TWP Semi-Solid Oil-Based Wood Stain – Low VOC (5 Gallon)
Now Low VOC & Compliant in All 50 States & Canada!
- The TWP Semi-Solid Pro-Series Low VOC stain is now compliant in all 50 states and Canada, using an oil-based formula that penetrates deep into wood.
- 30 custom colors are available, offering semi-solid coverage that enhances wood grain while providing richer opacity than a transparent stain.
- Coverage ranges from 100 to 200 square feet per gallon (per coat), with one to two coats recommended using a wet-on-wet application method.
- All TWP Pro-Series Semi-Solid colors are custom-made, so they cannot be returned or exchanged. Orders may take one to three days to process before shipping.
Available in 30 Custom Colors, the TWP® Semi-Solid Pro-Series Low VOC stain is engineered for maximum durability, color retention, and UV protection. This advanced oil-based stain formula penetrates deep into the wood while forming a protective layer to resist weathering, water absorption, and fading.
🔹 Why Choose TWP® Semi-Solid Pro-Series?
✔ Maximum UV Protection – Resists fading and extends stain life
✔ Superior Water Resistance – Protects against warping, cracking, and splitting
✔ Long-Lasting Performance – Ideal for harsh weather conditions
✔ Easy Application & Maintenance – Applies smoothly with brush, roller, or sprayer
✔ Mildew & Mold Resistant Finish – Keeps wood cleaner for longer
✔ Rich Color with Semi-Solid Coverage – Enhances wood grain while offering more opacity
🔹 Where to Use TWP® Semi-Solid Pro-Series Low VOC?
Perfect for all types of exterior wood, including:
✔ Decks
✔ Siding & Shingles
✔ Rough Sawn Cedar
✔ Log Homes
✔ Fences
✔ Shakes & Fascia
🔹 Color Selection
✔ Available in 30 Custom Colors
✔ Provides richer coverage while allowing wood grain to show through
✔ Color appearance varies based on sunlight, wood type, and prep
🔹 Important Notes
❗ Custom Colors – All TWP Pro-Series Semi-Solid stains are custom-made and cannot be returned or exchanged.
❗ Color Variations – Stain colors vary based on wood type, age, and application method. Small samples available for testing.
❗ Shipping Time – Custom orders may take 1-3 days to process before shipping.
🛒 Order TWP® Semi-Solid Pro-Series Low VOC Stain Today!
✔ Oil-Based Formula with Low VOC Compliance
✔ Long-Lasting, Durable Protection
✔ Designed for All Exterior Wood Surfaces
Upgrade your wood protection with TWP Semi-Solid Pro-Series Stain – Low VOC.
Order now for long-lasting, rich color and enhanced durability!
Technical Specifications – TWP Semi-Solid Wood Stain
Stain Type: Semi-Solid, Oil-Based
Coverage: 100–200 sq. ft. per gallon
Recommended Coats: 1-2 Coats (Wet-on-Wet Application)
Dry Time: 4 to 24 Hours
