TWP Semi-Solid Pro-Series Stain & Gemini Restore-A-Deck Kit Combo Pack
Prep, Restore & Protect Your Exterior Wood in One Complete Package!
The TWP Semi-Solid Pro-Series Stain & Gemini Restore-A-Deck Kit is the ultimate solution for deep-penetrating wood protection with maximum UV resistance and long-lasting durability. This oil-based, semi-solid stain provides superior weather protection while enhancing wood grain visibility. Combined with the Restore-A-Deck Cleaner & Brightener Kit, this package ensures your wood is properly prepped for optimal stain adhesion and longevity.
- The TWP Semi-Solid Pro-Series Stain is an oil-based formula offering deep penetration, UV resistance, and protection against moisture, mold, and freeze damage.
- The Gemini Restore-A-Deck Cleaner removes dirt, mold, and graying, covering 750 to 1,000 sq. ft. per container, but is not designed for solid stain removal.
- The Gemini Restore-A-Deck Brightener neutralizes the cleaner, restores natural wood pH, removes tannin and rust stains, and improves overall stain adhesion.
- TWP Semi-Solid Pro-Series is not VOC-compliant in all 50 states; a Low-VOC version is available for full US and Canadian compliance.
✔ (1) TWP Semi-Solid Pro-Series 5-Gallon Pail – Maximum UV & Moisture Protection
✔ (1) Gemini Restore-A-Deck Kit – Includes Cleaner & Brightener for Best Prep
🏆 #1 Rated Semi-Solid Stain for Durability & Fade Resistance
🌿 Eco-Safe & VOC Compliant for All US States & Canada
🛡 Water-Repellent, Mold-Resistant, & Easy to Apply
🔹 Why Choose the TWP Semi-Solid Stain & Restore-A-Deck Combo Kit?
✅ Cleans & Prepares Wood Before Staining – Removes dirt, mold, algae, & graying
✅ Max UV Protection = Longer Color Retention – Prevents fading, cracking, & warping
✅ Deep Penetrating Semi-Solid Oil-Based Stain – Protects against water & weather damage
✅ Works on All Exterior Wood Surfaces – Decks, fences, siding, log homes, outdoor furniture
✅ Easy Application & Maintenance – Professional results with minimal effort
📌 TWP Semi-Solid Pro-Series is not VOC-compliant in all 50 states. Look the TWP Low-VOC Semi-Solid Version for all 50 States and Canada,
🔹 What’s Included in the TWP Semi-Solid Stain & Gemini Restore-A-Deck Kit?
(5 Gallons) TWP Semi-Solid Pro-Series Stain – Maximum UV Protection & Weather Resistance
✔ Premium oil-based stain & sealer with deep penetration
✔ Semi-solid finish for high UV resistance & superior longevity
✔ Repels water & resists mildew and mold growth
✔ Prevents cracking, splitting, & freeze damage in colder climates
✔ Enhances wood grain while providing rich, long-lasting color
Technical Specifications – TWP Semi-Solid Wood Stain
Stain Type: Semi-Solid, Oil-Based
Coverage: 100–200 sq. ft. per gallon
Recommended Coats: 1-2 Coats (Wet-on-Wet Application)
Dry Time: 4 to 24 Hours
Available in 30 Stunning Custom Colors:
🎨 From rich, deep browns to vibrant wood tones – choose your perfect shade!
🎨 Semi-solid opacity enhances wood grain while providing superior protection.
📌 Note: TWP Pro-Series Semi-Solid colors are custom orders and may require 1-3 days for processing before shipping.
Step 1: Gemini Restore-A-Deck Wood Cleaner
✔ Removes dirt, grime, mold, mildew, & weathered graying
✔ Eco-safe, biodegradable formula – safe for plants & pets
✔ Prepares wood for better stain penetration & adhesion
✔ Works on both oil-based & water-based stains
📏 Coverage: 750-1,000 sq. ft. per container.
🚫 Not designed to remove solid color stains or thick coatings.
✔ For those coatings, use the Restore-A-Deck Paint & Solid Stain Stripper.
Step 2: Gemini Restore-A-Deck Wood Brightener
✔ Neutralizes the wood cleaner & restores natural wood color
✔ Removes rust stains & tannin stains from fallen leaves
✔ Improves stain adhesion & enhances stain longevity
✔ Eco-safe & easy to apply
🔹 Where to Use the TWP Semi-Solid Stain & Restore-A-Deck Kit?
✔ Wood Decks & Railings
✔ Fences & Pergolas
✔ Siding & Log Homes
✔ Outdoor Furniture & Playsets
📌 Perfect for any exterior wood that needs high UV resistance and rich, semi-solid color.
🔹 How to Use the TWP Semi-Solid Stain & Prep Combo Kit
Step 1: Clean the Wood with Gemini Restore-A-Deck Cleaner
1️⃣ Mix the Cleaner: Each container makes 5 gallons.
2️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the wood surface.
3️⃣ Let Sit for 15-20 Minutes: Cleaner will break down dirt, mold, & old coatings.
4️⃣ Scrub or Pressure Wash Off: Rinse thoroughly with a garden hose or pressure washer.
Step 2: Brighten the Wood with Gemini Restore-A-Deck Brightener
5️⃣ Mix the Brightener: Each container makes 5 gallons.
6️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the surface.
7️⃣ Let Sit for 10-15 Minutes: Neutralizes the cleaner and restores wood pH balance.
Step 3: Apply TWP Semi-Solid Pro-Series Stain
9️⃣ Ensure Surface is Ready: Wood must be completely dry before staining (24-48 hours after cleaning).
🔟 Apply Stain Using Brush, Roller, or Pump Sprayer: Work wet-on-wet for even absorption.
1️⃣1️⃣ Back-Brush or Use a Stain Pad: Ensures even penetration & smooth finish.
1️⃣2️⃣ Let Dry Completely: Allow 24-48 hours before heavy foot traffic.
📌 For best results, apply TWP stain when temperatures are between 50°F-90°F.
✔ Get Professional-Quality Results with the TWP Semi-Solid Stain & Prep Kit!
✔ Deep penetrating oil-based stain with high UV protection
✔ Cleans, brightens, and stains wood for long-lasting beauty & durability
✔ Eco-friendly, easy to use, and works on multiple wood surfaces
🔹 Order the TWP Semi-Solid Pro-Series Stain & Gemini Restore-A-Deck Kit today and protect your exterior wood for years to come!
