Chapin 1949 Industrial Sprayer – 3.5-Gallon Heavy-Duty Steel Sprayer
The Chapin 1949 is a professional-grade industrial sprayer designed for high-performance applications, including deck stains, sealers, concrete sealers, and wood restoration products. Built for durability and efficiency, this sprayer is trusted by contractors, painters, and wood restoration professionals for its superior chemical resistance and even application.
- The Chapin 1949 features a 3.5-gallon Tri-Poxy steel tank that resists corrosion, dents, and rust for long-lasting durability.
- A brass spray wand and nozzle deliver consistent, precise application for deck stains, sealers, and professional coatings.
- The 4-inch wide funnel opening makes filling and cleaning straightforward, reducing mess and downtime on larger projects.
- Chemical-resistant seals and gaskets make this sprayer compatible with most oil-based and water-based stains and sealers.
🔹 Key Features of the Chapin 1949 Sprayer
✔ Heavy-Duty 3.5-Gallon Tri-Poxy Steel Tank – Resists corrosion, dents, and rust for long-lasting use.
✔ Brass Spray Wand & Nozzle – Durable components ensure consistent performance and precise application.
✔ 4-Inch Wide Funnel Opening – Easy to fill and clean without spills.
✔ Compatible with Most Wood & Concrete Sealers – Ideal for deck stains, penetrating sealers, and other professional coatings.
✔ 40-60 PSI Operating Pressure – Delivers consistent spraying power.
✔ Ergonomic Handle with Lock-On Feature – Reduces fatigue during large applications.
✔ Chemical-Resistant Seals & Gaskets – Compatible with a variety of oil-based and water-based stains and sealers.
