Save Money with the Armstrong Clark Stain & Restore-A-Deck Kit Combo Pack!
Complete Wood Restoration & Staining Kit for Maximum Durability and Protection
Get everything you need to prep, restore, and stain your deck or wood surfaces with the Armstrong Clark Stain & Restore-A-Deck (RAD) Kit Combo Pack. This cost-effective bundle includes 5 gallons of premium Armstrong Clark Stain along with the RAD Cleaner & Brightener system, ensuring professional results at a great value.
- The Armstrong Clark Stain and Restore-A-Deck Combo Pack bundles 5 gallons of premium stain with a complete Cleaner and Brightener Kit.
- The Restore-A-Deck Cleaner and Brightener removes mold, mildew, and graying while neutralizing pH to maximize stain absorption.
- Armstrong Clark uses a unique oil-based formula with deep penetration to prevent wood cracking and provide long-lasting UV and moisture protection.
- The stain covers 150 to 200 square feet per gallon (per coat) and can be applied in direct sunlight using a roller, brush, or airless sprayer.
- Available in transparent, semi-transparent, and semi-solid colors, the stain is VOC-compliant in all US states and Canada.
🔹 What’s Included in the Combo Pack?
✅ 1 Restore-A-Deck Cleaner & Brightener Kit – Prepares wood for staining by removing dirt, mildew, algae, and graying while neutralizing pH and restoring wood color.
✅ 5 Gallon Pail of Armstrong Clark Stain – A deep-penetrating oil-based wood stain that conditions wood while providing long-lasting UV and moisture protection.
🔹 Step 1: Restore-A-Deck Cleaner & Brightener System
✔ Eco-Friendly, Two-Part System – Cleans & brightens wood surfaces safely and effectively.
✔ Powerful Wood Cleaner – Removes dirt, mold, mildew, algae, and general weathering.
✔ Wood Brightener – Neutralizes the cleaner and enhances wood grain for better stain absorption.
✔ Covers 750-1,000 sq. ft. when mixed.
🔹 Step 2: Armstrong Clark 5-Gallon Wood Stain
✔ Unique Oil-Based Formula – Nondrying conditioning oils restore wood while drying oils lock in protection.
✔ Deep Penetration for Maximum Durability – Replaces natural oils lost over time, preventing wood cracking and drying out.
✔ UV & Moisture Protection – Transparent and semi-transparent pigments protect against sun and water damage.
✔ Applies Easily – Can be applied in direct sunlight with roller, brush, or airless sprayer.
✔ Recoat Option for Extra Protection – If the first coat absorbs in 30 minutes, a second coat may be applied.
✔ Covers 150-200 sq. ft. per gallon, depending on wood porosity.
🔹 Available Colors
🌲 Transparent Colors: Cedar Tone, Natural Tone, Redwood Tone, Amber, Mahogany
🌲 Semi-Transparent Colors: Black Walnut, Cedar, Chestnut, Driftwood Gray, Natural Oak, Rustic Brown, Sierra Redwood
🌲 Semi-Solid Colors: Espresso, Mountain Cedar, Oxford Brown, Sequoia, Woodland Brown
📌 Note: Stain colors will vary based on wood type, age, prep, and application method. Small samples are available for testing.
🔹 Why Choose the Armstrong Clark Stain & Restore-A-Deck Combo?
✅ Complete Wood Restoration & Staining in One Kit – Save time & money by getting everything you need in one package.
✅ Prepares & Conditions Wood Before Staining – Cleaner & brightener maximize stain absorption and longevity.
✅ Deep Penetration for Long-Lasting Results – Armstrong Clark revives old wood and protects new wood from UV & water damage.
✅ Eco-Friendly & VOC-Compliant – Safe, low-odor formula meets environmental standards.
✔ Restore & Protect Your Wood with the Best Staining Kit!
✔ Save money with this all-in-one prep & stain combo!
✔ Clean, brighten, and stain for long-lasting beauty and protection!
✔ Get professional results with premium-quality products!
🔹 Order the Armstrong Clark Stain & Restore-A-Deck Kit Combo Pack today and bring your deck back to life!
Technical Info Armstrong Clark Stains
Gallon Sizes:
1’s & 5’s
Coverage Per Gallon:
150-200 sq feet (Softwoods) 300+ (Hardwoods)
Coats Required:
1-2 Coats
Temperature:
50-110+ F
Application Tools:
Pad, Airless Sprayer, Brush
Dry Time:
8-24 Hours
Cleanup:
Mineral Spirits
VOC Limits:
50 VOCs. Compliant in all States and Canada
Product Data Sheets
Semi-Trans Hardwood Product Data
Safety Data Sheets
