PermaBond Bonding Primer – For Use Before Deck Revive or Dock Revive
- PermaBond is a VOC-free, acrylic-based bonding primer required before applying Deck Revive, Dock Revive, or Concrete Revive.
- It works best on very worn, weathered, or distressed wood and concrete surfaces showing gray, petrified, or brittle appearance.
- The acrylic-based polymer penetrates at a molecular level, locking into surface fibers for a strong, durable foundation.
- The formula is tintable, allowing it to match your final resurfacing product color for better color continuity across surface gaps.
- Application is straightforward using a brush, roller, or sprayer, with easy water cleanup and roughly 350 to 400 sq. ft. per gallon coverage.
- Think of PermaBond as an insurance policy for your project, reducing the risk of coating failure on dry-rotted or hardened surfaces.
IMPORTANT: PermaBond must be applied before using Deck Revive or Dock Revive for optimal performance and adhesion.
Product Overview:
PermaBond is a VOC-free, acrylic-based bonding primer specifically developed for very worn, weathered, or distressed wood and concrete surfaces. It acts as a vital primer layer that enhances the adhesion of Gulf Synthetics’ resurfacing products, including Deck Revive, Dock Revive, and Concrete Revive.
If your deck, dock, or concrete patio shows signs of aging—such as a gray, petrified appearance or deep surface wear—PermaBond offers added peace of mind. It penetrates and locks into wood or concrete at a molecular level, providing a strong foundation for your resurfacing system.
Key Features:
- Essential for Worn Surfaces: Strengthens adhesion on poorly maintained or distressed wood and concrete.
- Strong Molecular Bond: Acrylic-based polymer penetrates deeply into surface fibers.
- Tintable Formula: Can be tinted to match the final resurfacing product color for better color continuity between deck boards or surface gaps.
- Easy Application:
- Apply with a brush, roller, or sprayer.
- Tools clean up easily with water.
- Eco-Friendly: 100% VOC-free formulation.
Coverage:
- Approximately 350–400 sq. ft. per gallon, depending on surface porosity and condition.
When to Use PermaBond:
- Before using Deck Revive, Dock Revive, or Concrete Revive
- On very worn, distressed, or poorly maintained wood or concrete
- When you’re unsure about the surface condition and want to ensure optimal bonding
Why Prime with PermaBond?
Using PermaBond is like adding an insurance policy for your resurfacing project. Aging wood and concrete surfaces can resist coatings, especially when they’re dry-rotted or have a hardened, brittle texture. Priming with PermaBond helps ensure a lasting, durable bond—minimizing risk and maximizing performance.
Planning an overlay on a stamped pool deck that has been previously sealed with a solvent sealer-varying remnants remain. Plan permabond as a primer, and also mixed into the aggregate. can a satisfactory bond be achieved without stripping the old sealer?
We would not count on it. Any overlay or bonding primer needs to grab onto bare, porous concrete, and remnants of a solvent-based sealer will act as a bond breaker in those areas, even if other spots look clean. Using Perma Bond as a primer and in the mix helps adhesion to the concrete itself, but it will not reliably bond through leftover sealer. The safest route is to strip the old sealer completely and clean the surface before the overlay.
I see in the description above the mention of Dock Revive but when I search for it, I only get Deck Revive. Are they the same product?
Only Deck Revive is made now. Same product.
Thanks again!
Can I prime my entire dock and then apply Deck Revive over a couple of weeks? The dock is larger than I can complete in a couple of hours.
No. The Deck Revive should be applied on the same day as Permabond or within 24 hours. It is very easy to apply and should not take weeks. Do in sections if needed.
