Restore-A-Deck Stain Stripper & Brightener Kit – Complete Deck Restoration Solution
Removes Old Stains & Brightens Wood for the Best Staining Results
The Restore-A-Deck Stain Stripper & Brightener Kit is a powerful, eco-friendly 2-step system designed to strip old wood stains and coatings while restoring and brightening the wood surface. This biodegradable, powdered concentrate kit includes:
- The Restore-A-Deck Stain Stripper & Brightener Kit is a 2-step system that removes old stains and restores wood's natural color and pH balance.
- Each kit makes 10 gallons total, costing less than $7 per gallon, making it one of the most cost-effective deck prep options available.
- The kit works on most oil and latex-based finishes, including clear, transparent, and semi-transparent stains, but is not designed for solid stains or paints.
- Safe for use on decks, fences, siding, pergolas, furniture, and other exterior wood surfaces, with a biodegradable, eco-safe formula that won't harm plants or pets.
- For tougher stains, mix the stripper at a 3:1 ratio of water to concentrate, then always follow with the brightener before applying any new deck stain.
✔ Step 1: Restore-A-Deck Stain Stripper – Removes old stains, dirt, mildew, and coatings
✔ Step 2: Restore-A-Deck Wood Brightener – Neutralizes the stripper, brightens wood, and restores pH balance
🌱 Eco-Safe & Biodegradable – Won’t harm plants or pets when properly rinsed
🏆 #1 Rated Deck Stain Stripper & Brightener Kit – Trusted by homeowners & professionals
🔹 Why Choose the Restore-A-Deck Stain Stripper & Brightener Kit?
✅ Removes Most Oil & Latex-Based Finishes – Strips clear film-forming varnishes, transparent, and semi-transparent stains.
✅ Brightens & Restores Natural Wood Color – Eliminates tannin & rust stains, prepping wood for new stain.
✅ Neutralizes Stain Strippers – Ensures optimal pH balance for better stain absorption.
✅ Prepares Wood for Staining – Ensures proper adhesion and longer stain life.
✅ Powdered Concentrate for Easy Mixing – Makes 10 gallons total (5 gallons per product).
✅ Safe for All Exterior Wood Surfaces – Use on decks, fences, siding, furniture, pergolas, and more.
📌 Note: This kit is not needed for removing solid color stains or paints. For those, use Restore-A-Deck Paint & Solid Stain Stripper Gel.
🔹 Where to Use the Restore-A-Deck Stain Stripper & Brightener Kit?
✔ Wood Decks & Railings
✔ Fences & Outdoor Furniture
✔ Siding, Gazebos, & Playsets
✔ Pergolas & Wood Walkways
📌 Use before re-staining for best results.
🔹 How to Use the Restore-A-Deck Stain Stripper & Brightener Kit
1️⃣ Mix the Stripper: 1 container with 5 gallons of water.
2️⃣ Apply Stripper Using a Pump Sprayer: Fully saturate the wood surface.
3️⃣ Let Sit for 10-20 Minutes: Allow the stripper to lift old coatings & stains.
4️⃣ Scrub or Pressure Wash Off: Rinse thoroughly.
5️⃣ Mix & Apply Brightener: Mix 1 container with 5 gallons of water.
6️⃣ Let the Brightener Sit for 10-15 Minutes: Restores pH balance and brightens wood.
7️⃣ Rinse & Allow Wood to Dry Completely Before Staining.
📌 Pro Tip: For tougher stains, mix stripper at a 3:1 ratio (3 gallons water per container).
✔ Get Your Deck Ready for Staining with the Restore-A-Deck Stain Stripper & Brightener Kit!
✔ Removes old stains & prepares wood for a fresh finish!
✔ Brightens & restores wood to its natural beauty!
🔹 Order the Restore-A-Deck Stain Stripper & Brightener Kit today and give your deck a professional-grade restoration!
Stain Types Removed
Can these products be used to strip, or at least prep a PT deck that was previously coated with “Ready Seal”?
The Ready Seal product didn’t work out.
I’m looking to be able to coat the deck with a solid oil based stain.
Yes, the RAD Stripper and Brightener kit will remove Ready Seal. It is a penetrating stain and strips off fairly easily. Use the stripper first, then the brightener, and let the deck dry before staining. Since you are switching to a solid stain, you want to get the wood all the way back to bare so the solid adheres properly.
For the Restore-A-Deck Stripper/Brightener Kit, do you have to mix 5 gallons at one time, or can a smaller batch be made?
You can mix smaller batches. 6-8 oz of powder per gallon.
So we need to strip and stain our deck. Full sun, coastal environment. If we use the Armstrong oil based stain will we have to strip it every year?
No.
I have a PTP deck that was rebuilt 2 years ago. treated after waiting a year with Behr transparent waterproofing wood finish in clear – I think this is different than a stain – acrylic? the deck needs to be stained now. I used a deck cleaner but not sure if can now stain with a product it need to strip first ?? And will a stripper remove this ?
Yes, you need to strip. Use the RAD Stripper and both additives: https://www.deckstainhelp.com/product-category/restore-a-deck-stain-stripper-additives
Brightener last.
Will this work to remove the Rock salad 20 times De stain that we previously have on our deck
No deck stain stripper will remove deck resurface coatings like the Rust-Oleum Rock Solid:
