- The Restore-A-Deck Cleaner & Brightener Kit is a two-step system that removes dirt, mildew, algae, and UV graying before staining.
- This kit is not a stain stripper; use the Restore-A-Deck Stain Stripper Kit if you need to remove an existing semi-transparent stain.
- Each kit makes 10 gallons of solution, costing less than $7 per gallon, making it a cost-effective prep option for DIYers and contractors.
- Works on multiple exterior surfaces including wood and composite decks, fences, siding, log homes, outdoor furniture, and pergolas.
- For best results, apply your stain within 48 hours after using the brightener to maximize adhesion and long-term durability.
✔ Wood & Composite Decks
✔ Fences & Railings
✔ Siding & Log Homes
✔ Gazebos & Wood Playsets
