- Restore-A-Deck Thickening Gel Additive is an additive only; it will not work as a standalone product.
- Restore-A-Deck Thickening Gel Additive improves removal of transparent, semi-transparent, and semi-solid stains and works on acrylic and oil-based finishes.
- Restore-A-Deck Thickening Gel Additive is ideal for railings, balusters, fences, log homes, siding, and horizontal decking.
- Restore-A-Deck Thickening Gel Additive mixes into premixed stripper; apply with pump sprayer, brush, or roller, then scrub or pressure wash off.
- Restore-A-Deck Thickening Gel Additive requires neutralizing with Restore-A-Deck Wood Brightener after stripping; consider RAD Paint and Solid Stain Stripper for heavy solids.
✔ Log Homes & Siding
2️⃣ Add Thickening Gel: Stir Restore-A-Deck Thickening Gel Powder Additive into the premixed stripper solution.
Stain Types Removed
