TWP 1500 Series Stain & Restore-A-Deck Stripper & Brightener Combo – Complete Wood Restoration System
Strip, Brighten & Stain for Long-Lasting Protection
The TWP 1500 Series Stain & Restore-A-Deck Stripper & Brightener Combo Pack is the ultimate solution for removing old coatings, restoring wood color, and applying a long-lasting protective stain. This all-in-one system provides everything you need to prep, clean, and protect your deck, fence, siding, or outdoor wood surfaces.
- The TWP 1500 Series kit includes a 5-gallon oil-based stain, a Restore-A-Deck Stain Stripper, and a Restore-A-Deck Wood Brightener.
- The Restore-A-Deck Stain Stripper removes most transparent, semi-transparent, and semi-solid stains but will not remove solid paints or thick acrylic coatings.
- The Restore-A-Deck Wood Brightener neutralizes the stripper, restores natural wood color, and improves stain adhesion for better long-term results.
- TWP 1500 Series is a semi-transparent, oil-based stain available in 9 colors, covering 100 to 300 sq. ft. per gallon (per coat) depending on wood porosity.
- Apply two coats using a wet-on-wet method at temperatures between 50°F and 90°F; allow 24 to 48 hours of dry time before heavy foot traffic.
- The complete kit works on decks, fences, siding, log homes, and outdoor furniture, and is VOC-compliant in all 50 states.
✔ (1) TWP 1500 Series 5-Gallon Pail – Premium Semi-Transparent Oil-Based Stain & Sealer
✔ (1) Restore-A-Deck Stain Stripper – Removes Old Coatings & Stains
✔ (1) Restore-A-Deck Wood Brightener – Neutralizes & Restores Natural Wood Color
🏆 #1 Rated Wood Restoration System – Trusted by professionals & homeowners
🌿 Eco-Safe, Low VOC, & Easy to Apply – Ensures a hassle-free wood restoration process
🛡 Deep Penetrating Protection Against Water & UV Damage – Extends the life of your wood
🔹 Why Choose the TWP 1500 Stain & Restore-A-Deck Stripper & Brightener Kit?
✅ Strips Old Stains & Preps Wood for New Coating – Removes previous coatings, dirt, & mildew
✅ Restores Natural Wood Color – Brightens & neutralizes the stripper for better stain absorption
✅ Deep Penetrating Semi-Transparent Oil-Based Stain – Protects against water, UV damage, & mold
✅ Superior Weather Resistance – Prevents warping, cracking, & fading
✅ Works on All Exterior Wood Surfaces – Decks, fences, siding, log homes, outdoor furniture
✅ Easy Application & Maintenance – Professional results with minimal effort
📌 TWP 1500 Series is VOC-compliant in all 50 states.
🔹 What’s Included in the TWP 1500 Stain & Prep Kit?
(5 Gallons) TWP 1500 Series Stain – Deep Penetrating, Long-Lasting Protection
✔ Premium oil-based stain & sealer for superior longevity
✔ Preserves natural wood color while preventing graying
✔ Repels water & resists mildew and mold growth
✔ Prevents cracking, splitting, & freeze damage in colder climates
✔ Enhances wood tones & protects against UV exposure
📏 Coverage: 150-250 sq. ft. per gallon (varies by wood porosity).
Technical Specifications – TWP 1500 Wood Stain
Coverage: 100–300 sq. ft. per gallon, per coat.
Recommended Coats: 2 Coats (Wet-on-Wet Application). *1 coat for new wood less than 12 months.
Application Methods: Stain Pad, Sprayer, Brush
Dry Time: 4 to 24 Hours
Available in 9 Stunning Colors:
🎨 1501 Cedartone – Classic natural cedar finish
🎨 1502 Redwood – Rich, warm redwood tone
🎨 1503 Dark Oak – Deep, timeless wood stain
🎨 1504 Black Walnut – Bold & modern dark finish
🎨 1505 Honeytone – Light golden hue
🎨 1506 Rustic – Medium brown with warm tones
🎨 1507 Natural – Transparent with minimal tint
🎨 1508 Pecan – Reddish-brown hue with warm undertones
🎨 1511 California Redwood – Vibrant redwood color
Step 1: Restore-A-Deck Stain Stripper
✔ Removes most transparent, semi-transparent, & semi-solid stains
✔ Eliminates dirt, mildew, algae, & old coatings
✔ Eco-safe & biodegradable – safe for plants, pets, and grass
✔ Works on both oil-based & water-based stains
📏 Coverage: 500-1,000 sq. ft. per container.
🚫 Not designed to remove solid color stains, paints, varnishes, or thick acrylic coatings.
✔ For those coatings, use the Restore-A-Deck Paint & Solid Stain Stripper.
Step 2: Restore-A-Deck Wood Brightener
✔ Neutralizes the stain stripper & restores wood’s natural color
✔ Removes rust stains & tannin stains from fallen leaves
✔ Improves stain adhesion & enhances stain longevity
✔ Eco-safe & easy to apply
📏 Coverage: 750-1,000 sq. ft. per container.
🔹 Where to Use the TWP 1500 Stain & Restore-A-Deck Stripper & Brightener Kit?
✔ Wood Decks & Railings
✔ Fences & Pergolas
✔ Siding & Log Homes
✔ Outdoor Furniture & Playsets
📌 Perfect for any exterior wood that needs previous coatings removed before applying a fresh finish.
🔹 How to Use the TWP 1500 Stain & Prep Combo Kit
Step 1: Strip the Wood with Restore-A-Deck Stain Stripper
1️⃣ Mix the Stripper: Each container makes 5 gallons.
2️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the wood surface.
3️⃣ Let Sit for 15-20 Minutes: Stripper will begin breaking down old coatings.
4️⃣ Scrub or Pressure Wash Off: Rinse thoroughly with a garden hose or pressure washer.
Step 2: Brighten the Wood with Restore-A-Deck Brightener
5️⃣ Mix the Brightener: Each container makes 5 gallons.
6️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the surface.
7️⃣ Let Sit for 10-15 Minutes: Neutralizes the stripper and restores wood pH balance.
Step 3: Apply TWP 1500 Series Stain
9️⃣ Ensure Surface is Ready: Wood must be completely dry before staining (24-48 hours after cleaning).
🔟 Apply Stain Using Brush, Roller, or Pump Sprayer: Work wet-on-wet for even absorption.
1️⃣1️⃣ Back-Brush or Use a Stain Pad: Ensures even penetration & smooth finish.
1️⃣2️⃣ Let Dry Completely: Allow 24-48 hours before heavy foot traffic.
📌 For best results, apply TWP stain when temperatures are between 50°F-90°F.
✔ Get Professional-Quality Results with the TWP 1500 Stain & Prep Kit!
✔ Strip, brighten, & stain your wood for maximum protection!
✔ Removes old coatings & penetrates deep into wood fibers for long-lasting results!
✔ Eco-friendly, easy to use, and works on multiple wood surfaces!
🔹 Order the TWP 1500 Series Stain & Restore-A-Deck Stripper & Brightener Kit today and keep your deck or exterior wood looking beautiful for years!
