Please Note:
TWP 100 Series is not compliant in all states. TWP 1500 series can be shipped to all 50 states.
*We do not guarantee stain colors as they will vary widely depending on the wood type, age, of wood, prepping of wood, and application. Small samples are available.
*TWP 105 Cape Cod Gray and 106 Prairie Gray are close to semi-solid in appearance.
TWP 100 Series 1 Gallon Deck Stain
Technical Specifications – TWP 100 Wood Stain
Coverage: 150–250 sq. ft. per gallon, per coat.
Recommended Coats: 2 Coats (Wet-on-Wet Application)
Application Methods: Stain Pad, Sprayer, or Brush.
Dry Time: 4 to 24 Hours
Can you send me a color scheme of all the colors? I’m trying my best to match and not redo all of a cedar pavilion.
The TWP 100 Series comes in 100 Clear, 101 Cedartone, 102 Redwood, 103 Dark Oak, 105 Cape Cod Gray, 106 Prairie Gray, 115 Honeytone, 116 Rustic, and 120 Pecan. Note that 100 Clear has no pigment and gives you no UV protection.
If you are trying to match existing color on a cedar pavilion, do not go off the color chart — final color varies a lot based on the wood species, its age, how it was prepped, and how it is applied. Order samples of the two or three closest tones and test them on an inconspicuous spot on the actual pavilion.
https://www.deckstainhelp.com/product-category/stain-samples/
What two colors go best together for a two tone deck on pressure treated pine, prefer one to be natural or as close as possible to natural wood color.
Honeytone is the lightest color, so it’s up to you what you would like for the darker color. Maybe Dark Oak?
I’m interested in a 5 gallon pail of TWP 100 Pro Series semi-transparent deck stain in the Pecan 120. How much would it cost with shipment to Graniteville, SC?
You can buy directly on this link, and it shows the cost as well:
https://www.deckstainhelp.com/product/twp-100-series-5-gallon/
What is the voc level of this stain
The 100 Series is 550 VOC.
How to figure the amount of stain you need for a job?
You need to add up your square footage first.
Is there anywhere I can buy this at a store?
We sell online only.
What does the “HOT” icon on the color samples mean?
“Hot” = selling hot, as in a hot-selling product.
I used TWP 100 Series on my deck and I’m really happy with it. It went on smoothly, brought out the wood grain, and the color looks amazing. Water beads right off and there’s no peeling or cracking. Very easy to maintain too. Highly recommend for anyone staining a deck or fence!
