TWP 200 Series 1-Gallon – Now Available for Shipping to Canada!
The TWP 200 Series is a high-performance semi-transparent oil-based penetrating finish, originally designed for shakes and shingles but versatile enough for all exterior wood surfaces, including fencing, log homes, cedar-framed homes, and more.
- TWP 200 Series uses a deep-penetrating oil-based formula with paraffin oil to prevent cracking, cupping, and surface erosion.
- The formula features 94%+ solids content, making it VOC compliant in all U.S. states and Canada.
- TWP 200 Series will not crack, peel, or blister, making maintenance easier and extending overall wood protection significantly.
- Coverage ranges from 100 to 250 square feet per gallon, depending on wood porosity, with full cure taking up to 30 days.
- Available in 8 colors, including TWP 200 Clear, which allows wood to gray naturally for a weathered, rustic look.
- Ideal for cedar shake siding, log homes, wood fencing, and other aged exterior wood surfaces requiring long-lasting protection.
Now compliant in all U.S. states and Canada, this stain offers deep penetration and long-lasting protection while enhancing the natural beauty and structural integrity of aged wood.
🔹 Key Features of TWP 200 Series
✔ Deep-Penetrating Oil-Based Formula – Absorbs into wood to prevent cracking, cupping, and surface erosion.
✔ Paraffin Oil-Based System – A non-drying oil that enhances wood cell stability, improving lifespan and appearance.
✔ Semi-Transparent Protection – Enhances the natural grain while offering UV protection.
✔ Will Not Crack, Peel, or Blister – Ensures easy maintenance and extended wood protection.
✔ High Solids Content (94%+) – Complies with all VOC regulations in the U.S. and Canada.
✔ Superior Water Resistance – Sheds and repels water to prevent warping, swelling, and moisture damage.
✔ Available in 8 Colors – Allows for customization while preserving a natural wood look.
✔ TWP® 200 Clear Allows Wood to Gray Naturally – A great option for a weathered, rustic appearance.
🔹 Ideal for Use On:
✔ Cedar Shake Siding & Shingles
✔ Log Homes & Cedar-Framed Homes
✔ Wood Fencing & Outdoor Structures
✔ Aged Roofing & Exterior Wood Applications
🔹 Coverage & Application
✔ 1-Gallon Coverage: Approximately 100-250 sq. ft. per gallon, depending on wood porosity.
✔ Drying Time: Can take up to 30 days to fully cure to the final color.
✔ Application Methods: Brush, roller, sprayer.
🔹 Important Notes:
✔ Material Preparation: Always test stain on a small area to check for color accuracy before full application.
✔ Color Variation: Due to different wood densities, sanding, wiping, and application methods, final color may vary.
✔ TWP® 200 Clear: Designed to allow wood to gray naturally over time.
🔹 Now available in Canada! Get long-lasting wood protection with TWP 200 Series 1-Gallon Stain – Order today!
