Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My Armstrong Clark Semi-Solid review is based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
Armstrong Clark Semi-Solid Wood Stain Review
Here at DeckStainHelp.com, we take pride in becoming the Internet’s number one reference for all things exterior wood and deck restoration related. Today, we are reviewing Armstrong Clark in the Semi-Solid Colors. We have found that the higher the solid content, the longer the UV protection when using Armstrong Clark Stains.
Armstrong Clark’s newer color is Espresso Semi-Solid, a rich, deep brown tone that promises excellent UV resistance.
Armstrong Clark Deck Stains are uniquely blended with drying and non-drying oils that are isolated from each other during application. The non-drying oils penetrate the wood fibers and help rejuvenate and condition lost natural oils, while the drying oils cure on the surface to lock in the conditioning oils and form a barrier of weather protection at the surface.
How I Rated Armstrong Clark Semi-Solid Stains
My Armstrong Clark Semi-Solid Stains review contains an 8-step process and the final average score. Each step is on a scale of 1-10.
- The appearance of Armstrong Clark Semi-Solid Stains after Application
- Preventing UV Graying
- Peeling or Wearing
- Cost Per Square Foot Armstrong Clark Semi-Solid Stains
- Preventing Mold and Mildew
- How Easy Was the Application for Armstrong Clark Semi-Solid Stains
- Color Shifting
- Ease of Reapplication
- Armstrong Clark Semi-Solid Stains Final Score
8-Step Review of Armstrong Clark Semi-Solid
The initial appearance of Armstrong Clark Semi-Solid Mountain Cedar was a rich, deep finish with naturally enhanced wood grain showing through the semi-solid cedar tone. See the picture to the right.
Upon our 2-year inspection, Armstrong Clark Semi-Solid Wood Deck Stain produced above-average UV resistance. Using the Semi-Solid Mountain Cedar color, we projected better-than-average UV shielding, which did not disappoint. The Armstrong semi-solid colors have been shown to have better UV protection than their transparent and semi-transparent colors.
3. Wear/Tear and Peeling: 9
No peeling was detected at the 2-year point. There was a slight wearing on the high-traffic areas, around the furniture, and on the stairs.
4. Cost Per Square Foot: 9
Armstrong Clark Semi-Solid Deck Stain can be purchased for about $45.99 per gallon. In our test experience, Armstrong Clark Semi-Solids had one of the best spread rates of any stain. We used a total of 4 gallons on our 800-square-foot deck and applied them in one coat.
5. Preventing Mold/Mildew/Algae: 8
At 2 years, we noticed some slight mold growth on top of the Armstrong Clark Semi-Solid stain in some shaded areas. We did not detect any mildew spores within the stain, and the mildew spores could be wiped away using a wet towel.
Armstrong Clark Mountain Cedar Semi-Solid
6. Ease of Application: 9
The Armstrong Clark Semi-Solid Deck Stain was easy to apply. The stain did not dry too quickly and was applied even in those conditions, avoiding potential issues with Applying a Deck Stain in Full Sun. We used stain pads and brushes to apply the stain to the deck. It took about 2-3 hours to apply with a team of 2 workers. One Note: It did take the Armstrong Clark Semi-Solid a few days to fully cure.
7. Color Shifting (darkening) after 2 Years: 8.5
Our 2-year test of Armstrong Clark Semi-Solid Mountain Cedar color did show signs of slight darkening from its original color. We figured this was likely due to the formula’s higher solid content. The AC is over 70% solids containing linseed and paraffin oils.
Because Armstrong Clark Wood Deck Stains penetrate well and do not overly darken, it would be easy to recoat. Prior to reapplying, a simple cleaning with a wood deck cleaner to remove dirt, grime, and mold spores would be sufficient.
Overall Score Armstrong Clark Semi-Solid Stain at 2-Year Period: 8.5
Armstrong Clark Semi-Solid Mountain Cedar held up well at our 2-year test mark. Its easy application and terrific coverage rates raise Armstrong Clark to a high level. No peeling and only a slight darkening color shift were more than acceptable. It is also easy to maintain and prep prior to re-coating. Armstrong Clark is definitely one of our top choices for a professional, durable finish that lasts and is easy to work with in the future.
ArmstrongClarkStain.com: Armstrong Clark Semi-Solid Stains
Cost: $57.99 per Gallon, $299.99 per 5 Gallon Pail
Stain Type: Semi-Solid – Oil-Based
Available Colors: Semi-Solid Mountain Cedar, Semi-Solid Woodland Brown, Semi-Solid Oxford Brown, Semi-Solid Sequoia, Semi-Solid Espresso
Application Temperature: 50-110 F
Coats Required: 1 Coat
Coverage Per Gallon: 200-250 sq. ft
Application Tools: Airless Sprayer, Pad, Brush, Roller
Dry Time: 8-72 Hours, Depending on UV exposure and air temps
VOC Compliant: Under 50 VOCs. Compliant in all 50 States and Los Angeles Counties.
Manufacturer: Armstrong Clark
Deck Square Footage: 800
Stain Color Used: Semi-Solid Mountain Cedar
Semi-Solid Deck Stain Review Video – DeckStainHelp.com
Would this product be ok for new pressure treated wood? My old deck has a lot of patches just installed this week. I hope to stain in about 3 weeks, before it gets too cold. Or is there a better product for my situation?
You cannot stain new wood right away. See here for tips: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
Can I roll on the armstrong clark semi solid stain? Thanks for the help
Use stain pads or brushes, rollers “splatter” and do not apply that evenly.
I am in the process of refurbishing a pergola and deck that was previously stained with an unknown brand of oil based stain. I am unable to remove a 100 percent of old stain. Can I clean and sand and restain over some of the existing stain using a semi solid stain such as Armstrong Clark.
You must remove the old stain completely first. Do you have pictures that you can add in comments of your prep so far?
This product seems great, with one caveat about “sitting surfaces”. Apparently it rubs off onto clothing. This is concerning because I like to sit right on the deck sometimes, and guests have done that. This could be ok, depending on the degree of rub-off, and how easily it washes out of clothing. Can you comment on it?
Only the semi-solid colors are not suggested for furniture. The higher solids can be an issue.
hi – do you have photo’s of all of the semi solid stain colors in the Armstrong Clark brand. also i removed nearly all of the existing paint – probably 7 coats applied over probably 40 years. The wood did get a bit beat up in the process – I plan on sanding the deck to reduce the damaged spots. originally I was going to use semitrans but since I cannot remove 100% of the paint regardless of pressure washing and sanding I figure semi solid would be the way to go and i definitely dont want to deal with peeling paint again. any further tips on surface prep for an old deck?
See this link for photos: https://www.armstrongclarkstain.com/armstrong-clark-photo-album
You cannot apply the AC stains unless all of the prior paint is removed. Does not matter if semi-solid, it will not work. If you cannot get it all off, you will need a solid stain and AC does not make one.
