DEFY Solid Color Wood Stain – Maximum Protection with a Durable, Matte Finish
Advanced Acrylic Stain Fortified with Zinc Nano-Technology
DEFY Solid Color Wood Stain is a high-performance, acrylic-based, opaque wood finish designed to provide long-lasting protection against the elements. This water-based, eco-friendly formula delivers a beautiful matte finish while shielding wood surfaces from UV rays, water damage, and mildew growth.
- DEFY Solid Color Wood Stain uses zinc nanoparticle technology to block UV radiation, preventing fading, graying, and wood deterioration over time.
- This water-based, low-VOC formula resists mold and mildew, cleans up with soap and water, and is safe around plants and pets.
- Available in 7 pre-mixed colors, including White, Barn Red, and Stone Gray, making it easy to match any outdoor aesthetic.
- Works on a wide range of surfaces, including decks, fences, wood siding, and lumber types like Cedar, Redwood, and Ipe.
Fortified with transparent zinc nanoparticles, DEFY Solid Color Stain acts like sunscreen for your wood, blocking out harmful UV radiation to prevent fading, graying, and deterioration over time.
🔹 Why Choose DEFY Solid Color Wood Stain?
✅ Tough & Durable Protection – Zinc nanoparticle technology enhances stain longevity and prevents premature wear.
✅ 7 Beautiful Pre-Mixed Colors – Available in White, Taupe, Light Walnut, Dark Walnut, Dark Cocoa, Barn Red, and Stone Gray.
✅ Superior UV Resistance – Blocks sun damage to keep wood looking newer, longer.
✅ Water-Based & Eco-Friendly – Low VOC, easy cleanup with soap and water, and safe for use around plants and pets.
✅ Resists Mold & Mildew – Helps prevent staining and discoloration caused by fungal growth.
✅ Easy Application & Maintenance – Applies smoothly with brush, roller, or sprayer, and can be recoated as needed.
🔹 Where Can You Use DEFY Solid Color Wood Stain?
✔ Decks & Patios (Horizontal & Vertical Surfaces)
✔ Wood Siding & Log Homes
✔ Fences, Pergolas & Outdoor Structures
✔ Interior & Exterior Wood Surfaces
✔ Pressure-Treated Lumber, Pine, Cedar, Redwood, Mahogany, Ipe & More
DEFY Solid Color Wood Stain – Available Colors
🟠 White
🟠 Taupe
🟠 Light Walnut
🟠 Dark Walnut
🟠 Dark Cocoa
🟠 Barn Red
🟠 Stone Gray
✔ Get Long-Lasting, Beautiful Protection with DEFY Solid Color Wood Stain!
✔ Choose from 7 pre-mixed colors for a custom, durable finish!
✔ Protect your wood from UV rays, mold, and water damage!
✔ Enjoy an easy-to-apply, low-maintenance, water-based formula!
🔹 Order DEFY Solid Color Wood Stain today and give your wood surfaces the ultimate protection and beauty!
Defy Solid Color Wood Stains Photos
The gallery was not found!Warning: This product can expose you to chemicals including cumene, which is known to the State of California to cause cancer, and ethylene oxide, which is known to the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov
