• Home
  • Buy Products
          • Restore A Deck Wood Stains
          • TWP Wood Stains
                • TWP-100-Pro-Series-1-Gallonjpg-1pngTWP 100 Series Wood and Deck Stain ...$64.99 – $74.99Price range: $64.99 through $74.99
              • TWP 1500 Series
              • TWP 200 Series Wood Stain
          • Armstrong-Clark Wood Stains
          • Defy Wood Deck Stains
              • Defy Extreme Wood Stain
              • Defy Essential Wood Stain
      • Semi-Solid Wood Deck Stains
      • Solid Color Deck Stains
          • Messmers Hardwood Stain
      • Wood & Deck Cleaners
          • Gemini Restore-A-Deck Kit
          • CUTEK® Quickclean
          • Defy Wood Cleaner 2 Pounds
      • Wood & Deck Stain Strippers
          • RAD™ PaintStrip Paint & Solid Stain Stripping Gel
          • CUTEK® Wood Stripper
          • Defy Exterior Wood Stripper
            • defy-stain-stripper-1galpngDefy Exterior Wood Stripper$44.99
      • Wood & Deck Brighteners
      • Stain Application Tools
        • Deck_Scrub_Brush_4a3e178533e42jpgDeck Scrub Brush$21.99
  • Product Reviews
      • Deck Stain Reviews
      • Deck Cleaner Reviews
      • Deck Stain Stripper Reviews
      • Deck Brightener Reviews
  • Best Deck Stains
      • Deck Staining Help and Tips
      • Best Semi-Solid Deck Stain
      • Best Solid Color Deck Stain
      • New Wood Deck Staining Help
      • Deck Staining Facts
  • Best Deck Cleaner
      • Deck Cleaning Tips
      • Deck Brightening Tips
      • Top Deck Help Guides
      • How to Sand a Deck
  • Best Deck Strippers
  • How to Stain a Deck
      • Two-Toned Decks in 2026
  • Videos & Photos
      • Wood & Deck Stain Photos
      • Deck Stain Colors Tips
      • DSH YouTube Channel
  • 0
  • Home
  • Buy Products
          • TWP Wood Stains
              • TWP 1500 Series
          • CUTEK® Quickclean
  • Product Reviews
  • Best Deck Stains
  • Best Deck Cleaner
  • Videos & Photos
  • 0
DeckStainHelp
  • 0
DeckStainHelp
  • Home
  • Buy Products
      • TWP Wood Stains
        • TWP 1500 Series
      • CUTEK® Extreme
      • CUTEK® Quickclean
      • Deck Stain Sprayers
  • Product Reviews
      Deck Cleaning Tips
      Defy Stain Stripper Review
      HD80 Deck Stripper Review
      Defy Wood Brightener Review
  • Best Deck Stains
  • Best Deck Cleaner
      How Long Do Wood Decks Last?
  • Videos and Photos
    • Wood & Deck Staining Videos
  • Deck Stain Calculator
HomeRestore-A-Deck Wood Stain Strippers and Additives
Show All 9 24 36 42
  • Hot
    Free shipping
    Add to cart Quick View
    $79.99
  • Hot
    Free shipping
    $44.99
  • Free shipping
    $29.99
  • Free shipping
    $29.99
  • Hot
    Free shipping
    $69.99
  • Hot
    Free shipping
    RAD Paint & Solid Stain Stripper 5 Gallon
    $259.99
If you’re ready to buy a deck stain stripper that delivers real results, this category offers proven solutions for removing old stain, sealers, and stubborn coatings. Restore-A-Deck® wood stain strippers are designed to quickly and effectively break down failing finishes, helping you avoid uneven absorption and premature stain failure. This is the critical prep step for consistent color and long-lasting performance in your next stain application.
Whether you need a complete stripper and brightener kit, a high-strength stripper, or an additive to boost performance on tough coatings, you can shop this collection to find the right product for your project. These solutions are ideal for decks, fences, siding, and other exterior wood surfaces where proper stain removal is essential before re-staining.
Buy Restore-A-Deck Wood Stain Strippers & Additives – The Ultimate Solution for Stain Removal
Effectively Remove Old Stains, Sealers & Coatings for a Fresh Start
The Restore-A-Deck (RAD) Wood Stain Stripping System is designed to make removing old stains, sealers, and coatings easier and more effective. Whether you’re dealing with semi-transparent stains, over-applied coatings, or stubborn finishes, RAD Strippers and Additives will help break down and remove unwanted coatings, restoring your wood to its natural state before re-staining.
🔹 Restore-A-Deck Stain Stripper – Removes Old & Worn-Out Stains
✔ Breaks down and removes semi-transparent and semi-solid oil-based and water-based stains.
✔ Eliminates the need for sanding before re-staining.
✔ Prepares wood for proper stain adhesion by stripping away unwanted layers.
✔ Works on decks, fences, log homes, and other exterior wood surfaces.
🔹 Best For: Removing semi-transparent stains, worn-out sealers, and coatings before re-staining.
🔹 Restore-A-Deck Stain Stripper Thickening Gel – Clings to Vertical Surfaces
✔ Enhances the effectiveness of RAD Stain Stripper by extending dwell time up to 1 hour.
✔ Prevents runoff on vertical and horizontal surfaces, making stripping easier.
✔ Perfect for wood railings, fences, and wood-sided homes.
✔ Mixes with 5-gallon premixed Restore-A-Deck Stain Stripper for best results.
🔹 Best For: Vertical surfaces such as railings, fences, log homes, and siding where runoff can be an issue.
🔹 Restore-A-Deck Stain Stripper Booster – Boosts Stripping Power by 300%
✔ Strengthens the stain stripper’s ability to break down hard-to-remove coatings.
✔ Deeply penetrates the wood grain to dissolve stubborn finishes.
✔ Improves performance on both oil-based and water-based stains.
✔ Simply mix into 5-gallon premixed Restore-A-Deck Stain Stripper.
🔹 Best For: Difficult-to-remove wood stain finishes that require extra stripping power.
🔹 RAD Paint & Solid Stain Stripper – Removes Heavy Coatings & Paint
✔ Specifically designed to remove solid color wood stains, paints, and varnishes.
✔ Works on thick or excessively over-applied acrylic semi-transparent and semi-solid coatings.
✔ Penetrates deep to break down stubborn film-forming finishes.
🔹 Best For: Removing solid color stains, paint, and thick acrylic coatings that RAD Stain Stripper cannot fully remove.
✔ Get Professional-Grade Stripping Power with Restore-A-Deck!
For the best results, use RAD Stain Stripper with Thickening Gel and Stripper Booster for maximum effectiveness on tough stains. If you’re dealing with solid color stains, paints, or heavy coatings, opt for the RAD Paint & Solid Stain Stripper instead.
✔ Easily strip away old stains for a fresh new start!
✔ Restore your deck, fence, or siding with minimal effort!
✔ Ensure better stain adhesion and long-lasting results!
🔹 Order your Restore-A-Deck Stain Strippers & Additives today for a cleaner, fresher wood surface!
Expert Help When You Need It
FAQs About Restore-A-Deck Wood Stain Strippers & Additives
How do I know which deck stain stripper to buy?
The right stripper depends on what you are removing. Most homeowners start with a standard Restore-A-Deck® wood stain stripper for old or failing stains and sealers. If you are dealing with heavy buildup, solid stains, or paint, adding a booster or thickening gel can significantly improve stripping power and dwell time.
Can I use Restore-A-Deck strippers on my type of wood?
Yes. Restore-A-Deck wood stain strippers are designed for common exterior woods, including pressure-treated pine, cedar, redwood, and many hardwoods. Always review the product label and instructions before use, especially on exotic hardwoods or previously coated surfaces, to ensure proper application and results.
What surfaces can I use these strippers and additives on?
These products are ideal for removing stains and coatings from decks, fences, railings, siding, pergolas, and other exterior wood surfaces. Additives such as boosters and thickening gels help tackle vertical areas and stubborn finishes where standard stripping alone may not be sufficient.
Do I need additives, or is the stripper sufficient on its own?
For many projects, the stripper alone is sufficient. Additives are recommended when removing thick, solid, or multiple layers of old stain or paint. Booster additives increase stripping strength, while thickening gels help the stripper cling longer to vertical or difficult surfaces for more effective removal.
Why is proper stain removal so important before re-staining?
If the old stain is not fully removed, the new stain cannot penetrate evenly, leading to blotchy color, poor adhesion, and premature failure. Using a quality stripper and the right additives ensures the wood is properly prepped, allowing your new stain to perform and last as intended.
Ready to strip and restore your wood the right way?
Buy Restore-A-Deck® wood stain strippers and additives today to prep your deck, fence, or other exterior wood surfaces for a long-lasting, professional-quality finish.
Deck Staining Forum
My Top Deck Staining Articles
Staining New Wood & Deck Tips
Become a DSH Contributor?
Wood Restoration Contributors
My CURRENT RATINGS FOR 2026
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP Semi-Solid Pro-Series
4. TWP 1500 Series
2. TWP Natural Effect Stain
3. Defy Extreme Stain
1. Restore-A-Deck Solid Stain
2. Defy Extreme Solid Stain
Deck Resurface Products
My Top IPE Stain Ratings
…See IPE Stain Reviews
The Worst Deck Stain Ratings
1. Behr Premium Wood Stain
3. Benjamin Moore Arbor Coat
…See All Deck Stain Reviews
My Top Deck Cleaner Ratings
1. Restore-A-Deck
2. Gemini Restore Deck
3. Defy Timberwash Cleaner
My Top Stain Stripper Ratings
1. Restore-A-Deck Stripper
2. Defy Stain Stripper
  • 39,000+ Contributors
  • 6,800+ Forum Help Posts
Best Deck Stains Reviewed
Best Solid Color Deck Stains
Best Deck Cleaners
Best Deck Stain Strippers
Best Clear Deck Stains
Best Semi-Solid Deck Stains
Best IPE Hardwood Deck Stains
Top Deck Stain Help Articles
DeckStainHelp.com
Disclaimer
Footer Logo
Back To Top
× qcwpbotmodal-content
  • Home
  • Buy Products
      • TWP Wood Stains
        • TWP 1500 Series
      • CUTEK® Extreme
      • CUTEK® Quickclean
  • Product Reviews
      Deck Cleaning Tips
  • Best Deck Stains
      Best Deck Sealers and Wood Sealers for 2026:…
  • Best Deck Cleaner
  • Videos and Photos
Shopping Cart
Close
No products in the cart.
Close
