Restore-A-Deck Stain & Stripper Combo Kit – Prep & Stain in One Day!
Everything You Need for a Complete Deck Restoration
The Restore-A-Deck Stain & Stripper Combo Kit allows you to remove old stains, brighten wood, and apply a fresh coat of stain all in a single day. This all-in-one system is perfect for decks, fences, and other exterior wood surfaces, ensuring maximum protection and long-lasting beauty.
- Restore-A-Deck Semi-Transparent Wood Stain: Kit includes stain plus Step 1 stripper and Step 2 brightener for full deck restoration.
- Restore-A-Deck Semi-Transparent Wood Stain: Water-based, deep-penetrating stain that prevents graying, cracking, and moisture damage; dries to a flat natural finish.
- Restore-A-Deck Semi-Transparent Wood Stain: Coverage 100 to 200 sq ft per gallon; stripper and brightener cover 750 to 1,000 sq ft per container; use wet-on-wet.
- Restore-A-Deck Semi-Transparent Wood Stain: Eco-friendly, low VOC; The RAD stripper may not remove solid paints or heavy acrylics.
✔ (2) 2.5-Gallon Containers (Total 5 Gallons) of Restore-A-Deck Semi-Transparent Wood Stain
✔ (1) Restore-A-Deck Step 1 Stain Stripper
✔ (1) Restore-A-Deck Step 2 Wood Brightener
🌿 Eco-Safe & Low VOC – Safe for wood, pets, grass, and plants when properly rinsed
🌞 Stain & Protect in Just One Day – No waiting between prep & staining
🏆 #1 Rated Deck Restoration System – Trusted by homeowners & professionals
🔹 Why Choose the Restore-A-Deck Stain & Stripper Combo Kit?
✅ Strip, Brighten, & Stain in One Day – Saves time with a fast and easy application process.
✅ Removes Old & Worn Finishes – Eliminates previous stains, varnishes, and coatings.
✅ Advanced Semi-Transparent Stain – Provides deep wood penetration & long-lasting protection.
✅ Prevents UV & Moisture Damage – Blocks harmful sun rays, water absorption, & mold growth.
✅ Perfect for All Exterior Wood Surfaces – Works on decks, fences, log homes, siding, outdoor furniture, and more.
✅ Cost-Effective Solution – Professional-quality results at a fraction of the cost.
✅ Water-Based & Easy Cleanup – No harsh odors or difficult cleanup.
📌 New Wood Note: New wood must weather & be prepped before staining to ensure proper adhesion.
🔹 What’s Included in the Restore-A-Deck Stain & Stripper Combo Kit?
(5 Gallons) Restore-A-Deck Semi-Transparent Wood Stain
✔ Deep penetrating, water-based stain for superior protection
✔ Prevents graying, cracking, and water damage
✔ Applies to dry or damp wood – Stain the same day as prep
✔ Eco-friendly, low VOC, and safe for all exterior wood
✔ Dries to a flat, natural-looking finish
Available in 4 Beautiful Semi-Transparent Colors:
🎨 Natural – Enhances wood’s natural tones
🎨 Cedar – Rich, warm wood finish
🎨 Light Walnut – Medium, warm brown
🎨 Dark Walnut – Deep, rich brown
📏 Coverage: 100-200 sq. ft. per gallon (varies by wood porosity).
Step 1: Restore-A-Deck Stain Stripper
✔ Removes most clear, transparent, semi-transparent, and semi-solid coatings
✔ Eliminates worn finishes, dirt, mold, mildew, and mill glaze
✔ Eco-friendly & safe for pets, plants, and grass when properly rinsed
✔ Preps previously stained wood for a fresh new coat
📏 Coverage: 750-1,000 sq. ft. per container.
Step 2: Restore-A-Deck Wood Brightener
✔ Neutralizes the stain stripper & restores wood’s natural color
✔ Removes rust stains & tannin stains from fallen leaves
✔ Enhances stain absorption & longevity
✔ Eco-safe & easy to use
🔹 Where to Use the Restore-A-Deck Stain & Stripper Combo Kit?
✔ Wood Decks & Railings
✔ Fences & Pergolas
✔ Siding & Log Homes
✔ Outdoor Furniture & Playsets
📌 Perfect for restoring previously stained or coated wood before applying a fresh finish.
🔹 How to Use the Restore-A-Deck Stain & Stripper Combo Kit
Step 1: Strip the Wood with Restore-A-Deck Stain Stripper
1️⃣ Mix the Stripper: Each container makes 5 gallons.
2️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the wood surface.
3️⃣ Let Sit for 15-20 Minutes: Stripper will begin breaking down old coatings.
4️⃣ Scrub or Pressure Wash Off: Rinse thoroughly with a garden hose or pressure washer.
Step 2: Brighten the Wood with Restore-A-Deck Brightener
5️⃣ Mix the Brightener: Each container makes 5 gallons.
6️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the surface.
7️⃣ Let Sit for 10-15 Minutes: Neutralizes the stripper and restores wood pH balance.
Step 3: Apply Restore-A-Deck Semi-Transparent Stain
9️⃣ Ensure Surface is Ready: All standing water should be dried off (typically 2-4 hours after prep).
🔟 Apply Stain Using Brush, Roller, or Pump Sprayer: Work wet-on-wet for even absorption.
1️⃣1️⃣ Back-Brush or Use a Stain Pad: Ensures even penetration & smooth finish.
1️⃣2️⃣ Let Dry Completely: Allow 24-48 hours before heavy foot traffic.
📌 For detailed guides:
- Aplying RAD Stain Wet-on-Wet
- How to Apply RAD Stain to Damp Wood
- RAD Stain & New Wood Prep
- Two-Tone Deck Application Tips
✔ Get a Complete Deck Restoration in Just One Day!
✔ Strip, brighten, & stain your wood in a single day!
✔ Eliminates old coatings for a fresh, long-lasting finish!
✔ Eco-friendly, easy to use, and works on multiple wood surfaces!
🔹 Order the Restore-A-Deck Stain & Stripper Combo Kit today and restore your deck, fence, or exterior wood with a beautiful, professional-quality finish!
Coverage: 750-1000 sq.feet per container.
AVAILABLE SEMI-TRANSPARENT COLORS:
NATURAL, CEDAR, LIGHT WALNUT, DARK WALNUT, COTTAGE GRAY
