TWP Semi-Solid Pro Series Oil-Based Stain & Gemini Restore-A-Deck Kit Combo Pack
New Version – Low VOC, Compliant for All 50 States & Canada!
Achieve professional-grade wood restoration and staining results with the TWP Semi-Solid Pro Series Oil-Based Stain & Gemini Restore-A-Deck Kit Combo Pack. This all-in-one package allows you to clean, brighten, and stain your deck, fence, or siding with ease, while enhancing color retention, UV resistance, and overall durability.
- The TWP Semi-Solid Pro-Series is a low VOC, oil-based stain compliant in all 50 states and Canada, offering deep wood penetration.
- This combo includes 5 gallons of TWP Semi-Solid Stain plus the Gemini Restore-A-Deck Cleaner and Brightener Kit for complete wood prep.
- Coverage ranges from 100 to 200 square feet per gallon (per coat), applied in 1 to 2 coats using a wet-on-wet method for even absorption.
- The Gemini Wood Cleaner removes mold, algae, and graying, while the Gemini Wood Brightener neutralizes pH and improves stain adhesion.
- The stain resists UV fade, repels water, prevents mold growth, and protects against cracking and freeze damage in colder climates.
- TWP Semi-Solid Pro-Series is available in 30 custom colors and works on decks, fences, siding, log homes, and outdoor furniture.
✔ (1) TWP Semi-Solid Pro-Series 5-Gallon Pail – Low VOC Formula
✔ (1) Gemini Restore-A-Deck Cleaner & Brightener Kit
✔ Eco-Safe, Long-Lasting, and Easy to Maintain
🏆 #1 Rated Semi-Solid Stain for Maximum UV Protection & Longevity
🌿 Low VOC, Compliant in All 50 States & Canada
🛡 Superior Water Resistance & Mold/Mildew Protection
🔹 Why Choose the TWP Semi-Solid Stain & Gemini Restore-A-Deck Kit?
✅ Cleans, Brightens, & Stains Wood in One Complete System
✅ Low VOC, Oil-Based Semi-Solid Stain for Deep Penetration & Longevity
✅ Highest UV Protection Available for Maximum Fade Resistance
✅ Works on All Exterior Wood Surfaces – Decks, Fences, Siding, & More
✅ Eco-Friendly, Easy to Apply & Maintain
📌 TWP Semi-Solid Pro-Series is VOC-compliant in all 50 states & Canada!
🔹 What’s Included in the TWP Semi-Solid Stain & Gemini Restore-A-Deck Kit?
(5 Gallons) TWP Semi-Solid Pro-Series Stain – Low VOC, High-Performance Stain
✔ Premium oil-based stain & sealer with deep penetration
✔ Semi-solid finish for superior longevity & fade resistance
✔ Repels water & resists mildew and mold growth
✔ Prevents cracking, splitting, & freeze damage in colder climates
✔ Enhances wood grain while providing rich, long-lasting color
Technical Specifications – TWP Semi-Solid Wood Stain
Stain Type: Semi-Solid, Oil-Based
Coverage: 100–200 sq. ft. per gallon
Recommended Coats: 1-2 Coats (Wet-on-Wet Application)
Dry Time: 4 to 24 Hours
Available in 30 Stunning Custom Colors:
🎨 From deep browns to vibrant wood tones – choose your perfect shade!
🎨 Semi-solid opacity enhances wood grain while providing superior protection.
📌 Note: TWP Pro-Series Semi-Solid colors are custom orders and may require 1-3 days for processing before shipping.
Step 1: Gemini Restore-A-Deck Wood Cleaner – Deeply Cleans & Prepares Wood
✔ Removes dirt, grime, mold, algae, & weathered graying
✔ Prepares wood for even stain absorption
✔ Biodegradable & safe for plants when used as directed
✔ Powdered concentrate – makes 5 gallons of solution
📏 Coverage: 750-1,000 sq. ft. per container.
Step 2: Gemini Restore-A-Deck Wood Brightener – Restores Natural Wood Color
✔ Neutralizes wood cleaner & enhances stain absorption
✔ Removes rust stains, tannins, and weathering effects
✔ Eco-safe & easy to apply
✔ Improves stain adhesion & enhances stain longevity
🔹 Where to Use the TWP Semi-Solid Stain & Gemini Restore-A-Deck Kit?
✔ Wood Decks & Railings
✔ Fences & Pergolas
✔ Siding & Log Homes
✔ Outdoor Furniture & Playsets
📌 Perfect for any exterior wood that needs high UV resistance and rich, semi-solid color.
🔹 How to Use the TWP Semi-Solid Stain & Prep Combo Kit
Step 1: Clean & Prepare Wood with Gemini Restore-A-Deck Wood Cleaner
1️⃣ Mix the Cleaner: Each container makes 5 gallons.
2️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the wood surface.
3️⃣ Let Sit for 15-20 Minutes: Cleaner will break down dirt, mold, and graying.
4️⃣ Scrub or Pressure Wash Off: Rinse thoroughly with a garden hose or pressure washer.
Step 2: Brighten & Neutralize with Gemini Restore-A-Deck Wood Brightener
5️⃣ Mix the Brightener: Each container makes 5 gallons.
6️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the surface.
7️⃣ Let Sit for 10-15 Minutes: Neutralizes the cleaner and restores wood pH balance.
Step 3: Apply TWP Semi-Solid Pro-Series Stain
9️⃣ Ensure Surface is Ready: Wood must be completely dry before staining (24-48 hours after cleaning).
🔟 Apply Stain Using Brush, Roller, or Pump Sprayer: Work wet-on-wet for even absorption.
1️⃣1️⃣ Back-Brush or Use a Stain Pad: Ensures even penetration & smooth finish.
1️⃣2️⃣ Let Dry Completely: Allow 24-48 hours before heavy foot traffic.
📌 For best results, apply TWP stain when temperatures are between 50°F-90°F.
✔ Get Professional-Quality Results with the TWP Semi-Solid Stain & Prep Kit!
✔ Deep penetrating oil-based stain with high UV protection
✔ Cleans, brightens, and stains wood for long-lasting beauty & durability
✔ Eco-friendly, easy to use, and works on multiple wood surfaces
🔹 Order the TWP Semi-Solid Pro-Series Stain & Gemini Restore-A-Deck Kit today and protect your exterior wood for years to come!
