BEHR PREMIUM Transparent Waterproofing Wood Finish Review 2.4/5 (13)
4.625 Overall Rating BEHR Transparent Deck Stain
BEHR PREMIUM Transparent Waterproofing Wood Finish ReviewImportant Note: This is our third review of Behr Premium Exterior Weatherproofing Wood and Deck Stains. The BEHR PREMIUM Transparent Waterproofing Wood Finish and the BEHR DECKplus Transparent Waterproofing Wood Finish are essentially the same product. They differ only in price point and availability in three stocked pre-mixed colors.
  • BEHR PREMIUM Transparent Waterproofing Wood Finish earns an overall score of 4.625 out of 10, making it one of the weaker deck stain options available.
  • The finish does not penetrate wood as claimed, instead drying on the surface like paint and masking wood grain with a semi-solid appearance.
  • Peeling and wear were severe, with over half the deck floor failing within two years, especially on horizontal surfaces exposed to foot traffic.
  • Removal is a serious challenge, requiring RAD Stain Stripper at high concentration, pressure washing, sanding, and over 12 hours of prep work.
  • The finish is best suited for low-traffic, shaded areas where a natural look matters more than long-term durability or UV protection.
  • Frequent reapplication every 6 to 12 months is required, making it a poor long-term value compared to higher-quality pigmented deck stains.
These are simply re-labeled “Transparent” versions of the Behr Premium Semi-Transparent Weatherproofing Wood Stain that we’ve reviewed previously. The formulation and performance remain unchanged, and therefore, this review reflects the same ratings as our last Behr Deck Premium Stain review.
Behr Premium Transparent Waterproofing Wood Finish is a water-based wood treatment designed to provide a clear or lightly tinted finish while offering basic water protection. It is marketed as a product that enhances the natural look of the wood without significantly altering its appearance.
From my experience restoring decks since 1993, products like this fall into the category of very light coatings rather than true penetrating stains. While they can improve the initial appearance and provide some water resistance, they typically do not offer strong UV protection or long-term durability.
Overall, Behr Premium Transparent Waterproofing Wood Finish can work for short-term appearance, but it is not one of the better options for long-lasting deck protection.
🔹 Behr Premium Transparent Waterproofing Wood Finish – Quick Verdict
  • Best For: Minimal color change and short-term protection
  • Not Ideal For: Long-term durability and UV protection
  • Type: Water-based transparent wood finish
  • My Overall Rating: 4.625/10
Behr Transparent Waterproofing Finish offers a natural look initially, but from my experience, it does not provide enough protection or longevity compared to better-performing stains.
Behr Stain Opacity Issues
One significant issue we’ve noted is Behr’s misleading claims about the opacity of its stains:
  • Opacity Misrepresentation: Behr’s so-called “semi-transparent” stains do not allow the wood grain to show through properly. Instead, they appear more like semi-solid or even fully opaque colors, giving the wood a painted look.
  • Removal Challenges: This heavy opacity not only masks the wood’s natural beauty but also makes removing the stain exceptionally difficult when it begins to peel.
See the pics below that show these opacity issues.
See here for our first Review: Behr Premium Deck Stain Review
BEHR PREMIUM Transparent Waterproofing Wood Stain
Behr Deck Stain Manufacturer Description
Give wood the ultimate in protection with BEHR PREMIUM Transparent Weatherproofing All-In-One Wood Finish. This 100% acrylic formula seals out the elements and the sun’s harmful UV rays, for up to 4 yrs. on decks and up to 6 yrs.on fences and siding. It’s available in 3 pre-mixed colors as well as 6 custom colors so you can get the look you want while preserving your valuable investment.
Best for use in
For properly prepared new to slightly weathered, unsealed exterior wood surfaces (0-5 years exposure) such as: Decks, Railings, Shakes, Shingles, Siding, Roofs, Fences, and Wood Patio Furniture.
BEHR PREMIUM Transparent Waterproofing Wood Finish Stain Scores (1-10)
Appearance After Initial Stain Application: 2
– The application of the BEHR PREMIUM Transparent Waterproofing Wood Finish was a repeat of our first test.  We found that the Behr does not penetrate into the wood like the product claims it should. It dries on top of the surface like paint. It had the look of a semi-solid with much of the wood grain masked by the pigment. The Cedar color on the deck made it look like a pumpkin.
– The one positive about the BEHR PREMIUM Transparent Waterproofing Wood Finish is that it has excellent UV protection in the areas where the stain had not failed. Unfortunately, this was only half of the deck floor and most of the railings.
Wear/Tear and Peeling: 1
– The cedar porch was “Behr” of stain on more than half of the flooring. The stain had peeled or worn in large uneven patches. Vertical rails did not have any issues.
Cost Per Square Foot: 4
– BEHR PREMIUM Transparent Waterproofing Wood Finish costs $35 per gallon. We used 5 gallons for the 300 square feet for the 2 coats applied.
$.55 per foot.
– BEHR PREMIUM Transparent Waterproofing Wood Finish had some mold growing on the flooring near the home and on top of the rail cap.
Ease of Application: 2
– Applying the BEHR PREMIUM Transparent Waterproofing Wood Finish is like painting your deck except it does not apply evenly. We have stained 1000’s of decks and have never found a stain to be more difficult to apply than Behr. It dries extremely fast and will show overlaps if not careful. We used a paintbrush and hand-applied the stain to the entire deck as that seemed to give the best results.
Color Shifting (darkening) after 2 Years: 8
– Behr Premium Weatherproofing Stain does not darken in color much or at all.
The difficulty of Reapplication: 2
– This is how we fixed the BEHR PREMIUM Transparent Waterproofing Wood Finish. We applied a heavy dose of the Behr Stain Remover and tried to pressure wash off the remaining stain. It did not work. We then used the RAD Stain Stripper at a very high concentration and repeated. This removed about 85% of the stain. We were left sanding off the rest then cleaning and brightening the wood to even out the porosity of the wood. Prepping took 12 hours and needless to say, the customer switched brands.
Overall Score Behr Premium Stain at 2 Year Period: 4.625
While Behr may market their stains as premium products, these opacity issues and the lack of true transparency can lead to frustration for homeowners. If maintaining the natural wood grain is important to you—or if you want to avoid the hassle of stripping heavily pigmented stain—there are better options available.
Note: Rated tops By Consumers Reports. I’m not sure why, and feedback from most of our users agrees. Consumers Reports website has a user rating of 1 out of 5 stars. Thirteen out of the 14 user reviews gave it a 1 star.
This stain should be removed from sale to the public.
Buyer Beware!
Looking For the Best Deck Stains? See Below
Information:
Cost: $44.99 per Gallon, $2069.99 per 5 Gallon Pail
Stain Type: Premium Semi-Transparent – Water Based
Available Colors: 3 Stocked pre-mixed colors
Coats Required: 2 Coats
Dry Time: 1-2 Hours
Cleanup: Soap and Water
Deck Wood Type: Cedar Porch
Deck Square Footage: 300 Square Feet
UV Exposure: Full sun
Cedar
BEHR Deck Stain Photos
*All products tested and results are from our hands-on experience. We offer no guarantee of similar results. Consider that results may differ widely due to different wood types, exposure to UV radiation, and natural weathering.
Disgruntled Behr Stain Customer
🔹 Behr Premium Transparent Waterproofing Wood Finish – Pros and Cons
Pros
  • Water-based for easy cleanup
  • Readily available at local stores
  • Minimal color change to wood
Cons
  • Pocaity is more opaque than transparent
  • Very limited UV protection
  • Short lifespan in most conditions
  • Does not penetrate deeply into the wood, resulting in peeling
  • Requires frequent reapplication
  • Not suitable for high-exposure decks
🔹 Best Wood Types for Behr Transparent Finish
  • Decks where natural appearance is the main goal
  • Low-traffic or shaded areas
Not Ideal For:
  • Full sun exposure – will fade quickly
  • Decks needing long-term protection
  • Hardwoods (IPE, Cumaru, etc.) – limited effectiveness
  • Apply thin, even coats
  • Do not over-apply
  • Best used in low-exposure environments
Maintenance is frequent with transparent finishes like this.
  • Reapply every 6–12 months depending on exposure
  • Clean and brighten before reapplication
  • Monitor closely for fading or water absorption
  • Expect shorter lifespan compared to pigmented stains
From my experience, transparent finishes require more upkeep due to lack of UV protection.
🔹 Who Should Use Behr Transparent Waterproofing Finish?
You should consider this product if:
  • You want a very natural, almost invisible finish
  • Your deck is in a shaded or low-exposure area
  • You are okay with frequent maintenance
  • Appearance is more important than durability
  • Your deck is in full sun
  • You want long-term protection
  • You prefer a stain with color and UV resistance
🔹 Behr Premium Transparent Waterproofing Wood Finish – FAQs
Is Behr Transparent Waterproofing Finish a stain?
Not really. It acts more like a clear or lightly tinted sealer rather than a true deck stain.
How long does Behr Transparent Waterproofing Finish last?
Typically 6–12 months depending on exposure.
Does it protect against UV damage?
Very little. Lack of pigment means limited UV protection.
Does it peel or flake?
It typically does not peel, but it fades and wears off quickly.
Can it be reapplied easily?
Yes, but frequent reapplication is required.
Is it good for full sun decks?
No, it will break down quickly in high UV exposure.
🔹 Behr Premium Transparent Waterproofing Wood Finish – Final Thoughts
Behr Premium Transparent Waterproofing Wood Finish is designed to provide a natural look with minimal color change, but it falls short when it comes to long-term protection and durability.
From my hands-on experience, products with little to no pigment simply do not hold up well on exterior wood, especially in areas with full sun exposure.
If your goal is to maintain a natural appearance and you are willing to reapply frequently, this product may work. However, for most decks, a higher-quality stain with better UV protection will provide far better results over time.
25 Comments
Amy
Amy
I used this product on my 7-year-old deck which was in great shape in 2019. Two years later (2012), I noticed some peeling and floorboard rot. I replaced the rotted floorboard and reapplied the entire deck with this same product. Last summer (2022) it really started to peel and rot. Currently, the deck floor is rotten. I had the deck power washed and the product peeled up, just like in the video above. It clearly sat on top of the wood and locked in the moisture causing the boards to rot. A contractor evaluated it and says most of the deck now needs to be replaced because it’s covered in mold and you can push a screwdriver all the way through many floorboards. I’ve contacted Behr but they are giving me the run around. Is there by chance a class action lawsuit? This is going to cost me thousands of dollars to rectify.
lawrence
lawrence
Why would anyone waste their time and $$ as there are class action lawsuits against behr deck products.My deck was painted in Aug 2018 on 2019 April it was blistering and big patches stiped off. Behr customer service people are pleasant but do not help you.Do not buy.
Chuck
Chuck
Reply to  lawrence
Because these big box stores run smaller businesses out and then they limit their selection to mass marketed choices that aren’t necessarily good.
TWP is made in Missouri and is an excellent line of products. It is so easy to use and recoat!
The original “non-epa” product is the absolute best if your state allows it. It is a solvent based penetrating tinted sealer. When time to reapply, just hit it with a good deck cleaner with bleach and a QUICK powerwash. No fuss no mess, just reapply.
AND it will sit in the metal bucket it comes in for a few years if you clean the rim and close it up tight, and it can be thinned out.
As long as you don’t let puddles dry and keep them brushed out, it will not peel. It supposedly will peel if you let a puddle dry, but I have left it on thick and never had a problem. Its not really an oil, not sure what is in it, but it beads the water up, without the product laying on top of the wood.
Great company with no marketing.
Chuck
Chuck
I have used TWP tinted penetrating wood sealer for years, easiest stuff to use period. Just hit it with a bleach cleaner and recoat every 2 years if exposed, 3 or more if under roof. I couldn’t find it here in South Florida.
This behr Transparent waterproofing mistuff does not penetrate at all. I am using it to stain some 3yr old reed/bamboo privacy screen and you really have to work it with a brush to get a decent look.
20251014_090034
Ilya
Ilya
What would you recommend putting on top of Behr Premium Transparent Clear (#500-N)? The deck is about two years old and last year the prior owner put a coat (or maybe two) of the Behr stain on it. I prepped the deck today to restain with more of the same, but just saw all these reviews and think I should use something else…but I’m not sure what. I don’t mind the color of the existing boards, and so far the stain looks fine. I’m just re-staining because there are some scratches on the deck, and I generally just want to preserve the deck for as long as I can because it’s huge. Thank you!
Deb
Deb
Reply to  Ilya
Used on my year old deck last week
Put 2 coats let dry a day before doing second coat. Waited for 5 days before
putting furniture back. Moved table yesterday and it scratched the finish!!
It sounds like you can’t put a stronger sealer over the top for protection is that correct? A lot of time and effort went into this project and not happy with results What to do?
Deb
Deb
Thank you for your reply
wish I would have done some research before I just took the guys word at Home Depot. Guess ill
just touch up the scratches as they happen
connie
connie
I am using Behr Premium transparent waterproofing wood finish, clear (#500-N) and after about 30 mins, of course, it started to rain. What should I do ?
Eugene
Eugene
I noticed that Bear Premium stain are low rated here but wasn’t able to find any thoughts on product like BEHR PREMIUM ® Transparent Penetrating Oil Wood Finish.
Should I assume it’s in the same product family as this review or completely different?https://www.deckstainhelp.com/behr-premium-transparent-waterproofing-wood-finish-review/
Eugene
Eugene
These look like chemically different products:
  • BEHR Premium Transparent Waterproofing Wood Finish Penetrating Oil
  • Model#: 450001
  • 4 hour try time
  • BEHR Premium Quick Dry Oil Base Wood Finish
  • Model #492905 (one of the options)
  • 60 minute dry time
Bryan Fuss
Bryan Fuss
I applied Behr Premium transparent waterproofing wood finish to 4×8 plywood for a stair ramp and after 3 days it’s still has sticky feel to it, the plywood will be walked on constantly with bare feet, is it safe to do so?
Bryan Fuss
Bryan Fuss
So you are telling me my family, friends and pets won’t develop cancer, a skin disease, or any other illness.
I will save your response for the future.
Bryan Fuss
Bryan Fuss
I applied product to 4×8 plywood for a stair ramp and after 3 days it’s still has sticky feel to it, the plywood will be walked on constantly with bare feet, it it safe ?
Maxine M.
Maxine M.
We prepped our 2 year old deck as advised; power wash and wait a few days to dry. We applied Behr semi-transparent deck stain with 2 rollers so as not to have any dry edges. It was late afternoon of a fall day. We live in NE so after the mild winter, we found our deck had started to peel already. Now 2 years out we have peeling everywhere! “One and done” my arse. Now we are looking to hire someone to sand and restain the deck. What a waste of $$$$.
dan garrett
dan garrett
I should have done some research on this product, Behr Premium transparent waterproofing wood finish #500-N. This is not a stain, it does not penetrate, but rather makes a coating over the wood. The final appearance was not transparent, it definitely yellowed the wood. It looked acceptable but did hide some of the wood grain of my 2 year old cedar decking. The coating seems to allow dirt to impregnate and is impossible to get it to look clean. I have used a mild TSP solution and a mild detergent cleaner, neither worked. After one year the coating is peeling and looks dirty. I am trying to figure out how to prep it for staining again this year. I used Valspar All in One wood prep (oxalic acid), and pressure washed to no avail. I used my belt sander with 80 grit sandpaper which, while painfully slow, would work except the coating gums up the sandpaper very quickly.
Any ideas for a way to strip this coating?
Frank T. Slade
Frank T. Slade
Reply to  dan garrett
My Allentown PA Condo association specifies Behr. Eighteen years ago Behr solid stain did not peel like the last coat did applied 5 years ago. On my hands and knees it was torture prepping using 6 inch round disc sander (80 grit) sections that did not peel off. Prep done over days easily took 7+ hours on a 12′ x 14′ deck.
Next I “stained” 1/2 the dry deck surface one weekend & returned 6 days later to finish the job. Part of what I stained before was already starting to bubble! I could not believe it
I have to sell this place Spring 2022 because of this deck/Behr issue. Promise.
25
