- DEFY Wood Deck Cleaner uses an oxygen bleach formula that removes mold, mildew, algae, dirt, and weathered graying from exterior wood surfaces.
- Unlike chlorine bleach cleaners, DEFY Wood Cleaner is biodegradable and eco-friendly, making it safe for plants, pets, and surrounding vegetation.
- One 2 lb. container makes 5 gallons of solution, covering approximately 500 to 1,000 square feet of deck, fence, or siding.
- The powdered concentrate creates a foaming action that penetrates deep into wood pores, lifting contaminants and improving stain absorption and durability.
- For best results, apply DEFY Wood Brightener after cleaning and allow the surface to dry completely before staining.
🔹 Product Data & Coverage
