- The Restore-A-Deck Cleaner & Brightener Kit covers up to 1,600 sq. ft., enough for large decks, railings, steps, and fences.
- This two-step system removes mold, mildew, dirt, and UV graying, then neutralizes and brightens wood for better stain absorption.
- Restore-A-Deck Cleaner is not a stain stripper. For removing semi-transparent stain, use the Restore-A-Deck Stain Stripper Kit instead.
- The kit works on wood decks, fences, siding, pergolas, concrete, and awnings, making it versatile for multiple exterior surfaces.
- Apply stain within 48 hours after using the brightener for the best adhesion and longest-lasting results.
✔ Includes:
