anger Patch RE-18 – Heavy-Duty Epoxy Floor Patch for Wood, Decking & Concrete
- Ranger Patch RE-18 is a 100% epoxy resin compound with a catalyst hardener and proprietary aggregate for maximum bonding strength.
- With 18,000 psi compressive strength, it handles heavy traffic, shock, vibration, and extreme temperatures up to 350°F.
- It bonds to concrete, wood, and steel surfaces and resists acids, alkalies, solvents, heat, and cold for long-term durability.
- Each Ranger Patch RE-18 kit covers approximately 15 to 18 sq. ft. at ¼" thickness, making it suitable for targeted repairs.
- Mixing involves combining Part A, Part B, and aggregate bags in sequence, with a working time of only 25 to 30 minutes.
- Light traffic is safe after 12 to 18 hours, but heavy traffic areas require 48 to 72 hours of cure time before use.
Ranger Patch RE-18 is a high-performance, industrial-strength epoxy patching compound designed to repair and resurface damaged wood, decks, and concrete floors. With a compressive strength of 18,000 psi, this professional-grade floor patch is ideal for areas exposed to heavy traffic, shock, and vibration.
Use Ranger Patch before applying Permabond or Deck Revive for a smoother, longer-lasting restoration.
Key Benefits
- 100% epoxy resin base with catalyst hardener and proprietary aggregate
- 18,000 psi compression strength for extreme durability
- Withstands temperatures up to 350°F
- Excellent for high-traffic or industrial-use environments
- Absorbs vibration and shock without cracking
- Ideal for expansion and contraction zones
- Highly resistant to acids, alkalies, solvents, heat, and cold
- Permanently resilient and long-wearing
- Self-leveling formula requires minimal trowel work
- Bonds effectively to concrete, wood, and steel surfaces
Coverage
Each Ranger Patch RE-18 kit covers approximately 15–18 sq. ft. at ¼” thickness.
How to Use Ranger Patch on Wood Decks & Concrete Floors
Follow these steps for a successful application:
Surface Prep
- Clean the surface thoroughly. Remove all loose materials, dirt, oils, or old coatings.
Mixing Instructions
- Empty one 12 lb. aggregate bag into the provided pail.
- Add the Quart container (Part A) and mix until uniform.
- Add the Pint container (Part B) and continue mixing for 2–3 minutes.
- Add the second bag of aggregate to adjust the consistency:
- Thicker mix = easier troweling
- Thinner mix = ideal for pouring applications
Application
- Apply the mixture to fill holes, cracks, and voids. Level to match surrounding surfaces.
- Feather edges with a trowel for a seamless finish.
- Wet the trowel with an epoxy thinner (like Xylene) for a smooth surface finish.
Important Notes
- Working Time: 25–30 minutes after mixing
- Dry Time:
- Light traffic: 12–18 hours
- Heavy traffic: 48–72 hours
- Kit Coverage: 15–18 sq. ft. at ¼” thickness
