TWP Semi-Solid Pro Series Oil-Based Wood Stain – 5 Gallon
Available in 30 Custom Colors, the TWP® Semi-Solid Pro-Series is formulated to preserve and enhance the beauty of your exterior wood. With superior UV protection and long-lasting performance, this stain ensures your wood looks fresh, vibrant, and protected for years.
- The TWP Semi-Solid Pro-Series is an oil-based stain offering superior UV protection, water repellency, and mildew resistance for exterior wood.
- It covers 100 to 200 square feet per gallon (per coat) and requires only 1 to 2 coats using a wet-on-wet application method.
- Available in 30 custom colors, all orders are custom made and cannot be returned or exchanged, so order samples first.
- Suitable for decks, fences, log homes, siding, and shingles, making it a versatile choice for nearly any exterior wood surface.
🔹 Why Choose TWP® Semi-Solid Pro-Series?
✔ Unmatched UV Protection – Prevents fading and extends stain life.
✔ Superior Penetration & Water Repellency – Protects against warping, cracking, and splitting.
✔ Ideal for Harsh Climates – Resists freeze damage and withstands extreme weather conditions.
✔ Easy Application & Maintenance – Applies with brush, roller, or sprayer for even coverage.
✔ Mildew-Resistant Finish – Keeps wood cleaner for longer.
✔ Customizable Appearance – Semi-solid formula offers more coverage while still showcasing the wood grain.
🔹 Where to Use TWP® Semi-Solid Pro-Series
TWP Semi-Solid is perfect for all types of exterior wood, including:
✔ Decks
✔ Siding & Shingles
✔ Rough Sawn Cedar
✔ Log Homes
✔ Fences
✔ Shakes & Fascia
🔹 Color Selection
✔ Available in 30 Custom Colors
✔ View Full Sun vs. Shade Effects on Each Color
🔹 Important Notes
❗ Custom Colors – All TWP Pro-Series Semi-Solid stains are custom made and cannot be returned or exchanged.
❗ Color Variations – Stain colors vary based on wood type, prep, and application. Small samples available for testing.
❗ Shipping Time – Custom orders may take 1-3 days to process before shipping.
🛒 Order TWP® Semi-Solid Pro-Series Stain Today!
✔ Premium Oil-Based Formula
✔ Superior Color Retention & Durability
Protect and enhance your deck, siding, fences, and more with TWP Semi-Solid Pro-Series Stain. Order now for long-lasting, beautiful results!
Technical Specifications – TWP Semi-Solid Wood Stain
Stain Type: Semi-Solid, Oil-Based
Coverage: 100–200 sq. ft. per gallon
Recommended Coats: 1-2 Coats (Wet-on-Wet Application)
Dry Time: 4 to 24 Hours
TWP Semi-Solid Pro-Series 5-Gallon Deck Stain
