If you want your deck, fence, or exterior wood to look its best and take stain evenly, proper brightening after cleaning or stripping is essential. Buy Restore-A-Deck Brightener Only to restore the wood’s natural color and balance its pH, creating an ideal surface for stain penetration and long-lasting results.
- Restore-A-Deck Wood Brightener neutralizes wood cleaners and strippers, restoring the wood's natural pH balance before staining for better results.
- This biodegradable, eco-friendly powdered concentrate is safe for plants, pets, and landscaping, making it a responsible choice for outdoor use.
- One container mixes with water to make 5 gallons, covering 750 to 1,000 square feet at less than $6 per gallon.
- The brightener removes tannin stains, rust stains, and watermarks, restoring natural wood color on decks, fences, siding, and other exterior surfaces.
- Skipping the brightening step can cause blotchy color, poor stain adhesion, and premature stain failure, even when wood appears visually clean.
- Application is straightforward: mix, apply with a pump sprayer or brush, let sit 10 to 15 minutes, rinse thoroughly, and allow wood to fully dry before staining.
This biodegradable wood brightener works as a powerful neutralizer and color booster after prep, removing tannin stains and helping wood regain its natural beauty without harsh chemicals. Use it after cleaning or stripping to unlock better stain performance and more even, vibrant color on decks, siding, and outdoor wood surfaces
Restore-A-Deck Wood Brightener – The Best Deck Brightener & Neutralizer
We had a soft wash done professionally. They did not apply brighter. We cant do this for several days. Is it effective after the cleaned deck dries? This was never stained wood that had grayed. Our painter will be staining afterwards.
Yes, it is.
Hello, Do i need the Brightener if i power sand the deck?
