cumaru, and IPE decking and wood siding surfaces. It aids in preserving the natural beauty of these exotic wood types. IPE Oil Hardwood is an oil-based VOC compliant formula.
Contents
  1. IPE Oil Hardwood Stain Scores
  2. How IPE Oil Compares to Other Hardwood Stains
  3. How to Apply IPE Oil Hardwood Stain
  4. Product Information
  5. Frequently Asked Questions
Important Note: Testing for Exotic Hardwood Deck Stains
Naturally dense hardwoods such as IPE are difficult to penetrate. The stain will always fade quicker on these wood types than other types of exterior woods like cedar and pressure-treated pine. Therefore our typical 2-year test will be changed to 1-year.
IPE Oil Hardwood Stain Stain Scores (1-10)
–IPE Oil is available only in a natural finish. This pigmented transparent finish helps enhance the natural wood grain beauty. The final finish of our test IPE surface after drying was a rich, warm brown tone with a slight reddish glow. It really was quite beautiful.
Preventing UV Graying at 1 Year Mark: 4
–At our exotic wood stain inspection after 1 year we observed 70% color retention. Considering the dense nature of IPE this was a fair amount of color retention compared to other hardwood stains we have tested.
Wear/Tear and Peeling: 9
–No peeling was visible after 1 year. This is common for a good penetrating oil stain. Even the high traffic areas showed no peeling or wearing.
Cost Per Square Foot: 6
–IPE Oil Stain for Hardwoods is on the more expensive side at $74.99 per gallon with free shipping. Luckily IPE Oil has a great coverage rate. We experienced a coverage rate at over 300 square feet per gallon. This is twice the coverage rate of softwoods. For our 600 square foot IPE test deck, we used 2 gallons in total.
–There was some mildew present after 1 year on the outside rails and in some corners.
Ease of Application: 8
–IPE Oil Hardwood Stain was applied using a stain pad. We back wiped excess stain after waiting 20 minutes. Coverage was very good and the whole stain project was finished in 3 hours.
Color Shifting (darkening) after 2 Years: 8
– With small amounts of mildew growth, there was no noticeable darkening or color shifting with IPE Oil Hardwood Stain after 1 year.
–Prior to a recoat of IPE Oil Hardwood, a thorough cleaning would be needed using a wood cleaner to rid the wood of dirt and grime. This is all that would be needed for a proper prep before a recoat of IPE Oil.
Overall Score IPE Oil Hardwood Stain at 1 Year Period: 7.38
–Besides the user-friendly application and excellent coverage rate, the finished appearance is very rich. We believe that IPE Oil Hardwood Stain is a decent product for any exotic hardwood that requires yearly maintenance. That said, it is priced higher per gallon than two competitors that scored better in our testing — see the comparison below before you buy.
IPE Oil is one of several hardwood-specific stains we’ve tested on exotic wood. Here’s how it stacks up against Restore-A-Deck, Armstrong Clark, and Penofin based on our independent testing.
Product Our Score Cost/Gallon Coverage on Hardwood Key Note
Restore-A-Deck Wood Stain Excellent color retention, no wear or peeling at 1 year $52.99 250 to 300 sq ft Only hardwood stain that can go on damp wood — prep and stain same day
Armstrong Clark Hardwood Best-in-class color retention on IPE at 13 months $83.95 200 to 300 sq ft Outperformed every other hardwood stain we tested for fade resistance
IPE Oil (this review) 7.38/10 — 70% color retention at 1 year $74.99 300+ sq ft Same formula as Messmers UV Plus for Hardwood, relabeled
Penofin Hardwood 6/10 — UV failure, mold issues $74.99 300 to 400 sq ft Not recommended — manufacturer suggests reapplication every 3 to 6 months on IPE
My Pro Tip: If you want the best color retention on IPE regardless of price, Armstrong Clark tested best in our lineup. If you want the best value with strong performance, Restore-A-Deck is the more affordable option and offers the added convenience of same-day prep and stain. IPE Oil performs adequately but costs nearly as much as Penofin while outperforming it — if you’re already considering this price range, it’s a reasonable middle choice.
  1. Clean the wood. Use a wood cleaner to remove dirt, mildew, and any surface grime. For decks with existing stain, strip and brighten before applying IPE Oil.
  2. Let the wood dry fully. Allow at least 24 to 48 hours of dry time before staining, since IPE Oil is oil-based and will not bond well to damp wood.
  3. Apply with a stain pad, brush, sprayer, or roller. A stain pad gives the most even coverage on dense hardwood surfaces.
  4. Wait 20 minutes, then back wipe excess stain. IPE and other hardwoods absorb far less product than softwoods, so excess stain left on the surface will remain tacky if not wiped off.
  5. Apply only 1 coat. Hardwood is too dense to properly absorb a second coat — a single coat is both sufficient and correct for exotic hardwood species.
  6. Allow 4 to 12 hours to dry before exposing the surface to foot traffic or moisture.
Where To Buy: Mostly Online with a few retail stores
Cost: $74.99 per Gallon, Free Shipping
Stain Type: Semi-Transparent – Oil-Based for Hardwoods
Available Colors: Natural Finish
Coats Required: 1 coat for most hardwood decking surfaces
Coverage Per Gallon: 300+ sq. ft for Exotic Hardwoods
Dry Time: 4-12 Hours
Manufacturer: IPE Clip
My Test Deck Stats:
Deck Wood Type: IPE Exotic Wood
Deck Square Footage: 800 Square feet
How Many Years Tested: 1 Year
Natural Finish
The Best IPE Hardwood Deck Stain Video – DeckStainHelp.com
Frequently Asked Questions About IPE Oil Hardwood Stain
How often do I need to reapply IPE Oil on an IPE deck?
Based on our 1-year test showing 70% color retention, IPE Oil should be reapplied annually on IPE and other exotic hardwoods. This is consistent with most hardwood stains, since dense woods like IPE absorb far less product and lose color faster than softer woods like cedar or pressure-treated pine, regardless of brand.
Is IPE Oil the same product as Messmers UV Plus?
Based on our testing and formula comparison, IPE Oil is Messmers UV Plus for Hardwood Stain relabeled with a slightly browner tint. The application characteristics, coverage rate, and performance we observed closely match what we’ve seen from Messmers UV Plus in prior testing.
How does IPE Oil compare to Armstrong Clark for hardwood decks?
Armstrong Clark scored better than IPE Oil in our testing, delivering the best color retention on IPE of any hardwood stain we’ve reviewed at $83.95 per gallon. IPE Oil scored 7.38 out of 10 with 70% color retention at 1 year and costs $74.99 per gallon. If budget allows, Armstrong Clark is the stronger long-term performer; IPE Oil is a reasonable middle-tier option at a similar price point.
How much IPE Oil do I need for my deck?
IPE Oil covers 300 or more square feet per gallon on exotic hardwoods like IPE, roughly double the coverage rate of softwood stains. Our 600 square foot IPE test deck required 2 gallons total. Since only 1 coat is needed on hardwood, measure your total square footage and divide by 300 to estimate gallons required, then round up.
Can I apply a second coat of IPE Oil for extra protection?
No. Exotic hardwoods like IPE are too dense to properly absorb a second coat of any hardwood stain, including IPE Oil. A second coat will sit on the surface rather than penetrate, leading to a tacky, uneven finish that takes much longer to cure. One properly applied coat is both correct and sufficient for hardwood decking.
What’s the least expensive hardwood stain that still performs well?
Based on our testing, Restore-A-Deck Wood Stain is the best value in this category at $52.99 per gallon, significantly less than IPE Oil, Armstrong Clark, or Penofin, while still delivering excellent color retention and zero wear or peeling at the 1-year mark. It also offers the unique advantage of same-day prep and staining.
14 Comments
Cindy
Cindy
We are going to install IPE wood decking on our new porch. Once we have treated the wood with IPE Oil Plus, how soon can we install the flooring on our deck? Does the newly oiled IPE need to cure before installation of the wood on our deck
Michele
Michele
Does a brightener need to be used after cleaner before reapplying IPE oil?
Robert William McMahon
will this product work well for pressure treated wood
Brian
Brian
what are your thoughts on Flood CWF for Hardwood?
Just finished new Ipe deck and siding on home in coastal home in Montauk NY. We are preparing to use Ipe oil throughout however painter informed us that we may prefer to let this gray naturally without initially staining if we are not prepared to re-stain annually as we may see peeling on edges and other adverse problems if we skipped a year or two. He recommended a clear preservative instead. Do you have any thoughts on this?
Also, it appears that parts of our deck that have received more sunlight than the siding have already grayed faster than the siding by the time the home was complete. Do you recommend any special procedures prior to oil application in the different areas?
Do you see any issues if we were to decide to let it grey later down the line after our initial application?
Donna
Donna
Can I use this on my cedar deck to get better penetration of the oils & color?
14
