TWP Semi-Solid Pro Series Stain & Restore-A-Deck Stripper/Brightener Combo Pack
New Version – Low VOC, Compliant for All 50 States & Canada!
Upgrade your deck restoration project with the TWP Semi-Solid Pro Series Stain & Restore-A-Deck Stripper/Brightener Combo Pack. This all-in-one kit includes everything you need to remove old coatings, brighten wood, and apply a premium oil-based stain for long-lasting beauty and protection.
- The TWP Semi-Solid Pro-Series Stain is a low VOC, oil-based formula compliant in all 50 states and Canada.
- The kit includes Restore-A-Deck Wood Stain Stripper and Restore-A-Deck Wood Brightener, covering up to 1,000 sq. ft. each.
- TWP Semi-Solid covers 100 to 200 sq. ft. per gallon, applied in one to two coats using a brush, roller, sprayer, or stain pad.
- Available in 30 custom colors, the semi-solid finish enhances wood grain while delivering superior UV protection and mold resistance.
✔ (1) TWP Semi-Solid Pro-Series 5-Gallon Pail – Low VOC Formula
✔ (1) Restore-A-Deck Wood Stain Stripper – Removes Most Previous Coatings
✔ (1) Restore-A-Deck Wood Brightener – Restores & Neutralizes Wood
✔ Max UV Protection, Mold/Mildew Resistance & Deep Penetration
🏆 #1 Rated Semi-Solid Stain for Maximum UV Protection & Longevity
🌿 Low VOC, Compliant in All 50 States & Canada
🛡 Superior Water Resistance & Mold/Mildew Protection
🔹 Why Choose the TWP Semi-Solid Stain & Restore-A-Deck Stripper/Brightener Kit?
✅ Cleans, Brightens & Stains Wood in One Complete System
✅ Low VOC, Oil-Based Semi-Solid Stain for Deep Penetration & Longevity
✅ Removes Old Transparent, Semi-Transparent & Semi-Solid Stains
✅ Works on All Exterior Wood Surfaces – Decks, Fences, Siding & More
✅ Eco-Friendly, Easy to Apply & Maintain
📌 TWP Semi-Solid Pro-Series is VOC-compliant in all 50 states & Canada!
🔹 What’s Included in the TWP Semi-Solid Stain & Restore-A-Deck Kit?
(5 Gallons) TWP Semi-Solid Pro-Series Stain – Low VOC, High-Performance Stain
✔ Premium oil-based stain & sealer with deep penetration
✔ Semi-solid finish for superior longevity & fade resistance
✔ Repels water & resists mildew and mold growth
✔ Prevents cracking, splitting, & freeze damage in colder climates
✔ Enhances wood grain while providing rich, long-lasting color
Technical Specifications – TWP Semi-Solid Wood Stain
Stain Type: Semi-Solid, Oil-Based
Coverage: 100–200 sq. ft. per gallon
Recommended Coats: 1-2 Coats (Wet-on-Wet Application)
Dry Time: 4 to 24 Hours
Available in 30 Stunning Custom Colors:
🎨 From deep browns to vibrant wood tones – choose your perfect shade!
🎨 Semi-solid opacity enhances wood grain while providing superior protection.
📌 Note: TWP Pro-Series Semi-Solid colors are custom orders and may require 1-3 days for processing before shipping.
Step 1: Restore-A-Deck Wood Stain Stripper – Removes Previous Coatings
✔ Removes most oil-based and water-based transparent, semi-transparent, and semi-solid stains
✔ Eliminates dirt, mold, mildew, and aged coatings
✔ Eco-safe, biodegradable, and plant-friendly when used as directed
✔ Powdered concentrate – makes 5 gallons of solution
📏 Coverage: 500-1,000 sq. ft. per container.
Step 2: Restore-A-Deck Wood Brightener – Restores Natural Wood Color
✔ Neutralizes wood stain stripper & enhances stain absorption
✔ Removes rust stains, tannins, and weathering effects
✔ Eco-safe & easy to apply
✔ Improves stain adhesion & enhances stain longevity
📏 Coverage: 750-1,000 sq. ft. per container.
🔹 Where to Use the TWP Semi-Solid Stain & Restore-A-Deck Stripper/Brightener Kit?
✔ Wood Decks & Railings
✔ Fences & Pergolas
✔ Siding & Log Homes
✔ Outdoor Furniture & Playsets
📌 Perfect for any exterior wood that needs high UV resistance and rich, semi-solid color.
🔹 How to Use the TWP Semi-Solid Stain & Prep Combo Kit
Step 1: Strip & Prepare Wood with Restore-A-Deck Wood Stain Stripper
1️⃣ Mix the Stripper: Each container makes 5 gallons.
2️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the wood surface.
3️⃣ Let Sit for 15-20 Minutes: Stripper will break down old coatings.
4️⃣ Scrub or Pressure Wash Off: Rinse thoroughly with a garden hose or pressure washer.
Step 2: Brighten & Neutralize with Restore-A-Deck Wood Brightener
5️⃣ Mix the Brightener: Each container makes 5 gallons.
6️⃣ Apply Using a Pump Sprayer or Brush: Fully saturate the surface.
7️⃣ Let Sit for 10-15 Minutes: Neutralizes the stripper and restores wood pH balance.
Step 3: Apply TWP Semi-Solid Pro-Series Stain
9️⃣ Ensure Surface is Ready: Wood must be completely dry before staining (24-48 hours after cleaning).
🔟 Apply Stain Using Brush, Roller, or Pump Sprayer: Work wet-on-wet for even absorption.
1️⃣1️⃣ Back-Brush or Use a Stain Pad: Ensures even penetration & smooth finish.
1️⃣2️⃣ Let Dry Completely: Allow 24-48 hours before heavy foot traffic.
📌 For best results, apply TWP stain when temperatures are between 50°F-90°F.
✔ Get Professional-Quality Results with the TWP Semi-Solid Stain & Prep Kit!
✔ Deep penetrating oil-based stain with high UV protection
✔ Cleans, brightens, and stains wood for long-lasting beauty & durability
✔ Eco-friendly, easy to use, and works on multiple wood surfaces
🔹 Order the TWP Semi-Solid Pro-Series Stain & Restore-A-Deck Stripper/Brightener Kit today and protect your exterior wood for years to come!
